Vega 64 installation problems
drivers
amdgpu
#21
Still no other resolutions available
#22
please post this info again, along with:
#23
[nikolai@nikolai-pc ~]$ ls -la /etc/modprobe.d/
totalt 24
drwxr-xr-x   2 root root  4096 11 feb 16:23 .
drwxr-xr-x 108 root root 12288 11 feb 16:27 ..
-rw-r--r--   1 root root    16  5 dec 17:43 r8169_blacklist.conf
[nikolai@nikolai-pc ~]$ cat /etc/modprobe.d/*
blacklist r8169
[nikolai@nikolai-pc ~]$ cat /etc/modules-load.d/*
## Generated by mhwd - Manjaro Hardware Detection
# List of modules to load at boot
[nikolai@nikolai-pc ~]$ cat /etc/default/grub | grep CMDLINE
GRUB_CMDLINE_LINUX_DEFAULT="quiet resume=UUID=530508f6-bdf1-428d-b870-5076881180a2"
GRUB_CMDLINE_LINUX=""
#24
1st rule on troubleshooting:
Check the logs!
cat /var/log/Xorg.0.log
#25
This is what it spits out
[     4.861] (--) Log file renamed from "/var/log/Xorg.pid-717.log" to "/var/log/Xorg.0.log"
[     4.862]
X.Org X Server 1.20.3
[     4.862] Build Operating System: Linux Arch Linux
[     4.862] Current Operating System: Linux nikolai-pc 4.20.7-1-MANJARO #1 SMP PREEMPT Wed Feb 6 21:54:48 UTC 2019 x86_64
[     4.862] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.20-x86_64 root=UUID=8668ba97-9d50-49eb-a7c5-86924aff5ff3 rw quiet resume=UUID=530508f6-bdf1-428d-b870-5076881180a2
[     4.862] Build Date: 25 October 2018  04:42:32PM
[     4.862]
[     4.862] Current version of pixman: 0.36.0
[     4.862]    Before reporting problems, check http://wiki.x.org
[     4.862] Markers: (--) probed, (**) from config file, (==) default setting,
[     4.863] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Feb 11 16:27:33 2019
[     4.863] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     4.863] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     4.864] (==) No Layout section.  Using the first Screen section.
[     4.864] (==) No screen section available. Using defaults.
[     4.864] (**) |-->Screen "Default Screen Section" (0)
[     4.864] (**) |   |-->Monitor "<default monitor>"
[     4.865] (==) No monitor specified for screen "Default Screen Section".
[     4.865] (==) Automatically adding devices
[     4.865] (==) Automatically enabling devices
[     4.865] (==) Automatically adding GPU devices
[     4.865] (==) Automatically binding GPU devices
[     4.865] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     4.866] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     4.866]    Entry deleted from font path.
[     4.866] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     4.867] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[     4.867]    Entry deleted from font path.
[     4.867]    (Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[     4.867] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[     4.867]    (Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[     4.867] (==) FontPath set to:
        /usr/share/fonts/misc,
        /usr/share/fonts/TTF
[     4.867] (==) ModulePath set to "/usr/lib/xorg/modules"
[     4.867] (II) The server relies on udev to provide the list of input devices.
