Very slow shut down
Hi Manjaro,
when I shut down my 2in1 lenovo x390, I see the manjaro logo with the three dots pulsing for a long time. Then just before power off I see watchdog: watchdog0: did not stop.
I tried “nowatchdog” on kernel boot line, but no result ….
System:Kernel: 6.18.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1clocksource: tsc avail: acpi_pm parameters: BOOT_IMAGE=/vmlinuz-6.18-x86_64root=UUID=f9b1e170-4180-422d-9fde-3ed1dc55e2b1 rw quietcryptdevice=UUID=a621da8d-7e97-4684-a588-eeb873d7b749:luks-a621da8d-7e97-4684-a588-eeb873d7b749root=/dev/mapper/luks-a621da8d-7e97-4684-a588-eeb873d7b749 splashudev.log_priority=3 nowatchdogDesktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A wm: kwin_wayland with: krunnerdm: SDDM Distro: Manjaro base: Arch LinuxMachine:Type: Convertible System: LENOVO product: 20NQS0W600 v: ThinkPad X390 Yogaserial:  Chassis: type: 31 serial: Mobo: LENOVO model: 20NQS0W600 v: SDK0J40697 WIN serial: part-nu: LENOVO_MT_20NQ_BU_Think_FM_ThinkPad X390 Yogauuid: ded7dbcc-2c48-11b2-a85c-9a6db42bbb2a Firmware: UEFI vendor: LENOVOv: N2LET74W (1.74 ) date: 03/24/2020Battery:ID-1: BAT0 charge: 45.7 Wh (88.9%) condition: 51.5/50.5 Wh (101.9%)power: 5.8 W volts: 11.89 min: 11.55 model: LGC 5B10W13927 type: Li-polyserial:  charging: status: discharging control: start: 0%end: 100% cycles: 488Memory:System RAM: total: 8 GiB available: 7.41 GiB used: 4.38 GiB (59.1%)igpu: 32 MiBArray-1: capacity: 32 GiB slots: 2 modules: 2 EC: Nonemax-module-size: 16 GiB note: est.Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 4 GiB speed:spec: 2667 MT/s actual: 2400 MT/s volts: curr: 1.2 width (bits): data: 64total: 64 manufacturer: Micron part-no: 4ATF51264HZ-2G6E1 serial: N/ADevice-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 4 GiB speed:spec: 2667 MT/s actual: 2400 MT/s volts: curr: 1.2 width (bits): data: 64total: 64 manufacturer: Micron part-no: 4ATF51264HZ-2G6E1 serial: N/APCI Slots:Slot: N/A type: N/A status: available length: other bus-ID: 00ff:ff:1f.7CPU:Info: model: Intel Core i5-8365U socket: BGA1528 (U3E1) note: check bits: 64type: MT MCP arch: Comet/Whiskey Lake note: check gen: core 8 level: v3note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)stepping: 0xC (12) microcode: 0x100Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiBdesc: 4x256 KiB L3: 6 MiB desc: 1x6 MiBSpeed (MHz): avg: 800 min/max: 400/4100 base/boost: 1600/1900 scaling:driver: intel_pstate governor: powersave volts: 1.1 V ext-clock: 100 MHzcores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800bogomips: 30399Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic aratarch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflushclflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwphwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_ptinvpcid lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrrnonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge plnpni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep sgx smapsmep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsctsc_adjust tsc_deadline_timer vme x2apic xgetbv1 xsave xsavec xsaveoptxsaves xtopology xtprVulnerabilities:Type: gather_data_sampling mitigation: MicrocodeType: ghostwrite status: Not affectedType: indirect_target_selection mitigation: Aligned branch/return thunksType: itlb_multihit status: KVM: VMX unsupportedType: l1tf status: Not affectedType: mds status: Not affectedType: meltdown status: Not affectedType: mmio_stale_data mitigation: Clear CPU buffers; SMT vulnerableType: old_microcode status: Not affectedType: reg_file_data_sampling status: Not affectedType: retbleed mitigation: Enhanced IBRSType: spec_rstack_overflow status: Not affectedType: spec_store_bypass mitigation: Speculative Store Bypass disabled viaprctlType: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointersanitizationType: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB:conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loopType: srbds mitigation: MicrocodeType: tsa status: Not affectedType: tsx_async_abort mitigation: TSX disabledType: vmscape mitigation: IBPB before exit to userspaceGraphics:Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovodriver: i915 v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0chip-ID: 8086:3ea0 class-ID: 0300Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 04f2:b67cclass-ID: 0e02 serial: Display: unspecified server: X.Org v: 24.1.9 with: Xwayland v: 24.1.9compositor: kwin_wayland driver: X: loaded: intel dri: i965 gpu: i915display-ID: :1 screens: 1Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22")s-diag: 582mm (22.93")Monitor-1: eDP-1 model: ChiMei InnoLux 0x1387 