VirtualBox 6.1.4-3 Issue
[jshand@johns-pc ~]$ inxi -Fxxxza
System:    Host: johns-pc Kernel: 5.4.28-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=ce8821e5-cd7b-41a8-bfa2-6a6b09111eaa rw quiet
           apparmor=1 security=apparmor resume=UUID=762d6676-239c-4d2e-935a-390f5a100d75 udev.log_priority=3
           modprobe.blacklist=radeon amdgpu.dcfeaturemask=0x4
           Desktop: KDE Plasma 5.18.3 tk: Qt 5.14.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: Acer product: Aspire A315-21G v: V1.12 serial: <filter>
           Mobo: SR model: Squirtle_SR v: V1.12 serial: <filter> UEFI [Legacy]: Insyde v: 1.12 date: 06/19/2018
Battery:   ID-1: BAT1 charge: 32.5 Wh condition: 32.5/37.0 Wh (88%) volts: 8.3/7.7 model: PANASONIC AP16M5J
           type: Li-ion serial: <filter> status: Full
           Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
           charge: 55% (should be ignored) rechargeable: yes status: Discharging
CPU:       Topology: Dual Core model: AMD A9-9420e RADEON R5 5 COMPUTE CORES 2C+3G bits: 64 type: MCP arch: Excavator
           family: 15 (21) model-id: 70 (112) stepping: N/A microcode: 6006705 L2 cache: 1024 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 7189
           Speed: 2390 MHz min/max: 1200/1800 MHz boost: enabled Core speeds (MHz): 1: 2616 2: 1872
           Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Stoney [Radeon R2/R3/R4/R5 Graphics]
           vendor: Acer Incorporated ALI driver: amdgpu v: kernel bus ID: 00:01.0 chip ID: 1002:98e4
           Device-2: AMD Jet PRO [Radeon R5 M230 / R7 M260DX / Radeon 520 Mobile] vendor: Acer Incorporated ALI
           driver: N/A bus ID: 01:00.0 chip ID: 1002:6665
           Display: x11 server: X.Org 1.20.7 driver: amdgpu FAILED: ati unloaded: modesetting alternate: fbdev,vesa
           compositor: kwin_x11 resolution: 1366x768~60Hz
           OpenGL: renderer: AMD STONEY (DRM 3.35.0 5.4.28-1-MANJARO LLVM 9.0.1) v: 4.5 Mesa 19.3.5 direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
           bus ID: 00:01.1 chip ID: 1002:15b3
           Device-2: Advanced Micro Devices [AMD] Family 15h Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
           v: kernel bus ID: 00:09.2 chip ID: 1022:157a
           Sound Server: ALSA v: k5.4.28-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI
           driver: r8169 v: kernel port: 2000 bus ID: 02:00.1 chip ID: 10ec:8168
           IF: enp2s0f1 state: down mac: <filter>
           Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lite-On driver: ath10k_pci
           v: kernel port: 2000 bus ID: 03:00.0 chip ID: 168c:0042
Drives:    Local Storage: total: 931.51 GiB used: 66.24 GiB (7.1%)
           ID-1: /dev/sda vendor: Western Digital model: WD10SPZX-21Z10T0 size: 931.51 GiB block size:
           physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1A02 scheme: MBR
Partition: ID-1: / raw size: 922.71 GiB size: 907.23 GiB (98.32%) used: 66.24 GiB (7.3%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 8.80 GiB used: 0 KiB (0.0%) fs: swap swappiness: 60 (default)
           cache pressure: 100 (default) dev: /dev/sda2
Sensors:   System Temperatures: cpu: 40.0 C mobo: N/A gpu: amdgpu temp: 38 C
Info:      Processes: 166 Uptime: 10m Memory: 7.24 GiB used: 1.99 GiB (27.4%) Init: systemd v: 244 Compilers:
           gcc: 9.3.0 Shell: bash v: 5.0.16 running in: konsole inxi: 3.0.37
above is my computer setup.
i have just installed virtualbox 6.1.4-3 after latest stable updates and got the error after rebooting:
[jshand@johns-pc ~]$ systemctl status systemd-modules-load.service
‚óŹ systemd-modules-load.service - Load Kernel Modules
     Loaded: loaded (/usr/lib/systemd/system/systemd-modules-load.service; static; vendor preset: disabled)
     Active: failed (Result: exit-code) since Thu 2020-03-26 21:35:52 NZDT; 5min ago
       Docs: man:systemd-modules-load.service(8)
             man:modules-load.d(5)
    Process: 834 ExecStart=/usr/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
   Main PID: 834 (code=exited, status=1/FAILURE)
Mar 26 21:35:31 johns-pc systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
Mar 26 21:35:31 johns-pc systemd[1]: Failed to start Load Kernel Modules.
Mar 26 21:35:43 johns-pc systemd[1]: Starting Load Kernel Modules...
Mar 26 21:35:43 johns-pc systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
Mar 26 21:35:43 johns-pc systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
Mar 26 21:35:43 johns-pc systemd[1]: Failed to start Load Kernel Modules.
Mar 26 21:35:52 johns-pc systemd[1]: Starting Load Kernel Modules...
Mar 26 21:35:52 johns-pc systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
Mar 26 21:35:52 johns-pc systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
Mar 26 21:35:52 johns-pc systemd[1]: Failed to start Load Kernel Modules.
These above errors never existed until in installed virtualbox. since i am running the latest LTS kernel, i installed the LTS version of kernel modules for virtualbox.
I will include dmesg as well to see if this help debugging.
[   20.300313] cryptd: max_cpu_qlen set to 1000
[   20.304141] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   20.335610] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   20.427599] acer_wmi: Acer Laptop ACPI-WMI Extras
[   20.427639] acer_wmi: Function bitmap for Communication Button: 0x801
[   20.458978] AVX2 version of gcm_enc/dec engaged.
[   20.458980] AES CTR mode by8 optimization enabled
[   20.480763] input: Acer WMI hotkeys as /devices/virtual/input/input30
[   20.790294] r8169 0000:02:00.1 enp2s0f1: renamed from eth0
[   20.862819] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:09.2/sound/card1/input29
[   20.862974] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:09.2/sound/card1/input31
[   21.101140] ath10k_pci 0000:03:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[   21.385925] vboxdrv: disagrees about version of symbol module_layout
[   21.409154] vboxdrv: disagrees about version of symbol module_layout
[   21.437232] vboxdrv: disagrees about version of symbol module_layout
[   21.439742] audit: type=1130 audit(1585211743.855:22): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[   21.476734] ath10k_pci 0000:03:00.0: qca9377 hw1.1 target 0x05020001 chip_id 0x003821ff sub 11ad:08a6
[   21.476738] ath10k_pci 0000:03:00.0: kconfig debug 1 debugfs 1 tracing 1 dfs 0 testmode 0
[   21.477363] ath10k_pci 0000:03:00.0: firmware ver WLAN.TF.2.1-00021-QCARMSWP-1 api 6 features wowlan,ignore-otp crc32 4
2e41877
[   21.560670] kvm: Nested Virtualization enabled
[   21.560677] kvm: Nested Paging enabled
[   21.560678] SVM: Virtual VMLOAD VMSAVE supported
[   21.560678] SVM: Virtual GIF supported
[   21.583476] ath10k_pci 0000:03:00.0: board_file api 2 bmi_id N/A crc32 8aedfa4a
[   21.630725] MCE: In-kernel MCE decoding enabled.
[   21.641534] ath10k_pci 0000:03:00.0: unsupported HTC service id: 1536
[   21.660011] ath10k_pci 0000:03:00.0: htt-ver 3.56 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[   21.758017] ath: EEPROM regdomain: 0x69
[   21.758021] ath: EEPROM indicates we should expect a direct regpair map
[   21.758026] ath: Country alpha2 being used: 00
[   21.758027] ath: Regpair used: 0x69
[   21.764699] ath10k_pci 0000:03:00.0 wlp3s0: renamed from wlan0
[   21.980797] audit: type=1130 audit(1585211744.398:23): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   22.646702] Adding 9227464k swap on /dev/sda2.  Priority:-2 extents:1 across:9227464k FS
[   22.845003] audit: type=1130 audit(1585211745.262:24): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   26.985837] audit: type=1131 audit(1585211749.402:25): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
[   28.300013] audit: type=1130 audit(1585211750.718:26): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=ldconfig comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   28.676810] mousedev: PS/2 mouse device common for all mice
[   28.696203] mc: Linux media interface: v0.10
[   28.859065] videodev: Linux video capture interface: v2.00
[   28.933957] Bluetooth: Core ver 2.22
[   28.933995] NET: Registered protocol family 31
[   28.933996] Bluetooth: HCI device and connection manager initialized
[   28.934003] Bluetooth: HCI socket layer initialized
[   28.934006] Bluetooth: L2CAP socket layer initialized
[   28.934027] Bluetooth: SCO socket layer initialized
[   29.263308] uvcvideo: Found UVC 1.00 device VGA WebCam (0408:a031)
[   29.269542] uvcvideo 1-1.4:1.0: Entity type for entity Extension 4 was not initialized!