[     4.867] (II) Module ABI versions:
[     4.867]    X.Org ANSI C Emulation: 0.4
[     4.867]    X.Org Video Driver: 24.0
[     4.867]    X.Org XInput driver : 24.1
[     4.867]    X.Org Server Extension : 10.0
[     4.867] (++) using VT number 1
[     4.867] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     4.868] (II) xfree86: Adding drm device (/dev/dri/card0)
[     4.882] (--) PCI:*(30@0:0:0) 1002:687f:1da2:e37f rev 193, Mem @ 0xe0000000/268435456, 0xf0000000/2097152, 0xfe500000/524288, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[     4.882] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     4.882] (II) LoadModule: "glx"
[     4.884] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     4.892] (II) Module glx: vendor="X.Org Foundation"
[     4.892]    compiled for 1.20.3, module version = 1.0.0
[     4.892]    ABI class: X.Org Server Extension, version 10.0
[     4.892] (II) Applying OutputClass "AMDgpu" to /dev/dri/card0
[     4.892]    loading driver: amdgpu
[     4.892] (==) Matched amdgpu as autoconfigured driver 0
[     4.892] (==) Matched ati as autoconfigured driver 1
[     4.892] (==) Matched modesetting as autoconfigured driver 2
[     4.892] (==) Matched fbdev as autoconfigured driver 3
[     4.892] (==) Matched vesa as autoconfigured driver 4
[     4.892] (==) Assigned the driver to the xf86ConfigLayout
[     4.892] (II) LoadModule: "amdgpu"
[     4.894] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[     4.896] (II) Module amdgpu: vendor="X.Org Foundation"
[     4.896]    compiled for 1.20.1, module version = 18.1.0
[     4.896]    Module class: X.Org Video Driver
[     4.896]    ABI class: X.Org Video Driver, version 24.0
[     4.896] (II) LoadModule: "ati"
[     4.896] (WW) Warning, couldn't open module ati
[     4.896] (EE) Failed to load module "ati" (module does not exist, 0)
[     4.896] (II) LoadModule: "modesetting"
[     4.896] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     4.896] (II) Module modesetting: vendor="X.Org Foundation"
[     4.896]    compiled for 1.20.3, module version = 1.20.3
[     4.896] (II) LoadModule: "fbdev"
[     4.897] (WW) Warning, couldn't open module fbdev
[     4.897] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     4.897] (II) LoadModule: "vesa"
[     4.897] (WW) Warning, couldn't open module vesa
[     4.897] (EE) Failed to load module "vesa" (module does not exist, 0)
[     4.897] (II) AMDGPU: Driver for AMD Radeon:
        All GPUs supported by the amdgpu kernel driver
[     4.897] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     4.897] (II) AMDGPU(0): [KMS] Kernel modesetting enabled.
[     4.913] (WW) Falling back to old probe method for modesetting
[     4.913] (II) AMDGPU(0): Creating default Display subsection in Screen section
        "Default Screen Section" for depth/fbbpp 24/32
[     4.913] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[     4.913] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[     4.913] (==) AMDGPU(0): Default visual is TrueColor
[     4.913] (==) AMDGPU(0): RGB weight 888
[     4.913] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[     4.913] (--) AMDGPU(0): Chipset: "Radeon RX Vega" (ChipID = 0x687f)
[     4.913] (II) Loading sub module "fb"
[     4.913] (II) LoadModule: "fb"
[     4.913] (II) Loading /usr/lib/xorg/modules/libfb.so
[     4.913] (II) Module fb: vendor="X.Org Foundation"
[     4.913]    compiled for 1.20.3, module version = 1.0.0
[     4.913]    ABI class: X.Org ANSI C Emulation, version 0.4
[     4.913] (II) Loading sub module "dri2"
[     4.913] (II) LoadModule: "dri2"
[     4.913] (II) Module "dri2" already built-in
[     5.062] (II) Loading sub module "glamoregl"
[     5.062] (II) LoadModule: "glamoregl"
[     5.062] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[     5.067] (II) Module glamoregl: vendor="X.Org Foundation"
[     5.067]    compiled for 1.20.3, module version = 1.0.1
[     5.067]    ABI class: X.Org ANSI C Emulation, version 0.4
[     5.083] (II) AMDGPU(0): glamor X acceleration enabled on Radeon RX Vega (VEGA10, DRM 3.27.0, 4.20.7-1-MANJARO, LLVM 7.0.1)
[     5.083] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[     5.083] (==) AMDGPU(0): TearFree property default: auto
