Video On Demand playback issue
Hello,
I’m quite new on Manjaro but I used to be ubuntu/debian user 15 years before. Yesterday, after a “regular” update, I discovered that I could not read any video from the internet anymore, whatever the website or the browser. I tried a lot of things to fix it with the help of the chatbot Claude.ai, but nothing worked. Here’s a report of my investigations generated with and by Claude. If something talks to you, don’t hesitate to share it and tell me :slight_smile:
Thanks.
Adrien
Report by Claude.ai:
VOD (Video On Demand) Playback Issue on Manjaro - All Browsers Affected
System Configuration
  • Distribution: Manjaro Linux
  • Kernel: 6.12.48-1-MANJARO
  • Graphics Card: Intel HD Graphics 620 (Mesa)
  • Browsers Tested: Firefox 143.0.3-1, Chromium, Vivaldi, Google Chrome
  • Affected Services: Netflix, Canal+, Auvio (all VOD platforms)
Symptoms
  • Date of Occurrence: October 11, 2025 in the evening
  • Behavior: Video image appears then freezes immediately (after ~1 second)
  • Type of Content Affected: VOD (Video On Demand) only
  • Important Note: Live streaming has not been tested
  • All browsers are affected in the same way
  • All VOD platforms exhibit the same problem
Errors in Firefox Console (F12)
Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at https://replay-dshmkpc1-aka-canalplus.akamaized.net/...
Reason: CORS request failed. Status code: (null).
HTTP Status Codes in Network Tab:
  • 302 (redirect - normal)
  • 202 (accepted - normal)
  • Several requests with no status code (0 or empty) - blocked/cancelled requests
Actions Performed on October 11, 2025
22:47 - Package Removal
pacman -Rns aribb24 ffmpeg4.4 libdvbpsi libmatroska libsoup libtar libupnp mathjax python-coverage
Removed Packages:
  • ffmpeg4.4 (4.4.6-2)
  • libmatroska (1.7.1-2)
  • libebml (1.4.5-1)
  • libdvbpsi (1:1.3.3-3)
  • libmfx (23.2.2-5)
  • aribb24 (1.0.3-4)
  • libupnp (1.14.24-1)
  • libtar (1.2.20-7)
  • libsoup (2.74.3-4)
23:08 - 23:14 - System Update Attempts
Multiple executions of pacman -Syudd (with double “-d” = ignore dependencies)
23:17 - Firefox Reinstallation
Firefox 143.0.3-1 reinstalled
Attempted Solutions (Unsuccessful)
1. Firefox Configuration (about:config)
  • media.hardware-video-decoding.enabled = false
  • media.ffmpeg.vaapi.enabled = false
  • network.http.referer.XOriginPolicy = 0 (was already set to 0)
2. Codec and Library Reinstallation
sudo pacman -S ffmpeg gstreamer gst-plugins-base gst-plugins-good gst-plugins-bad gst-plugins-ugly gst-libav
sudo pacman -S libva-intel-driver intel-media-driver vulkan-intel
sudo pacman -S ca-certificates nss
3. Reinstallation of Removed Libraries
sudo pacman -S libmatroska libdvbpsi libupnp libtar libsoup aribb24 ffmpeg4.4
4. Testing with a New User Account
  • Created “testuser” account → same problem (confirms this is a system-level issue, not user configuration)
5. System Verification
  • pacman -Dk: no missing files detected
  • pacman -Qkk 2>&1 | grep warning: no issues found
  • vainfo: Intel drivers functional
  • UFW (firewall): inactive
6. Broken Symbolic Link Repair
Discovery: /usr/lib/firefox/libonnxruntime.so was pointing to a non-existent file
Applied Solution:
sudo pacman -S onnxruntime
Link is now repaired, but video playback issue persists.
7. Massive Reinstallation of All Multimedia Packages
sudo pacman -S $(pacman -Qsq | grep -E 'ffmpeg|gstream|libva|codec|media')
20 packages reinstalled, no change.
System Diagnostics
Broken Symbolic Links Found
sudo find /usr/lib -xtype l
  • /usr/lib/firefox/libonnxruntime.so (now fixed after onnxruntime installation)
  • /usr/lib/thunderbird/hyphenation (normal)
  • /usr/lib/thunderbird/dictionaries (normal)
System Logs (journalctl -b -p err)
Nothing significant related to video playback. Only:
  • Minor WiFi/Bluetooth errors (normal)
  • Touchpad errors rmi4_f30 (unrelated)
Current Multimedia Package Versions
  • ffmpeg: 2:7.1.1-5
  • ffmpeg4.4: 4.4.6-2 (reinstalled)
  • gstreamer: 1.26.6-1
  • gst-plugins-*: 1.26.6-1
  • onnxruntime: 1.22.2-2 (reinstalled)
  • libva: 2.22.0-1
  • intel-media-driver: 25.2.6-1
Current Hypotheses
  1. Dependencies Broken by pacman -Syudd: The double “-d” forces installation while ignoring dependencies, which may have created invisible inconsistencies
  2. Undetected Missing Library: Despite verifications, there may be an obscure library used for DRM/protected video playback that’s missing
  3. SSL/TLS Certificate Issue: CORS requests failing without status code suggest a connection/certificate problem
Questions for the Community
  1. Has anyone encountered this problem after removing ffmpeg4.4 and running pacman -Syudd?
  2. Are there other critical libraries for DRM-protected VOD playback that might have been removed along with the listed packages?
  3. Is there a way to force complete dependency verification of all installed packages?
  4. Should I consider downgrading from kernel 6.12 to an earlier version?
Untested Solutions
  1. Installing an older LTS kernel (linux61, linux515) - but these packages seem no longer available in the repositories
  2. Timeshift Restoration - no snapshot available from before the problem
  3. Complete Manjaro Reinstallation - last resort solution
hello frads,
please post the mandatory inxi-infos first. use the </> option and paste the output of the following inside
inxi --admin --verbosity=7 --filter --no-host
additional post the output of
pacman-mirrors -G
to see what type of branch you’re using
 ~ inxi --admin --verbosity=7 --filter --no-host
  Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=1666d53e-9ab3-4889-bcab-b3e78caaa19b rw quiet splash apparmor=1
    security=apparmor resume=UUID=507b916d-b51c-4a5a-97dd-c508f0d29302
    udev.log_priority=3
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: LENOVO product: 20HGS0KE00 v: ThinkPad T470s
  Mobo: LENOVO model: 20HGS0KE00 v: SDK0J40697 WIN
    serial: <superuser required>
    part-nu: LENOVO_MT_20HG_BU_Think_FM_ThinkPad T470s
    uuid: <superuser required> UEFI: LENOVO v: N1WET63W (1.42 )
    date: 08/24/2021
  ID-1: BAT0 charge: 20.2 Wh (99.5%) condition: 20.3/23.5 Wh (86.2%)
    power: 2.8 W volts: 12.93 min: 11.25 model: SANYO 00HW022 type: Li-poly
    serial: <filter> charging: status: charging control: start: 0% end: 100%
    cycles: 794
  ID-2: BAT1 charge: 6 Wh (79%) condition: 7.6/26.1 Wh (29.1%) volts: 12.54
    min: 11.46 model: SMP 01AV406 type: Li-poly serial: <filter> charging:
    status: not charging control: start: 0% end: 100% cycles: 538
  System RAM: total: 8 GiB available: 7.63 GiB used: 3.46 GiB (45.3%)
  Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 2133 MT/s volts: curr: 1 width (bits):
    data: 64 total: 64 manufacturer: Samsung part-no: M471A1K43BB1-CRC
    serial: N/A
  Device-2: ChannelB-DIMM0 type: no module installed
  Info: model: Intel Core i5-7300U bits: 64 type: MT MCP arch: Amber/Kaby Lake
    note: check gen: core 7 level: v3 note: check built: 2017
    process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
    microcode: 0xF6
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 400 min/max: 400/3500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 bogomips: 21607
    smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
  Device-1: Intel HD Graphics 620 vendor: Lenovo driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
    empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5916
    class-ID: 0300
  Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:4 chip-ID: 5986:2118
    class-ID: 0e02
  Display: x11 server: X.org v: 1.21.1.18 compositor: xfwm4 v: 4.20.0
    driver: X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 model: AU Optronics 0x243d built: 2016 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 158 gamma: 1.2
    size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9
    modes: 1920x1080
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.3-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 620 (KBL GT2)
    device-ID: 8086:5916 memory: 7.45 GiB unified: yes
    gpu: nvidia-smi x11: xprop,xrandr
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:9d71 class-ID: 0403
  API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.8 status: active with: 1: wireplumber
    status: active 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli,wpctl
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
    tools: pacat,pactl,pavucontrol
  Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 3a:00.0 chip-ID: 8086:24fd
    class-ID: 0280
  IF: wlp58s0 state: up mac: <filter>
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 8087:0a2b
    class-ID: e001
  Local Storage: total: 238.47 GiB used: 30.16 GiB (12.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo
    model: LENSE20256GMSP34MEAT2TA size: 238.47 GiB block-size: physical: 512 B
    fw-rev: 2.8.8341 temp: 36.9 C scheme: GPT
  ID-1: / raw-size: 229.38 GiB size: 224.72 GiB (97.97%)
    used: 29.09 GiB (12.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 1666d53e-9ab3-4889-bcab-b3e78caaa19b
    used: 320 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 53F0-3CF3
  ID-1: swap-1 type: partition size: 8.8 GiB used: 1.07 GiB (12.2%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 507b916d-b51c-4a5a-97dd-c508f0d29302
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-5:2 info: Alcor Micro AU9540 Smartcard Reader type: smart card
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 50mA chip-ID: 058f:9540 class-ID: 0b00
  Device-2: 1-7:3 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0a2b class-ID: e001
  Device-3: 1-8:4 info: Bison Integrated Camera type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 5986:2118 class-ID: 0e02
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  Device-1: 2-3:2 info: Realtek Card Reader type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 800mA chip-ID: 0bda:0316 class-ID: 0806
    serial: <filter>
  System Temperatures: cpu: 43.0 C pch: 46.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 0
  Processes: 230 Power: uptime: 2h 22m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.04 GiB services: upowerd,xfce4-power-manager
  Packages: 1496 pm: pacman pkgs: 1478 libs: 387 tools: pamac,yay
    pm: flatpak pkgs: 6 pm: snap pkgs: 12 Compilers: gcc: 15.2.1 Shell: Zsh
    v: 5.9 running-in: xfce4-terminal inxi: 3.3.39
pacman-mirrors -G
stable
okay, let’s check some things before ongoing. please run the following to update the mirror-servers and do an ordinary update first. please report if there are any issues while this process. run
sudo pacman-mirrors -c all && sudo pacman -Syu
And a link to what is not playing will be useful, just to exclude the possibility that the site was broken. Cause my netflix, amazon, disney, and 2 local iptv providers work.