[   29.269549] uvcvideo 1-1.4:1.0: Entity type for entity Processing 2 was not initialized!
[   29.269552] uvcvideo 1-1.4:1.0: Entity type for entity Camera 1 was not initialized!
[   29.269718] input: VGA WebCam: VGA WebCam as /devices/pci0000:00/0000:00:12.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input32
[   29.269895] usbcore: registered new interface driver uvcvideo
[   29.269897] USB Video Class driver (1.1.1)
[   29.357979] usbcore: registered new interface driver btusb
[   29.583759] Bluetooth: hci0: using rampatch file: qca/rampatch_usb_00000302.bin
[   29.583766] Bluetooth: hci0: QCA: patch rome 0x302 build 0x3e8, firmware rome 0x302 build 0x111
[   29.605619] audit: type=1130 audit(1585211752.022:27): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
[   29.640407] vboxdrv: disagrees about version of symbol module_layout
[   29.658931] vboxdrv: disagrees about version of symbol module_layout
[   29.675814] vboxdrv: disagrees about version of symbol module_layout
[   29.677989] audit: type=1130 audit(1585211752.095:28): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
[   29.728645] Bluetooth: hci0: using NVM file: qca/nvm_usb_00000302.bin
[   32.814316] audit: type=1130 audit(1585211755.232:29): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   34.096207] audit: type=1130 audit(1585211756.512:30): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   34.127896] audit: type=1127 audit(1585211756.545:31): pid=839 uid=0 auid=4294967295 ses=4294967295 subj==unconfined ms
g=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[   34.206483] audit: type=1130 audit(1585211756.622:32): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   34.313984] audit: type=1130 audit(1585211756.732:33): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=systemd-journal-catalog-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succes
s'
[   34.381192] audit: type=1130 audit(1585211756.798:34): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=systemd-update-done comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   34.509990] audit: type=1131 audit(1585211756.928:35): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
[   34.524506] audit: type=1130 audit(1585211756.942:36): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=clamav-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   34.528071] audit: type=1130 audit(1585211756.945:37): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   34.535051] audit: type=1130 audit(1585211756.952:38): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   37.213919] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   37.213923] Bluetooth: BNEP filters: protocol multicast
[   37.213931] Bluetooth: BNEP socket layer initialized
[   37.371938] NET: Registered protocol family 38
[   38.124664] kauditd_printk_skb: 6 callbacks suppressed
[   38.124667] audit: type=1130 audit(1585211760.542:45): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   38.509452] audit: type=1130 audit(1585211760.925:46): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   38.511608] loop: module loaded
[   38.682054] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[   39.419535] audit: type=1130 audit(1585211761.835:47): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   40.074355] audit: type=1130 audit(1585211762.492:48): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   41.046321] audit: type=1130 audit(1585211763.462:49): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   44.427376] audit: type=1131 audit(1585211766.845:50): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
[   49.580483] audit: type=1130 audit(1585211771.995:51): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=firewalld comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   49.755397] audit: type=1325 audit(1585211772.172:52): table=filter family=2 entries=0
[   50.018624] audit: type=1325 audit(1585211772.435:53): table=filter family=10 entries=0
[   51.177328] audit: type=1130 audit(1585211773.592:54): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   51.273901] audit: type=1130 audit(1585211773.688:55): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   51.279652] audit: type=1130 audit(1585211773.695:56): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   53.214276] audit: type=1130 audit(1585211775.632:57): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   53.489322] audit: type=1325 audit(1585211775.905:58): table=security family=2 entries=0
[   53.509653] Generic FE-GE Realtek PHY r8169-201:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r
8169-201:00, irq=IGNORE)
[   53.513343] audit: type=1325 audit(1585211775.928:59): table=raw family=2 entries=0
[   53.527320] audit: type=1325 audit(1585211775.942:60): table=mangle family=2 entries=0
[   53.627287] r8169 0000:02:00.1 enp2s0f1: Link is Down
[   53.879321] ath10k_pci 0000:03:00.0: unsupported HTC service id: 1536
[   54.181415] ath10k_pci 0000:03:00.0: unsupported HTC service id: 1536
[   55.758428] kauditd_printk_skb: 16 callbacks suppressed
[   55.758431] audit: type=1130 audit(1585211778.175:77): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   60.161143] audit: type=1130 audit(1585211782.578:78): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=mariadb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   63.066538] audit: type=1131 audit(1585211785.482:79): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
[   65.189380] wlp3s0: authenticate with 18:f1:45:d0:1e:64
[   65.228782] wlp3s0: send auth to 18:f1:45:d0:1e:64 (try 1/3)
[   65.230576] wlp3s0: authenticated
[   65.233135] wlp3s0: associate with 18:f1:45:d0:1e:64 (try 1/3)
[   65.236747] wlp3s0: RX AssocResp from 18:f1:45:d0:1e:64 (capab=0x411 status=0 aid=3)
[   65.239492] wlp3s0: associated
[   65.391964] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
[   67.570890] audit: type=1130 audit(1585211789.988:80): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
[   67.914902] audit: type=1130 audit(1585211790.332:81): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   67.918505] audit: type=1130 audit(1585211790.335:82): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=clamav-freshclam comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   68.806672] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   68.813744] ata1.00: configured for UDMA/133
[   68.946411] audit: type=1130 audit(1585211791.362:83): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   69.538080] audit: type=1100 audit(1585211791.955:84): pid=1260 uid=0 auid=4294967295 ses=4294967295 subj==unconfined m
sg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res
=success'
[   69.538147] audit: type=1101 audit(1585211791.955:85): pid=1260 uid=0 auid=4294967295 ses=4294967295 subj==unconfined m
sg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=suc
cess'
[   69.618547] audit: type=1103 audit(1585211792.035:86): pid=1260 uid=0 auid=4294967295 ses=4294967295 subj==unconfined m
sg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=succes
s'
[   69.742576] audit: type=1130 audit(1585211792.158:87): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=user-runtime-dir@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   69.845112] audit: type=1101 audit(1585211792.262:88): pid=1263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined m
sg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/system
[   69.845628] audit: type=1006 audit(1585211792.262:89): pid=1263 uid=0 subj==unconfined old-auid=4294967295 auid=968 tty
=(none) old-ses=4294967295 ses=1 res=1
[   69.895924] audit: type=1105 audit(1585211792.312:90): pid=1263 uid=0 auid=968 ses=1 subj==unconfined msg='op=PAM:sessi
on_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="s
ddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   70.526481] audit: type=1130 audit(1585211792.942:91): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=user@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   70.536830] audit: type=1105 audit(1585211792.952:92): pid=1260 uid=0 auid=4294967295 ses=4294967295 subj==unconfined m
sg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? termin
al=:0 res=success'
[   78.014771] audit: type=1131 audit(1585211800.432:93): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
[   78.794331] audit: type=1130 audit(1585211801.212:94): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   79.637052] audit: type=1130 audit(1585211802.055:95): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   81.361632] audit: type=1131 audit(1585211803.778:96): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
[   84.062120] logitech-hidpp-device 0003:046D:4023.0003: HID++ 2.0 device connected.