[     5.083] (II) AMDGPU(0): KMS Pageflipping: enabled
[     5.083] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[     5.083] (II) AMDGPU(0): Output DisplayPort-1 has no monitor section
[     5.083] (II) AMDGPU(0): Output HDMI-A-0 has no monitor section
[     5.083] (II) AMDGPU(0): Output HDMI-A-1 has no monitor section
[     5.096] (II) AMDGPU(0): EDID for output DisplayPort-0
[     5.096] (II) AMDGPU(0): EDID for output DisplayPort-1
[     5.096] (II) AMDGPU(0): Printing probed modes for output DisplayPort-1
[     5.096] (II) AMDGPU(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     5.096] (II) AMDGPU(0): EDID for output HDMI-A-0
[     5.096] (II) AMDGPU(0): EDID for output HDMI-A-1
[     5.096] (II) AMDGPU(0): Output DisplayPort-0 disconnected
[     5.096] (II) AMDGPU(0): Output DisplayPort-1 connected
[     5.096] (II) AMDGPU(0): Output HDMI-A-0 disconnected
[     5.096] (II) AMDGPU(0): Output HDMI-A-1 disconnected
[     5.096] (II) AMDGPU(0): Using exact sizes for initial modes
[     5.096] (II) AMDGPU(0): Output DisplayPort-1 using initial mode 640x480 +0+0
[     5.096] (II) AMDGPU(0): mem size init: gart size :1fe761000 vram size: s:1fddea000 visible:edea000
[     5.096] (==) AMDGPU(0): DPI set to (96, 96)
[     5.096] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[     5.096] (II) Loading sub module "ramdac"
[     5.096] (II) LoadModule: "ramdac"
[     5.096] (II) Module "ramdac" already built-in
[     5.096] (II) UnloadModule: "modesetting"
[     5.096] (II) Unloading modesetting
[     5.096] (II) AMDGPU(0): [DRI2] Setup complete
[     5.096] (II) AMDGPU(0): [DRI2]   DRI driver: radeonsi
[     5.096] (II) AMDGPU(0): [DRI2]   VDPAU driver: radeonsi
[     5.096] (II) AMDGPU(0): Front buffer pitch: 2560 bytes
[     5.097] (II) AMDGPU(0): SYNC extension fences enabled
[     5.097] (II) AMDGPU(0): Present extension enabled
[     5.097] (==) AMDGPU(0): DRI3 enabled
[     5.097] (==) AMDGPU(0): Backing store enabled
[     5.097] (II) AMDGPU(0): Direct rendering enabled
[     5.102] (II) AMDGPU(0): Use GLAMOR acceleration.
[     5.102] (II) AMDGPU(0): Acceleration enabled
[     5.102] (==) AMDGPU(0): DPMS enabled
[     5.102] (==) AMDGPU(0): Silken mouse disabled
[     5.102] (II) AMDGPU(0): Set up textured video (glamor)
[     5.113] (II) Initializing extension Generic Event Extension
[     5.113] (II) Initializing extension SHAPE
[     5.113] (II) Initializing extension MIT-SHM
[     5.113] (II) Initializing extension XInputExtension
[     5.113] (II) Initializing extension XTEST
[     5.113] (II) Initializing extension BIG-REQUESTS
[     5.113] (II) Initializing extension SYNC
[     5.113] (II) Initializing extension XKEYBOARD
[     5.114] (II) Initializing extension XC-MISC
[     5.114] (II) Initializing extension SECURITY
[     5.114] (II) Initializing extension XFIXES
[     5.114] (II) Initializing extension RENDER
[     5.114] (II) Initializing extension RANDR
[     5.114] (II) Initializing extension COMPOSITE
[     5.114] (II) Initializing extension DAMAGE
[     5.114] (II) Initializing extension MIT-SCREEN-SAVER
[     5.114] (II) Initializing extension DOUBLE-BUFFER
[     5.114] (II) Initializing extension RECORD
[     5.114] (II) Initializing extension DPMS
[     5.114] (II) Initializing extension Present
[     5.114] (II) Initializing extension DRI3
[     5.114] (II) Initializing extension X-Resource
[     5.114] (II) Initializing extension XVideo
[     5.114] (II) Initializing extension XVideo-MotionCompensation
[     5.114] (II) Initializing extension GLX
[     5.117] (II) AIGLX: Loaded and initialized radeonsi
[     5.117] (II) GLX: Initialized DRI2 GL provider for screen 0
[     5.117] (II) Initializing extension XFree86-VidModeExtension
[     5.117] (II) Initializing extension XFree86-DGA
[     5.118] (II) Initializing extension XFree86-DRI
[     5.118] (II) Initializing extension DRI2
[     5.120] (II) AMDGPU(0): Setting screen physical size to 169 x 127
[     5.178] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     5.178] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     5.178] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     5.178] (**) Power Button: Applying InputClass "system-keyboard"