Although if you used -Syudd you already know what broke your system (you following stupid AI advice to use dd and skip all important checks).
You have started another thread on the same issue in the french language section of this forum here
(to which I responded with the help of google translate) -
with, it seems, slightly different description of the issue and how it came to be.
It could be helpful to know (for you and for us as well) what commands you actually used to remove stuff like ffmpeg4.4 and some libraries.
This, these commands, will still be in your shell command history and can be recalled:
history
or
history | less
to be able to easily scroll through with up/down arrow keys
… if you use pacman -Rns xyz to remove stuff, a lot of things will be affected outside of just the package xyz
@frads
It seems unlikely that you should be experiencing so many apparant problems with a new Manjaro installation; I note similar issues are discussed in your topic posted in the French language area of the forum;
Did you remember to check your Manjaro ISO for consistency after downloading it? Compare it to the checksum file (also available from the Downloads page).
Waiting for others to blindly ask questions can be counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Highly Recommended
Technical Resources
Required Reading
Hello, thank you for your answers. I’ll try to answer again. And I’m sorry if I’m not precise enough, don’t hesitate to tell me if useful infos are missing (here, I think I gave all I know).
  • I am sorry for the “double posting” (in french and in english). I first thought that it was 2 differents forums and when I realised my mistake it was already done…
  • I understand that I should not have use Syudd, I followed the advice of the AI.
  • I don’t know how ffmpeg4.4 was removed, it was probably with a command that makes a lot of things. The history command doesn’t go so far.
  • I understand that I broke my system, does it mean I have to reinstall it or there’s is still any possibility to fix the problem?
thank you for welcoming and happy to be with you !
And, will you answer this as well? :slight_smile:
If you didn’t check the ISO after downloading, that could easily be the cause of your problems – if it is damaged while downloading, Manjaro might still install, but it could be broken in ways we cannot predict.
well, I don’t know where is the ISO I use to install manjaro (probably on a lost usb key) :roll_eyes:
btw, I finally have the log of what I did with pamac & pacman during that crazy night… is it more clear for you?
[2025-10-11T22:30:22+0200] [PAMAC] synchronizing package lists
[2025-10-11T22:49:01+0200] [PACMAN] Running ‘pacman -S -c --config /etc/pacman.conf --’
[2025-10-11T23:08:26+0200] [PACMAN] Running ‘pacman -Syyu’
[2025-10-11T23:08:26+0200] [PACMAN] synchronizing package lists
[2025-10-11T23:08:31+0200] [PACMAN] starting full system upgrade
[2025-10-11T23:14:01+0200] [PACMAN] Running ‘pacman -Syudd’
[2025-10-11T23:14:01+0200] [PACMAN] synchronizing package lists
[2025-10-11T23:14:12+0200] [PACMAN] starting full system upgrade
[2025-10-11T23:14:24+0200] [PACMAN] Running ‘pacman -Syudd’
[2025-10-11T23:14:24+0200] [PACMAN] synchronizing package lists
[2025-10-11T23:14:31+0200] [PACMAN] Running ‘pacman -Syudd’
[2025-10-11T23:14:31+0200] [PACMAN] synchronizing package lists
[2025-10-11T23:14:38+0200] [PACMAN] Running ‘pacman -Syudd’
[2025-10-11T23:14:38+0200] [PACMAN] synchronizing package lists
[2025-10-11T23:14:57+0200] [PACMAN] Running ‘pacman -Syudd’
[2025-10-11T23:14:57+0200] [PACMAN] synchronizing package lists
[2025-10-11T23:14:58+0200] [PACMAN] starting full system upgrade
[2025-10-11T23:28:34+0200] [PACMAN] Running ‘pacman -S pipx’
[2025-10-11T23:28:39+0200] [PACMAN] Running ‘pacman -S pip’
[2025-10-11T23:29:01+0200] [PACMAN] Running ‘pacman -S vity’
[2025-10-11T23:29:41+0200] [PACMAN] Running ‘pacman -S --noconfirm python-pip’
[2025-10-11T23:29:44+0200] [PACMAN] Running ‘pacman -S --noconfirm python-pipx’
[2025-10-12T00:00:35+0200] [PACMAN] Running ‘pacman -S ffmpeg gst-plugins-base gst-plugins-good gst-plugins-bad gst-plugins-ugly’
[2025-10-12T00:22:05+0200] [PACMAN] Running ‘pacman -S widevine’
[2025-10-12T00:22:47+0200] [PACMAN] Running ‘pacman -S widevinecdm’
[2025-10-12T00:22:58+0200] [PACMAN] Running ‘pacman -S libwidevinecdm’
[2025-10-12T00:33:28+0200] [PACMAN] Running ‘pacman -Scc’
[2025-10-12T00:33:41+0200] [PAMAC] synchronizing package lists
[2025-10-12T00:33:58+0200] [PACMAN] Running ‘pacman -S ffmpeg gstreamer gst-plugins-base gst-plugins-good gst-plugins-bad gst-plugins-ugly gst-libav’
[2025-10-12T00:42:05+0200] [PACMAN] Running ‘pacman -S libva-utils’
[2025-10-12T00:54:28+0200] [PACMAN] Running ‘pacman -S ca-certificates nss’
[2025-10-12T01:01:27+0200] [PACMAN] Running ‘pacman -S libva-intel-driver intel-media-driver gst-plugins-bad gst-plugins-ugly gst-libav’
Mod edit:- General tidy. No charge.
If that is the full log, you didn’t remove anything so it should be ok.
Give an example of what doesn’t play.
It’s not the full log - it has been filtered to only contain lines with [PACMAN] .
There are others in between, containing [ALPM] and [ALPM-SCRIPTLET] and possibly [PAMAC]
Still, nothing has been removed as far as the log snippet shows.
You tried to install widevine and widevinecdm and libwidevinecdm.
These are neither packages in the repo nor in the AUR - nothing happened there and you had to have gotten an (error) message to that effect when you issued the command.
such as:
error: target not found: widevine
As far as I know this is part of the browser itself - not separate packages.
