Hi, today i switched to a amd vega 56 from an rtx 2060, installed the drivers, and removed the nvidia ones of course. Everything is smoother now than with the 2060 and im finally not experiencing any framedrops while using the system.
BUT: I am using three Monitors , 2 dp, 1 hdmi. The two dp ones are working but the third one is just glitching, that meens it shows up in the settings for a few seconds, then removes itself for a few seconds and so on…
Here is what i tried:
booting several distros in live and installed version on a second partition:
distro | working in live? | working when installed? |
win 10 | N/A | y |
Manjaro gnome (kernel 5.10) | n | n |
Manjaro KDE (current system)(5.10) | n | n |
Ubuntu 21.04 | n | N/A |
Ubuntu 20.04 (5.4) | y | y |
Ubuntu 20.10 (5.8) | y | n |
Suse tumbleweed (5.12) | N/A | n |
Fedora 34 (5.11) | n | n |
After realising only sucess was with a older kernel, i tried different kernels on my main system (manjaro kde 5.10
I tried everything avaible through mhwd from 5.4 upwards:
- 5.4 working, but my motherboards ethernet controller not supported (same on ubuntu 20.04)
- 5.9_rt working
- everything above not working, even tried 5.13_rc1
Is there a possibility to install a 5.9 kernel non rt? don’t really wanna use the “slower”/“throttled” rt version?
inxi:
Kernel: 5.9.1-1-rt19-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.9-rt-x86_64
root=UUID=fa9a4af6-777a-4e52-8768-207cc178c510 rw rootflags=subvol=@ quiet
udev.log_priority=3
resume=/dev/disk/by-uuid/fa9a4af6-777a-4e52-8768-207cc178c510
resume_offset=2102528 nvidia-drm.modeset=1 nmi_watchdog=0 nowatchdog
video.use_native_backlight=1
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Desktop Mobo: ASRock model: B550M Steel Legend serial: <filter>
UEFI: American Megatrends v: P1.80 date: 12/01/2020
RAM: total: 15.56 GiB used: 3.43 GiB (22.0%)
Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L2: 3 MiB bogomips: 86276
Speed: 3725 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 3725 2: 2059 3: 3590 4: 2226 5: 4134 6: 2062 7: 3592 8: 2072 9: 3598
10: 2055 11: 3648 12: 2078
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sha_ni skinit
smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm
svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
conditional, RSB filling
Device-1: AMD Vega 10 XL/XT [Radeon RX Vega 56/64] vendor: ASUSTeK
driver: amdgpu v: kernel bus-ID: 0b:00.0 chip-ID: 1002:687f class-ID: 0300
Device-2: Microdia Webcam Vitade AF type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-2.4.3:11 chip-ID: 0c45:6366 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 8560x1440 s-dpi: 96 s-size: 2264x381mm (89.1x15.0")
s-diag: 2296mm (90.4")
Monitor-1: DisplayPort-0 res: 3440x1440 dpi: 109
size: 800x335mm (31.5x13.2") diag: 867mm (34.1")
Monitor-2: DisplayPort-1 res: 2560x1440 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
Monitor-3: HDMI-A-0 res: 2560x1440 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
OpenGL:
renderer: Radeon RX Vega (VEGA10 DRM 3.39.0 5.9.1-1-rt19-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.3 direct render: Yes
Device-1: AMD Vega 10 HDMI Audio [Radeon Vega 56/64] driver: snd_hda_intel
v: kernel bus-ID: 0b:00.1 chip-ID: 1002:aaf8 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Realtek USB-C to 3.5mm-Headphone Adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2.3:7 chip-ID: 0bda:4995
class-ID: 0300 serial: <filter>
Device-4: Microdia Webcam Vitade AF type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.9.1-1-rt19-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.27 running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus-ID: 04:00.0
chip-ID: 8086:2526 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
port: f000 bus-ID: 07:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-1ca7876678b8 state: down mac: <filter>
IF-ID-2: br-1ec52863ec7e state: down mac: <filter>
IF-ID-3: br-34c85e09d7d3 state: down mac: <filter>
IF-ID-4: br-70e5dcbc1f1f state: down mac: <filter>
IF-ID-5: br-9664a204375e state: down mac: <filter>
IF-ID-6: br-b7e7c344ce1f state: down mac: <filter>
IF-ID-7: br-ec5122f745d8 state: down mac: <filter>
IF-ID-8: docker0 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-7.3:6 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 1.02 TiB used: 232.21 GiB (22.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte model: GP-AG41TB
lanes: 4 rotation: SSD serial: <filter> rev: EGFM11.3 temp: 44.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Patriot model: N/A
size: 115.5 GiB block-size: physical: 512 B logical: 512 B serial: <filter>
rev: PMAP scheme: MBR
ID-1: / raw-size: 273.44 GiB size: 273.44 GiB (100.00%)
used: 169.26 GiB (61.9%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: fa9a4af6-777a-4e52-8768-207cc178c510
ID-2: /.snapshots raw-size: 273.44 GiB size: 273.44 GiB (100.00%)
ID-3: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%)
used: 47.9 MiB (50.4%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: E470-B875
ID-4: /btrfs raw-size: 273.44 GiB size: 273.44 GiB (100.00%)
ID-5: /home raw-size: 273.44 GiB size: 273.44 GiB (100.00%)