[   88.938959] audit: type=1100 audit(1585211811.355:97): pid=1365 uid=0 auid=4294967295 ses=4294967295 subj==unconfined m
sg='op=PAM:authentication grantors=pam_tally2,pam_shells,pam_unix,pam_permit acct="jshand" exe="/usr/lib/sddm/sddm-helper"
[   89.042551] audit: type=1101 audit(1585211811.462:98): pid=1365 uid=0 auid=4294967295 ses=4294967295 subj==unconfined m
sg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="jshand" exe="/usr/lib/sddm/sddm-he
lper" hostname=? addr=? terminal=? res=success'
[   89.043765] audit: type=1103 audit(1585211811.462:99): pid=1365 uid=0 auid=4294967295 ses=4294967295 subj==unconfined m
sg='op=PAM:setcred grantors=pam_tally2,pam_shells,pam_unix,pam_permit acct="jshand" exe="/usr/lib/sddm/sddm-helper" hostna
[   89.043989] audit: type=1006 audit(1585211811.462:100): pid=1365 uid=0 subj==unconfined old-auid=4294967295 auid=1000 t
ty=(none) old-ses=4294967295 ses=2 res=1
[   89.083217] audit: type=1130 audit(1585211811.502:101): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg
='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   89.097837] audit: type=1101 audit(1585211811.515:102): pid=1369 uid=0 auid=4294967295 ses=4294967295 subj==unconfined
msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="jshand" exe="/usr/lib/systemd/sys
[   89.098228] audit: type=1006 audit(1585211811.515:103): pid=1369 uid=0 subj==unconfined old-auid=4294967295 auid=1000 t
ty=(none) old-ses=4294967295 ses=3 res=1
[   89.102222] audit: type=1105 audit(1585211811.518:104): pid=1369 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:ses
sion_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct=
"jshand" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   89.345646] audit: type=1130 audit(1585211811.762:105): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg
='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   89.357767] audit: type=1105 audit(1585211811.775:106): pid=1365 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:ses
sion_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_kwallet5 acct=
"jshand" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
[  100.209848] kauditd_printk_skb: 2 callbacks suppressed
[  100.209850] audit: type=1131 audit(1585211822.625:109): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg
='unit=user@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  100.227051] audit: type=1131 audit(1585211822.642:110): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg
='unit=user-runtime-dir@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  104.683636] audit: type=1130 audit(1585211827.098:111): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg
='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  109.717326] Bluetooth: RFCOMM TTY layer initialized
[  109.717335] Bluetooth: RFCOMM socket layer initialized
[  109.717344] Bluetooth: RFCOMM ver 1.11
[  112.189840] fuse: init (API version 7.31)
[  112.189919] *** VALIDATE fuse ***
[  112.189927] *** VALIDATE fuse ***
[  120.463769] audit: type=1130 audit(1585211842.882:112): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg
='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  120.480979] audit: type=1131 audit(1585211842.898:113): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg
[  155.074461] logitech-hidpp-device 0003:046D:4054.0004: HID++ 4.5 device connected.
[  519.216062] audit: type=1130 audit(1585212241.632:114): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg
[  922.797922] audit: type=1130 audit(1585212645.215:115): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg
='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  922.797927] audit: type=1131 audit(1585212645.215:116): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg
[  944.727519] audit: type=1100 audit(1585212667.145:117): pid=2655 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:
authentication grantors=pam_unix,pam_permit acct="jshand" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=su
ccess'
[  944.727527] audit: type=1101 audit(1585212667.145:118): pid=2655 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:
accounting grantors=pam_unix,pam_permit,pam_time acct="jshand" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 r
es=success'
[  944.727933] audit: type=1110 audit(1585212667.145:119): pid=2655 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:set
cred grantors=pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  944.732673] audit: type=1105 audit(1585212667.148:120): pid=2655 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:ses
sion_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 re
s=success'
vboxdrv module seems to have a strange error.
here is my currently installed application list:
a52dec 0.7.4-10
aalib 1.4rc5-13
accounts-qml-module 0.7-2
accountsservice 0.6.55-1
acl 2.2.53-2
acpi 1.7-2
acpid 2.0.32-1
adobe-source-code-pro-fonts 2.030ro+1.050it-5
adwaita-icon-theme 3.36.0-1
akonadi-contacts 19.12.3-1
alsa-firmware 1.2.1-2
alsa-lib 1.2.2-1
alsa-oss 1.1.8-3
alsa-plugins 1.2.2-1
alsa-topology-conf 1.2.2-2
alsa-ucm-conf 1.2.2-1
alsa-utils 1.2.2-1
amd-ucode 20200320.r1602.edf390c-1
android-tools 29.0.6-1
android-udev 20191103-1
aom 1.0.0.errata1+avif-1
apparmor 2.13.3-5
appstream 0.12.10-2
appstream-glib 0.7.17-1
