Hello I am Magi, I am fairly new to the forums, but I been trying to switch browsers since I want something that is a bit more privacy focused since Firefox is switching up their game and with better resource management, I heard Vivaldi fits these requirements from a couple of friends, so I decided to go ahead and try it out, but when I installed it was missing text, I try to do some fixes nothing complicated (just uninstalling and installing again with no luck). So now I am coming here if someone can help me out figure out how to fix this, I apologize in advance for any trouble, I am like very new to linux so I don’t know commands to show info or what I should do base on my system, again very sorry, love and care ! - Mango
Hi @Mango_magi and welcome to the Manjaro Community! ![]()
No trouble at all. A quick guide here:
Mini HowTo: Providing System Information (click to expand)
In a Terminal window (preferably maximized, or at least bigger than the usual default size, to help to avoid chopped lines), issue:
inxi -zv8
Select all the text, copy it and paste here.
Note: Please use the code formatting (the </> button at the top of the Reply window after highlighting the pasted Terminal output, or the three backticks ``` on lines above and below the pasted text).
Important point: This output is privacy-filtered using the above command.
Cheers! ![]()
This might be a problem with your local config. One thing you can try is to create a new user and see if that user has the same problem - if it does not, then it’s your local config.
You could also try removing ~/.cache/vivaldi (when Vivaldi is not running). You might also try temporarilly renaming ~/.config/vivaldi to some temporary name to see of that makes a difference (I suggest renaming so that you can remove any newly created directory and rename the saved one to avoid losing settings you might want to keep).
Another possibility is a conflict with your Plasma theme, so you could try switching the theme to see if that makes a difference.
I am running Vivaldi and I don’t have your problem, so there is hope ![]()
I am guessing - looks like a font issue on your system - like if you have chosen a Vivaldi UI language for which you do not have the fonts available on your system.
But it is a guess… and the thought that it could be theme related is a valid thought too.
You can likely work around it by removing the folder ~/.config/vivaldi. Close Vivaldi before attempting to remove the folder.
The .config is a hidden folder in your user’s home, so it will normally not be visible in the file manager - you can change visibility using Ctrl+h key combination in Dolphin.
I don’t think it would be theme-related, because vivaldi is proprietary software and does not rely on the usual suspects, i.e.qt and gtk.
I am however wondering where the OP has installed vivaldi from. If it’s something installed from vivaldi’s website — as opposed to from the Manjaro repositories — then there may be a compatibility issue with the version of pango supplied by Manjaro.
vivaldifrom
That is a valid thought too.
Vivaldi is in Manjaro official repo - so I will assume that you used the package manager e.g.
sudo pacman -Syu vivaldi
If you used the package manager - then it should just work - just as it does for the thousands other Manjaro users - myself included.
Thank for your help, and I apologize about coming back to this so late :<
^[[DSystem:
Kernel: 7.0.13-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-7.0-x86_64
root=UUID=d04a464a-36e5-4725-bfe9-f6b1ef633941 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.6.5 tk: Qt v: N/A info: frameworks v: 6.27.0
Type: Laptop System: Dell product: XPS 14 9440 v: N/A
Mobo: Dell model: 0539M9 v: A00 serial: <superuser required> part-nu: 0C6B
uuid: <superuser required> Firmware: UEFI vendor: Dell v: 1.10.0
date: 11/15/2024
ID-1: BAT0 charge: 49.7 Wh (94.1%) condition: 52.9/69 Wh (76.6%)
health: good temp: 31.3 C volts: 12.27 min: 11.7 model: SMP DELL N80X245R
made: 2024-05-27 type: Li-poly serial: <filter> charging:
status: discharging control: start: 50% end: 100% type: custom
avail: adaptive,custom,fast,standard,trickle cycles: 278
System RAM: total: 32 GiB available: 30.79 GiB used: 5.34 GiB (17.3%)
Array-1: capacity: 32 GiB slots: 8 modules: 8 EC: None
max-module-size: 4 GiB note: est.
