Very small scale, but the sharpest
Hello everyone, I’m having a problem that’s actually somewhat annoying to a certain extent.
It’s directly related to KDE Plasma, and when 6.2 arrived, the default Plasma scaling on my screen was always 100%. However, since this Plasma update, the scaling has remained at 100%, leaving the text really small and almost everything on the screen. Previously, it looked really comfortable and at a pleasant size, but now I’m really straining my eyes to see the letters and buttons, and it’s worse when I use software like Blender or GIMP, it remains really minimal.
The first solution was to increase the scaling, but the icons and some letters remain blurry so as not to use partitioning. It’s barely the system-recommended 250%, but some things still look blurry.
It’s probably best to inform KDE about this possible problem. It seems to be related to my video card. According to what I’ve searched on the Arch wiki, it also stems from Plasma itself.
Updated information about my system is in my profile.
screen #0:
  dimensions:    1920x1080 pixels (508x285 millimeters)
  resolution:    96x96 dots per inch
KDE Plasma Version: 6.3.3
KDE Frameworks Version: 6.11.0
Qt Version: 6.8.2
Kernel Version: 6.12.19-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 4 × Intel® Core™ i3-1005G1 CPU @ 1.20GHz
Memory: 11.5 GiB of RAM
Graphics Processor: Intel® UHD Graphics
Manufacturer: Acer
Product Name: Aspire A315-56
System Version: V1.27
:kangaroo:
As always, system information from *-fetch type apps is seldom actually useful, except maybe for someone wishing to buy your computer.
To be useful for support purposes it’s usually best to ask your system directly. Please provide the inxi output as described (below) which may be generally more useful for those wishing to help.
You might also use the forum Search as this issue has reared its ugly head many times before.
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Be prepared to provide more information and outputs from other commands whenever asked.
Ok, no problem hehe.
Here:
  Kernel: 6.6.83-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
    root=UUID=f1f05b4f-23fe-40dd-962e-4e1995a40766 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.11.0
  Type: Laptop System: Acer product: Aspire A315-56 v: V1.27
    serial: <superuser required>
  Mobo: IL model: Sleepy_IL v: V1.27 serial: <superuser required>
    part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.27
    date: 07/07/2022
  ID-1: BAT1 charge: 15.4 Wh (100.0%) condition: 15.4/41.6 Wh (37.1%)
    volts: 12.5 min: 11.2 model: LGC AP19B8K type: Li-ion serial: N/A
    status: full
  System RAM: total: 12 GiB available: 11.48 GiB used: 2.3 GiB (20.1%)
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
    speed: 2667 MT/s volts: curr: 1 min: 1.25 max: 1.35 width (bits): data: 64
    total: 64 manufacturer: Crucial part-no: CB8GS2666.C8PT serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 4 GiB
    speed: 2667 MT/s volts: curr: 1 min: 1.25 max: 2 width (bits): data: 64
    total: 64 manufacturer: Kingston part-no: N/A serial: N/A
  Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
    gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
    family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xC6
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB
    desc: 2x512 KiB L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 3400 min/max: 400/3400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 3400 2: 3400 3: 3400 4: 3400 bogomips: 9524
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
    avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm
    fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
    rdrand rdseed rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect
    ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
  Type: retbleed mitigation: Enhanced IBRS
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
    loop
  Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
    driver: i915 v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21
    ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a56
    class-ID: 0300
  Device-2: Quanta VGA WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3 chip-ID: 0408:a031
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: AU Optronics 0x61ed built: 2018 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red:
    x: 0.561 y: 0.337 green: x: 0.345 y: 0.576 blue: x: 0.161 y: 0.125 white:
    x: 0.314 y: 0.329 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (ICL GT1)
    device-ID: 8086:8a56 memory: 5.6 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.304 layers: 4 device: 0 type: integrated-gpu name: Intel
    UHD Graphics (ICL GT1) driver: N/A device-ID: 8086:8a56
    surfaces: xcb,xlib,wayland
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
    bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
  API: ALSA v: k6.6.83-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
  Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
  IF: wlp0s20f3 state: down mac: <filter>
    vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4
  Local Storage: total: 1.36 TiB used: 326.81 GiB (23.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: PNY model: CS1031 500GB SSD
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: CS103C00 temp: 27.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD10SPZX-21Z10T0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 1A02 scheme: GPT
  ID-1: / raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
    used: 38.45 GiB (8.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: f1f05b4f-23fe-40dd-962e-4e1995a40766
    used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: A2CA-D085
  ID-3: /home raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
  ID-4: /run/media/roobertjackjr/Disco raw-size: 466 GiB
    size: 931.5 GiB (199.89%) used: 272.85 GiB (29.3%) fs: exfat dev: /dev/sda1
    maj-min: 8:1 label: Disco uuid: 4413-F04C
  ID-5: /run/media/roobertjackjr/Steam raw-size: 465.51 GiB
    size: 457.13 GiB (98.20%) used: 15.5 GiB (3.4%) fs: ext4 dev: /dev/sda2
    maj-min: 8:2 label: Steam uuid: d1f299f6-113f-4587-a98c-9c1a2f45c032
  ID-6: /swap raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
  ID-7: /var/cache raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
  ID-8: /var/log raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
    file: /swap/swapfile
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-4:2 info: CX 2.4G Receiver type: keyboard,mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3554:fc03 class-ID: 0301
  Device-2: 1-7:3 info: Quanta VGA WebCam type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 0408:a031 class-ID: 0e02 serial: <filter>
  Device-3: 1-10:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  Src: lm-sensors+/sys Message: No sensor data found using /sys/class/hwmon
    or lm-sensors.
