When attemping to launch some software, PPSSPP and dolphin-emu both give me these libGL error.
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
However I can launch other applications seemingly with no errors at all: glxgears
and steam
both launch with no errors.
Output of inxi -Fazy
is:
Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: fs0:\vmlinuz.efi root=/dev/sda2 rw initrd=\intel-ucode.img
initrd=\initramfs-5.10-x86_64.img
Desktop: i3 4.19 info: i3bar dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: Apple product: MacBook7,1 v: 1.0 serial: <filter>
Chassis: type: 10 v: Mac-F22C89C8 serial: <filter>
Mobo: Apple model: Mac-F22C89C8 serial: <filter> UEFI: Apple
v: MB71.88Z.0039.B0B.1006012319 date: 06/01/10
ID-1: BAT0 charge: 38.2 Wh condition: 47.7/62.9 Wh (76%) volts: 11.0/10.9
model: SMP bq20z451 type: Li-ion serial: N/A status: Discharging cycles: 509
Info: Dual Core model: Intel Core2 Duo P8600 bits: 64 type: MCP arch: Penryn
family: 6 model-id: 17 (23) stepping: A (10) microcode: A0B L2 cache: 3 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 9561
Speed: 2350 MHz min/max: 798/2394 MHz Core speeds (MHz): 1: 2350 2: 2342
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Device-1: NVIDIA MCP89 [GeForce 320M] vendor: Apple driver: nvidia
v: 340.108 alternate: nouveau bus ID: 02:00.0 chip ID: 10de:08a0
Device-2: Apple Built-in iSight type: USB driver: uvcvideo bus ID: 1-6:2
chip ID: 05ac:8507 serial: <filter>
Display: x11 server: XOrg 1.20.10 driver: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 1280x800 s-dpi: 112 s-size: 290x181mm (11.4x7.1")
s-diag: 342mm (13.5")
Monitor-1: LVDS-0 res: 1280x800 hz: 60 dpi: 114 size: 286x179mm (11.3x7.0")
diag: 337mm (13.3")
OpenGL: renderer: GeForce 320M/integrated/SSE2 v: 3.3.0 NVIDIA 340.108
direct render: Yes
Device-1: NVIDIA MCP89 High Definition Audio driver: snd_hda_intel v: kernel
bus ID: 00:08.0 chip ID: 10de:0d94
Sound Server: ALSA v: k5.10.2-2-MANJARO
Device-1: NVIDIA MCP89 Ethernet vendor: Apple driver: forcedeth v: kernel
port: 22a0 bus ID: 00:09.0 chip ID: 10de:0d7d
IF: enp0s9 state: down mac: <filter>
Device-2: Broadcom BCM43224 802.11a/b/g/n vendor: Apple AirPort Extreme
driver: wl v: kernel modules: bcma port: 2280 bus ID: 01:00.0
chip ID: 14e4:4353
Local Storage: total: 238.47 GiB used: 200.95 GiB (84.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: A-Data model: SU800 size: 238.47 GiB
block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter>
rev: 7ANR
ID-1: / raw size: 218.18 GiB size: 213.75 GiB (97.97%)
used: 200.89 GiB (94.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 60.2 MiB (20.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 20 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 91.0 C mobo: N/A gpu: nvidia temp: 87 C
Processes: 157 Uptime: 31m wakeups: 2 Memory: 15.38 GiB
used: 2.24 GiB (14.5%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 1641 lib: 420 flatpak: 0 Shell: Bash v: 5.1.0 running in: server
inxi: 3.2.01
Output of glxinfo -B
is:
name of display: :0
display: :0 screen: 0
direct rendering: Yes
Memory info (GL_NVX_gpu_memory_info):
Dedicated video memory: 256 MB
Total available memory: 256 MB
Currently available dedicated video memory: 43 MB
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce 320M/integrated/SSE2
OpenGL core profile version string: 3.3.0 NVIDIA 340.108
OpenGL core profile shading language version string: 3.30 NVIDIA via Cg compiler
OpenGL core profile profile mask: core profile
OpenGL version string: 3.3.0 NVIDIA 340.108
OpenGL shading language version string: 3.30 NVIDIA via Cg compiler
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL ES profile version string: OpenGL ES 2.0 NVIDIA 340.108 340.108
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 1.00
Thanks for the help, If you need any more info please let me know.