Device-1: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB
speed: 7467 MT/s volts: curr: 0.5 width (bits): data: 16 total: 16
manufacturer: N/A part-no: N/A serial: N/A
Device-2: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB
Device-3: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB
Device-4: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB
Device-5: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB
Device-6: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB
Device-7: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB
Device-8: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB
Info: model: Intel Core Ultra 7 155H bits: 64 type: MST AMCP
arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x28
Topology: cpus: 1x dies: 1 clusters: 9 cores: 16 threads: 22 mt: 6 tpc: 2
st: 10 smt: enabled cache: L1: 1.6 MiB desc: d-10x32 KiB, 6x48 KiB; i-16x64
KiB L2: 18 MiB desc: 9x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 400 min/max: 400/4500:4800:3800:2500 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 21: 400 22: 400
bogomips: 131788
bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
conditional; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: Dell driver: i915
v: kernel alternate: xe arch: Xe-LPG process: Intel 4 (7nm+) built: 2023+
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 0000:00:02.0
chip-ID: 8086:7d55 class-ID: 0300
Device-2: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile] vendor: Dell
driver: nvidia v: 610.43.02 alternate: nouveau,nvidia_drm
non-free: 550-580.xx+ status: current (as of 2025-11) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ bus-ID: 0000:01:00.0
chip-ID: 10de:28a1 class-ID: 0302
Display: wayland server: X.org v: 1.21.1.23 with: Xwayland v: 24.1.12
compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: Samsung 0x41a2 built: 2023 res: mode: 3200x2000
hz: 120 scale: 200% (2) to: 1600x1000 dpi: 262 gamma: 1.2 chroma: red:
x: 0.682 y: 0.318 green: x: 0.243 y: 0.714 blue: x: 0.137 y: 0.043 white:
x: 0.314 y: 0.329 size: 310x200mm (12.2x7.87") diag: 369mm (14.52")
modes: 3200x2000
EDID-Warnings: 1: parse_edid: unknown flag 0 2: parse_edid: unknown tag
112
drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 26.1.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc Graphics (MTL)
device-ID: 8086:7d55 memory: 30.07 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.350 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4050 Laptop GPU driver: nvidia v: 610.43.02
device-ID: 10de:28a1 surfaces: N/A
Device-1: Intel Meteor Lake IPU vendor: Dell driver: intel-ipu6
alternate: intel_ipu6 bus-ID: 0000:00:05.0 chip-ID: 8086:7d19 class-ID: 0480
Device-2: Intel Meteor Lake-P HD Audio vendor: Dell
driver: sof-audio-pci-intel-mtl
alternate: snd_sof_pci_intel_mtl,snd_hda_intel bus-ID: 0000:00:1f.3
chip-ID: 8086:7e28 class-ID: 0401
API: ALSA v: k7.0.13-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.6 status: active with: 1: pipewire-pulse
Device-1: Intel Meteor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:7e40 class-ID: 0280
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0033
class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:7d0b rev:
class-ID: 0104
Local Storage: total: 953.87 GiB used: 190.29 GiB (19.9%)
model: PC SN740 NVMe WD 1TB size: 953.87 GiB block-size: physical: 512 B
fw-rev: 73914108 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
used: 190.29 GiB (20.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: d04a464a-36e5-4725-bfe9-f6b1ef633941
used: 700 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 321E-9687
ID-3: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
ID-4: /var/cache raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
ID-5: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-7:2 info: Shenzhen Goodix Fingerprint USB Device
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 27c6:633c class-ID: ef00 serial: <filter>
Device-2: 3-9:3 info: Intel USB Bridge type: <vendor specific>
driver: gpio_ljca,i2c_ljca,ljca,spi_ljca interfaces: 1 rev: 2.0
chip-ID: 8086:0b63 class-ID: 0000
Device-3: 3-10:4 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0033 class-ID: e001
System Temperatures: cpu: 44.0 C mobo: 37.0 C sodimm: 36.0 C
Fan Speeds (rpm): cpu: 1742 fan-1: 1789 fan-2: 1570
Packages: 1444 pm: pacman pkgs: 1402 libs: 376 tools: pamac,yay pm: flatpak
pkgs: 28 pm: snap pkgs: 14
1: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
4: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
5: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
6: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
7: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
9: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
10: https://mirror.init7.net/manjaro/stable/$repo/$arch
11: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
12: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
13: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
14: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
15: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
16: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
17: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
18: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
19: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
20: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
21: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
22: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
23: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
24: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
25: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
26: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
27: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
28: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
29: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
30: https://manjaro.ynh.ovh/stable/$repo/$arch
31: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
32: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
33: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
34: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
35: https://muug.ca/mirror/manjaro/stable/$repo/$arch
36: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
37: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
38: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
39: https://mirrors2.manjaro.org/stable/$repo/$arch
40: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
41: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
42: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
43: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
44: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
45: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
46: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
47: https://mirrors.manjaro.org/repo/stable/$repo/$arch
48: https://mirror.23m.com/manjaro/stable/$repo/$arch
49: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
50: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
51: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
52: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
53: https://mirror.fcix.net/manjaro/stable/$repo/$arch
54: https://manjaro.grena.ge/stable/$repo/$arch
55: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
56: https://mirror.easyname.at/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 464
1: cpu: 24.3% command: firefox pid: 1844 mem: 660.8 MiB (2.0%)
2: cpu: 13.4% command: firefox pid: 2592 mem: 494.6 MiB (1.5%)
3: cpu: 13.3% command: kwin_wayland pid: 1405 mem: 272.1 MiB (0.8%)
4: cpu: 10.0% command: vesktop.bin pid: 4608 mem: 403.2 MiB (1.2%)
5: cpu: 7.0% command: firefox pid: 2140 mem: 82.0 MiB (0.2%)
Memory top: 5 of 464
1: mem: 660.8 MiB (2.0%) command: firefox pid: 1844 cpu: 24.3%
2: mem: 494.6 MiB (1.5%) command: firefox pid: 2592 cpu: 13.4%
3: mem: 403.2 MiB (1.2%) command: vesktop.bin pid: 4608 cpu: 10.0%
4: mem: 401.4 MiB (1.2%) command: plasmashell pid: 1568 cpu: 2.6%
5: mem: 342.9 MiB (1.0%) command: konsole pid: 8394 cpu: 2.8%
Processes: 464 Power: uptime: 9m states: freeze,mem,disk suspend: s2idle
image: 12.21 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 260 default: graphical tool: systemctl
Compilers: gcc: 16.1.1 Shell: Zsh v: 5.9.1 running-in: konsole
inxi: 3.3.40
