Been pulling my hair out for an hour or 2 each day trying to get this working again. I’m trying to get GPU passthrough working again on Manjaro with 2 identical 1080TI’s. I had this working previously but something borked my Manjaro install so I had to reinstall from scratch, now I can’t seem to get it going again. I haven’t made any hardware changes in between so I know UEFI is setup correctly.
Following the steps on the Arch Wiki, but jumping from step 3 to 6.1 because of the identical GPUs. IOMMU is working but the 2nd GPU to be passed through is not using the vfio-pci driver which it would be if it were being properly passed through. Not really sure what I’m missing.
Pretty much exactly this as per the Arch wiki (no links in posts?)
##### Passthrough selected GPU
In this case we manually specify the GPU to bind.
#!/bin/sh DEVS="0000:03:00.0 0000:03:00.1" if [ ! -z "$(ls -A /sys/class/iommu)" ]; then for DEV in $DEVS; do echo "vfio-pci" > /sys/bus/pci/devices/$DEV/driver_override done fi modprobe -i vfio-pci
#### Script installation
Edit `/etc/mkinitcpio.conf`:
1. Add `modconf` to the [HOOKS](https://wiki.archlinux.org/index.php/Mkinitcpio#HOOKS) array and `/usr/local/bin/vfio-pci-override.sh` to the [FILES](https://wiki.archlinux.org/index.php/Mkinitcpio#BINARIES_and_FILES) array.
Edit `/etc/modprobe.d/vfio.conf`:
1. Add the following line: `install vfio-pci /usr/local/bin/vfio-pci-override.sh`
2. [Regenerate the initramfs](https://wiki.archlinux.org/index.php/Regenerate_the_initramfs) and reboot.
This isn’t exactly what I did the first time. I can’t find the tutorial I originally used. I don’t recall using the script
please try to replace in your grub config or vfio.conf respectively devices ID from e.g. 10de:1f06 format to 0000:0e:00.0 and 0000:0e:00.1 where 0e:00.0 and 0e:00.1 stands for device group from lspci -nnk command. Regenerate the initramfs using command sudo mkinitcpio -p linuxXXX where XXX stands for kernel version (e.g. for 5.10 kernel it should be sudo mkinitcpio -p linux510) then reboot the system. Check if GPU uses vfio-pci driver.
Hey! I was at the same spot.
Assuming you have done everything else properly, I think I know the cause for this.
In /etc/modules-load.d/mhwd-gpu.conf you have to comment the lines “nvidia” and “nvidia-drm” (had to figure thiis out myself)
and then you have to blacklist nvidia drivers in /etc/modprob.d/mhwd-gpu.conf
Here, check this guide- www.tauceti.blog/post/linux-amd-x570-nvidia-gpu-pci-passthrough-2-prepare-linux/