You get the full log in reverse order - newest first, oldest last - with:
tac /var/log/pacman.log | less
scroll with the up/down arrow key …
or:
less +G /var/log/pacman.log
jumps to the end and you can scroll up (back in time) from there
Video playback might be failing if audio playback is not possible
Data for audio suggests audio servers are mis-configured
To use PipeWire as default audio server install pipewire-pulse to replace pulseaudio;
reboot system and check audio server - inxi -Aa
  Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
To use PulseAudio as default audio server install pulseaudio-alsa to replace pipewire-alsa;
    Server-4: PulseAudio v: 17.0-43-g3e2bb status: active with:
    1: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
Any video from any vod-streaming service (except live stream services) doesn’t work (I tried Youtube, Netflix, Canalplus, Auvio, Arte dot tv, vidéos on Facebook, etc). I can’t give a precise example without writing a link here, which is forbidden…
You can add backticks to the beginning and end of the URL, so it appears like this:
https://www.manjaro.org :wink:
I can give the full log, I thought it could be great to filter but maybe it was too much, again I’m sorry, I feel like I’m an eternal noob :-/ … Here’s the full log
[2025-10-11T03:57:48+0200] [PAMAC] synchronizing package lists
[2025-10-11T09:58:53+0200] [PAMAC] synchronizing package lists
[2025-10-11T10:58:59+0200] [PAMAC] synchronizing package lists
[2025-10-11T16:59:59+0200] [PAMAC] synchronizing package lists
[2025-10-11T22:30:38+0200] [ALPM] running ‘00-timeshift-autosnap.hook’…
[2025-10-11T22:30:38+0200] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2025-10-11T22:30:38+0200] [ALPM] transaction started
[2025-10-11T22:30:38+0200] [ALPM] upgraded archlinux-keyring (20250807.1-1 → 20250929-1)
[2025-10-11T22:30:38+0200] [ALPM-SCRIPTLET] ==> Ajout des clés depuis archlinux.gpg…
[2025-10-11T22:30:43+0200] [ALPM-SCRIPTLET] ==> Mise à jour de la base de données de confiance…
[2025-10-11T22:30:43+0200] [ALPM-SCRIPTLET] gpg: la prochaine vérification de la base de confiance aura lieu le 2025-11-16
[2025-10-11T22:30:43+0200] [ALPM] transaction completed
[2025-10-11T22:30:43+0200] [ALPM] running ‘30-systemd-daemon-reload-system.hook’…
[2025-10-11T22:30:44+0200] [ALPM] running ‘30-systemd-restart-marked.hook’…
[2025-10-11T22:30:44+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-11T22:31:56+0200] [ALPM] running ‘00-timeshift-autosnap.hook’…
[2025-10-11T22:31:56+0200] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2025-10-11T22:31:56+0200] [ALPM] running ‘firefox-pre.hook’…
[2025-10-11T22:31:56+0200] [ALPM] transaction started
[2025-10-11T22:31:58+0200] [ALPM] upgraded chromium (140.0.7339.207-1 → 141.0.7390.76-1)
[2025-10-11T22:31:59+0200] [ALPM] upgraded firefox (143.0.1-1 → 143.0.3-1)
[2025-10-11T22:31:59+0200] [ALPM] upgraded grub (2:2.12.r359.g19c698d1-3 → 2:2.12.r382.gee789e1a-2)
[2025-10-11T22:32:00+0200] [ALPM-SCRIPTLET] :: To use the new features provided in this GRUB update, it is recommended
[2025-10-11T22:32:00+0200] [ALPM-SCRIPTLET]    to install it to the MBR or UEFI. Due to potential configuration
[2025-10-11T22:32:00+0200] [ALPM-SCRIPTLET]    incompatibilities, it is advised to run both, installation and generation
[2025-10-11T22:32:00+0200] [ALPM-SCRIPTLET]    of configuration:
[2025-10-11T22:32:00+0200] [ALPM-SCRIPTLET]      # install-grub
[2025-10-11T22:32:00+0200] [ALPM-SCRIPTLET]      # update-grub
[2025-10-11T22:32:00+0200] [ALPM] upgraded install-grub (2:2.12.r359.g19c698d1-3 → 2:2.12.r382.gee789e1a-2)
[2025-10-11T22:32:00+0200] [ALPM] upgraded mhwd-db (20250918-1 → 20250929-2)
[2025-10-11T22:32:03+0200] [ALPM] upgraded mhwd (0.6.6-5 → 0.6.6-6)
[2025-10-11T22:32:03+0200] [ALPM] upgraded update-grub (2:2.12.r359.g19c698d1-3 → 2:2.12.r382.gee789e1a-2)
[2025-10-11T22:32:05+0200] [ALPM] upgraded vivaldi (7.6.3797.56-1 → 7.6.3797.63-1)
[2025-10-11T22:32:06+0200] [ALPM] upgraded yt-dlp (2025.09.05-1 → 2025.09.26-1)
[2025-10-11T22:32:07+0200] [ALPM] transaction completed
[2025-10-11T22:32:07+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-11T22:32:07+0200] [ALPM] running ‘98-install-grub.hook’…
[2025-10-11T22:32:08+0200] [ALPM-SCRIPTLET] Grub will be installed on: EFI
[2025-10-11T22:32:08+0200] [ALPM-SCRIPTLET] Installation pour la plate-forme x86_64-efi.
[2025-10-11T22:32:09+0200] [ALPM-SCRIPTLET] Installation terminée, sans erreur.
[2025-10-11T22:32:09+0200] [ALPM-SCRIPTLET] Création du fichier de configuration GRUB…
[2025-10-11T22:32:09+0200] [ALPM-SCRIPTLET] Thème trouvé : /usr/share/grub/themes/manjaro/theme.txt
[2025-10-11T22:32:09+0200] [ALPM-SCRIPTLET] Image Linux trouvée : /boot/vmlinuz-6.12-x86_64
[2025-10-11T22:32:09+0200] [ALPM-SCRIPTLET] Image mémoire initiale trouvée : /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.12-x86_64.img
[2025-10-11T22:32:10+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-6.12-x86_64-fallback.img
[2025-10-11T22:32:10+0200] [ALPM-SCRIPTLET] Attention : le sondeur de systèmes d’exploitation sera exécuté pour détecter d’autres partitions amorçables.
[2025-10-11T22:32:10+0200] [ALPM-SCRIPTLET] Sa sortie sera utilisée pour détecter les binaires amorçables qu’elles contiennent et créer de nouvelles entrées d’amorçage.
[2025-10-11T22:32:12+0200] [ALPM-SCRIPTLET] Ajout de l’entrée du menu d’amorçage pour les paramètres du firmware UEFI …
[2025-10-11T22:32:12+0200] [ALPM-SCRIPTLET] Root filesystem isn’t btrfs
[2025-10-11T22:32:12+0200] [ALPM-SCRIPTLET] If you think an error has occurred, please file a bug report at “https://github.com/Antynea/grub-btrfs”
[2025-10-11T22:32:12+0200] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2025-10-11T22:32:12+0200] [ALPM-SCRIPTLET] /usr/bin/grub-probe : attention : type de périphérique nvme0n1 inconnu.
