VirtualBox won't start any VMs (says kernel module is not loaded)
In the wiki it says vbox-reload, but vboxreload outputs:
Unloading modules:
Loading modules: modprobe: FATAL: Module vboxnetadp not found in directory /lib/modules/6.6.23-1-MANJARO
modprobe: FATAL: Module vboxnetflt not found in directory /lib/modules/6.6.23-1-MANJARO
modprobe: FATAL: Module vboxdrv not found in directory /lib/modules/6.6.23-1-MANJARO
First i enabled svm (Amd Hardware Virtualization) in my bios, then i ran
sudo pacman -Syu virtualbox linux66-virtualbox-host-modules
and afterwards rebooted my system twice.
What happens (post the output of) when you run:
sudo modprobe vboxdrv
I tried this (didn’t explicitly install dmks and linux66-headers before), but after running sudo vboxreload is still get
Unloading modules:
There is something utterly out of whack with your system.
I am running the exact same kernel
15:32:06 ○ [fh@tiger] ~
 $ uname -a
Linux tiger 6.6.23-1-MANJARO #1 SMP PREEMPT_DYNAMIC Wed Mar 27 14:11:44 UTC 2024 x86_64 GNU/Linux
15:33:10 ○ [fh@tiger] ~
 $ sudo vboxreload
[sudo] password for fh:
Unloading modules: vboxnetadp vboxnetflt vboxdrv
Loading modules: vboxnetadp vboxnetflt vboxdrv
It is impossible to guess - since all your efforts are done the right way - I have no idea … completely blank.
Mmh, i don’t experience any other issues…
Well i guess i’ll try QEMU then if no one else has any ideas…
Thanks anyways!
You could do that - my last question is - do you by any chance use btrfs on your root filesystem?
Yes, i use btrfs.
Also my root is encrypted with luks, if that makes any difference.
Dang - I think your filesystem has gotten confused with all the adding and removing packages.
I have experienced that myself with btrfs - more than once … one of my main reassons for not running btrfs on production system.
Virtual machines hosted on btfs filesystem is a recipe for disaster - be sure to disable CoW for the partition or subvolume where you plan to store the VMs.
Possilby you need to do some maintenance on the filesystem - please see Btrfs Maintenance - Manjaro
Technically it shouldn’t make any difference…
Ok i’ll keep that in mind with QEMU and take a look into the maintenance article, thanks.
Please do fix the underlying issue before heading out for new adventures on the current system.
A post was split to a new topic: Virtualbox - kernel module not loaded
A post was merged into an existing topic: Virtualbox - kernel module not loaded
