Since I updated yesterday I have received a new Vivaldi. Many thanks for the updates. I can’t explain how much your continued work on Manjaro ARM is appreciated.
It is however missing codecs. When I start Vivaldi it complains about a missing patented HTML-media (h.264/aac) component.
Probably a missing vivaldi-ffmpeg-codecs package?
I can’t find one that works though. And it didn’t warn me about this until yesterday.
Any ideas how to get it going right again on Manjaro ARM?
[Solved]
Solved it by reinstalling the vivaldi-codecs-ffmpeg-extra-bin AUR package. It was already installed. It required an uninstall and reinstall.
So: Strit’s solution worked. Many thanks, it is very much appreciated.
It seems so. It was installed, required a reinstall. So I’m guessing it becomes version dependant after you install it. And so need to reinstall it after update. AUR rocks.