[2025-10-11T22:32:12+0200] [ALPM-SCRIPTLET] Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
[2025-10-11T22:32:12+0200] [ALPM-SCRIPTLET] fait
[2025-10-11T22:32:12+0200] [ALPM] running ‘firefox-post.hook’…
[2025-10-11T22:32:13+0200] [ALPM] running ‘gtk-update-icon-cache.hook’…
[2025-10-11T22:32:13+0200] [ALPM] running ‘texinfo-install.hook’…
[2025-10-11T22:32:13+0200] [ALPM] running ‘update-desktop-database.hook’…
[2025-10-11T22:45:03+0200] [PACMAN] Running ‘pacman -Sc’
[2025-10-11T22:45:29+0200] [PAMAC] synchronizing package lists
[2025-10-11T22:45:38+0200] [PACMAN] Running ‘pacman -Scc’
[2025-10-11T22:46:06+0200] [PAMAC] synchronizing package lists
[2025-10-11T22:46:56+0200] [PACMAN] Running ‘pacman -Rns’
[2025-10-11T22:47:10+0200] [PACMAN] Running ‘pacman -Rns aribb24 ffmpeg4.4 libdvbpsi libmatroska libsoup libtar libupnp mathjax python-coverage’
[2025-10-11T22:47:30+0200] [ALPM] transaction started
[2025-10-11T22:47:31+0200] [ALPM] removed python-coverage (7.10.6-1)
[2025-10-11T22:47:31+0200] [ALPM] removed mathjax (4.0.0-1)
[2025-10-11T22:47:31+0200] [ALPM] removed libupnp (1.14.24-1)
[2025-10-11T22:47:31+0200] [ALPM] removed libtar (1.2.20-7)
[2025-10-11T22:47:31+0200] [ALPM] removed libsoup (2.74.3-4)
[2025-10-11T22:47:31+0200] [ALPM] removed libmatroska (1.7.1-2)
[2025-10-11T22:47:31+0200] [ALPM] removed libebml (1.4.5-1)
[2025-10-11T22:47:31+0200] [ALPM] removed libdvbpsi (1:1.3.3-3)
[2025-10-11T22:47:31+0200] [ALPM] removed ffmpeg4.4 (4.4.6-2)
[2025-10-11T22:47:31+0200] [ALPM] removed libmfx (23.2.2-5)
[2025-10-11T22:47:31+0200] [ALPM] removed aribb24 (1.0.3-4)
[2025-10-11T22:47:31+0200] [ALPM] transaction completed
[2025-10-11T22:47:31+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-11T22:48:26+0200] [PAMAC] synchronizing package lists
[2025-10-11T22:48:54+0200] [ALPM] transaction started
[2025-10-11T22:48:54+0200] [ALPM] installed yay (12.5.0-1)
[2025-10-11T22:48:54+0200] [ALPM] installed opendoas (6.8.2-3)
[2025-10-11T22:48:54+0200] [ALPM] transaction completed
[2025-10-11T22:48:54+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-11T23:17:40+0200] [ALPM] running ‘00-timeshift-autosnap.hook’…
[2025-10-11T23:17:40+0200] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2025-10-11T23:17:40+0200] [ALPM] running ‘firefox-pre.hook’…
[2025-10-11T23:17:40+0200] [ALPM] transaction started
[2025-10-11T23:17:40+0200] [ALPM] reinstalled firefox (143.0.3-1)
[2025-10-11T23:17:40+0200] [ALPM] transaction completed
[2025-10-11T23:17:40+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-11T23:17:41+0200] [ALPM] running ‘firefox-post.hook’…
[2025-10-11T23:17:41+0200] [ALPM] running ‘gtk-update-icon-cache.hook’…
[2025-10-11T23:17:41+0200] [ALPM] running ‘update-desktop-database.hook’…
[2025-10-11T23:29:43+0200] [ALPM] transaction started
[2025-10-11T23:29:43+0200] [ALPM] installed python-attrs (25.3.0-1)
[2025-10-11T23:29:43+0200] [ALPM] installed python-cryptography (45.0.7-1)
[2025-10-11T23:29:43+0200] [ALPM] installed python-wheel (0.45.1-1)
[2025-10-11T23:29:44+0200] [ALPM] installed python-pip (25.2-1)
[2025-10-11T23:29:44+0200] [ALPM] transaction completed
[2025-10-11T23:29:44+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-11T23:29:45+0200] [ALPM] transaction started
[2025-10-11T23:29:45+0200] [ALPM] installed python-click (8.2.1-1)
[2025-10-11T23:29:45+0200] [ALPM] installed python-distro (1.9.0-3)
[2025-10-11T23:29:45+0200] [ALPM] installed python-userpath (1.9.2-3)
[2025-10-11T23:29:45+0200] [ALPM] installed python-argcomplete (3.6.2-1)
[2025-10-11T23:29:45+0200] [ALPM] installed python-platformdirs (4.4.0-1)
[2025-10-11T23:29:45+0200] [ALPM] installed python-pipx (1.7.1-2)
[2025-10-11T23:29:46+0200] [ALPM] transaction completed
[2025-10-11T23:29:46+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-12T00:00:45+0200] [ALPM] running ‘00-timeshift-autosnap.hook’…
[2025-10-12T00:00:45+0200] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2025-10-12T00:00:45+0200] [ALPM] transaction started
[2025-10-12T00:00:45+0200] [ALPM] reinstalled ffmpeg (2:7.1.1-5)
[2025-10-12T00:00:45+0200] [ALPM] reinstalled gst-plugins-base (1.26.6-1)
[2025-10-12T00:00:45+0200] [ALPM] reinstalled gst-plugins-good (1.26.6-1)
[2025-10-12T00:00:45+0200] [ALPM] reinstalled gst-plugins-bad (1.26.6-1)
[2025-10-12T00:00:45+0200] [ALPM] reinstalled gst-plugins-ugly (1.26.6-1)
[2025-10-12T00:00:45+0200] [ALPM] transaction completed
[2025-10-12T00:00:45+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-12T00:34:06+0200] [ALPM] running ‘00-timeshift-autosnap.hook’…
[2025-10-12T00:34:06+0200] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2025-10-12T00:34:06+0200] [ALPM] transaction started
[2025-10-12T00:34:06+0200] [ALPM] reinstalled ffmpeg (2:7.1.1-5)
[2025-10-12T00:34:06+0200] [ALPM] reinstalled gstreamer (1.26.6-1)
[2025-10-12T00:34:06+0200] [ALPM] reinstalled gst-plugins-base (1.26.6-1)
[2025-10-12T00:34:06+0200] [ALPM] reinstalled gst-plugins-good (1.26.6-1)
[2025-10-12T00:34:06+0200] [ALPM] reinstalled gst-plugins-bad (1.26.6-1)
[2025-10-12T00:34:06+0200] [ALPM] reinstalled gst-plugins-ugly (1.26.6-1)
[2025-10-12T00:34:06+0200] [ALPM] reinstalled gst-libav (1.26.6-1)
[2025-10-12T00:34:07+0200] [ALPM] transaction completed
[2025-10-12T00:34:07+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-12T00:35:08+0200] [PACMAN] Running ‘pacman -S libva-intel-driver intel-media-driver vulkan-intel’
[2025-10-12T00:35:19+0200] [ALPM] running ‘00-timeshift-autosnap.hook’…
[2025-10-12T00:35:19+0200] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2025-10-12T00:35:19+0200] [ALPM] transaction started
[2025-10-12T00:35:19+0200] [ALPM] reinstalled libva-intel-driver (2.4.1-5)
[2025-10-12T00:35:19+0200] [ALPM] installed intel-gmmlib (22.8.1-1)
[2025-10-12T00:35:19+0200] [ALPM] installed intel-media-driver (25.2.6-1)
[2025-10-12T00:35:19+0200] [ALPM] reinstalled vulkan-intel (1:25.2.3-2)
[2025-10-12T00:35:19+0200] [ALPM] transaction completed
[2025-10-12T00:35:19+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-12T00:42:14+0200] [ALPM] transaction started
[2025-10-12T00:42:14+0200] [ALPM] installed libva-utils (2.22.0-1)
[2025-10-12T00:42:14+0200] [ALPM] transaction completed
[2025-10-12T00:42:14+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-12T00:54:36+0200] [ALPM] running ‘00-timeshift-autosnap.hook’…
[2025-10-12T00:54:36+0200] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2025-10-12T00:54:36+0200] [ALPM] transaction started
[2025-10-12T00:54:36+0200] [ALPM] reinstalled ca-certificates (20240618-1)
[2025-10-12T00:54:36+0200] [ALPM] reinstalled nss (3.116-1)
[2025-10-12T00:54:36+0200] [ALPM] transaction completed
[2025-10-12T00:54:36+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-12T01:01:30+0200] [ALPM] running ‘00-timeshift-autosnap.hook’…
[2025-10-12T01:01:30+0200] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2025-10-12T01:01:30+0200] [ALPM] transaction started
[2025-10-12T01:01:30+0200] [ALPM] reinstalled libva-intel-driver (2.4.1-5)
[2025-10-12T01:01:30+0200] [ALPM] reinstalled intel-media-driver (25.2.6-1)
[2025-10-12T01:01:30+0200] [ALPM] reinstalled gst-plugins-bad (1.26.6-1)
[2025-10-12T01:01:30+0200] [ALPM] reinstalled gst-plugins-ugly (1.26.6-1)
