edit: a reboot fixed it…
Hi there,
This is the error I get (I can’t add any links to this post for some reason)
https://imgur.com/YAnMVjc
I checked for the error 1912 and read that I needed to add the proper kernel modules, as the error message says.
~ $ uname -a
Linux XPS15 5.4.62-1-MANJARO #1 SMP PREEMPT Thu Sep 3 14:38:22 UTC 2020 x86_64 GNU/Linux
So I will need modules for linux54, correct?
~ $ sudo pacman -S linux54-virtualbox-host-modules
What do I need to do next? In this old post https://classicforum.manjaro.org/index.php?topic=24594.msg213948#msg213948
I read that I should " load vboxdrv with modprobe vboxdrv and then run your virtual machine", is that correct?
When I try this I get an error but maybe I am doing it wrong…
~ $ modprobe vboxdrv
modprobe: FATAL: Module vboxdrv not found in directory /lib/modules/5.4.62-1-MANJARO
Can someone point me into the right direction?
edit: why does the new forum not allow external links or media in a post?
