VirtualBox - out of the blue (probably not) error
virtualbox
#1
[fh@thinkstation ~]$ virtualbox
VirtualBox: Error -610 in supR3HardenedMainInitRuntime!
VirtualBox: dlopen("/usr/lib/virtualbox/VBoxRT.so",) failed: <NULL>
VirtualBox: Tip! It may help to reinstall VirtualBox.
Well - I can do that :slight_smile:
$ sudo pacman -Rns virtualbox virtualbox-guest-iso virtualbox-ext-oracle linux49-virtualbox-host-modules
reboot
Back after reboot
[fh@thinkstation ~]$ sudo pacman -Syu virtualbox virtualbox-guest-iso linux49-virtualbox-host-modules
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
 zorglub is up to date
resolving dependencies...
Packages (4) qt5-x11extras-5.9.1-2  linux49-virtualbox-host-modules-5.1.28-4
             virtualbox-5.1.28-1  virtualbox-guest-iso-5.1.28-1
Total Download Size:    58,77 MiB
Total Installed Size:  157,07 MiB
:: Retrieving packages...
 qt5-x11extras-5.9.1...    12,4 KiB  0,00B/s 00:00 [######################] 100%
 linux49-virtualbox-...   199,4 KiB  12,2M/s 00:00 [######################] 100%
 virtualbox-5.1.28-1...    20,6 MiB  11,3M/s 00:02 [######################] 100%
 virtualbox-guest-is...    38,0 MiB  11,2M/s 00:03 [######################] 100%
(4/4) checking keys in keyring                     [######################] 100%
(4/4) checking package integrity                   [######################] 100%
(4/4) loading package files                        [######################] 100%
(4/4) checking for file conflicts                  [######################] 100%
(4/4) checking available disk space                [######################] 100%
(1/4) installing qt5-x11extras                     [######################] 100%
(2/4) installing linux49-virtualbox-host-modules   [######################] 100%
===> You must load vboxdrv module before starting VirtualBox:
===> # modprobe vboxdrv
(3/4) installing virtualbox                        [######################] 100%
Optional dependencies for virtualbox
    vde2: Virtual Distributed Ethernet support
    virtualbox-guest-iso: Guest Additions CD image [pending]
    virtualbox-ext-vnc: VNC server support
    virtualbox-sdk: Developer kit
(4/4) installing virtualbox-guest-iso              [######################] 100%
===> virtualbox-guest-iso post install message:
===> Redistribution of VBoxGuestAdditions.iso from the binary packages
===> on www.virtualbox.org with Arch Linux has been granted by
===> InnoTek Systemberatung GmbH.
===> By using this package you accept
===> the VirtualBox Personal Use and Evaluation License (PUEL)
===> which can be found here: http://virtualbox.org/wiki/VirtualBox_PUEL
===> If you do not accept this license, you must remove the package immediately.
(1/5) Updating icon theme caches...
(2/5) Updating system user accounts...
(3/5) Arming ConditionNeedsUpdate...
(4/5) Updating the desktop file MIME type cache...
(5/5) Updating the MIME type database...
[fh@thinkstation ~]$ sudo vboxdrv
sudo: vboxdrv: command not found
[fh@thinkstation ~]$ sudo vboxreload
Unloading modules: vboxnetadp vboxnetflt vboxpci vboxdrv
Loading modules: vboxnetadp vboxnetflt vboxpci vboxdrv
No errors during install or reloading of drivers alas the error repeats and I have no clue.
I have scoured for the phrase Error -610 in supR3HardenedMainInitRuntime! and all points to a mismatch of files. But where?
#2
A bright moment occurred: Why don’t I check the ownership of the filesystem - where did I get that?
As it came out - I have some scripts - not packaged - which I copy to /usr/bin /usr/lib /usr/share.
Those are copied using sudo but this time - to my surprise the ownership of the files was fh:users after changing the user:group relation on those files to root:root - the problem disappeared.
#3
This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