appstream-qt 0.12.10-2
apr 1.7.0-2
apr-util 1.6.1-6
archlinux-appstream-data 20200315-1.1
archlinux-keyring 20200108-1
argon2 20190702-2
aribb24 1.0.3-2
ark 19.12.3-1
aspell 0.60.8-1
aspell-en 2018.04.16-1
at-spi2-atk 2.34.2-1
at-spi2-core 2.36.0-1
atk 2.34.1-1
attica 5.68.0-1
attr 2.4.48-2
audiofile 0.3.6-5
audit 2.8.5-6
autoconf 2.69-7
automake 1.16.1-2
avahi 0.8+15+ge8a3dd0-1
b43-fwcutter 019-3
baloo 5.68.0-1
baloo-widgets 19.12.3-1
bash 5.0.016-1
bashrc-manjaro 5.0.016-1
bc 1.07.1-3
binutils 2.34-2.1
bison 3.5.3-1
bluedevil 1:5.18.3-1
bluez 5.54-1
bluez-libs 5.54-1
bluez-qt 5.68.0-1
boost-libs 1.72.0-1
breath2-icon-themes 1.0.6-1
breath2-wallpaper 1.0.6-1
breeze 5.18.3-1
breeze-icons 5.68.0-1
brotli 1.0.7-3
btrfs-progs 5.4-1
bubblewrap 0.4.0-1
bzip2 1.0.8-3
ca-certificates 20181109-3
ca-certificates-mozilla 3.51-1
ca-certificates-utils 20181109-3
cairo 1.17.2+17+g52a7c79fd-2
cairo-perl 1.107-1
cantarell-fonts 1:0.201-1
cdparanoia 10.2-7
cdrdao 1.2.4-1
cdrtools 3.02a09-2
celt 0.11.3-3
chromaprint 1.4.3-2
chromium 80.0.3987.149-1
cifs-utils 6.10-1
ckbcomp 1.194-1
clamav 0.102.2-1
clamtk 6.02-2
clucene 2.3.3.4-10
colord 1.4.4+9+g1ce26da-1
colord-sane 1.4.4+9+g1ce26da-1
confuse 3.2.2-1
conntrack-tools 1.4.5-1
convertlit 1.8-8
coreutils 8.31-3
cpupower 5.5-1
cracklib 2.9.7-2
crda 4.14-3
cronie 1.5.5-1
cryptsetup 2.3.0-1.1
cups 2.3.1-1
cups-filters 1.27.3-1
cups-pdf 3.0.1-4
cups-pk-helper 0.2.6-3
curl 7.69.1-1
dav1d 0.5.2-1
db 5.3.28-5
dbus 1.12.16-5
dbus-glib 0.110-1
dconf 0.36.0-1
desktop-file-utils 0.24-2
device-mapper 2.02.186-5
dhclient 4.4.2-2
dhcpcd 8.1.6-1
diffutils 3.7-3
ding-libs 0.6.1-3
discount 2.2.6-1
djvulibre 3.5.27-5
dmidecode 3.2-1
dmraid 1.0.0.rc16.3-12
dnsmasq 2.80-4
dnssec-anchors 20190629-2
docbook-xml 4.5-8
docbook-xsl 1.79.2-5
dolphin 19.12.3-1
dolphin-plugins 19.12.3-1
dosfstools 4.1-3
double-conversion 3.1.5-1
dvd+rw-tools 7.1-8
e2fsprogs 1.45.6-1
ebook-tools 0.2.2-6
ecryptfs-utils 111-3
editorconfig-core-c 0.12.3-1
efibootmgr 16-2
efivar 37-3
elfutils 0.178-2
emovix 0.9.0-7
enchant 2.2.8-1
exfat-utils 1.3.0-1
exiv2 0.27.2-1
expat 2.2.9-3
f2fs-tools 1.13.0-1
faac 1.30-2
faad2 2.9.1-2
fakeroot 1.24-2
farstream 0.2.9-1
ffmpeg 1:4.2.2-3
ffmpegthumbs 19.12.3-1
fftw 3.3.8-2
file 5.38-3
filelight 19.12.3-1
filesystem 2019.10-4
findutils 4.7.0-2
firewalld 0.8.1-2
flac 1.3.3-1
flatpak 1.6.2-1
flex 2.6.4-3
fluidsynth 2.1.1-1
fontconfig 2:2.13.1+12+g5f5ec56-1
foomatic-db 3:20200220-1
foomatic-db-engine 4:20200206-1
foomatic-db-gutenprint-ppds 5.3.3-2
fpc 3.2.0-1
fpc-src 3.2.0-1
frameworkintegration 5.68.0-1
freeglut 3.2.1-1
freetype2 2.10.1-2
fribidi 1.0.9-1
fuse-common 3.9.1-1
fuse2 2.9.9-3
fuse3 3.9.1-1
fwupd 1.3.9-1
game-devices-udev 0.5-1
gawk 5.0.1-2
gc 8.0.4-3
gcab 1.4-1
gcc 9.3.0-1
gcc-libs 9.3.0-1
gcr 3.36-1
gd 2.3.0-1
gdb 9.1-2
gdb-common 9.1-2
gdbm 1.18.1-3
gdk-pixbuf2 2.40.0-2
geoclue 2.5.6-1
geocode-glib 3.26.2-1
gettext 0.20.1-3
ghostscript 9.52-1
giflib 5.2.1-1
git 2.26.0-1
glew 2.1.0-1
glib-networking 2.64.0-1
glib-perl 1.329-2
glib2 2.64.1-1
glibc 2.31-2
glu 9.0.1-1
gmp 6.2.0-1
gnome-icon-theme 3.12.0-5
gnome-icon-theme-symbolic 3.12.0-5
gnome-themes-extra 3.28-1
gnupg 2.2.20-1
gnustep-base 1.26.0-3
gnutls 3.6.12-1
gobject-introspection-runtime 1.64.0-1
gpgme 1.13.1-3
gpm 1.20.7.r27.g1fd1941-2
gptfdisk 1.0.5-1
grantlee 5.2.0-2
graphene 1.10.0-1
graphite 1:1.3.13-2
grep 3.4-1
groff 1.22.4-3
grub 2.04-10
grub-theme-manjaro 18.1-1
gsettings-desktop-schemas 3.36.0-1
gsfonts 20180524-2
gsm 1.0.18-1
gssdp 1.2.2-1
gssproxy 0.8.2-3
gst-libav 1.16.2-1
gst-plugins-bad 1.16.2-5
gst-plugins-bad-libs 1.16.2-5
gst-plugins-base 1.16.2-1
gst-plugins-base-libs 1.16.2-1
gst-plugins-good 1.16.2-3
gst-plugins-ugly 1.16.2-2
gstreamer 1.16.2-1
gtk-theme-breath 5.9.0-1
gtk-update-icon-cache 1:3.24.14+9+g429a6287e0-1
gtk2 2.24.32-2
gtk3 1:3.24.14+9+g429a6287e0-1
gtkspell 2.0.16-7
guile 2.2.6-1
guile2.0 2.0.14-3
gupnp 1.2.2-1
gupnp-igd 0.2.5+3+gedd78a6-2
gutenprint 5.3.3-2
gvfs 1.44.0-1
gvfs-afc 1.44.0-1
gvfs-gphoto2 1.44.0-1
gvfs-mtp 1.44.0-1
gvfs-nfs 1.44.0-1
gvfs-smb 1.44.0-1
gzip 1.10-3
handbrake 1.3.1-1
harfbuzz 2.6.4-2
harfbuzz-icu 2.6.4-2
hdparm 9.58-3
hicolor-icon-theme 0.17-1
highlight 3.55-1
hplip 1:3.20.3-2
hspell 1.4-2
http-parser 2.9.3-1
hunspell 1.7.0-2
hunspell-en_US 2019.10.06-1
hwids 20200306-1
hwinfo 21.68-2
hwloc 2.1.0-2
hyphen 2.8.8-2
hyphen-en 2.8.8-2
iana-etc 20200311-1
icu 65.1-3
ijs 0.35-2
illyria-wallpaper 1.4-1
imagemagick 7.0.10.2-2
imagewriter 1.10.1420800585.134a9b3-4
imlib2 1.6.1-1
inetutils 1.9.4-8
iniparser 4.1-1
inxi 3.0.37-1
iproute2 5.5.0-1
iptables 1:1.8.4-1.1
iputils 20190709-2
iso-codes 4.4-1
iw 5.4-1
jack 0.125.0-8
jansson 2.12-1
jasper 2.0.16-1
jbig2dec 0.18-1
jemalloc 1:5.2.1-1
jfsutils 1.1.15-7
js60 60.9.0-2
json-c 0.13.1-3
json-glib 1.4.4-1
k3b 1:19.12.3-1
kaccounts-integration 19.12.3-1
kaccounts-providers 19.12.3-1
kactivities 5.68.0-1
kactivities-stats 5.68.0-1
kactivitymanagerd 5.18.3-1
kamera 19.12.3-1
karchive 5.68.0-1
kate 19.12.3-1
kauth 5.68.0-1
kbd 2.2.0-5
kbookmarks 5.68.0-1
kcalc 19.12.3-1
kcmutils 5.68.0-1
kcodecs 5.68.0-1
kcompletion 5.68.0-1
kconfig 5.68.0-1
kconfigwidgets 5.68.0-1
kcontacts 1:5.68.0-1
kcoreaddons 5.68.0-1
kcrash 5.68.0-1
kdbusaddons 5.68.0-1
kde-cli-tools 5.18.3-1
kde-gtk-config 5.18.3-1
