If i launch the application and then close it, it seems to still be running in the background (i don`t know the technical term) so alarms or the stopwatch remain active.
So, when i boot, i want gnome clocks to automatically start running in the background, how can i do that?
PS: Using gnome tweaks startup applications isn`t the ideal solution because i don’t want to launch the gui
Generated on 2020-11-04 13:58:1604509139
#################### inxi -Fxzc0 ########################
System: Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A Desktop: GNOME 3.36.6
Distro: Manjaro Linux
Machine: Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter>
Mobo: Gigabyte model: H61M-S1 v: x.x serial: <filter> BIOS: American Megatrends v: FC
date: 02/25/2013
CPU: Topology: Quad Core model: Intel Core i5-3340 bits: 64 type: MCP arch: Ivy Bridge
rev: 9 L2 cache: 6144 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 24757
Speed: 1597 MHz min/max: 1600/3300 MHz Core speeds (MHz): 1: 1597 2: 1597 3: 1597
4: 1597
Graphics: Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics vendor: Gigabyte
driver: i915 v: kernel bus ID: 00:02.0
Display: wayland server: X.org 1.20.9 compositor: gnome-shell driver: i915
note: display driver n/a - try sudo/root resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa DRI Intel HD Graphics 2500 (IVB GT1) v: 4.2 Mesa 20.1.8
direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k5.8.16-2-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte
driver: r8169 v: kernel port: e000 bus ID: 02:00.0
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 931.51 GiB used: 41.60 GiB (4.5%)
ID-1: /dev/sda vendor: Toshiba model: DT01ACA100 size: 931.51 GiB
Partition: ID-1: / size: 907.80 GiB used: 41.60 GiB (4.6%) fs: ext4 dev: /dev/sda1
Swap: ID-1: swap-1 type: partition size: 8.22 GiB used: 0 KiB (0.0%) dev: /dev/sda2
Sensors: System Temperatures: cpu: 45.0 C mobo: N/A
Info: Processes: 191 Uptime: 2h 14m Memory: 3.73 GiB used: 1.82 GiB (48.7%) Init: systemd
Compilers: gcc: N/A Packages: 1099 Client: shell wrapper v: 5.0.18-release inxi: 3.1.05
