Hi community. Yesterday i ran sudo pacman -Syu, but after all the packages were downloaded and the system starts upgrade them my pc frozes out and i have not choise other than restart, obviously when i try to load again the O.S the first error was that the kernel file was not found so i make an manjaro live usb and boot it to try to solve my problem:
The first in my mind was sudo manjaro-chroot -a but that shows me the following error: bin/bash: error while loading shared libraries: /usr/lib/libncursesw.so.6: file too short
i kept searching for an answer and try out all this:
since i can’t run sudo manjaro-chroot -a i followed this guide https://wiki.archlinux.org/title/Pacman#Pacman_crashes_during_an_upgrade
but when get to the step 4 to pacman --sysroot /mnt -Syu thats show me: error: GPGME error: Invalid crypto engine
but returns me the same: /bin/bash: error while loading shared libraries: /usr/lib/libncursesw.so.6: file too short
Another thing i tried was: pacman --root /mnt --cachedir /mnt/var/cache/pacman/pkg -S ncurses
but shows me several errors: error: failed to commit transaction (conflicting files) ncurses: /mnt/usr/bin/captoinfo exists in filesystem ncurses: /mnt/usr/bin/clear exists in filesystem ncurses: /mnt/usr/bin/infocmp exists in filesystem ncurses: /mnt/usr/bin/infotocap exists in filesystem ncurses: /mnt/usr/bin/ncursesw6-config exists in filesystem
indicating that a lot of files already exist, and if i try to: pacman --root /mnt --cachedir /mnt/var/cache/pacman/pkg -S ncurses --overwrite "*"
i get the following error again: /bin/bash: error while loading shared libraries: /usr/lib/libncursesw.so.6: file too short
finally i check for size of this /usr/lib/libncursesw.so.6 file and it was 0kb
No i can’t run sudo manjaro-chroot -a because shows me the following error: bin/bash: error while loading shared libraries: /usr/lib/libncursesw.so.6: file too short
are you using manjaro iso?
try chrooting manually with this without the manjaro-chroot -a command… if you cant chroot, i dont know how do you want to repair your system…
[manjaro lib]# cd /mnt/usr/lib
[manjaro lib]# rm libncursesw.so.6 libncursesw.so
[manjaro lib]# ln -s libncursesw.so.6.3 libncursesw.so.6
[manjaro lib]# ln -s libncursesw.so.6 libncursesw.so
[manjaro lib]# manjaro-chroot /mnt /bin/bash
but check this:
libncursesw.so.6.3 file size is 0bytes
so i think the file is corrupt, may i copy the same file located in /usr/lib that belongs to the system loaded by the live-usb?
is the exact same version so.6.3 and the size is 459.2KiB
what do you think?
great, so rerun the update again: pamac update
and i dont think that only running the update again will be enough, also reinstalling kernels, checking graphics, running update grub and mkinitcpio … let me know how it went with the update
hey brahma, i’ve been a liitle bussy here so, i ran pamac update and give me this error:
[manjaro /]# pamac update
Warning: Building packages as dynamic user
Warning: Setting build directory to /var/cache/pamac
Preparing...
https://mirrors.manjaro.org/repo/stable/core/x86_64/core.db: Unacceptable TLS certificate
Failed to synchronize databases
https://aur.manjaro.org/packages-meta-ext-v1.json.gz: Unacceptable TLS certificate
Failed to synchronize AUR database
Failed to query https://aur.archlinux.org/rpc/?v=5&type=info&arg[]=gnome-icon-theme&arg[]=gnome-icon-theme-symbolic&arg[]=google-chrome&arg[]=insomnia-bin&arg[]=qpdfview&arg[]=rtl8812au-dkms-git&arg[]=smartgit&arg[]=visual-studio-code-bin&arg[]=yay-git from AUR: Unacceptable TLS certificate
Failed to initialize alpm library (could not find or read directory)
** (pamac:172): WARNING **: 20:54:22.100: alpm_utils.vala:290: Failed to initialize alpm library
Error: Alpm Error: Failed to initialize alpm library
and if run pacman -S samba for example give this error instead:
(2/2) checking keys in keyring [######################] 100%
(2/2) checking package integrity [######################] 100%
(2/2) loading package files [######################] 100%
(2/2) checking for file conflicts [######################] 100%
(2/2) checking available disk space [######################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
Wrong paramater in /etc/timeshift-autosnap.conf. Using skipAutosnap=false
Wrong paramater in /etc/timeshift-autosnap.conf. Using skipRsyncAutosnap=false
Wrong paramater in /etc/timeshift-autosnap.conf. Using snapshotDescription={timeshift-autosnap} {created before upgrade}
Application needs admin access.
Please run the application as admin (using 'sudo' or 'su')
Unable to run timeshift-autosnap! Please close Timeshift and try again. Script will now exit...
error: command failed to execute correctly
error: failed to commit transaction (failed to run transaction hooks)