[     5.178] (II) LoadModule: "libinput"
[     5.178] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     5.181] (II) Module libinput: vendor="X.Org Foundation"
[     5.181]    compiled for 1.20.1, module version = 0.28.1
[     5.181]    Module class: X.Org XInput Driver
[     5.181]    ABI class: X.Org XInput driver, version 24.1
[     5.181] (II) Using input driver 'libinput' for 'Power Button'
[     5.181] (**) Power Button: always reports core events
[     5.181] (**) Option "Device" "/dev/input/event1"
[     5.181] (**) Option "_source" "server/udev"
[     5.187] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     5.187] (II) event1  - Power Button: device is a keyboard
[     5.187] (II) event1  - Power Button: device removed
[     5.213] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[     5.213] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     5.213] (**) Option "xkb_model" "pc105"
[     5.213] (**) Option "xkb_layout" "dk"
[     5.213] (**) Option "xkb_variant" "winkeys"
[     5.228] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     5.228] (II) event1  - Power Button: device is a keyboard
[     5.228] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[     5.228] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     5.228] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     5.228] (**) Power Button: Applying InputClass "system-keyboard"
[     5.228] (II) Using input driver 'libinput' for 'Power Button'
[     5.228] (**) Power Button: always reports core events
[     5.228] (**) Option "Device" "/dev/input/event0"
[     5.228] (**) Option "_source" "server/udev"
[     5.229] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     5.229] (II) event0  - Power Button: device is a keyboard
[     5.229] (II) event0  - Power Button: device removed
[     5.243] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[     5.243] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[     5.243] (**) Option "xkb_model" "pc105"
[     5.243] (**) Option "xkb_layout" "dk"
[     5.243] (**) Option "xkb_variant" "winkeys"
[     5.244] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     5.244] (II) event0  - Power Button: device is a keyboard
[     5.244] (II) config/udev: Adding input device Cosair Corsair VOID PRO Surround USB Adapter Consumer Control (/dev/input/event2)
[     5.244] (**) Cosair Corsair VOID PRO Surround USB Adapter Consumer Control: Applying InputClass "evdev keyboard catchall"
[     5.244] (**) Cosair Corsair VOID PRO Surround USB Adapter Consumer Control: Applying InputClass "libinput keyboard catchall"
[     5.244] (**) Cosair Corsair VOID PRO Surround USB Adapter Consumer Control: Applying InputClass "system-keyboard"
[     5.244] (II) Using input driver 'libinput' for 'Cosair Corsair VOID PRO Surround USB Adapter Consumer Control'
[     5.245] (**) Cosair Corsair VOID PRO Surround USB Adapter Consumer Control: always reports core events
[     5.245] (**) Option "Device" "/dev/input/event2"
[     5.245] (**) Option "_source" "server/udev"
[     5.246] (II) event2  - Cosair Corsair VOID PRO Surround USB Adapter Consumer Control: is tagged by udev as: Keyboard
[     5.246] (II) event2  - Cosair Corsair VOID PRO Surround USB Adapter Consumer Control: device is a keyboard
[     5.246] (II) event2  - Cosair Corsair VOID PRO Surround USB Adapter Consumer Control: device removed
[     5.306] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-1/1-1:1.3/0003:1B1C:0A18.0003/input/input2/event2"
[     5.306] (II) XINPUT: Adding extended input device "Cosair Corsair VOID PRO Surround USB Adapter Consumer Control" (type: KEYBOARD, id 8)
[     5.306] (**) Option "xkb_model" "pc105"
[     5.306] (**) Option "xkb_layout" "dk"
[     5.306] (**) Option "xkb_variant" "winkeys"
[     5.307] (II) event2  - Cosair Corsair VOID PRO Surround USB Adapter Consumer Control: is tagged by udev as: Keyboard
[     5.307] (II) event2  - Cosair Corsair VOID PRO Surround USB Adapter Consumer Control: device is a keyboard
[     5.308] (II) config/udev: Adding input device Cosair Corsair VOID PRO Surround USB Adapter (/dev/input/event3)
[     5.308] (II) No input driver specified, ignoring this device.
