Hi I installed linux58-virtualbox-host-modules and I get the error:
WARNING: The vboxdrv kernel module is not loaded. Either there is no module
available for the current kernel (5.8.11-1-MANJARO) or it failed to
load. Please recompile the kernel module and install it by
sudo /sbin/vboxconfig
You will not be able to start VMs until this problem is fixed.
