I would like to start by saying I am fairly new to linux, definitely new to these forums.
I have been trying to play Lego Star Wars The Skywalker Saga, and it just won’t open. I also have this problems with Black Ops III, but I do not have this issue with Raft. Those are the only games I have really tired playing so I figured I’d include them.
I have been trying it fix this for a few days now and well I can’t seem to find any solutions that works.
Here is information about my system
Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=aada8b93-56b1-40a1-aafb-bab1dbf91d5f rw quiet apparmor=1
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B360M-A v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2602
date: 07/24/2019
RAM: total: 31.27 GiB used: 8.27 GiB (26.4%)
RAM Report:
Info: model: Intel Core i9-9900K bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xEC
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4129 high: 4220 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 4141 2: 4108 3: 4149
4: 4078 5: 4082 6: 4110 7: 4039 8: 4100 9: 4065 10: 4082 11: 4178 12: 4194
13: 4180 14: 4220 15: 4200 16: 4150 bogomips: 115232
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx
msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep
smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Type: srbds mitigation: TSX disabled
Device-1: NVIDIA TU116 [GeForce GTX 1660] vendor: PNY driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:2184 class-ID: 0300
Device-2: Logitech StreamCam type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 2-1:2
chip-ID: 046d:0893 class-ID: 0300 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: nvidia gpu: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1524x286mm (60.00x11.26")
s-diag: 1551mm (61.05")
Monitor-1: DP-1 pos: right res: 1920x1080 hz: 60 dpi: 92
size: 531x299mm (20.91x11.77") diag: 609mm (23.99") modes: N/A
Monitor-2: DVI-D-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 92
Monitor-3: HDMI-0 pos: primary,center res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
Device-2: NVIDIA TU116 High Definition Audio vendor: PNY
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-3: C-Media Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2:2 chip-ID: 0d8c:0005
Device-4: Logitech StreamCam type: USB
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.48 running: yes
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 5.03 TiB used: 1.03 TiB (20.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: PCIe SSD size: 1.86 TiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
type: SSD serial: <filter> rev: ECFM13.3 temp: 27.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM003-1SB102
type: HDD rpm: 7200 serial: <filter> rev: HPH4 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 model: SATA SSD size: 447.13 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 61.3 scheme: GPT
ID-1: / raw-size: 446.83 GiB size: 438.75 GiB (98.19%)
used: 50.38 GiB (11.5%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: aada8b93-56b1-40a1-aafb-bab1dbf91d5f
used: 292 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: NO_LABEL
uuid: 7F1D-D28A
ID-3: /media/GamesDrive raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 878.63 GiB (47.2%) fs: ntfs dev: /dev/sda2 maj-min: 8:2
label: GamesDrive uuid: 98DCFF8FDCFF65C2
ID-4: /media/OldDrive raw-size: 931.5 GiB size: 931.5 GiB (100.00%)
used: 124.3 GiB (13.3%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18
label: Old Drive uuid: A61A24701A244023
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: N/A
uuid: F68D-DDB9
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 1.85 TiB fs: ntfs label: Windows
uuid: 4C5C2ACF5C2AB39C
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 980 MiB fs: ntfs
label: Windows RE tools uuid: F6363BE1363BA213
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 16.15 GiB fs: ntfs
label: RECOVERY uuid: 30F47683F4764ADC
ID-6: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-7: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-2:2 info: C-Media Blue Snowball type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0005 class-ID: 0300
serial: <filter>
Device-2: 1-6:3 info: Microsoft Xbox Wireless Controller (model 1914)
type: <vendor specific> driver: xpad interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 045e:0b12 class-ID: ff00 serial: <filter>
Device-3: 1-7:4 info: Holtek Mechanical Keyboard type: Keyboard,HID
power: 100mA chip-ID: 04d9:1836 class-ID: 0300
