Videos do not work in all browsers
After an upgrade no browser plays any video (youtube or even local videos). But mpv plays youtube videos fine.
Searching the forum I found that issuing
systemctl --user restart pulseaudio
solves the problem, and browsers work again (although mpv was working anyways). But I found no solution to this issue. I can arrange for this command to execute at each login, but this is not the solution. How to find what is causing this and resolve it?
A bit hard to provide specific advice due to the lack of system information provided, however in previous topics with similar playback issues, including the one below, installing manjaro-pipewire resolved the issue:
The manjaro-pipewire metapackage will install the following packages:
gst-plugin-pipewire pipewire pipewire-alsa pipewire-pulse
replacing these packages:
manjaro-pulse pulseaudio-equalizer pulseaudio-jack pulseaudio-lirc pulseaudio-rtp pulseaudio-zeroconf
You may need to reboot after installation.
pamac info manjaro-pipewire
Version               : 20231009-1
Description           : Manjaro meta package for complete PipeWire support.
URL                   : https://wiki.archlinux.org/title/PipeWire
Licenses              : GPL
Repository            : extra
Installed Size        : 1.6 kB
Groups                : --
Depends On            : gst-plugin-pipewire pipewire pipewire-alsa pipewire-pulse
Optional Dependencies : easyeffects: advanced equalizer and effects
                        pipewire-jack: Jack support
                        pipewire-v4l2: V4L2 interceptor
                        pipewire-x11-bell: X11 bell
                        pipewire-zeroconf: Zeroconf support
                        realtime-privileges: Realtime privileges for users
Required By           : --
Optional For          : --
Provides              : --
Replaces              : --
Conflicts With        : manjaro-pulse pulseaudio-equalizer pulseaudio-jack pulseaudio-lirc pulseaudio-rtp
                        pulseaudio-zeroconf
Packager              : Mark Wagie <mark@manjaro.org>
Build Date            : Tue 10 Oct 2023 11:27:33
Install Date          : Fri 17 Nov 2023 16:49:01
Install Reason        : Explicitly installed
Validated By          : Signature
Backup files          : --
What kind of information could I provide? It is a fully updated Manjaro Linux.
In any case, thank you very much. I will follow your advice and report back.
pacman -S manjaro-pipewire
resolving dependencies...
:: manjaro-pipewire-20231009-1 and manjaro-pulse-20240817-1 are in conflict. Remove manjaro-pulse? [y/N] ```
What should I do here?
You need to select y for everything.
The output of inxi -zv8.
inxi -zv8 does not do anything. It stays there with no output.
Answering y in all says
:: removing pulseaudio breaks dependency 'pulseaudio=17.0+r43+g3e2bb8a1e-1' required by pulseaudio-bluetooth
So I guess I need to remove everything like pulseaudio-bluetooth. Correct?
Yes - you should remove pulseaudio-bluetooth and any other conflicting pulseaudio dependencies if they are preventing the installation of manjaro-pipewire.
Oops, how to get out of this loop:
and
pacman -R pulseaudio-bluetooth
checking dependencies...
:: removing pulseaudio-bluetooth breaks dependency 'pulseaudio-bluetooth' required by manjaro-pulse
Try removing the pulseaudio stuff first before installing pipewire
sudo pacman -R pulseaudio-bluetooth manjaro-pulse
then
sudo pacman -Syu manjaro-pipewire
This worked. Thank you. But before I reboot, do I need any of the optional packages? It says:
Optional dependencies for manjaro-pipewire
No - you don’t need any of them. They’re only optional to add extra features. However, it was mentioned in the other topic I linked to that the helvum package might need to be installed. I don’t have helvum or any of those optional pipewire-pulse dependencies installed on my Plasma system, however it may be different for Gnome systems (I’m not sure which desktop environment you are using).
Maybe see how things are after you reboot before you look at installing anything else.
I do not use KDE/Plasma. I typically use MATE and NsCDE (that is fvwm). OK, I reboot and check how it goes. Will report back.
Great! Videos work again. Thank you very much for the help!
(I marked the solution you provided as “solution”.)
