I’m trying to install Odoo 12 from a .tar.gz
I can install the source from the AUR, but i need the version 12, not the 16
I’m downloading the package from I’m trying to install Odoo 12 from a .tar.gz
Businesses often use older versions. Same logic as using Ubuntu LTS. But installing 12.0 could be only worth for testing, comparison, development purposes etc. For example to install an addon module which is only available for 12.0 and try to upgrade it.
Installing Odoo on Arch or Manjaro is a bit tricky, because it uses older versions of python and postgresql.
Ubuntu is the way to go, see the guide I linked. (Debian and derivatives also work.)
