When playing some games for some time, particularly if a video or stream is running on my second screen, the environment freezes, sound cuts off for a second, everything. Then sound starts playing again, a freeze frame of the last frame is displayed with some green and purple dots scattered here and there, sometimes there’s squares there too. The mouse is movable an the cursor also moves, with input being registered from the keyboard, through which I could open the terminal and save a log.
Yes I REISUB!
Important to note is that this problem started after spring.
Usually I just brushed the problem away, because it happened in these specific circuimstances.
However, I’ve now been able to continiously repeat the event without fail via Minecraft of all games.
Things to note from it:
Having an unlimited framerate and running it at 600fps makes the freeze happen faster, whilist having it lower delays it.
This seems to only happen in imported maps that I’ve created in World Painter.
How do I know this is a Driver or similar problem?
This doesn’t happen in my Windows dualboot.
I’ve also installed another instance of Manjaro on another Disk, and ran the same MultiMC file, to be greeted by the same event. So me reinstalling the OS wouldn’t help (afaik).
I’ve tried many fixes from this forum and the arch one aswell.
I’ve Disabled Global C staes, have PSU current as typical when idle, added a few boot options to the Grub that I do not remember outright, but will post when I get home.
inxi:
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=f3686958-379c-4665-bfa1-37ecfc185922 rw quiet apparmor=1
security=apparmor resume=UUID=2d0bb0f9-792e-401f-b1c1-853fe91d0b48
udev.log_priority=3 idle=nomwait iommu=soft
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 0807
date: 07/08/2019
RAM: total: 31.25 GiB used: 4.37 GiB (14.0%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 2319 high: 3941 min/max: 2200/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3115 2: 2048
3: 2019 4: 2793 5: 1861 6: 1863 7: 2194 8: 2196 9: 2195 10: 2196 11: 2195
12: 2196 13: 3941 14: 2049 15: 2043 16: 2079 17: 2053 18: 3593 19: 2053
20: 2193 21: 2196 22: 2194 23: 2196 24: 2195 bogomips: 182134
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-1 code: Navi
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 09:00.0
chip-ID: 1002:731f class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left
model: Dell S2522HG serial: <filter> built: 2021 res: 1920x1080 hz: 60
dpi: 90 gamma: 1.2 size: 544x303mm (21.42x11.93") diag: 623mm (24.5")
ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: Dell S2522HG
serial: <filter> built: 2021 res: 1920x1080 hz: 60 dpi: 90 gamma: 1.2
size: 544x303mm (21.42x11.93") diag: 623mm (24.5") ratio: 16:9 modes:
OpenGL: renderer: AMD Radeon RX 5700 XT (navi10 LLVM 14.0.6 DRM 3.42
5.15.60-1-MANJARO) v: 4.6 Mesa 22.3.0-devel (git-78564b5b84)
direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:ab38
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 342.81 GiB used: 167.63 GiB (48.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Corsair model: Performance3 SSD
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1.1 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Intel model: SSDSC2CW240A3
size: 223.56 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 400i scheme: GPT
ID-1: / raw-size: 214.47 GiB size: 210.04 GiB (97.94%) used: 167.63 GiB
(79.8%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: f3686958-379c-4665-bfa1-37ecfc185922
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 288 KiB
(0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: 2380-5356
dev: /dev/sdb3 maj-min: 8:19 label: swap
uuid: 2d0bb0f9-792e-401f-b1c1-853fe91d0b48
ID-1: /dev/sda1 maj-min: 8:1 size: 300 MiB fs: vfat label: NO_LABEL
uuid: 0D4B-134B
ID-2: /dev/sda2 maj-min: 8:2 size: 118.95 GiB fs: ext4 label: N/A
uuid: c192997f-2563-44d1-b23d-027cdc05dfe2
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 1-5:2 info: IBM NetVista Full Width Keyboard type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 04b3:3025 class-ID: 0301
Device-2: 1-6:3 info: Logitech Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c077 class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-6:2 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 41.5 C mobo: N/A gpu: amdgpu temp: 23.0 C
mem: 24.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 65535
Processes: 510 Uptime: 2m wakeups: 0 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: 1736
pm: pacman pkgs: 1723 libs: 497 tools: pamac,yay pm: flatpak pkgs: 0
pm: snap pkgs: 13 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.21
systemctl of the failure event:
elo 24 15:30:57 Tehosekoitin kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx_0.0.0 timeout, signaled seq=99486, emitted seq=99487
elo 24 15:30:57 Tehosekoitin kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process java pid 3514 thread java:cs0 pid 3631
elo 24 15:31:01 Tehosekoitin kernel: amdgpu 0000:09:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring kiq_2.1.0 test failed (-110)
elo 24 15:31:01 Tehosekoitin kernel: [drm:gfx_v10_0_hw_fini [amdgpu]] *ERROR* KGQ disable failed
elo 24 15:31:01 Tehosekoitin kernel: [drm:gfx_v10_0_hw_fini [amdgpu]] *ERROR* KCQ disable failed
elo 24 15:31:01 Tehosekoitin kernel: [drm:gfx_v10_0_hw_fini [amdgpu]] *ERROR* failed to halt cp gfx
elo 24 15:31:05 Tehosekoitin kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
That last parser line is then repeated 10 times every 5 seconds untill I REISUB
One time when switching Kernels it gave this as an extra, though it happened only once on 515 kernel:
elo 24 15:31:15 Tehosekoitin kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx_0.0.0 timeout, but soft recovered
I’ve tried to figure out that Parser -125 error, but when tried fixing it last night with It just freezed to the last frame of the boot line.
loglevel=3 quiet radeon.si_support=0 radeon.cik_support=0 amdgpu.si_support=1 amdgpu.cik_support=1 radeon.modeset=0 pcie_aspm=off intel_iommu=igfx_off immu=pt intel_iommu=off amdgpu.dpm=0 amdgpu.aspm=0 amdgpu.runpm=0 amdgpu.bapm=0
Ofc I should’ve read beforehand what these did, but it was late into the night and I was very frustrated.
After I managed to remove this from the grub via my second manjaro system and got it to show video again, I just gave up and now I’m here writing this to this forum.
Hope that’s most of the information covered, let me know if more is needed.
Hopefully we can get this working, had to freeze a few passion projects to focus on this.
