Video stop playing when sound is unmuted, replay when muted
Good morning,
For a reason I ignore, when I wanna play a video, it stop when the sound unmuted (the load cursor appeared and it locks), and then when the sound is muted the video replay again …
I cannot play any video on VLC too …
It does that on Firefox, Google Chrome, and any video, I tried on Youtube, Udemy, or other website, you turned the sound and the video stop playing and locks in this state.
I can provide you information from command to support me in this issue.
Thank you
Other information:
inxi -Aazy
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:9d70 class-ID: 0403
  API: ALSA v: k6.12.28-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.2 status: off with: wireplumber status: off
    tools: pw-cat,pw-cli,wpctl
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with: pulseaudio-alsa
Another information, when I use this command, the sound start playing and video player behave normally:
systemctl --user stop wireplumber.service
But if I restart the sound stop and the issue described above is back.
Maybe try disable instead, with that command, after using your example to stop it first?
I did try but I got this message:
~ systemctl --user disable wireplumber.service
The following unit files have been enabled in global scope. This means
they will still be started automatically after a successful disablement
in user scope:
wireplumber.service
inxi data shows PulseAudio is active and pulseaudio-alsa is installed to use PulseAudio as default ALSA output
Wireplumber is a session/policy manager for PipeWire and is not needed if PipeWire is not running
Try masking the service
systemctl --user mask wireplumber.service
thank you all for your support.
Created symlink '/home/workstation/.config/systemd/user/wireplumber.service' → '/dev/null'.
Why it created a symlink ?
systemctl --user status wireplumber.service
○ wireplumber.service
     Loaded: masked (Reason: Unit wireplumber.service is masked.)
     Active: inactive (dead) since Fri 2025-05-23 11:15:21 CEST; 9h ago
   Duration: 2min 49.650s
 Invocation: d31a7e9800204567b6f1172e052dd8c0
   Main PID: 2658 (code=exited, status=0/SUCCESS)
   Mem peak: 9M
        CPU: 300ms
I am going to reboot and see if it keep this state
It worked, I reboot my system and everything is fine now.
Thanks to all !
Linux TLDR - Systemctl Mask vs Systemctl Disable
if you mask your services using the systemctl mask command, no matter what services or dependencies require your service, it will not start manually or on the system boot.
This is all done with the help of symbolic links also known as symlinks
In the systemctl mask command, the service is a symlink to the /dev/null file. which makes it impossible to start on system boot or manually by you, even if it is required by another service or dependency.
Using the systemctl unmask command will delete the symlink to /dev/null
Ok thank you for the explanation
Thank all for support