  Packages: pm: pacman pkgs: 1353 libs: 373 tools: pamac pm: flatpak pkgs: 0
    1: https://mirrors2.manjaro.org/stable/$repo/$arch
    2: https://manjaro.kurdy.org/stable/$repo/$arch
    3: https://linorg.usp.br/manjaro/stable/$repo/$arch
    4: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    5: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    6: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    7: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    8: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    9: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    10: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    11: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    12: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    13: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    14: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    15: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    16: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    17: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    18: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    19: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    20: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    21: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    22: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    23: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    24: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    25: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    26: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    27: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    28: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    29: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    30: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    31: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    32: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    33: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    34: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    35: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    36: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    37: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    38: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    39: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    40: https://mirror.init7.net/manjaro/stable/$repo/$arch
    41: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    42: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    43: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    44: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    45: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    46: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    47: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    48: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    49: http://manjaro.mirror.ac.za/stable/$repo/$arch
    50: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    51: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    52: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    53: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    54: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    55: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    56: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    57: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    58: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    59: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    60: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    61: https://manjaro.ynh.ovh/stable/$repo/$arch
    62: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    63: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    64: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    65: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    66: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    67: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    68: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    69: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    70: http://manjaro.grena.ge/stable/$repo/$arch
    71: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    72: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    73: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    74: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    75: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    76: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    77: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    78: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    79: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    80: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    81: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    82: https://mirror.23m.com/manjaro/stable/$repo/$arch
    83: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    84: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    85: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    86: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    87: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    88: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    89: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    90: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    91: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    92: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    93: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    94: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    95: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    96: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    97: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    98: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    99: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    100: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    101: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    102: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    103: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    104: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    105: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    106: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    107: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    108: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    109: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    110: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    111: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    112: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    113: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    114: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    115: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 247
  1: cpu: 4.0% command: vivaldi-bin pid: 1325 mem: 299.8 MiB (2.5%)
  2: cpu: 3.9% command: vivaldi-bin pid: 1250 mem: 389.7 MiB (3.3%)
  3: cpu: 2.9% command: vivaldi-bin pid: 1425 mem: 258.4 MiB (2.1%)
  4: cpu: 2.4% command: konsole pid: 1620 mem: 199.7 MiB (1.6%)
  5: cpu: 1.9% command: kwin_wayland pid: 723 mem: 189.8 MiB (1.6%)
  Memory top: 5 of 247
  1: mem: 389.7 MiB (3.3%) command: vivaldi-bin pid: 1250 cpu: 3.9%
  2: mem: 305.6 MiB (2.6%) command: plasmashell pid: 914 cpu: 1.4%
  3: mem: 299.8 MiB (2.5%) command: vivaldi-bin pid: 1325 cpu: 4.0%
  4: mem: 258.4 MiB (2.1%) command: vivaldi-bin pid: 1425 cpu: 2.9%
  5: mem: 199.7 MiB (1.6%) command: konsole pid: 1620 cpu: 2.4%
  Processes: 247 Power: uptime: 4m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 4.58 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.37
There are actually similar but not identical issues mentioned within the forum. I’ve searched, but they haven’t been resolved yet. The issue was sent directly to KDE Bugs.
They didn’t mention anything similar in the Updates category, and it’s part of the old one that’s now closed. I hadn’t really paid much attention to it at the time, so much so that I marked the option as working normally.
For the privacy of providing system data, I don’t really care much. That data can be useful.
Absolute online privacy simply means not having internet access.
:kangaroo:
Nonetheless, your privacy is protected using the commands given. :wink: Hardware serial numbers (for example) are not needed for Support purposes, so best practice is to filter them from the inxi output.
Privacy:- Those with privacy concerns, note that when -z, or --filter is used, all personally identifiable information is filtered out from the resulting inxi output. :eyes:
What you describe seems unusual. I know that many using screens the size of Canberra have experienced scaling issues on both X11 and Wayland (usually switching to Wayland seems to help, but you’re already there).
I’ve personally noticed no change is default scaling (using a typical 1920x1080 screen and Wayland). As it stands, I really have nothing to suggest.
We can best wait and see what others might contribute.
Thank you for your kindness. I’ll be on the lookout for anything.
:kangaroo:
