I really have very long boot time and it seems getting longer and longer, maybe someone can assist me about this. I tried to seek solutions over the past forum questions but nothing help.
systemd-analyze
Startup finished in 3.065s (firmware) + 11.556s (loader) + 20.103s
(kernel) + 37.838s (userspace) = 1min 12.564s
graphical.target reached after 37.320s in userspace
systemd-analyze blame
14min 32.691s pkgfile-update.service
7min 7.868s updatedb.service
53.090s man-db.service
17.614s systemd-journal-flush.service
13.296s lvm2-monitor.service
12.424s dev-sda2.device
10.265s dev-loop6.device
7.706s polkit.service
7.558s snapd.service
5.896s systemd-rfkill.service
5.150s avahi-daemon.service
5.150s bluetooth.service
4.976s systemd-logind.service
4.301s systemd-udevd.service
2.969s ModemManager.service
2.852s ldconfig.service
2.372s NetworkManager.service
2.144s systemd-tmpfiles-setup-dev.service
2.015s systemd-sysusers.service
2.014s apparmor.service
2.012s dev-disk-by\x2duuid-012b2228\x2dda15\x2d4a81\x2d861d\x2df61455e3e0d2.swap
1.883s logrotate.service
1.794s var-lib-snapd-snap-core18-1988.mount
1.722s var-lib-snapd-snap-core18-1997.mount
1.584s systemd-tmpfiles-clean.service
1.535s systemd-fsck@dev-disk-by\x2duuid-75A5\x2d8B67.service
1.510s udisks2.service
1.423s var-lib-snapd-snap-flutter-62.mount
1.099s systemd-modules-load.service
908ms user@1000.service
906ms dev-loop5.device
906ms NetworkManager-wait-online.service
875ms snapd.apparmor.service
588ms systemd-random-seed.service
556ms systemd-journal-catalog-update.service
537ms wpa_supplicant.service
520ms systemd-tmpfiles-setup.service
514ms tlp.service
454ms systemd-timesyncd.service
453ms dev-hugepages.mount
451ms dev-mqueue.mount
449ms sys-kernel-debug.mount
447ms sys-kernel-tracing.mount
447ms modprobe@drm.service
446ms lm_sensors.service
431ms kmod-static-nodes.service
428ms modprobe@configfs.service
425ms modprobe@fuse.service
inxi -Fazy
Kernel: 5.4.105-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=8d3c71fe-2d9a-4aa7-9fd0-0de4dae0023e rw quiet acpi_backlight=none
apparmor=1 security=apparmor
resume=UUID=012b2228-da15-4a81-861d-f61455e3e0d2 udev.log_priority=3
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Hewlett-Packard product: HP EliteBook 8470p
v: A1029D1102 serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Hewlett-Packard model: 179B v: KBC Version 42.38 serial: <filter>
UEFI: Hewlett-Packard v: 68ICF Ver. F.74 date: 04/11/2019
Info: Dual Core model: Intel Core i5-3320M bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L2: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20760
Speed: 1197 MHz min/max: 1200/3300 MHz Core speeds (MHz): 1: 1197 2: 1198
3: 1197 4: 1196
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: AMD Thames [Radeon HD 7550M/7570M/7650M] vendor: Hewlett-Packard
driver: radeon v: kernel bus-ID: 01:00.0 chip-ID: 1002:6841 class-ID: 0300
Device-2: Primax HP HD Webcam [Fixed] type: USB driver: uvcvideo
bus-ID: 1-1.3:4 chip-ID: 0461:4dfe class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4")
s-diag: 485mm (19.1")
Monitor-1: LVDS res: 1600x900 hz: 60 dpi: 131 size: 310x174mm (12.2x6.9")
diag: 355mm (14")
OpenGL: renderer: AMD TURKS (DRM 2.50.0 / 5.4.105-1-MANJARO LLVM 11.1.0)
v: 3.3 Mesa 20.3.4 compat-v: 3.1 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1e20 class-ID: 0403
Device-2: AMD Turks HDMI Audio [Radeon HD 6500/6600 / 6700M Series]
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aa90 class-ID: 0403
Sound Server-1: ALSA v: k5.4.105-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: no
Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: 3.8.7-NAPI port: 5020 bus-ID: 00:19.0 chip-ID: 8086:1502
class-ID: 0200
IF: eth0 state: down mac: <filter>
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
v: kernel port: 4000 bus-ID: 25:00.0 chip-ID: 8086:0085 class-ID: 0280
Device-1: Broadcom HP Portable SoftSailing type: USB driver: btusb v: 0.8
bus-ID: 3-1.6:3 chip-ID: 0a5c:21e1 class-ID: fe01 serial: <filter>
Local Storage: total: 298.09 GiB used: 65.28 GiB (21.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD3200LPVX-22V0TT0 size: 298.09 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1A01
scheme: GPT
ID-1: / raw-size: 289.49 GiB size: 283.94 GiB (98.09%)
used: 64.92 GiB (22.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 8.31 GiB used: 363.4 MiB (4.3%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 58.0 C mobo: 53.0 C gpu: radeon temp: 53.5 C
Processes: 198 Uptime: 7h 40m wakeups: 1 Memory: 3.78 GiB
used: 1.21 GiB (32.1%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 clang: 11.1.0 Packages: 1529 pacman: 1519 lib: 431 flatpak: 6
snap: 4 Shell: Bash v: 5.1.0 running-in: konsole inxi: 3.3.03
Any Commands I needed to do so, will do it right away.