[2025-10-12T01:01:30+0200] [ALPM] reinstalled gst-libav (1.26.6-1)
[2025-10-12T01:01:30+0200] [ALPM] transaction completed
[2025-10-12T01:01:30+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-12T07:05:23+0200] [PAMAC] synchronizing package lists
[2025-10-12T13:06:23+0200] [PAMAC] synchronizing package lists
[2025-10-12T13:37:33+0200] [PACMAN] Running ‘pacman -R org.freedesktop.Platform’
[2025-10-12T13:37:55+0200] [PACMAN] Running ‘pacman -R org.freedesktop.Platform’
[2025-10-12T13:38:19+0200] [PACMAN] Running ‘pacman -R freedesktop-sdk-25.08.1’
[2025-10-12T13:38:32+0200] [PACMAN] Running ‘pacman -R freedesktop-sdk’
[2025-10-12T13:38:41+0200] [PACMAN] Running ‘pacman -R freedesktop’
[2025-10-12T13:49:04+0200] [PACMAN] Running ‘pacman -S hexchat’
[2025-10-12T13:49:10+0200] [ALPM] transaction started
[2025-10-12T13:49:10+0200] [ALPM] installed hexchat (2.16.2-5)
[2025-10-12T13:49:10+0200] [ALPM] transaction completed
[2025-10-12T13:49:10+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-12T13:49:10+0200] [ALPM] running ‘gtk-update-icon-cache.hook’…
[2025-10-12T13:49:11+0200] [ALPM] running ‘update-desktop-database.hook’…
[2025-10-12T15:12:37+0200] [ALPM] transaction started
[2025-10-12T15:12:38+0200] [ALPM] installed google-chrome (141.0.7390.76-1)
[2025-10-12T15:12:38+0200] [ALPM-SCRIPTLET] tput: No value for $TERM and no -T specified
[2025-10-12T15:12:38+0200] [ALPM-SCRIPTLET] ==> NOTE: Custom flags should be put directly in: ~/.config/chrome-flags.conf
[2025-10-12T15:12:38+0200] [ALPM-SCRIPTLET] ==> NOTE: The launcher is called: ‘google-chrome-stable’
[2025-10-12T15:12:39+0200] [ALPM] transaction completed
[2025-10-12T15:12:39+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-12T15:12:39+0200] [ALPM] running ‘gtk-update-icon-cache.hook’…
[2025-10-12T15:12:39+0200] [ALPM] running ‘update-desktop-database.hook’…
[2025-10-12T15:13:45+0200] [ALPM] running ‘00-timeshift-autosnap.hook’…
[2025-10-12T15:13:45+0200] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2025-10-12T15:13:45+0200] [ALPM] transaction started
[2025-10-12T15:13:46+0200] [ALPM] reinstalled google-chrome (141.0.7390.76-1)
[2025-10-12T15:13:47+0200] [ALPM] transaction completed
[2025-10-12T15:13:47+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-12T15:13:47+0200] [ALPM] running ‘gtk-update-icon-cache.hook’…
[2025-10-12T15:13:47+0200] [ALPM] running ‘update-desktop-database.hook’…
[2025-10-12T15:49:35+0200] [PACMAN] Running ‘pacman -S ffmpeg4.4’
[2025-10-12T15:49:50+0200] [ALPM] transaction started
[2025-10-12T15:49:50+0200] [ALPM] installed libmfx (23.2.2-5)
[2025-10-12T15:49:50+0200] [ALPM] installed ffmpeg4.4 (4.4.6-2)
[2025-10-12T15:49:50+0200] [ALPM] transaction completed
[2025-10-12T15:49:50+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-12T15:50:52+0200] [PACMAN] Running ‘pacman -S avisynthplus intel-media-sdk ladspa nvidia-utils’
[2025-10-12T15:52:17+0200] [ALPM] transaction started
[2025-10-12T15:52:17+0200] [ALPM] installed avisynthplus (3.7.5-2)
[2025-10-12T15:52:17+0200] [ALPM] installed eglexternalplatform (1.2.1-1)
[2025-10-12T15:52:17+0200] [ALPM] installed egl-wayland (4:1.1.20-1)
[2025-10-12T15:52:17+0200] [ALPM] installed egl-gbm (1.1.2.1-1)
[2025-10-12T15:52:17+0200] [ALPM] installed egl-x11 (1.0.3-1)
[2025-10-12T15:52:18+0200] [ALPM] installed nvidia-utils (580.82.09-1)
[2025-10-12T15:52:19+0200] [ALPM-SCRIPTLET] Created symlink ‘/etc/systemd/system/systemd-suspend.service.wants/nvidia-resume.service’ → ‘/usr/lib/systemd/system/nvidia-resume.service’.
[2025-10-12T15:52:19+0200] [ALPM-SCRIPTLET] Created symlink ‘/etc/systemd/system/systemd-hibernate.service.wants/nvidia-resume.service’ → ‘/usr/lib/systemd/system/nvidia-resume.service’.
[2025-10-12T15:52:19+0200] [ALPM-SCRIPTLET] Created symlink ‘/etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-resume.service’ → ‘/usr/lib/systemd/system/nvidia-resume.service’.
[2025-10-12T15:52:19+0200] [ALPM-SCRIPTLET] Created symlink ‘/etc/systemd/system/systemd-hibernate.service.wants/nvidia-hibernate.service’ → ‘/usr/lib/systemd/system/nvidia-hibernate.service’.
[2025-10-12T15:52:19+0200] [ALPM-SCRIPTLET] Created symlink ‘/etc/systemd/system/systemd-suspend.service.wants/nvidia-suspend.service’ → ‘/usr/lib/systemd/system/nvidia-suspend.service’.
[2025-10-12T15:52:19+0200] [ALPM] installed intel-media-sdk (23.2.2-5)
[2025-10-12T15:52:19+0200] [ALPM] installed ladspa (1.17-6)
[2025-10-12T15:52:19+0200] [ALPM] transaction completed
[2025-10-12T15:52:19+0200] [ALPM] running ‘20-systemd-sysusers.hook’…
[2025-10-12T15:52:20+0200] [ALPM-SCRIPTLET] Creating group ‘nvidia-persistenced’ with GID 143.
[2025-10-12T15:52:20+0200] [ALPM-SCRIPTLET] Creating user ‘nvidia-persistenced’ (NVIDIA Persistence Daemon) with UID 143 and GID 143.
[2025-10-12T15:52:20+0200] [ALPM] running ‘30-systemd-daemon-reload-system.hook’…
[2025-10-12T15:52:20+0200] [ALPM] running ‘30-systemd-udev-reload.hook’…
[2025-10-12T15:52:21+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-12T15:52:21+0200] [ALPM] running ‘30-update-mime-database.hook’…
[2025-10-12T15:52:22+0200] [ALPM] running ‘90-mkinitcpio-install.hook’…
[2025-10-12T15:52:22+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: ‘default’
[2025-10-12T15:52:22+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: ‘/etc/mkinitcpio.conf’
[2025-10-12T15:52:22+0200] [ALPM-SCRIPTLET]   → -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
[2025-10-12T15:52:22+0200] [ALPM-SCRIPTLET] ==> Starting build: ‘6.12.48-1-MANJARO’
[2025-10-12T15:52:22+0200] [ALPM-SCRIPTLET]   → Running build hook: [base]
[2025-10-12T15:52:22+0200] [ALPM-SCRIPTLET]   → Running build hook: [udev]
[2025-10-12T15:52:23+0200] [ALPM-SCRIPTLET]   → Running build hook: [autodetect]
[2025-10-12T15:52:23+0200] [ALPM-SCRIPTLET]   → Running build hook: [microcode]
[2025-10-12T15:52:23+0200] [ALPM-SCRIPTLET]   → Running build hook: [kms]
[2025-10-12T15:52:24+0200] [ALPM-SCRIPTLET]   → Running build hook: [modconf]
[2025-10-12T15:52:24+0200] [ALPM-SCRIPTLET]   → Running build hook: [block]
[2025-10-12T15:52:25+0200] [ALPM-SCRIPTLET]   → Running build hook: [keyboard]
[2025-10-12T15:52:25+0200] [ALPM-SCRIPTLET]   → Running build hook: [keymap]
[2025-10-12T15:52:25+0200] [ALPM-SCRIPTLET]   → Running build hook: [consolefont]
[2025-10-12T15:52:25+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-10-12T15:52:25+0200] [ALPM-SCRIPTLET]   → Running build hook: [plymouth]
[2025-10-12T15:52:27+0200] [ALPM-SCRIPTLET]   → Running build hook: [resume]
[2025-10-12T15:52:27+0200] [ALPM-SCRIPTLET]   → Running build hook: [filesystems]
[2025-10-12T15:52:27+0200] [ALPM-SCRIPTLET]   → Running build hook: [fsck]
[2025-10-12T15:52:27+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-10-12T15:52:27+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: ‘/boot/initramfs-6.12-x86_64.img’
[2025-10-12T15:52:27+0200] [ALPM-SCRIPTLET]   → Early uncompressed CPIO image generation successful
[2025-10-12T15:52:28+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-10-12T15:52:28+0200] [ALPM-SCRIPTLET] ==> Running post hooks
[2025-10-12T15:52:28+0200] [ALPM-SCRIPTLET]   → Running post hook: [sbctl]
[2025-10-12T15:52:28+0200] [ALPM-SCRIPTLET] Secureboot key directory doesn’t exist, not signing!