ID-6: /home/.snapshots raw-size: 273.44 GiB size: 273.44 GiB (100.00%)
ID-7: /home/<filter>/Nextcloud raw-size: 273.44 GiB
size: 273.44 GiB (100.00%) used: 169.26 GiB (61.9%) fs: btrfs
dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
ID-8: /run/media/jonathan/USB Jona raw-size: 115.47 GiB
size: 115.46 GiB (100.00%) used: 62.9 GiB (54.5%) fs: exfat dev: /dev/sda1
maj-min: 8:1 label: USB Jona uuid: 35C2-A9F1
ID-9: /var raw-size: 273.44 GiB size: 273.44 GiB (100.00%)
Kernel: swappiness: 10 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: partition size: 19.53 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: bfde55a7-bedf-486b-9eae-20a35d5b3f1f
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: vfat label: N/A
uuid: 7860-556E
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 534.57 GiB fs: ntfs label: N/A
uuid: 8CDC712ADC711026
ID-4: /dev/nvme0n1p7 maj-min: 259:7 size: 103.34 GiB fs: ext4 label: N/A
uuid: c8d5cf64-f653-46e5-b5da-548e1585d5d3
ID-5: /dev/sda2 maj-min: 8:2 size: 32 MiB fs: vfat label: VTOYEFI
uuid: C644-48F2
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-2.2:4 info: Yubicom Yubikey 4/5 OTP+U2F+CCID
type: Keyboard,HID,Smart Card driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 30mA chip-ID: 1050:0407 class-ID: 0b00
Device-2: 1-2.3:7 info: Realtek USB-C to 3.5mm-Headphone Adapter
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0bda:4995 class-ID: 0300
serial: <filter>
Hub-3: 1-2.4:8 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 500mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-2.4.1:9 info: Holtek USB Gaming Mouse type: Mouse,Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 04d9:a259 class-ID: 0300
Device-2: 1-2.4.2:10 info: Apple Aluminium Keyboard (ISO)
type: Keyboard,Mouse driver: apple,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 05ac:0250 class-ID: 0301
Device-3: 1-2.4.3:11 info: Microdia Webcam Vitade AF type: Video,Audio
power: 500mA chip-ID: 0c45:6366 class-ID: 0102 serial: <filter>
Hub-4: 1-2.4.4:12 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Hub-5: 1-7:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-7.3:6 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Device-2: 1-8:5 info: ASRock LED Controller type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 26ce:01a2 class-ID: 0300 serial: <filter>
Hub-6: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-7: 2-2:2 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
Device-1: 2-2.1:3 info: Kingston Patriot Memory type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s power: 896mA
chip-ID: 13fe:6000 class-ID: 0806 serial: <filter>
Hub-8: 2-2.4:4 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
Hub-9: 2-2.4.4:5 info: Genesys Logic USB3.0 Hub ports: 4 rev: 3.0
speed: 5 Gb/s chip-ID: 05e3:0620 class-ID: 0900
Device-1: 2-2.4.4.4:6 info: Norelsys NS1081 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 8mA
chip-ID: 2537:1081 class-ID: 0806 serial: <filter>
Hub-10: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-11: 3-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 174c:2074 class-ID: 0900
Hub-12: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-13: 4-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s power: 8mA chip-ID: 174c:3074 class-ID: 0900
System Temperatures: cpu: 50.1 C mobo: 42.0 C gpu: amdgpu temp: 52.0 C
mem: 53.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 543 fan-3: 1532 fan-4: 352 fan-5: 0
fan-6: 0 fan-7: 248 gpu: amdgpu fan: 1256
Processes: 483 Uptime: 29m wakeups: 0 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 Packages: 1647 pacman: 1637 lib: 360 flatpak: 10
Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.04
xrandr:
Screen 0: minimum 320 x 200, current 8560 x 1440, maximum 16384 x 16384
DisplayPort-0 connected primary 3440x1440+2560+0 (normal left inverted right x axis y axis) 800mm x 335mm
3440x1440 143.92 + 75.05*+ 120.00 99.98
2560x1440 120.00 59.95
1720x1440 59.98
2048x1152 60.00
1920x1200 59.88
1920x1080 120.00 119.88 119.98 60.00 60.00 50.00 59.94
1600x1200 60.00
1680x1050 59.95
1600x900 60.00
1280x1024 75.02 60.02
1440x900 143.92
1280x800 59.81
1152x864 75.00
1280x720 60.00 59.94
1024x768 75.03 70.07 60.00
832x624 74.55
800x600 72.19 75.00 60.32 56.25
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
DisplayPort-1 connected 2560x1440+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 59.95 + 74.97*
1920x1200 59.95
1920x1080 74.97 60.00 50.00 59.94
1600x1200 59.95
1280x1440 59.91
1680x1050 59.95
1440x900 59.89
1280x960 60.00
1280x800 59.95
1280x720 60.00 50.00 59.94
832x624 74.55
720x576 50.00
720x480 60.00 59.94
720x400 70.08
HDMI-A-0 connected 2560x1440+6000+0 (normal left inverted right x axis y axis) 597mm x 336mm
1920x1200 59.95
1600x1200 59.95
1280x1440 59.91
1680x1050 59.88
1440x900 59.90
1280x960 60.00
1280x800 59.95
832x624 74.55
720x576 50.00
720x480 60.00 59.94
720x400 70.08
HDMI-A-1 disconnected (normal left inverted right x axis y axis)
DVI-D-0 disconnected (normal left inverted right x axis y axis)
Also there seems to be a bug in the kernel from 5.10 upwards?
Because it happens on the other distros as well