kde-servicemenus-rootactions 2.9.1-1
kdeclarative 5.68.0-1
kdecoration 5.18.3-1
kded 5.68.0-1
kdegraphics-thumbnailers 19.12.3-1
kdelibs4support 5.68.0-1
kdenetwork-filesharing 19.12.3-1
kdeplasma-addons 5.18.3-1
kdesu 5.68.0-1
kdialog 19.12.3-1
kdnssd 5.68.0-1
kdoctools 5.68.0-1
keditbookmarks 19.12.3-1
kemoticons 5.68.0-1
kernel-alive 0.5-1
keyutils 1.6.1-3
kfilemetadata 5.68.0-1
kfind 19.12.3-1
kgamma5 5.18.3-1
kglobalaccel 5.68.0-1
kgpg 19.12.3-1
kguiaddons 5.68.0-1
khelpcenter 19.12.3-1
kholidays 1:5.68.0-1
khotkeys 5.18.3-1
khtml 5.68.0-1
ki18n 5.68.0-1
kiconthemes 5.68.0-1
kidletime 5.68.0-1
kimageformats 5.68.0-1
kinfocenter 5.18.3-1
kinit 5.68.0-1
kio 5.68.0-1
kio-extras 19.12.3-1
kirigami2 5.68.0-1
kitemmodels 5.68.0-1
kitemviews 5.68.0-1
kjobwidgets 5.68.0-1
kjs 5.68.0-1
kmenuedit 5.18.3-1
kmime 19.12.3-1
kmod 27-1
knetattach 5.18.3-1
knewstuff 5.68.0-1
knotifications 5.68.0-1
knotifyconfig 5.68.0-1
konsole 19.12.3-1
konversation 1.7.5-2
kpackage 5.68.0-1
kparts 5.68.0-1
kpeople 5.68.0-1
kpmcore 4.1.0-1.1
kpty 5.68.0-1
kquickcharts 5.68.0-1
krb5 1.17.1-1
krunner 5.68.0-1
kscreen 5.18.3-1
kscreenlocker 5.18.3-1
kservice 5.68.0-1
ksshaskpass 5.18.3-1
ksysguard 5.18.3-1
ksystemlog 19.12.3-1
ktexteditor 5.68.0-1
ktextwidgets 5.68.0-1
kunitconversion 5.68.0-1
kuserfeedback 1.0.0-1
kwallet 5.68.0-1
kwallet-pam 5.18.3-1
kwalletmanager 19.12.3-1
kwayland 5.68.0-1
kwayland-integration 5.18.3-1
kwidgetsaddons 5.68.0-1
kwin 5.18.3-1
kwindowsystem 5.68.0-1
kwrited 5.18.3-1
kxmlgui 5.68.0-1
l-smash 2.14.5-1
ladspa 1.15-1
lame 3.100-2
lazarus 2.0.7-1
lazarus-qt5 2.0.7-1
lcms2 2.9-2
ldb 1:1.5.6-2
ldns 1.7.1-2
less 551-3
lib32-alsa-lib 1.2.2-1
lib32-alsa-oss 1.1.8-2
lib32-alsa-plugins 1.2.2-1
lib32-atk 2.34.1-1
lib32-attr 2.4.48-1
lib32-bzip2 1.0.8-2
lib32-cairo 1.17.2+17+g52a7c79fd-2
lib32-db 5.3.28-4
lib32-dbus 1.12.16-2
lib32-e2fsprogs 1.45.6-1
lib32-expat 2.2.9-1
lib32-flac 1.3.3-1
lib32-flex 2.6.4-2
lib32-fluidsynth 2.1.1-1
lib32-fontconfig 2:2.13.1+12+g5f5ec56-1
lib32-freetype2 2.10.1-2
lib32-fribidi 1.0.9-1
lib32-gcc-libs 9.3.0-1
lib32-gdk-pixbuf2 2.40.0-1
lib32-glew 2.1.0-1
lib32-glib2 2.64.1-1
lib32-glibc 2.31-2
lib32-glu 9.0.1-1
lib32-gmp 6.2.0-1
lib32-gnutls 3.6.12-1
lib32-gstreamer 1.16.2-1
lib32-gtk2 2.24.32-1
lib32-harfbuzz 2.6.4-2
lib32-icu 65.1-3
lib32-jack 0.125.0-2
lib32-keyutils 1.6-1
lib32-krb5 1.17.1-1
lib32-libasyncns 0.8+3+g68cd5af-2
lib32-libcanberra 0.30+2+gc0620e4-1
lib32-libcanberra-gstreamer 0.30+2+gc0620e4-1
lib32-libcanberra-pulse 0.30+2+gc0620e4-1
lib32-libcap 2.33-1
lib32-libcups 2.3.1-1
lib32-libdatrie 0.2.12-1
lib32-libdbusmenu-glib 16.04.0-4
lib32-libdbusmenu-gtk2 16.04.0-4
lib32-libdrm 2.4.100-1
lib32-libelf 0.177-1
lib32-libffi 3.2.1-2
lib32-libgcrypt 1.8.5-1
lib32-libglvnd 1.3.1-1
lib32-libgpg-error 1.37-1
lib32-libice 1.0.10-1
lib32-libidn 1.35-1
lib32-libindicator-gtk2 12.10.1-8
lib32-libinstpatch 1.1.3-1
lib32-libjpeg-turbo 2.0.4-1
lib32-libldap 2.4.49-1
lib32-libltdl 2.4.6+42+gb88cebd5-1
lib32-libogg 1.3.4-1
lib32-libpciaccess 0.16-1
lib32-libpng 1.6.37-2
lib32-libpulse 13.0-1
lib32-libsamplerate 0.1.9-2
lib32-libsm 1.2.3-1
lib32-libsndfile 1.0.28-3
lib32-libtasn1 4.16.0-1
lib32-libthai 0.1.28-1
lib32-libtiff 4.1.0-1
lib32-libunwind 1.3.1-1
lib32-libva 2.6.1-1
lib32-libva-intel-driver 2.4.0-1
lib32-libva-mesa-driver 19.3.5-1
lib32-libva-vdpau-driver 0.7.4-6
lib32-libvdpau 1.3-1
lib32-libvorbis 1.3.6-1.1
lib32-libx11 1.6.9-1
lib32-libxau 1.0.9-1
lib32-libxcb 1.14-1
lib32-libxcomposite 0.4.5-1
lib32-libxcursor 1.2.0-1
lib32-libxdamage 1.1.5-1
lib32-libxdmcp 1.1.3-1
lib32-libxext 1.3.4-1
lib32-libxfixes 5.0.3-2
lib32-libxft 2.3.3-1
lib32-libxi 1.7.10-2
lib32-libxinerama 1.1.4-1
lib32-libxml2 2.9.10-1
lib32-libxmu 1.1.3-1
lib32-libxrandr 1.5.2-1
lib32-libxrender 0.9.10-2
lib32-libxshmfence 1.3-1
lib32-libxss 1.2.3-1
lib32-libxt 1.2.0-1
lib32-libxtst 1.2.3-2
lib32-libxxf86vm 1.1.4-2
lib32-llvm-libs 9.0.1-1
lib32-lm_sensors 3.6.0-1
lib32-lz4 1.9.2-1
lib32-mesa 19.3.5-1
lib32-mesa-demos 8.4.0-1
lib32-mesa-vdpau 19.3.5-1
lib32-ncurses 6.2-1
lib32-nettle 3.5.1-1
lib32-nspr 4.25-1
lib32-nss 3.51-1
lib32-openal 1.20.1-1
lib32-openssl 1:1.1.1.e-1
lib32-p11-kit 0.23.20-3
lib32-pango 1:1.44.7+11+g73b46b04-1
lib32-pcre 8.44-1
lib32-pixman 0.38.4-1
lib32-portaudio 190600_20161030-2
lib32-readline 8.0.0-1
lib32-sdl2 2.0.12-1
lib32-sqlite 3.31.1-1
lib32-systemd 244.3-1
lib32-tdb 1.3.18-1
lib32-util-linux 2.35.1-1
lib32-vulkan-intel 19.3.5-1
lib32-vulkan-radeon 19.3.5-1
lib32-wayland 1.18.0-1
lib32-xz 5.2.4-1
lib32-zlib 1.2.11-2
lib32-zstd 1.4.4-2
libabw 0.1.3-1
libaccounts-glib 1.24-3
libaccounts-qt 1.16-1
libaio 0.3.112-2
libakonadi 19.12.3-1
libao 1.2.2-2
libappindicator-gtk3 12.10.0-14
libarchive 3.4.2-1
libass 0.14.0-1
libassuan 2.5.3-2
libatasmart 0.19-4
libatomic_ops 7.6.10-1
libavc1394 0.5.4-3
libblockdev 2.23-3
libbluray 1.2.0-1
libbs2b 3.1.0-6
libbsd 0.10.0-1
libburn 1.5.2-1
libbytesize 2.2-1
libcaca 0.99.beta19-2
libcanberra 0.30+2+gc0620e4-2
libcanberra-gstreamer 0.30+2+gc0620e4-2
libcanberra-pulse 0.30+2+gc0620e4-2
libcap 2.33-1
libcap-ng 0.7.10-1
libcddb 1.3.2-5
libcdio 2.1.0-1
libcdio-paranoia 10.2+2.0.1-1
libcdr 0.1.6-1
libcmis 0.5.2-4
libcroco 0.6.13-1
libcups 2.3.1-1
libdaemon 0.14-4
libdatrie 0.2.12-1
libdbusmenu-gtk3 16.04.0-4