[2025-10-12T15:52:28+0200] [ALPM-SCRIPTLET] ==> Post processing done
[2025-10-12T15:52:28+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: ‘fallback’
[2025-10-12T15:52:28+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: ‘/etc/mkinitcpio.conf’
[2025-10-12T15:52:28+0200] [ALPM-SCRIPTLET]   → -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64-fallback.img -S autodetect
[2025-10-12T15:52:28+0200] [ALPM-SCRIPTLET] ==> Starting build: ‘6.12.48-1-MANJARO’
[2025-10-12T15:52:28+0200] [ALPM-SCRIPTLET]   → Running build hook: [base]
[2025-10-12T15:52:28+0200] [ALPM-SCRIPTLET]   → Running build hook: [udev]
[2025-10-12T15:52:29+0200] [ALPM-SCRIPTLET]   → Running build hook: [microcode]
[2025-10-12T15:52:29+0200] [ALPM-SCRIPTLET]   → Running build hook: [kms]
[2025-10-12T15:52:29+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘ast’
[2025-10-12T15:52:37+0200] [ALPM-SCRIPTLET]   → Running build hook: [modconf]
[2025-10-12T15:52:37+0200] [ALPM-SCRIPTLET]   → Running build hook: [block]
[2025-10-12T15:52:39+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘wd719x’
[2025-10-12T15:52:39+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘qed’
[2025-10-12T15:52:39+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘qla2xxx’
[2025-10-12T15:52:40+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘qla1280’
[2025-10-12T15:52:40+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘aic94xx’
[2025-10-12T15:52:40+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘bfa’
[2025-10-12T15:52:40+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘xhci_pci_renesas’
[2025-10-12T15:52:42+0200] [ALPM-SCRIPTLET]   → Running build hook: [keyboard]
[2025-10-12T15:52:43+0200] [ALPM-SCRIPTLET]   → Running build hook: [keymap]
[2025-10-12T15:52:43+0200] [ALPM-SCRIPTLET]   → Running build hook: [consolefont]
[2025-10-12T15:52:43+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-10-12T15:52:43+0200] [ALPM-SCRIPTLET]   → Running build hook: [plymouth]
[2025-10-12T15:52:45+0200] [ALPM-SCRIPTLET]   → Running build hook: [resume]
[2025-10-12T15:52:45+0200] [ALPM-SCRIPTLET]   → Running build hook: [filesystems]
[2025-10-12T15:52:47+0200] [ALPM-SCRIPTLET]   → Running build hook: [fsck]
[2025-10-12T15:52:49+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-10-12T15:52:50+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: ‘/boot/initramfs-6.12-x86_64-fallback.img’
[2025-10-12T15:52:51+0200] [ALPM-SCRIPTLET]   → Early uncompressed CPIO image generation successful
[2025-10-12T15:52:52+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-10-12T15:52:52+0200] [ALPM-SCRIPTLET] ==> Running post hooks
[2025-10-12T15:52:52+0200] [ALPM-SCRIPTLET]   → Running post hook: [sbctl]
[2025-10-12T15:52:52+0200] [ALPM-SCRIPTLET] Secureboot key directory doesn’t exist, not signing!
[2025-10-12T15:52:52+0200] [ALPM-SCRIPTLET] ==> Post processing done
[2025-10-12T15:52:52+0200] [ALPM] running ‘dbus-reload.hook’…
[2025-10-12T15:52:52+0200] [ALPM] running ‘gtk-update-icon-cache.hook’…
[2025-10-12T16:01:44+0200] [PACMAN] Running ‘pacman -S --overwrite * libmatroska libdvbpsi libupnp libtar libsoup aribb24’
[2025-10-12T16:01:52+0200] [ALPM] transaction started
[2025-10-12T16:01:52+0200] [ALPM] installed libebml (1.4.5-1)
[2025-10-12T16:01:52+0200] [ALPM] installed libmatroska (1.7.1-2)
[2025-10-12T16:01:52+0200] [ALPM] installed libdvbpsi (1:1.3.3-3)
[2025-10-12T16:01:52+0200] [ALPM] installed libupnp (1.14.24-1)
[2025-10-12T16:01:52+0200] [ALPM] installed libtar (1.2.20-7)
[2025-10-12T16:01:52+0200] [ALPM] installed libsoup (2.74.3-4)
[2025-10-12T16:01:52+0200] [ALPM] installed aribb24 (1.0.3-4)
[2025-10-12T16:01:52+0200] [ALPM] transaction completed
[2025-10-12T16:01:52+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-12T16:08:31+0200] [PACMAN] Running ‘pacman -S linux68’
[2025-10-12T16:08:44+0200] [PACMAN] Running ‘pacman -S linux611’
[2025-10-12T16:18:25+0200] [PACMAN] Running ‘pacman -S ffmpeg ffmpeg4.4 ffmpegthumbnailer gstreamer intel-media-driver intel-media-sdk kcodecs lib32-libva lib32-libva-intel-driver libva libva-intel-driver libva-utils linux-firmware-mediatek manjaro-gstreamer media-player-info perl-lwp-mediatypes qt6-multimedia qt6-multimedia-ffmpeg thunar-media-tags-plugin vivaldi-ffmpeg-codecs’
[2025-10-12T16:18:44+0200] [ALPM] running ‘00-timeshift-autosnap.hook’…
[2025-10-12T16:18:44+0200] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2025-10-12T16:18:44+0200] [ALPM] transaction started
[2025-10-12T16:18:44+0200] [ALPM] reinstalled libva (2.22.0-1)
[2025-10-12T16:18:44+0200] [ALPM] reinstalled ffmpeg (2:7.1.1-5)
[2025-10-12T16:18:44+0200] [ALPM] reinstalled ffmpeg4.4 (4.4.6-2)
[2025-10-12T16:18:44+0200] [ALPM] reinstalled ffmpegthumbnailer (2.2.3-3)
[2025-10-12T16:18:44+0200] [ALPM] reinstalled gstreamer (1.26.6-1)
[2025-10-12T16:18:44+0200] [ALPM] reinstalled intel-media-driver (25.2.6-1)
[2025-10-12T16:18:44+0200] [ALPM] reinstalled intel-media-sdk (23.2.2-5)
[2025-10-12T16:18:44+0200] [ALPM] reinstalled kcodecs (6.18.0-1)
[2025-10-12T16:18:44+0200] [ALPM] reinstalled lib32-libva (2.22.0-1)
[2025-10-12T16:18:44+0200] [ALPM] reinstalled lib32-libva-intel-driver (2.4.1-2)
[2025-10-12T16:18:44+0200] [ALPM] reinstalled libva-intel-driver (2.4.1-5)
[2025-10-12T16:18:44+0200] [ALPM] reinstalled libva-utils (2.22.0-1)
[2025-10-12T16:18:44+0200] [ALPM] reinstalled linux-firmware-mediatek (20250917-2)
[2025-10-12T16:18:44+0200] [ALPM] reinstalled manjaro-gstreamer (20221002-1)
[2025-10-12T16:18:44+0200] [ALPM] reinstalled media-player-info (26-1)
[2025-10-12T16:18:44+0200] [ALPM] reinstalled perl-lwp-mediatypes (6.04-7)
[2025-10-12T16:18:44+0200] [ALPM] reinstalled qt6-multimedia-ffmpeg (6.9.2-3)
[2025-10-12T16:18:44+0200] [ALPM] reinstalled qt6-multimedia (6.9.2-3)
[2025-10-12T16:18:44+0200] [ALPM] reinstalled thunar-media-tags-plugin (0.6.0-1)
[2025-10-12T16:18:44+0200] [ALPM] reinstalled vivaldi-ffmpeg-codecs (140.0.7339.136-2)
[2025-10-12T16:18:45+0200] [ALPM] transaction completed
[2025-10-12T16:18:45+0200] [ALPM] running ‘30-systemd-hwdb.hook’…
[2025-10-12T16:18:45+0200] [ALPM] running ‘30-systemd-udev-reload.hook’…
[2025-10-12T16:18:46+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-12T16:18:46+0200] [ALPM] running ‘90-mkinitcpio-install.hook’…
[2025-10-12T16:18:46+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: ‘default’
[2025-10-12T16:18:46+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: ‘/etc/mkinitcpio.conf’
[2025-10-12T16:18:46+0200] [ALPM-SCRIPTLET]   → -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
[2025-10-12T16:18:46+0200] [ALPM-SCRIPTLET] ==> Starting build: ‘6.12.48-1-MANJARO’
[2025-10-12T16:18:46+0200] [ALPM-SCRIPTLET]   → Running build hook: [base]
[2025-10-12T16:18:47+0200] [ALPM-SCRIPTLET]   → Running build hook: [udev]
[2025-10-12T16:18:47+0200] [ALPM-SCRIPTLET]   → Running build hook: [autodetect]
[2025-10-12T16:18:47+0200] [ALPM-SCRIPTLET]   → Running build hook: [microcode]
[2025-10-12T16:18:47+0200] [ALPM-SCRIPTLET]   → Running build hook: [kms]
[2025-10-12T16:18:48+0200] [ALPM-SCRIPTLET]   → Running build hook: [modconf]
[2025-10-12T16:18:48+0200] [ALPM-SCRIPTLET]   → Running build hook: [block]
[2025-10-12T16:18:48+0200] [ALPM-SCRIPTLET]   → Running build hook: [keyboard]
[2025-10-12T16:18:49+0200] [ALPM-SCRIPTLET]   → Running build hook: [keymap]
[2025-10-12T16:18:49+0200] [ALPM-SCRIPTLET]   → Running build hook: [consolefont]
[2025-10-12T16:18:49+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-10-12T16:18:49+0200] [ALPM-SCRIPTLET]   → Running build hook: [plymouth]
[2025-10-12T16:18:50+0200] [ALPM-SCRIPTLET]   → Running build hook: [resume]
[2025-10-12T16:18:50+0200] [ALPM-SCRIPTLET]   → Running build hook: [filesystems]
[2025-10-12T16:18:50+0200] [ALPM-SCRIPTLET]   → Running build hook: [fsck]
[2025-10-12T16:18:50+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-10-12T16:18:50+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: ‘/boot/initramfs-6.12-x86_64.img’
[2025-10-12T16:18:51+0200] [ALPM-SCRIPTLET]   → Early uncompressed CPIO image generation successful
[2025-10-12T16:18:51+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-10-12T16:18:51+0200] [ALPM-SCRIPTLET] ==> Running post hooks
[2025-10-12T16:18:51+0200] [ALPM-SCRIPTLET]   → Running post hook: [sbctl]
[2025-10-12T16:18:51+0200] [ALPM-SCRIPTLET] Secureboot key directory doesn’t exist, not signing!