Device-4: 1-8:5 info: Pixart Imaging Gaming Mouse type: Mouse,Keyboard
power: 100mA chip-ID: 093a:2533 class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
Device-1: 2-1:2 info: Logitech StreamCam type: Video,Audio,HID
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo interfaces: 6 rev: 3.2
speed: 5 Gb/s power: 896mA chip-ID: 046d:0893 class-ID: 0300
serial: <filter>
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 61.0 C mobo: N/A gpu: nvidia temp: 32 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
Processes: 390 Uptime: 1h 50m wakeups: 0 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1407
pacman: 1385 lib: 434 flatpak: 11 snap: 11 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.15
So, I am not entirely sure what things I can provide to be helpful, but I open steam in the terminal and tried to launch Lego Star Wars The Skywalker Saga
GameAction [AppID 920210, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
wine: '/media/GamesDrive/SteamLibrary/steamapps/compatdata/920210/pfx' is not owned by you
GameAction [AppID 920210, ActionID 1] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 920210, ActionID 1] : LaunchApp changed task to SynchronizingControllerConfig with ""
GameAction [AppID 920210, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 920210, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 920210, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 920210, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0PROTON_USE_WINED3D=1 -WINEDEBUG="+timestamp,+pid,+tid,+seh,+debugstr,+module" /home/lukez/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=920210 -- '/media/GamesDrive/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/lukez/.local/share/Steam/compatibilitytools.d/GE-Proton7-14'/proton waitforexitandrun '/media/GamesDrive/SteamLibrary/steamapps/common/LEGO Star Wars - The Skywalker Saga/LEGOSTARWARSSKYWALKERSAGA_DX11.exe' -PROTON_LOG=1 /home/lukez/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=920210 -- '/media/GamesDrive/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/lukez/.local/share/Steam/compatibilitytools.d/GE-Proton7-14'/proton waitforexitandrun '/media/GamesDrive/SteamLibrary/steamapps/common/LEGO Star Wars - The Skywalker Saga/LEGOSTARWARSSKYWALKERSAGA_DX11.exe'\0
Game process added : AppID 920210 "PROTON_USE_WINED3D=1 -WINEDEBUG="+timestamp,+pid,+tid,+seh,+debugstr,+module" /home/lukez/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=920210 -- '/media/GamesDrive/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/lukez/.local/share/Steam/compatibilitytools.d/GE-Proton7-14'/proton waitforexitandrun '/media/GamesDrive/SteamLibrary/steamapps/common/LEGO Star Wars - The Skywalker Saga/LEGOSTARWARSSKYWALKERSAGA_DX11.exe' -PROTON_LOG=1 /home/lukez/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=920210 -- '/media/GamesDrive/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/lukez/.local/share/Steam/compatibilitytools.d/GE-Proton7-14'/proton waitforexitandrun '/media/GamesDrive/SteamLibrary/steamapps/common/LEGO Star Wars - The Skywalker Saga/LEGOSTARWARSSKYWALKERSAGA_DX11.exe'", ProcID 21329, IP 0.0.0.0:0
chdir /media/GamesDrive/SteamLibrary/steamapps/common/LEGO Star Wars - The Skywalker Saga
ERROR: ld.so: object '/home/lukez/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
GameAction [AppID 920210, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 920210, ActionID 1] : LaunchApp changed task to Completed with ""
/bin/sh: line 1: -WINEDEBUG=+timestamp,+pid,+tid,+seh,+debugstr,+module: command not found
Game process removed: AppID 920210 "PROTON_USE_WINED3D=1 -WINEDEBUG="+timestamp,+pid,+tid,+seh,+debugstr,+module" /home/lukez/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=920210 -- '/media/GamesDrive/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/lukez/.local/share/Steam/compatibilitytools.d/GE-Proton7-14'/proton waitforexitandrun '/media/GamesDrive/SteamLibrary/steamapps/common/LEGO Star Wars - The Skywalker Saga/LEGOSTARWARSSKYWALKERSAGA_DX11.exe' -PROTON_LOG=1 /home/lukez/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=920210 -- '/media/GamesDrive/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/lukez/.local/share/Steam/compatibilitytools.d/GE-Proton7-14'/proton waitforexitandrun '/media/GamesDrive/SteamLibrary/steamapps/common/LEGO Star Wars - The Skywalker Saga/LEGOSTARWARSSKYWALKERSAGA_DX11.exe'", ProcID 21329
Uploaded AppInterfaceStats to Steam
I have tried Proton 7.0-1, Proton Experimental, and GE-Proton7-14 and got the same results each time.
