Virt-Manager does not support aarch64 guests
Hi,
I am running several x86_64 VMs on my machine with virt-manager. Today I tried to get a aarch64 VM up and running but I am getting this problem:
But I installed most of the qemu packages:
Any ideas what I may be missing? I tested this on ubuntu 20.04 and it works there.
Maybe you have to build qemu-aarch64-static
Might be available in that dropdown menu, but ... from your screenshot:
https://wiki.archlinux.org/index.php/QEMU#Chrooting_into_arm/arm64_environment_from_x86_64
I want to compile cockroachdb for arm64 inside the VM so I am not sure if chroot is a sufficient solution.
I checked pamac and this package is still available:
Should I try that?
OK, it turns out that the necessary package is not available in the manjaro repositories. I had to use the package edk2-avmf from AUR to boot the VM. It seems to work so far.