[2025-10-12T16:18:51+0200] [ALPM-SCRIPTLET] ==> Post processing done
[2025-10-12T16:18:51+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: ‘fallback’
[2025-10-12T16:18:51+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: ‘/etc/mkinitcpio.conf’
[2025-10-12T16:18:51+0200] [ALPM-SCRIPTLET]   → -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64-fallback.img -S autodetect
[2025-10-12T16:18:51+0200] [ALPM-SCRIPTLET] ==> Starting build: ‘6.12.48-1-MANJARO’
[2025-10-12T16:18:51+0200] [ALPM-SCRIPTLET]   → Running build hook: [base]
[2025-10-12T16:18:52+0200] [ALPM-SCRIPTLET]   → Running build hook: [udev]
[2025-10-12T16:18:52+0200] [ALPM-SCRIPTLET]   → Running build hook: [microcode]
[2025-10-12T16:18:52+0200] [ALPM-SCRIPTLET]   → Running build hook: [kms]
[2025-10-12T16:18:53+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘ast’
[2025-10-12T16:19:00+0200] [ALPM-SCRIPTLET]   → Running build hook: [modconf]
[2025-10-12T16:19:00+0200] [ALPM-SCRIPTLET]   → Running build hook: [block]
[2025-10-12T16:19:01+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘wd719x’
[2025-10-12T16:19:01+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘qed’
[2025-10-12T16:19:01+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘qla2xxx’
[2025-10-12T16:19:01+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘qla1280’
[2025-10-12T16:19:01+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘aic94xx’
[2025-10-12T16:19:01+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘bfa’
[2025-10-12T16:19:01+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘xhci_pci_renesas’
[2025-10-12T16:19:03+0200] [ALPM-SCRIPTLET]   → Running build hook: [keyboard]
[2025-10-12T16:19:04+0200] [ALPM-SCRIPTLET]   → Running build hook: [keymap]
[2025-10-12T16:19:04+0200] [ALPM-SCRIPTLET]   → Running build hook: [consolefont]
[2025-10-12T16:19:04+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-10-12T16:19:04+0200] [ALPM-SCRIPTLET]   → Running build hook: [plymouth]
[2025-10-12T16:19:06+0200] [ALPM-SCRIPTLET]   → Running build hook: [resume]
[2025-10-12T16:19:06+0200] [ALPM-SCRIPTLET]   → Running build hook: [filesystems]
[2025-10-12T16:19:07+0200] [ALPM-SCRIPTLET]   → Running build hook: [fsck]
[2025-10-12T16:19:09+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-10-12T16:19:10+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: ‘/boot/initramfs-6.12-x86_64-fallback.img’
[2025-10-12T16:19:11+0200] [ALPM-SCRIPTLET]   → Early uncompressed CPIO image generation successful
[2025-10-12T16:19:12+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-10-12T16:19:12+0200] [ALPM-SCRIPTLET] ==> Running post hooks
[2025-10-12T16:19:12+0200] [ALPM-SCRIPTLET]   → Running post hook: [sbctl]
[2025-10-12T16:19:12+0200] [ALPM-SCRIPTLET] Secureboot key directory doesn’t exist, not signing!
[2025-10-12T16:19:12+0200] [ALPM-SCRIPTLET] ==> Post processing done
[2025-10-12T16:19:12+0200] [ALPM] running ‘detect-old-perl-modules.hook’…
[2025-10-12T16:22:27+0200] [PACMAN] Running ‘pacman -S ffmpeg ffmpeg4.4 ffmpegthumbnailer gstreamer intel-media-driver intel-media-sdk kcodecs lib32-libva lib32-libva-intel-driver libva libva-intel-driver libva-utils linux-firmware-mediatek manjaro-gstreamer media-player-info perl-lwp-mediatypes qt6-multimedia qt6-multimedia-ffmpeg thunar-media-tags-plugin vivaldi-ffmpeg-codecs’
[2025-10-12T16:22:31+0200] [ALPM] running ‘00-timeshift-autosnap.hook’…
[2025-10-12T16:22:31+0200] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2025-10-12T16:22:31+0200] [ALPM] transaction started
[2025-10-12T16:22:31+0200] [ALPM] reinstalled libva (2.22.0-1)
[2025-10-12T16:22:31+0200] [ALPM] reinstalled ffmpeg (2:7.1.1-5)
[2025-10-12T16:22:31+0200] [ALPM] reinstalled ffmpeg4.4 (4.4.6-2)
[2025-10-12T16:22:31+0200] [ALPM] reinstalled ffmpegthumbnailer (2.2.3-3)
[2025-10-12T16:22:32+0200] [ALPM] reinstalled gstreamer (1.26.6-1)
[2025-10-12T16:22:32+0200] [ALPM] reinstalled intel-media-driver (25.2.6-1)
[2025-10-12T16:22:32+0200] [ALPM] reinstalled intel-media-sdk (23.2.2-5)
[2025-10-12T16:22:32+0200] [ALPM] reinstalled kcodecs (6.18.0-1)
[2025-10-12T16:22:32+0200] [ALPM] reinstalled lib32-libva (2.22.0-1)
[2025-10-12T16:22:32+0200] [ALPM] reinstalled lib32-libva-intel-driver (2.4.1-2)
[2025-10-12T16:22:32+0200] [ALPM] reinstalled libva-intel-driver (2.4.1-5)
[2025-10-12T16:22:32+0200] [ALPM] reinstalled libva-utils (2.22.0-1)
[2025-10-12T16:22:32+0200] [ALPM] reinstalled linux-firmware-mediatek (20250917-2)
[2025-10-12T16:22:32+0200] [ALPM] reinstalled manjaro-gstreamer (20221002-1)
[2025-10-12T16:22:32+0200] [ALPM] reinstalled media-player-info (26-1)
[2025-10-12T16:22:32+0200] [ALPM] reinstalled perl-lwp-mediatypes (6.04-7)
[2025-10-12T16:22:32+0200] [ALPM] reinstalled qt6-multimedia-ffmpeg (6.9.2-3)
[2025-10-12T16:22:32+0200] [ALPM] reinstalled qt6-multimedia (6.9.2-3)
[2025-10-12T16:22:32+0200] [ALPM] reinstalled thunar-media-tags-plugin (0.6.0-1)
[2025-10-12T16:22:32+0200] [ALPM] reinstalled vivaldi-ffmpeg-codecs (140.0.7339.136-2)
[2025-10-12T16:22:32+0200] [ALPM] transaction completed
[2025-10-12T16:22:32+0200] [ALPM] running ‘30-systemd-hwdb.hook’…
[2025-10-12T16:22:33+0200] [ALPM] running ‘30-systemd-udev-reload.hook’…
[2025-10-12T16:22:34+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-12T16:22:34+0200] [ALPM] running ‘90-mkinitcpio-install.hook’…
[2025-10-12T16:22:34+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: ‘default’
[2025-10-12T16:22:34+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: ‘/etc/mkinitcpio.conf’
[2025-10-12T16:22:34+0200] [ALPM-SCRIPTLET]   → -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
[2025-10-12T16:22:34+0200] [ALPM-SCRIPTLET] ==> Starting build: ‘6.12.48-1-MANJARO’
[2025-10-12T16:22:34+0200] [ALPM-SCRIPTLET]   → Running build hook: [base]
[2025-10-12T16:22:34+0200] [ALPM-SCRIPTLET]   → Running build hook: [udev]
[2025-10-12T16:22:34+0200] [ALPM-SCRIPTLET]   → Running build hook: [autodetect]
[2025-10-12T16:22:34+0200] [ALPM-SCRIPTLET]   → Running build hook: [microcode]
[2025-10-12T16:22:34+0200] [ALPM-SCRIPTLET]   → Running build hook: [kms]
[2025-10-12T16:22:35+0200] [ALPM-SCRIPTLET]   → Running build hook: [modconf]
[2025-10-12T16:22:35+0200] [ALPM-SCRIPTLET]   → Running build hook: [block]
[2025-10-12T16:22:36+0200] [ALPM-SCRIPTLET]   → Running build hook: [keyboard]
[2025-10-12T16:22:36+0200] [ALPM-SCRIPTLET]   → Running build hook: [keymap]
[2025-10-12T16:22:36+0200] [ALPM-SCRIPTLET]   → Running build hook: [consolefont]
[2025-10-12T16:22:36+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-10-12T16:22:36+0200] [ALPM-SCRIPTLET]   → Running build hook: [plymouth]
[2025-10-12T16:22:37+0200] [ALPM-SCRIPTLET]   → Running build hook: [resume]
[2025-10-12T16:22:37+0200] [ALPM-SCRIPTLET]   → Running build hook: [filesystems]
[2025-10-12T16:22:37+0200] [ALPM-SCRIPTLET]   → Running build hook: [fsck]
[2025-10-12T16:22:37+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-10-12T16:22:37+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: ‘/boot/initramfs-6.12-x86_64.img’
[2025-10-12T16:22:38+0200] [ALPM-SCRIPTLET]   → Early uncompressed CPIO image generation successful
[2025-10-12T16:22:38+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-10-12T16:22:38+0200] [ALPM-SCRIPTLET] ==> Running post hooks
[2025-10-12T16:22:38+0200] [ALPM-SCRIPTLET]   → Running post hook: [sbctl]
[2025-10-12T16:22:38+0200] [ALPM-SCRIPTLET] Secureboot key directory doesn’t exist, not signing!
