I did an update and then installed the suggested 5.19 kernel.
Now when I launch VirtualBox I get a message that the kernel is unsupported and I should uninstall it.
I rebooted twice.
VirtualBox Graphical User Interface Version 6.1.36 r152435
system info and ls -al /boot
inxi -F ✔
Host: shmuel-manjaro Kernel: 5.19.1-3-MANJARO arch: x86_64 bits: 64
Desktop: GNOME v: 42.4 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B365M-A v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 1203
date: 10/10/2019
Info: 8-core model: Intel Core i7-9700 bits: 64 type: MCP cache: L2: 2 MiB
Speed (MHz): avg: 3200 min/max: 800/4700 cores: 1: 3000 2: 3000 3: 3000
4: 3000 5: 4601 6: 3000 7: 3000 8: 3000
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] driver: i915 v: kernel
Device-2: Microdia USB Live camera type: USB
driver: snd-usb-audio,uvcvideo
Display: wayland server: X.Org v: 22.1.3 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: X: loaded: modesetting gpu: i915
resolution: 1: 1920x1080~120Hz 2: 1600x900~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa
22.1.6
Device-1: Intel 200 Series PCH HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.19.1-3-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.56 running: yes
driver: r8169
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: a8:5e:45:e2:87:3c
Device-2: Realtek 802.11ac NIC type: USB driver: N/A
driver: btusb
Local Storage: total: 2.26 TiB used: 825.97 GiB (35.8%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
ID-2: /dev/sdb vendor: Toshiba model: HDWD120 size: 1.82 TiB
ID-1: / size: 249.61 GiB used: 142.57 GiB (57.1%) fs: ext4 dev: /dev/sda4
ID-2: /boot/efi size: 96 MiB used: 37.8 MiB (39.3%) fs: vfat
dev: /dev/sda1
System Temperatures: cpu: 42.0 C mobo: N/A
Processes: 328 Uptime: 4m Memory: 15.49 GiB used: 4.79 GiB (30.9%)
Shell: Zsh inxi: 3.3.20
~ ls -al /boot ✔
total 120857
drwxr-xr-x 5 root root 4096 Aug 17 14:33 .
drwxr-xr-x 19 root root 4096 Jul 21 10:15 ..
drwx------ 5 root root 1024 Jan 1 1970 efi
drwxr-xr-x 7 root root 4096 Aug 17 14:33 grub
-rw------- 1 root root 39688725 Aug 17 14:15 initramfs-5.18-x86_64-fallback.img
-rw------- 1 root root 8611886 Aug 17 14:15 initramfs-5.18-x86_64.img
-rw------- 1 root root 39739641 Aug 17 14:28 initramfs-5.19-x86_64-fallback.img
-rw------- 1 root root 8614217 Aug 17 14:28 initramfs-5.19-x86_64.img
-rw-r--r-- 1 root root 5180416 Aug 9 21:43 intel-ucode.img
-rw-r--r-- 1 root root 22 Aug 11 21:42 linux518-x86_64.kver
-rw-r--r-- 1 root root 21 Aug 13 09:33 linux519-x86_64.kver
drwxr-xr-x 2 root root 4096 Dec 11 2021 memtest86+
-rw-r--r-- 1 root root 10816576 Aug 17 14:15 vmlinuz-5.18-x86_64
-rw-r--r-- 1 root root 11061312 Aug 17 14:28 vmlinuz-5.19-x86_64