libdbusmenu-qt5 0.9.3+16.04.20160218-4
libdc1394 2.2.6-1
libdca 0.0.6-1
libde265 1.0.5-1
libdmtx 0.7.5-1
libdrm 2.4.100-1
libdv 1.0.0-7
libdvbpsi 1:1.3.3-1
libdvdcss 1.4.2-1
libdvdnav 6.1.0-1
libdvdread 6.1.0-1
libe-book 0.1.3-6
libebml 1.3.10-1
libedit 20191231_3.1-1
libelf 0.178-2
libepoxy 1.5.4-1
libepubgen 0.1.1-1
libetonyek 0.1.9-2
libevdev 1.9.0-1
libevent 2.1.11-5
libexif 0.6.21-3
libexttextcat 3.4.5-1
libfdk-aac 2.0.1-1
libffi 3.2.1-4
libfontenc 1.1.4-1
libfreehand 0.1.2-2
libftdi 1.4-4
libgadu 1.12.2-10
libgcrypt 1.8.5-2
libgee 0.20.3-2
libgit2 1:0.99.0-2
libglvnd 1.3.1-1
libgme 0.6.2-1
libgpg-error 1.37-1
libgphoto2 2.5.24-1
libgudev 233-1
libgusb 0.3.4-1
libibus 1.5.22-1
libical 3.0.8-1
libice 1.0.10-2
libid3tag 0.15.1b-9
libidn 1.35-2
libidn2 2.3.0-1
libiec61883 1.2.0-5
libieee1284 0.2.11-8
libimagequant 2.12.6-1
libimobiledevice 1.2.0+87+g92c5462-6
libindicator-gtk2 12.10.1-9
libindicator-gtk3 12.10.1-9
libinput 1.15.4-1
libixion 0.15.0-1
libkate 0.4.1-7
libkcddb 19.12.3-1
libkdcraw 19.12.3-1
libkexiv2 19.12.3-1
libkipi 19.12.3-1
libksba 1.3.5-2
libkscreen 5.18.3-1
libksysguard 5.18.3-1
libktorrent 2.1.1-1
liblangtag 0.6.3-1
libldap 2.4.49-1
liblouis 3.13.0-1
liblqr 0.4.2-2
liblrdf 0.6.1-3
libmad 0.15.1b-8
libmatroska 1.5.2-1
libmbim 1.22.0-1
libmfx 19.4.0-4
libmicrohttpd 0.9.70-1
libmikmod 3.3.11.1-4
libmm-glib 1.12.8-1
libmms 0.6.4-2
libmng 2.0.3-2
libmnl 1.0.4-3
libmodplug 0.8.9.0-2
libmpc 1.1.0-2
libmpcdec 1:0.1+r475-2
libmpdclient 2.18-1
libmpeg2 0.5.1-6
libmspack 1:0.10.1alpha-2
libmspub 0.1.4-6
libmtp 1.1.17-1
libmusicbrainz5 5.1.0-3
libmwaw 0.3.16-1
libndp 1.7-1
libnetfilter_conntrack 1.0.7-1
libnetfilter_cthelper 1.0.0-3
libnetfilter_cttimeout 1.0.0-5
libnetfilter_queue 1.0.3-1
libnewt 0.52.21-3
libnfnetlink 1.0.1-3
libnfs 4.0.0-3
libnftnl 1.1.5-1
libnghttp2 1.39.2-2
libnice 0.1.16-1
libnl 3.5.0-2
libnm 1.22.10-1
libnotify 0.7.9-1
libnsl 1.2.0-2
libnumbertext 1.0.5-1
libodfgen 0.1.7-1
libofa 0.9.3-8
libogg 1.3.4-1
libomxil-bellagio 0.9.3-2
liborcus 0.15.3-1
libp11 0.4.10-1
libp11-kit 0.23.20-3
libpagemaker 0.0.4-2
libpaper 1.1.28-1
libpcap 1.9.1-2
libpciaccess 0.16-1
libpgm 5.2.122-5
libpipeline 1.5.2-1
libplist 2.1.0-2
libpng 1.6.37-1
libproxy 0.4.15+33+g454a499-1
libpsl 0.21.0-2
libpulse 13.0-3
libpurple 2.13.0-9
libpwquality 1.4.2-2
libqalculate 3.8.0-1
libqmi 1.24.6-1
libqxp 0.0.2-3
libraqm 0.7.0-1
libraw 0.19.5-2
libraw1394 2.1.2-2
libreoffice-fresh 6.4.2-1
librevenge 0.0.4-2
librsvg 2:2.48.0-1
libsamplerate 0.1.9-3
libsasl 2.1.27-2
libseccomp 2.4.2-1
libsecret 0.20.2-1
libshout 1:2.4.3-2
libsidplay 1.36.59-9
libsm 1.2.3-1
libsmbios 2.4.3-1
libsndfile 1.0.28-3
libsodium 1.0.18-1
libsoup 2.70.0-1
libsoxr 0.1.3-1
libspectre 0.2.8-2
libsrtp 1:2.3.0-1
libssh 0.9.3-1
libssh2 1.9.0-2
libstaroffice 0.0.6-1
libstemmer 0+713-1
libtar 1.2.20-4
libtasn1 4.16.0-1
libteam 1.30-1
libthai 0.1.28-1
libtheora 1.1.1-4
libtiff 4.1.0-1
libtiger 0.3.4-5
libtirpc 1.2.5-1
libtommath 1.2.0-1
libtool 2.4.6+42+gb88cebd5-11
libtorrent-rasterbar 1:1.2.4-1
libunistring 0.9.10-2
libunwind 1.3.1-1
libupnp 1.6.25-1
libusb 1.0.23-2
libusb-compat 0.1.7-1
libusbmuxd 2.0.1-1
libutempter 1.1.6-3
libutf8proc 2.4.0-1
libutil-linux 2.35.1-1.1
libva 2.6.1-1
libva-vdpau-driver 0.7.4-4
libvdpau 1.3-1
libvisio 0.1.7-2
libvisual 0.4.0-7
libvoikko 4.3-1
libvorbis 1.3.6-1
libvpx 1.8.2-1
libwacom 1.2-1
libwbclient 4.10.10-2
libwebp 1.1.0-1
libwpd 0.10.3-1
libwpe 1.6.0-1
libwpg 0.3.3-1
libwps 0.4.10-1
libx11 1.6.9-6
libx86emu 3.1-1
libxau 1.0.9-2
libxaw 1.0.13-2
libxcb 1.14-1
libxcomposite 0.4.5-2
libxcursor 1.2.0-1
libxdamage 1.1.5-2
libxdmcp 1.1.3-2
libxext 1.3.4-2
libxfixes 5.0.3-3
libxfont2 2.0.4-2
libxft 2.3.3-1
libxi 1.7.10-2
libxinerama 1.1.4-2
libxkbcommon 0.10.0-1
libxkbcommon-x11 0.10.0-1
libxkbfile 1.1.0-1
libxml2 2.9.10-1
libxmlb 0.1.14-1
libxmu 1.1.3-1
libxpm 3.5.13-1
libxrandr 1.5.2-2
libxrender 0.9.10-3
libxres 1.2.0-1
libxshmfence 1.3-1
libxslt 1.1.34-2
libxss 1.2.3-2
libxt 1.2.0-1
libxtst 1.2.3-3
libxv 1.0.11-3
libxvmc 1.0.12-2
libxxf86vm 1.1.4-3
libyaml 0.2.2-1
libzip 1.5.2-2
libzmf 0.0.2-7
licenses 20191011-2
lilv 0.24.6-2
linux-api-headers 5.4.17-1
linux-firmware 20200320.r1602.edf390c-1
linux54 5.4.28-1
linux54-virtualbox-host-modules 6.1.4-8
lirc 1:0.10.1-4
llvm-libs 9.0.1-2
lm_sensors 3.6.0-1
lmdb 0.9.24-1
logrotate 3.16.0-1
lpsolve 5.5.2.5-3
lsb-release 1.4-13
lsof 4.93.2-1
lua 5.3.5-3
lvm2 2.02.186-5
lz4 1:1.9.2-2
lzo 2.10-3
m4 1.4.18-3
mailcap 2.1.48+14+g5811758-1
make 4.3-1
man-db 2.9.1-1
man-pages 5.05-2
manjaro-alsa 20200126-1
manjaro-application-utility 1.3.1-1
manjaro-base-skel 20171029-3
manjaro-browser-settings 20200124-1
manjaro-documentation-en 20181009-1
manjaro-firmware 20160419-1
manjaro-hello 0.6.5-5
manjaro-hotfixes 2018.08-6
manjaro-icons 20191015-1
manjaro-kde-settings-19.0 20200201-1
manjaro-keyring 20190608-1
manjaro-printer 20200215-2
manjaro-pulse 20200126-1
manjaro-release 19.0.2-1
manjaro-settings-manager 0.5.6-6
manjaro-settings-manager-kcm 0.5.6-6
manjaro-settings-manager-knotifier 0.5.6-6
manjaro-system 20200325-1
manjaro-wallpapers-18.0 1.4-3
mariadb 10.4.12-1
mariadb-clients 10.4.12-1
mariadb-libs 10.4.12-1
md4c 0.4.3-1
mdadm 4.1-2
media-player-info 24-1
megasync 4.3.1-1
memtest86+ 5.01-3
mesa 19.3.5-1
mesa-demos 8.4.0-2
mesa-vdpau 19.3.5-1
mhwd 0.6.4-2
mhwd-amdgpu 19.1.0-1
mhwd-ati 19.1.0-1
mhwd-db 0.6.4-9
mhwd-nvidia-340xx 340.108-1
mhwd-nvidia-390xx 390.132-1
mhwd-nvidia-418xx 418.113-1
mhwd-nvidia-430xx 430.64-1.0
mhwd-nvidia-435xx 435.21-1.0
mhwd-nvidia-440xx 440.64-1
milou 5.18.3-1
minizip 1:1.2.11-4
mjpegtools 2.1.0-4
mkinitcpio 27-3
mkinitcpio-busybox 1.31.1-1
mkinitcpio-openswap 0.1.0-3
mobile-broadband-provider-info 20190618-1
modemmanager 1.12.8-1
modemmanager-qt 5.68.0-1
mozilla-common 1.4-5
mpd 0.21.21-1
mpfr 4.0.2-2
mpg123 1.25.13-1
mtdev 1.1.6-1
mtpfs 1.1-3
musescore 3.4.2-1
nano 4.8-1
ncurses 6.2-1
ndctl 67-1
neon 0.30.2-3
net-snmp 5.8-4
nettle 3.5.1-2
networkmanager 1.22.10-1
networkmanager-openvpn 1.8.12-1
networkmanager-pptp 1.2.9dev+10+gb41b0d0-1
networkmanager-qt 5.68.0-1
networkmanager-vpnc 1.2.7dev+20+gdca3aea-1
nfs-utils 2.4.3-2
nfsidmap 2.4.3-2
nftables 1:0.9.3-1
noto-fonts 20190926-4
noto-fonts-cjk 20190409-1
noto-fonts-compat 20151217-1
noto-fonts-emoji 20191016-4
npth 1.6-2
nspr 4.25-1
nss 3.51-1
nss-mdns 0.14.1-2
ntfs-3g 2017.3.23-4
ntp 4.2.8.p14-1
numactl 2.0.13-2
numlockx 1.2-5
okular 19.12.3-3
openal 1.20.1-2
opencore-amr 0.1.5-3
openexr 2.4.1-2
openjpeg2 2.3.1-1
openmpi 4.0.3-1
openresolv 3.10.0-1
openssh 8.2p1-3
openssl 1.1.1.e-1
openvpn 2.4.8-4
opus 1.3.1-1
orc 0.4.31-1
os-prober 1.77-1
ostree 2019.6-1
oxygen 5.18.3-1
oxygen-icons 1:5.68.0-1
p11-kit 0.23.20-3
p7zip 16.02-5
pacman 5.2.1-4
pacman-mirrors 4.16.4-1
pam 1.3.1-2
pamac-cli 9.4.0-3
pamac-common 9.4.0-3
pamac-gtk 9.4.0-3
pamac-snap-plugin 9.4.0-3
pamac-tray-appindicator 9.4.0-3
pambase 20190105.1-2
parted 3.3-1
partitionmanager 4.1.0-1
patch 2.7.6-8
patchutils 0.3.4-3
pciutils 3.6.4-1
pcre 8.44-1
pcre2 10.34-3
perl 5.30.1-1
perl-alien-build 2.17-1
perl-alien-libxml2 0.15-1
perl-cairo-gobject 1.004-9
perl-capture-tiny 0.48-2
perl-clone 0.43-1
perl-dbi 1.643-1
perl-encode-locale 1.05-5
perl-error 0.17029-1
perl-ffi-checklib 0.26-1
perl-file-basedir 0.08-3
perl-file-chdir 0.1011-3
perl-file-desktopentry 0.22-5
perl-file-listing 6.04-6
perl-file-mimeinfo 0.29-2
perl-file-which 1.23-2
perl-glib-object-introspection 0.047-3
perl-gtk3 0.035-1
perl-html-parser 3.72-8
perl-html-tagset 3.20-8
perl-http-cookies 6.08-1
perl-http-daemon 6.06-1
perl-http-date 6.05-1
perl-http-message 6.22-1
perl-http-negotiate 6.01-6
perl-io-html 1.001-5
perl-io-socket-ssl 2.066-1
perl-ipc-system-simple 1.28-1
perl-json 2.97001-1
perl-libwww 6.43-1
perl-locale-gettext 1.07-8
perl-lwp-mediatypes 6.02-6
perl-lwp-protocol-https 6.07-3
perl-mailtools 2.21-2
perl-net-http 6.19-2
perl-net-ssleay 1.88-1
perl-parse-yapp 1.21-2
perl-path-tiny 0.112-1
perl-text-csv 1.97-2
perl-timedate 2.32-1
perl-try-tiny 0.30-3
perl-uri 1.76-2
perl-www-robotrules 6.02-6
perl-xml-libxml 2.0204-1
perl-xml-namespacesupport 1.12-3
perl-xml-sax 1.02-1
perl-xml-sax-base 1.09-3
phonon-qt5 4.11.1-1
phonon-qt5-gstreamer 4.10.0-1
pidgin 2.13.0-9
pinentry 1.1.0-5
pipewire 0.3.1-1
pixman 0.38.4-1
pkcs11-helper 1.26.0-1
pkgconf 1.6.3-3
plasma-desktop 5.18.3-1
plasma-framework 5.68.0-1
plasma-integration 5.18.3-1
plasma-nm 5.18.3-1
plasma-pa 5.18.3-1
plasma-simplemenu 1.0.12-1
plasma-workspace 5.18.3-1
plasma-workspace-wallpapers 5.18.3-1
plasma5-themes-breath2 1.0.6-1
polkit 0.116-4.1
polkit-kde-agent 5.18.3-1
polkit-qt5 0.113.0-1
poppler 0.86.1-1
poppler-data 0.4.9-1
poppler-qt5 0.86.1-1
popt 1.16-12
portaudio 1:19.6.0-6
portmidi 217-9
powerdevil 5.18.3-1
powertop 2.11-1
ppp 2.4.7-7
pptpclient 1.10.0-2
print-manager 19.12.3-1
prison 5.68.0-1
procps-ng 3.3.16-1
protobuf 3.11.4-1
protobuf-c 1.3.3-1
psmisc 23.3-2
pulseaudio 13.0-3
pulseaudio-alsa 2-5
pulseaudio-bluetooth 13.0-3
pulseaudio-ctl 1.67-1
pulseaudio-equalizer 13.0-3
pulseaudio-jack 13.0-3
pulseaudio-lirc 13.0-3
pulseaudio-zeroconf 13.0-3
purple-facebook 0.9.6-1
purpose 5.68.0-1
pygobject-devel 3.36.0-1
python 3.8.2-1
python-appdirs 1.4.3-5
python-asn1crypto 1.3.0-1
python-attrs 19.3.0-4
python-automat 20.2.0-1
python-cachecontrol 0.12.6-1
python-cairo 1.19.1-1
python-cffi 1.14.0-1
python-chardet 3.0.4-4
python-click 7.1.1-1
python-colorama 0.4.3-1
python-constantly 15.1.0-5
python-contextlib2 0.6.0.post1-1
python-cryptography 2.8-2
python-dbus 1.2.16-1
python-dbus-common 1.2.16-1
python-decorator 4.4.2-1
python-distlib 0.3.0-1
python-distro 1.4.0-3
python-docopt 0.6.2-7
python-gobject 3.36.0-1
python-html5lib 1.0.1-7
python-hyperlink 19.0.0-3
python-idna 2.9-1
python-incremental 17.5.0-4
python-keyutils 0.6-4
python-msgpack 0.6.2-3
python-npyscreen 4.10.5-4
python-ordered-set 3.1.1-1
python-packaging 20.3-1
python-pep517 0.8.1-1
python-pillow 6.2.1-1
python-pip 20.0.2-1
python-ply 3.11-4
python-progress 1.5-3
python-pyasn1 0.4.8-1
python-pyasn1-modules 0.2.8-1
python-pycparser 2.20-1
python-pycups 1.9.74-3
python-pycurl 7.43.0.5-1
python-pyhamcrest 1.9.0-5
python-pyparsing 2.4.6-1
python-pyqt5 5.14.1-2
python-pyqt5-sip 12.7.1-1
python-pysmbc 1.0.18-1
python-pytoml 0.1.21-3
python-reportlab 3.5.34-1
python-requests 2.23.0-1
python-retrying 1.3.3-6
python-setuptools 1:46.1.1-1
python-sip 4.19.21-1
python-six 1.14.0-1
python-slip 0.6.5-4
python-toml 0.10.0-3
python-twisted 19.10.0-3
python-urllib3 1.25.8-2
python-webencodings 0.5.1-4
python-yaml 5.3-1
python-zope-interface 4.7.2-1
qbittorrent 4.2.1-1
qca 2.3.0-1
qpdf 9.1.1-1
qqc2-desktop-style 5.68.0-1