[2025-10-12T16:22:38+0200] [ALPM-SCRIPTLET] ==> Post processing done
[2025-10-12T16:22:38+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: ‘fallback’
[2025-10-12T16:22:38+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: ‘/etc/mkinitcpio.conf’
[2025-10-12T16:22:38+0200] [ALPM-SCRIPTLET]   → -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64-fallback.img -S autodetect
[2025-10-12T16:22:38+0200] [ALPM-SCRIPTLET] ==> Starting build: ‘6.12.48-1-MANJARO’
[2025-10-12T16:22:38+0200] [ALPM-SCRIPTLET]   → Running build hook: [base]
[2025-10-12T16:22:38+0200] [ALPM-SCRIPTLET]   → Running build hook: [udev]
[2025-10-12T16:22:39+0200] [ALPM-SCRIPTLET]   → Running build hook: [microcode]
[2025-10-12T16:22:39+0200] [ALPM-SCRIPTLET]   → Running build hook: [kms]
[2025-10-12T16:22:39+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘ast’
[2025-10-12T16:22:46+0200] [ALPM-SCRIPTLET]   → Running build hook: [modconf]
[2025-10-12T16:22:46+0200] [ALPM-SCRIPTLET]   → Running build hook: [block]
[2025-10-12T16:22:47+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘wd719x’
[2025-10-12T16:22:47+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘qed’
[2025-10-12T16:22:47+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘qla2xxx’
[2025-10-12T16:22:47+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘qla1280’
[2025-10-12T16:22:47+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘aic94xx’
[2025-10-12T16:22:47+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘bfa’
[2025-10-12T16:22:47+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: ‘xhci_pci_renesas’
[2025-10-12T16:22:49+0200] [ALPM-SCRIPTLET]   → Running build hook: [keyboard]
[2025-10-12T16:22:50+0200] [ALPM-SCRIPTLET]   → Running build hook: [keymap]
[2025-10-12T16:22:50+0200] [ALPM-SCRIPTLET]   → Running build hook: [consolefont]
[2025-10-12T16:22:50+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-10-12T16:22:50+0200] [ALPM-SCRIPTLET]   → Running build hook: [plymouth]
[2025-10-12T16:22:51+0200] [ALPM-SCRIPTLET]   → Running build hook: [resume]
[2025-10-12T16:22:51+0200] [ALPM-SCRIPTLET]   → Running build hook: [filesystems]
[2025-10-12T16:22:53+0200] [ALPM-SCRIPTLET]   → Running build hook: [fsck]
[2025-10-12T16:22:55+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-10-12T16:22:55+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: ‘/boot/initramfs-6.12-x86_64-fallback.img’
[2025-10-12T16:22:56+0200] [ALPM-SCRIPTLET]   → Early uncompressed CPIO image generation successful
[2025-10-12T16:22:57+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-10-12T16:22:57+0200] [ALPM-SCRIPTLET] ==> Running post hooks
[2025-10-12T16:22:57+0200] [ALPM-SCRIPTLET]   → Running post hook: [sbctl]
[2025-10-12T16:22:57+0200] [ALPM-SCRIPTLET] Secureboot key directory doesn’t exist, not signing!
[2025-10-12T16:22:57+0200] [ALPM-SCRIPTLET] ==> Post processing done
[2025-10-12T16:22:57+0200] [ALPM] running ‘detect-old-perl-modules.hook’…
[2025-10-12T19:51:00+0200] [PAMAC] synchronizing package lists
[2025-10-12T20:19:43+0200] [PACMAN] Running ‘pacman -Fy libonnxruntime.so’
[2025-10-12T20:19:43+0200] [PACMAN] synchronizing package lists
[2025-10-12T20:21:17+0200] [PACMAN] Running ‘pacman -S onnxruntime’
[2025-10-12T20:28:13+0200] [ALPM] transaction started
[2025-10-12T20:28:14+0200] [ALPM] installed boost (1.88.0-3)
[2025-10-12T20:28:14+0200] [ALPM] installed nsync (1.29.2-1)
[2025-10-12T20:28:14+0200] [ALPM] installed onednn (3.7.2-1)
[2025-10-12T20:28:14+0200] [ALPM] installed intel-oneapi-common (2024.1.0-1)
[2025-10-12T20:28:14+0200] [ALPM] installed intel-oneapi-tcm (1.2.0-3)
[2025-10-12T20:28:14+0200] [ALPM] installed intel-oneapi-tbb (2021.12.0-2)
[2025-10-12T20:28:14+0200] [ALPM] installed spdlog (1.15.3-1)
[2025-10-12T20:28:15+0200] [ALPM] installed level-zero-loader (1.24.2-1)
[2025-10-12T20:28:15+0200] [ALPM] installed intel-oneapi-openmp (2025.0.4-1)
[2025-10-12T20:28:18+0200] [ALPM] installed intel-oneapi-mkl (2025.0.1-3)
[2025-10-12T20:28:41+0200] [ALPM] installed onnxruntime (1.22.2-2)
[2025-10-12T20:28:43+0200] [ALPM] transaction completed
[2025-10-12T20:28:43+0200] [ALPM] running ‘30-systemd-update.hook’…
[2025-10-13T01:53:27+0200] [PAMAC] synchronizing package lists
[2025-10-13T07:55:21+0200] [PAMAC] synchronizing package lists
[2025-10-13T13:59:00+0200] [PAMAC] synchronizing package lists
[2025-10-13T15:05:53+0200] [PAMAC] synchronizing package lists
[2025-10-13T15:58:37+0200] [PACMAN] Running ‘pacman -Syu’
[2025-10-13T15:58:37+0200] [PACMAN] synchronizing package lists
[2025-10-13T15:58:40+0200] [PACMAN] starting full system upgrade
[2025-10-13T16:01:25+0200] [ALPM] running ‘00-timeshift-autosnap.hook’…
[2025-10-13T16:01:25+0200] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2025-10-13T16:01:25+0200] [ALPM] transaction started
[2025-10-13T16:01:25+0200] [ALPM] upgraded manjaro-release (25.0.9-1 → 25.0.10-1)
[2025-10-13T16:01:25+0200] [ALPM] transaction completed
[2025-10-13T16:01:35+0200] [PAMAC] synchronizing package lists
assistant edit: have reformatted your post
Just copy/paste the terminal output, highlight it or keep it highlighted, then use the </> symbol to format it like it is now.
or put three backticks before and after the whole output (```)
No need to paste each line individually - that is what it looks like what you did …
ok, thank you very much @nikgnomic , I changed the audio output profile (in graphic mode) and streaming is back now !!! woaw ! but I don’t know if I really could changed the parameters as you suggested? just to know if my problem could come back frequently…
here’s my inxi -Aa
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss type: oss-emulator tools: alsactl,alsamixer,amixer
Server-2: PipeWire v: 1.4.8 status: active with: 1: wireplumber status: active 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli,wpctl
with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
okayyyy thank you very much ! :smiling_face_with_three_hearts:
but now it seems that the problem is solved ^^
in fact, I spoke too fast :sweat_smile:
the problem is well due to a sound problem, but sometimes, one sound profile works with one source of sound (any video from any website) but it will not work with another source, where another profile is required. Very strange, for me.
do you know how I could “screen” the situation in command line?
edit: and now, whatever the profile, the video works with the internal sound of my laptop, but it doesn’t go into my bluetooth devices…
Ah, nevermind it then; I must have confused yours with another topic. Somehow I had thought it was a new installation. :wink:
