Very slow after waking up pc from suspend mode. Balooo_file_extractor taking 90%+ ram
I did read those older posts but none had this baloo being slow after waking up error. And it's not a one-time thing, it happens every time I wake computer after leaving it untouched for half an hour or so.
As you can see, baloo thingy is taking 90%+ ram. and even if I kill this service, computer still stays totally unusable and had to log out to make this post.
Here is my inxi -Fxxxz output.
System:    Host: evilspark-pe627rd Kernel: 5.6.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: KDE Plasma 5.18.4
           tk: Qt 5.14.2 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: Micro-Star product: PE62 7RD v: REV:1.0 serial: <filter> Chassis: type: 10 serial: <filter>
           Mobo: Micro-Star model: MS-16J9 v: REV:1.0 serial: <filter> UEFI: American Megatrends v: E16J9IMS.320
           date: 02/08/2018
Battery:   ID-1: BAT1 charge: 36.9 Wh condition: 36.9/42.4 Wh (87%) volts: 12.3/10.8 model: MSI BIF0_9 type: Li-ion
           serial: N/A status: Full
CPU:       Topology: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake rev: 9 L2 cache: 6144 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44817
           Speed: 3479 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 3477 2: 3433 3: 3453 4: 3492 5: 3563 6: 3442 7: 3469
           8: 3568
Graphics:  Device-1: Intel HD Graphics 630 vendor: Micro-Star MSI driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:591b
           Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Micro-Star MSI driver: nvidia v: 440.82 bus ID: 01:00.0
           chip ID: 10de:1c8d
           Display: x11 server: X.Org 1.20.8 driver: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
           compositor: kwin_x11 tty: N/A
           OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 20.0.5 direct render: Yes
Audio:     Device-1: Intel CM238 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           chip ID: 8086:a171
           Sound Server: ALSA v: k5.6.7-1-MANJARO
Network:   Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel port: e000 bus ID: 02:00.0
           chip ID: 8086:24fb
           Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: Micro-Star MSI driver: alx v: kernel port: d000
           bus ID: 03:00.0 chip ID: 1969:10a1
Drives:    Local Storage: total: 931.51 GiB used: 93.74 GiB (10.1%)
           ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS721010A9E630 size: 931.51 GiB speed: 6.0 Gb/s rotation: 7200 rpm
           serial: <filter> rev: A3U0 scheme: GPT
Partition: ID-1: / size: 191.25 GiB used: 20.79 GiB (10.9%) fs: ext4 dev: /dev/sda2
           ID-2: /home size: 690.96 GiB used: 58.43 GiB (8.5%) fs: ext4 dev: /dev/sda4
           ID-3: swap-1 size: 31.25 GiB used: 14.53 GiB (46.5%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 92.0 C mobo: 27.8 C
Info:      Processes: 307 Uptime: 5h 56m Memory: 15.56 GiB used: 14.82 GiB (95.3%) Init: systemd v: 244 Compilers: gcc: 9.3.0
           clang: 10.0.0 Shell: zsh v: 5.8 running in: yakuake inxi: 3.0.37
My power settings are default.
Output of inxi -Fxxxz after logging out
           date: 02/08/2018
           Speed: 1600 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 1600 2: 1600 3: 1600 4: 1600 5: 1600 6: 1600 7: 1600
           8: 1600
           chip ID: 10de:1c8d
           chip ID: 8086:a171
           chip ID: 8086:24fb
Drives:    Local Storage: total: 931.51 GiB used: 79.31 GiB (8.5%)
Partition: ID-1: / size: 191.25 GiB used: 20.77 GiB (10.9%) fs: ext4 dev: /dev/sda2
           ID-3: swap-1 size: 31.25 GiB used: 111.5 MiB (0.3%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 62.0 C mobo: 27.8 C
Info:      Processes: 291 Uptime: 6h 21m Memory: 15.56 GiB used: 2.91 GiB (18.7%) Init: systemd v: 244 Compilers: gcc: 9.3.0
Hi,
I'm a kde user, but I don't use baloo, to avoid some problem like your actual problem.
I hope it will be helpful, first to know the statu, second point to disable baloo, and last reboot your device
(lifebook-wu2) $ balooctl status
Baloo is currently disabled. To enable, please run balooctl enable (on my computer)
lifebook-wu2) $ balooctl disable
Disabling the File Indexer, then reboot and launch balooctl status
Look in the kde system settings, disable some option, see below
balooctl disable
I was hoping for the solution which don't require disabling baloo. But found none. So I totally disabled it.
Here's the guide on how to totally disable it.
How To Completely Disable Baloo.
Disable baloo in System Settings -> Search -> Uncheck Enable File Search
Then issue these commands:
balooctl stop
balooctl suspend
balooctl disable
edit the following file:
~/.config/baloofilerc
Add these lines:
[Basic Settings]
Indexing-Enabled=false
Remove all unneeded baloo index files if they weren’t deleted automatically when baloo was disabled.
They are stored at:
 ~/.local/share/baloo/
From the ArchWiki:
Removing baloo_file
Baloo_file uses a lot of resources and slows down computers. It also increases power consumption on laptops. While it cannot be removed due to dependencies issues, it is however possible to deactivate it until the next update. As root, type:
killall baloo_file ; mv /usr/bin/baloo_file /usr/bin/baloo_file.bak ; echo '#!/bin/sh' > /usr/bin/baloo_file
Add this line to a pacman hook file, to disable baloo after every update so it is not automatically re-enabled.
The baloo file search feature has been much improved in KDE. However, it is still not my favorite search engine and I would rather have it permanently disabled. According to the ArchWiki baloo cant be uninstalled, and it may be automatically re-enabled during a system upgrade.
I have written a pacman hook to automatically disable baloo again after every system upgrade.
Here is the pacman hook:
/usr/share/libalpm/hooks/disable-baloo.hook
[Trigger]
Type = Package
Operation = Upgrade
Target = /usr/bin/baloo_file
[Action]
Description = Disable baloo file indexer after every upgrade operation
When = PostTransaction
Exec = /bin/sh -c 'killall baloo_file ; mv /usr/bin/baloo_file /usr/bin/baloo_file.bak ; echo '#!/bin/sh' > /usr/bin/baloo_file'
Install the recoll search engine (or any other suitable alternative) in place of baloo once baloo is fully disabled.
I've marked the below answer as the solution to your question as it is by far the best answer you'll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (I just want to avoid even more subjective opinions being posted and confusing you even more)
:innocent:
P.S. In the future, please mark a solution like this:
Solution
so that the next person that has the exact same problem you just had will benefit from your post as well.
P.P.S. I've also removed "Solved" from the title after doing that as our forum software works just a bit more efficient than most of them out there!
Thanks for the help. My first time here so was not much clear on how everything works.
