Hello there!
I have switched from windows to manjaro xfce a few days ago. I have problem with viewnior not showing images which have more memory. Error message: Backing store not supported.
Can anyone help me? Thanks in advance !
That seems be a a change at libjpeg-turbo
: JPEGLib: Backing store not supported in 1.5.2 · Issue #162 · libjpeg-turbo/libjpeg-turbo · GitHub
There is not much you can do, so you are better off telling that to the developer: Issues · hellosiyan/Viewnior · GitHub
Thank you for the answer. I have another problem. I can set all images as Desktop background image except for the image. If I set that image in Desktop settings, the background turns into black. Its size is 7.2 mb
Welcome to the forum!
See if you can open the image in GIMP. It is possible that the file is corrupted. If it’s not, you can try changing it to a different image format that XFCE supports for wallpapers — sorry I can’t help more in that regard, but I’m not using XFCE.
P.S.: Only one issue per thread, please.