built: 2018 res:mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 166 gamma: 1.2 chroma: red:x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white:x: 0.314 y: 0.329 size: 293x165mm (11.54x6.5") diag: 336mm (13.2")ratio: 16:9 modes: 1920x1080API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: irisdevice: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: irisinactive: waylandAPI: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.1-arch1.2glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (WHLGT2) device-ID: 8086:3ea0 memory: 7.24 GiB unified: yesAPI: Vulkan v: 1.4.328 layers: 2 device: 0 type: integrated-gpu name: IntelUHD Graphics 620 (WHL GT2) driver: mesa intel v: 25.3.1-arch1.2device-ID: 8086:3ea0 surfaces: N/AInfo: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfode: kscreen-console,kscreen-doctor wl: wayland-infox11: xdpyinfo, xprop, xrandrAudio:Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovodriver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnlbus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403API: ALSA v: k6.18.1-1-MANJARO status: kernel-api with: aosstype: oss-emulator tools: alsactl,alsamixer,amixerServer-1: sndiod v: N/A status: off tools: aucat,midicat,sndioctlServer-2: JACK v: 1.9.22 status: off tools: N/AServer-3: PipeWire v: 1.4.9 status: n/a (root, process) with:1: pipewire-pulse status: active 2: wireplumber status: active3: pipewire-alsa type: plugin tools: pactl,pw-cat,pw-cli,wpctlNetwork:Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernelbus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280IF: wlp0s20f3 state: up mac: IP v4:  type: dynamic noprefixroute scope: globalbroadcast: IP v6:  type: dynamic noprefixroute scope: globalIP v6:  type: noprefixroute scope: linkDevice-2: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernelport: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bd class-ID: 0200IF: enp0s31f6 state: down mac: IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/AIP v4:  scope: global broadcast: Info: services: NetworkManager, systemd-timesyncd, wpa_supplicantWAN IP: Bluetooth:Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusbv: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5chip-ID: 8087:0aaa class-ID: e001Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: enabled,runningrfk-block: hardware: no software: yes address: see --recommendsLogical:Message: No logical block device data found.Device-1: luks-a621da8d-7e97-4684-a588-eeb873d7b749 maj-min: 253:0type: LUKS dm: dm-0 size: 62.5 GiBComponents:p-1: nvme0n1p7 maj-min: 259:7 size: 62.5 GiBRAID:Message: No RAID data found.Drives:Local Storage: total: 238.47 GiB used: 17.12 GiB (7.2%)SMART Message: Required tool smartctl not installed. Check --recommendsID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsungmodel: MZVLB256HBHQ-000L7 size: 238.47 GiB block-size: physical: 512 Blogical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial: fw-rev: 4M2QEXH7 temp: 32.9 C scheme: GPTMessage: No optical or floppy data found.Partition:ID-1: / raw-size: 62.5 GiB size: 61.22 GiB (97.95%) used: 17.02 GiB (27.8%)fs: ext4 block-size: 4096 B dev: /dev/dm-0 maj-min: 253:0mapped: luks-a621da8d-7e97-4684-a588-eeb873d7b749 label: linux rootuuid: f9b1e170-4180-422d-9fde-3ed1dc55e2b1ID-2: /boot raw-size: 1024 MiB size: 973.4 MiB (95.06%)used: 104 MiB (10.7%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p6maj-min: 259:6 label: linux bootuuid: 3396fedb-3bda-431a-a439-80438fb6d4bbID-3: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)used: 328 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p5maj-min: 259:5 label: efi system uuid: 0164-1470Swap:Alert: No swap data was found.Unmounted:ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 200 MiB fs: vfat label: ESPuuid: B618-C398ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/Auuid: N/AID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 1.95 GiB fs: ntfslabel: Recovery uuid: 7638193C3818FD35ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 31.25 GiB fs: ntfs label: SYSTEMuuid: 6EEA1B5BEA1B1F41USB:Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d6b:0002class-ID: 0900Device-1: 1-6:2 info: Wacom Pen and multitouch sensor type: HIDdriver: usbhid,wacom interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)lanes: 1 mode: 1.1 power: 400mA chip-ID: 056a:51b2 class-ID: 0300Device-2: 1-8:3 info: Chicony Integrated Camera type: videodriver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b67c class-ID: 0e02serial: Device-3: 1-9:24 info: Synaptics Prometheus MIS Touch Fingerprint Readertype:  driver: N/A interfaces: 1 rev: 2.0speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mAchip-ID: 06cb:00bd class-ID: ff00 serial: Device-4: 1-10:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)type: bluetooth driver: btusb interfaces: 2 rev: 2.0speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mAchip-ID: 8087:0aaa class-ID: e001Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 1d6b:0003class-ID: 0900Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d6b:0002class-ID: 0900Hub-4: 4-0:1 info: super-speed hub ports: 2 rev: 3.1speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 1d6b:0003class-ID: 0900Sensors:System Temperatures: cpu: 41.0 C pch: 42.0 C mobo: 31.0 CFan Speeds (rpm): cpu: 1927Repos:Packages: 1226 pm: pacman pkgs: 1219 libs: 331 tools: pamac pm: flatpakpkgs: 7Active pacman repo servers in: /etc/pacman.d/mirrorlist1: https://mirrors.cicku.me/manjaro/stable/$repo/$arch2: https://mirrors2.manjaro.org/stable/$repo/$arch3: https://mirrors.manjaro.org/repo/stable/$repo/$archProcesses:CPU top: 5 of 2781: cpu: 14.3% command: firefox pid: 103325 mem: 564.9 MiB (7.4%)2: cpu: 9.5% command: firefox pid: 103523 mem: 288.2 MiB (3.7%)3: cpu: 3.0% command: firefox pid: 103689 mem: 297.4 MiB (3.9%)4: cpu: 1.8% command: firefox pid: 103585 mem: 157.1 MiB (2.0%)5: cpu: 1.6% command: audiotube pid: 60978 mem: 464.7 MiB (6.1%)Memory top: 5 of 2781: mem: 614.3 MiB (8.0%) command: krunner pid: 7303 cpu: 0.0%2: mem: 564.9 MiB (7.4%) command: firefox pid: 103325 cpu: 14.3%3: mem: 494.0 MiB (6.5%) command: plasmashell pid: 1056 cpu: 0.6%4: mem: 464.7 MiB (6.1%) command: audiotube pid: 60978 cpu: 1.6%5: mem: 368.6 MiB (4.8%) command: elisa pid: 60029 cpu: 0.6%Info:Processes: 278 Power: uptime: 3d 1h 6m states: freeze,mem,disk suspend: deepavail: s2idle wakeups: 18 hibernate: platform avail: shutdown, reboot,suspend, test_resume image: 2.95 GiB services: org_kde_powerdevil,power-profiles-daemon, upowerd Init: systemd v: 258 default: graphicaltool: systemctlCompilers: gcc: 15.2.1 Shell: Bash (su) v: 5.3.8 running-in: konsoleinxi: 3.3.40
Ideas?
Thxxxxx! :slight_smile:
Hi @rednose,
I also have that and never thought about it until now. Please see
https://unix.stackexchange.com/a/249660
This is normal. I see 3 of them as last messages. I actually tried to disable them but i guess i missed one somewhere.
For a home machine that is not a remote unattended server they do not matter at all. So you can ignore the warnings.
Hi thx for the answers. I need to say more I guess. I “assumed” the issue is related to the watchdog, as it is the last message I see before power off. But the issue I’m trying to solve is the looooong shutdown time. I see the manjaro graphic logo with the pulsating dot for at least two minutes, then the short text line about the watchdog, then finally power off.
If I run systemd-analyze blame I’ve a line:
5min 18ms archlinux-keyring-wkd-sync.service
Does it help?
The watchdog is not the cause of it. It actually happens after the problem. By default, the timeout for unsesponsive service is 90 second, so you have something busy on shutdown that is killed after timeout. The timeout can of course be reduced, but it is better to fix the problem.
You can do 2 things.
  1. go to /etc/default/grub and edit the boot line removing “quiet” and “splash”. Save, sudo update-grub. You will now see the boot and shutdown process in realtime and see the exact service that hangs. It will be red, with moving asterisk and “a stop job is running for XXXXX” with count in seconds up to 90.
  2. maybe you can find some error message in the journal
journalctl -b -1 -r
Will reverse sort the last boot so the error might be in the first screens.
P.s. i correctect the title
Thx for the title.
I tried using the x390 as I normally do in the last couple of days (e.g. as a tablet) and tried reboot/shutdown a couple fo times. Currently setting is as suggested (e.g. noquiet and nosplash). At the moment the problem is not appearing, start up and shutdown are not stuck …
I’ll keep it as-is for now. Not as nice as the graphic manjaro logo, but hey most of the time the x390 is in suspend mode … :slight_smile:
If I see the issue again, I’ll reply here. Thx!!! and happy new year!
Hi Manjaro,
now the problem is found: I see a message like “a stop job is running for fingerprint deamon” and a counter starting from 1min30sec
If I run the suggested jounrnalctl -b -1 -r, I see a line: “fprintd.service killing process with signal SIGKILL
Do you have a fingerprint reader to use? If you do, do you need it at login?
Hi yes there is a fingerprint on the x390. As it is used as a tablet, hence the finger sensor is “on the other side” when flipped up, I resolved to remove the fprintd package. I’ll login/unlock using the password …
Thx und Guten Rutsch!
