Very slow Shutdown
whenever I shutdown its taking about 20 to 40 min to shutdown.
System Info:
  Kernel: 5.4.105-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/vmlinuz-5.4-x86_64
  root=UUID=21db7367-8246-48de-b650-307bb1b32838 rw quiet apparmor=1
  Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A
  serial: <filter> Chassis: type: 9 serial: <filter>
  Mobo: Dell model: 0D53F5 v: A00 serial: <filter> UEFI-[Legacy]: Dell
  v: 2.14.0 date: 01/13/2021
  ID-1: BAT0 charge: 9.7 Wh (100.0%) condition: 9.7/41.4 Wh (23.4%)
  volts: 16.4 min: 14.8 model: SMP DELL VN3N047 type: Li-ion
  serial: <filter> status: Full
  Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP
  arch: Amber/Kaby Lake note: check family: 6 model-id: 8E (142)
  stepping: 9 microcode: DE cache: L2: 3 MiB
  bogomips: 21607
  Speed: 800 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 800 2: 801
  3: 800 4: 800
  Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes,
  SMT vulnerable
  Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
  Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 /
  Radeon 520 Mobile]
  vendor: Dell driver: radeon v: kernel alternate: amdgpu bus-ID: 01:00.0
  chip-ID: 1002:6660 class-ID: 0380
  Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
  bus-ID: 1-5:3 chip-ID: 0bda:5769 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
  loaded: ati,intel,radeon unloaded: modesetting alternate: fbdev,vesa
  display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
  s-diag: 414mm (16.3")
  Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102
  size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
  OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2)
  v: 4.6 Mesa 20.3.4 direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
  chip-ID: 8086:9d71 class-ID: 0403
  Sound Server-1: ALSA v: k5.4.105-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.23 running: no
  Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: e000
  bus-ID: 02:00.0 chip-ID: 8086:3165 class-ID: 0280
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
  driver: r8169 v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8136
  class-ID: 0200
  Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
  v: 0.8 bus-ID: 1-8:5 chip-ID: 8087:0a2a class-ID: e001
  Local Storage: total: 931.51 GiB used: 149.24 GiB (16.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
  size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
  speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: SDM3
  scheme: GPT
  ID-1: / raw-size: 120 GiB size: 117.56 GiB (97.97%)
  used: 9.46 GiB (8.1%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
  ID-2: /boot raw-size: 512 MiB size: 511 MiB (99.80%)
  used: 102.5 MiB (20.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 811.01 GiB size: 797.21 GiB (98.30%)
  used: 139.68 GiB (17.5%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
  System Temperatures: cpu: 49.0 C mobo: 48.0 C gpu: radeon temp: 45.0 C
  Fan Speeds (RPM): cpu: 0
  Processes: 166 Uptime: 25m wakeups: 1 Memory: 7.55 GiB
  used: 1.44 GiB (19.0%) Init: systemd v: 247 tool: systemctl Compilers:
  gcc: 10.2.0 Packages: pacman: 1268 lib: 354 flatpak: 0 Shell: Bash
  v: 5.1.0 running-in: konsole inxi: 3.3.03``````
recheck all option in your UEFI ( for linux)
SecureBoot off
Fast Boot off
No CSM
No Legacy
all disks on AHCI
No Optane/rst
but in UEFI with secure boot off manjaro is not installing, after the installation completion I rebooted but system is booting into live session. and the boot order has no problem Internal HDD is the first in boot order and the live session is on the second. In legacy mode with secure boot off manjaro is installing just fine.But my system is laggy and the shutdown problem.