qrencode 4.0.2-1
qt5-base 5.14.1-3
qt5-declarative 5.14.1-1
qt5-graphicaleffects 5.14.1-1
qt5-imageformats 5.14.1-1
qt5-location 5.14.1-1
qt5-multimedia 5.14.1-1
qt5-quickcontrols 5.14.1-1
qt5-quickcontrols2 5.14.1-1
qt5-script 5.14.1-1
qt5-sensors 5.14.1-1
qt5-speech 5.14.1-1
qt5-svg 5.14.1-1
qt5-tools 5.14.1-1
qt5-translations 5.14.1-1
qt5-virtualkeyboard 5.14.1-1
qt5-wayland 5.14.1-1
qt5-webchannel 5.14.1-1
qt5-webengine 5.14.1-2
qt5-webkit 5.212.0alpha4-1
qt5-websockets 5.14.1-1
qt5-x11extras 5.14.1-1
qt5-xmlpatterns 5.14.1-1
qt5pas 2.6.r62764-1
raptor 2.0.15-12
rasqal 1:0.9.33-2
re2 1:20200303-1
readline 8.0.004-1
redland 1:1.0.17-7
reiserfsprogs 3.6.27-3
rest 0.8.1-1
rpcbind 1.2.5-3
rsync 3.1.3-3
rtkit 0.12-1
rtmpdump 1:2.4.r96.fa8646d-5
ruby 2.7.0-1
rubygems 3.1.2-4
run-parts 4.8.6.1-2
s-nail 14.9.17-1
samba 4.10.10-2
sane 1.0.29-1
sbc 1.4-1
screenfetch 3.9.1-1
sddm 0.18.1-2
sddm-breath2-theme 1.0.6-1
sddm-kcm 5.18.3-1
sdl 1.2.15-13
sdl2 2.0.12-1
sed 4.8-1
serd 0.30.2-1
serf 1.3.9-3
shadow 4.8.1-1
shared-mime-info 1.15-2
signon-kwallet-extension 19.12.3-1
signon-plugin-oauth2 0.24-2
signon-ui 0.17+20171022-2
signond 8.60-1
slang 2.3.2-1
smartmontools 7.1-1
smbclient 4.10.10-2
snapd 2.44-1
snapd-glib 1.54-1
snappy 1.1.8-1
socat 1.7.3.4-1
solid 5.68.0-1
sonnet 5.68.0-1
sord 0.16.4-1
sound-theme-freedesktop 0.8-3
soundtouch 2.1.2-1
source-highlight 3.1.9-2
spandsp 0.0.6-2
spectacle 19.12.3-1
spectre-meltdown-checker 0.43-1
speex 1.2.0-2
speexdsp 1.2.0-1
splix 2.0.0-14
sqlite 3.31.1-1
squashfs-tools 4.4-1
sratom 0.6.4-1
srt 1.4.1-1
sshfs 3.7.0-1
startup-notification 0.12-6
steam-manjaro 1.0.0.61-7
subversion 1.13.0-2
sudo 1.8.31.p1-1
sweeper 19.12.3-1
syntax-highlighting 5.68.0-1
sysfsutils 2.1.0-11
system-config-printer 1.5.12+33+g23b454ef-1
systemd 244.3-2
systemd-fsck-silent 239-1
systemd-kcm 1.2.1-5
systemd-libs 244.3-2
systemd-sysvcompat 244.3-2
systemsettings 5.18.3-1
taglib 1.11.1-3
talloc 2.3.1-1
tar 1.32-3
tcl 8.6.10-1
tdb 1.3.18-4
terminus-font 4.48-1
tevent 1:0.9.39-4
texinfo 6.7-2
thin-provisioning-tools 0.8.5-3
threadweaver 5.68.0-1
thunderbird 68.6.0-1
timeshift 20.03.r0.gcecd294-1
tlp 1.3.1-2
tpm2-pkcs11 1.1.0-1
tpm2-tools 4.1.1-1
tpm2-tss 2.4.0-1
transcode 1.1.7-32
tslib 1.21-1
ttf-bitstream-vera 1.10-12
ttf-droid 20121017-7.2
ttf-hack 3.003-1
ttf-inconsolata 1:3.000-1
ttf-indic-otf 0.2-9
ttf-liberation 2.1.0-1
twolame 0.4.0-2
tzdata 2019c-3
udiskie 2.1.0-1
udisks2 2.8.4-2
unarchiver 1.10.1-8
upower 0.99.11-1
usb_modeswitch 2.6.0-1
usbmuxd 1.1.0+69+g8a69f1a-1
usbutils 012-2
user-manager 5.18.3-1
v4l-utils 1.18.0-1
v86d 0.1.10-5.1
vcdimager 2.0.1-2
vde2 2.3.2-13
vi 1:070224-4
vid.stab 1.1-2
virtualbox 6.1.4-3
vlc 3.0.8-10
volume_key 0.3.12-2
vpnc 1:0.5.3.r462.r78-1
vte-common 0.60.0-1
vte3 0.60.0-1
vulkan-icd-loader 1.2.135-1
wallpapers-2018 1.2-1
wallpapers-juhraya 1.1-2
wavpack 5.2.0-1
wayland 1.18.0-1
wayland-protocols 1.20-1
webkit2gtk 2.28.0-3
webrtc-audio-processing 0.3.1-1
wget 1.20.3-2
which 2.21-5
wildmidi 0.4.3-1
wireless-regdb 2019.06.03-2
woff2 1.0.2-1
wpa_supplicant 2:2.9-7
wpebackend-fdo 1.6.0-1
x264 3:0.159.r2991.1771b55-1
x265 3.2.1-1
xapian-core 1:1.4.15-1
xcb-proto 1.14-1
xcb-util 0.4.0-2
xcb-util-cursor 0.1.3-2
xcb-util-image 0.4.0-2
xcb-util-keysyms 0.4.0-2
xcb-util-renderutil 0.3.9-2
xcb-util-wm 0.4.1-2
xdg-dbus-proxy 0.1.2-1
xdg-desktop-portal 1.6.0-2
xdg-desktop-portal-kde 5.18.3-1.3
xdg-su 1.2.3-1
xdg-user-dirs 0.17-2
xdg-utils 1.1.3+19+g9816ebb-1
xf86-input-elographics 1.4.2-1
xf86-input-evdev 2.10.6-1
xf86-input-libinput 0.29.0-2
xf86-input-void 1.4.1-4
xf86-video-amdgpu 19.1.0-1
xf86-video-ati 1:19.1.0-1
xf86-video-intel 1:2.99.917+899+gf66d3954-1
xf86-video-nouveau 1.0.16-1
xfsprogs 5.4.0-1
xkeyboard-config 2.29-1
xmlsec 1.2.29-1
xorg-bdftopcf 1.1-1
xorg-font-util 1.3.2-1
xorg-font-utils 7.6-5
xorg-fonts-alias 1.0.3-2
xorg-fonts-encodings 1.0.5-1
xorg-mkfontscale 1.2.1-2
xorg-server 1.20.7-1
xorg-server-common 1.20.7-1
xorg-setxkbmap 1.3.2-1
xorg-twm 1.0.10-1
xorg-xauth 1.1-1
xorg-xdpyinfo 1.3.2-3
xorg-xinit 1.4.1-1
xorg-xkbcomp 1.4.3-1
xorg-xkill 1.0.5-1
xorg-xmessage 1.0.5-1
xorg-xmodmap 1.0.10-1
xorg-xprop 1.2.4-1
xorg-xrandr 1.5.1-1
xorg-xrdb 1.2.0-1
xorg-xset 1.2.4-1
xorg-xsetroot 1.1.2-1
xorgproto 2019.2-2
xvidcore 1.3.7-1
xz 5.2.5-1
yajl 2.1.0-2
zbar 0.23-2
zenity 3.32.0+17+gfb0938f-1
zeromq 4.3.2-1
zita-alsa-pcmi 0.3.2-2
zita-resampler 1.6.2-2
zlib 1:1.2.11-4
zsh 5.8-1
zstd 1.4.4-1
zvbi 0.2.35-3
zziplib 0.13.69-1
stable is on 5.4.27-1.
linux54-virtualbox-host-modules 6.1.4-8 doesn't match your kernel version (seems to be from testing? ).
Reinstall and (possibly downgrade) linux54.
nope, not from testing. i just compiled the most recent lts kernel from gitlab core 5.4.x
i always use stable
So you need to build your kernel modules as well to match your kernel..
oh, ok. i didn't realise that :slight_smile: i guess i assumed that lts meant that you could use the modules regardless of the kernel version
LTS stands for Long Term Support: this kernel will just be supported longer (by upstream kernel.org).
Modules always have to match your kernel.
ok will try it.
That is why you are having issues with VBox.
You can't can't combine a self compiled kernel with repo virtualbox modules - you will need to compile the necessary modules as well.
