Hello there,
There is an issue with sleek (AUR (en) - sleek): it displays a white window since the update.
[alex@nono ~]$ sleek
Persisted data located at: /home/alex/.config/sleek/user-preferences.json
Success: Translations loaded for: en
Success: Window events setup
Success: Renderer window created
libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
[12588:0416/102514.711106:ERROR:viz_main_impl.cc(188)] Exiting GPU process due to errors during initialization
[12642:0416/102515.054117:ERROR:viz_main_impl.cc(188)] Exiting GPU process due to errors during initialization
[12666:0416/102515.084019:ERROR:sandbox_linux.cc(377)] InitializeSandbox() called with multiple threads in process gpu-process.
[12666:0416/102515.087859:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
I see there is an issue with libva but I have no idea what to do.
I re-installed the dependencies (electron, nodejs, yarn) and also libva packages, then re-installed/re-build sleek but no change either.
Any idea on what I could do to try fixing this?
Well, since sleek uses electron it is possible that the problem is as @JKAbrams commented in the last part of post number 10 above, but I don’t know how to “modify the package to use electron17” if this would turn out to be the problem.
You need to modify the depends-line in (line 17) in the PKGBUILD before building the package.
Before: (defaults the the current Manjaro version of electron)
depends=("electron" "nodejs")
After:
depends=("electron17" "nodejs")
If you use a AUR builder like Trizen for example it will give you the option to change the PKGBUILD on build time, otherwise just put all the source packages in a folder, modify the PKGBUILD and run
Ah, yes, and you also need to change the sha512 hash of the file changed file sleek in order for the builder to accept it. Probably the easiest way to do it would be to just build it with --skipchecksums
makepkg --skipchecksums
A better way is to generate the checksum and update checksums PKGBUILD
