I use Manjaro Gnome with the latest update. I installed Windows 7 Starter Edition (32bit) as my VM.
I installed the Extension Pack from AUR repositories and add the user-name to the vbox user group, then rebooted, as shown in this Wiki: https://wiki.manjaro.org/index.php?title=VirtualBox.
However, Virtualbox cannot load but can recognise my USB devices. In the Virtualbox USB setting I couldn’t select which USB type to use as they were grey out. The USB driver installation on my VM also failed.
I tried several USB devices and they all have this problem. The same problem also happened several days ago when I ran a Windows 10 VM. So I think it’s not the problem with USB or Windows editions.
Here is my system output if it’s needed:
Host: js_f Kernel: 4.19.6-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1
Desktop: Gnome 3.30.2 wm: gnome-shell dm: GDM 3.30.2 Distro: Manjaro Linux
Type: Laptop System: Dell product: Latitude 5250 v: N/A serial: <filter>
Chassis: type: 9 serial: <filter>
Mobo: Dell model: 0HMFMD v: A00 serial: <filter> UEFI: Dell v: A14
date: 12/26/2016
ID-1: BAT0 charge: 23.4 Wh condition: 26.2/38.8 Wh (68%) volts: 12.0/11.4
model: Samsung SDI DELL R5MD0D9 type: Li-poly serial: <filter>
status: Discharging
Topology: Dual Core model: Intel Core i3-5010U bits: 64 type: MT MCP
arch: Broadwell rev: 4 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 16766
Speed: 798 MHz min/max: 500/2000 MHz Core speeds (MHz): 1: 798 2: 798
3: 798 4: 798
Device-1: Intel HD Graphics 5500 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:1616
Display: x11 server: X.org 1.20.3 driver: i915 compositor: gnome-shell
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa DRI Intel HD Graphics 5500 (Broadwell GT2)
v: 4.5 Mesa 18.2.6 compat-v: 3.0 direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Dell driver: snd_hda_intel
v: kernel bus ID: 00:03.0 chip ID: 8086:160c
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:9ca0
Sound Server: ALSA v: k4.19.6-1-MANJARO
Device-1: Intel Ethernet I218-LM vendor: Dell driver: e1000e v: 3.2.6-k
port: f080 bus ID: 00:19.0 chip ID: 8086:15a2
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: f040
bus ID: 02:00.0 chip ID: 8086:095a
Local Storage: total: 119.24 GiB used: 29.78 GiB (25.0%)
ID-1: /dev/sda vendor: Samsung model: SSD PM851 2.5 7mm 128GB
size: 119.24 GiB speed: 6.0 Gb/s serial: <filter> rev: 8D0Q scheme: GPT
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus ID: 00:1f.2 chip ID: 8086.282a rev: 03
ID-1: / size: 108.46 GiB used: 28.43 GiB (26.2%) fs: ext4 dev: /dev/sda2
ID-2: swap-1 size: 8.25 GiB used: 1.34 GiB (16.3%) fs: swap dev: /dev/sda3
System Temperatures: cpu: 45.0 C mobo: 37.0 C sodimm: 34.0 C
Fan Speeds (RPM): cpu: 0
Processes: 270 Uptime: 15h 46m Memory: 3.75 GiB used: 2.61 GiB (69.6%)
Init: systemd v: 239 Compilers: gcc: 8.2.1 Shell: bash v: 4.4.23
running in: gnome-terminal inxi: 3.0.27