[     5.308] (II) This device may have been added with another device file.
[     5.308] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=3 (/dev/input/event12)
[     5.309] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=7 (/dev/input/event13)
[     5.309] (II) No input driver specified, ignoring this device.
[     5.309] (II) This device may have been added with another device file.
[     5.309] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=8 (/dev/input/event14)
[     5.309] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=9 (/dev/input/event15)
[     5.309] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=10 (/dev/input/event16)
[     5.309] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=11 (/dev/input/event17)
[     5.310] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event18)
[     5.310] (II) No input driver specified, ignoring this device.
[     5.310] (II) This device may have been added with another device file.
[     5.310] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event19)
[     5.310] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event20)
[     5.310] (II) config/udev: Adding input device HD-Audio Generic Line Out Front (/dev/input/event21)
[     5.310] (II) config/udev: Adding input device HD-Audio Generic Line Out Surround (/dev/input/event22)
[     5.311] (II) config/udev: Adding input device HD-Audio Generic Line Out CLFE (/dev/input/event23)
[     5.311] (II) No input driver specified, ignoring this device.
[     5.311] (II) This device may have been added with another device file.
[     5.311] (II) config/udev: Adding input device HD-Audio Generic Line Out Side (/dev/input/event24)
[     5.311] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event25)
[     5.311] (II) config/udev: Adding input device PC Speaker (/dev/input/event9)
[     5.312] (II) config/udev: Adding input device ckb2: Corsair Gaming GLAIVE RGB Mouse vKB (/dev/input/event4)
[     5.312] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: Applying InputClass "evdev pointer catchall"
[     5.312] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: Applying InputClass "evdev keyboard catchall"
[     5.312] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: Applying InputClass "libinput pointer catchall"
[     5.312] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: Applying InputClass "libinput keyboard catchall"
[     5.312] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: Applying InputClass "system-keyboard"
[     5.312] (II) Using input driver 'libinput' for 'ckb2: Corsair Gaming GLAIVE RGB Mouse vKB'
[     5.312] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: always reports core events
[     5.312] (**) Option "Device" "/dev/input/event4"
[     5.312] (**) Option "_source" "server/udev"
[     5.312] (II) event4  - ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: is tagged by udev as: Keyboard Mouse
[     5.312] (II) event4  - ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: device is a pointer
[     5.312] (II) event4  - ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: device is a keyboard
[     5.312] (II) event4  - ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: device removed
[     5.330] (II) libinput: ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: needs a virtual subdevice
[     5.330] (**) Option "config_info" "udev:/sys/devices/virtual/input/input26/event4"
[     5.330] (II) XINPUT: Adding extended input device "ckb2: Corsair Gaming GLAIVE RGB Mouse vKB" (type: MOUSE, id 9)
[     5.330] (**) Option "AccelerationScheme" "none"
[     5.330] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: (accel) selected scheme none/0
[     5.330] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: (accel) acceleration factor: 2.000
[     5.330] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: (accel) acceleration threshold: 4
[     5.330] (II) event4  - ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: is tagged by udev as: Keyboard Mouse
[     5.330] (II) event4  - ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: device is a pointer
[     5.330] (II) event4  - ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: device is a keyboard
[     5.331] (II) config/udev: Adding input device ckb2: Corsair Gaming GLAIVE RGB Mouse vM (/dev/input/event5)
[     5.331] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vM: Applying InputClass "evdev pointer catchall"
[     5.331] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vM: Applying InputClass "evdev keyboard catchall"
[     5.331] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vM: Applying InputClass "libinput pointer catchall"
[     5.331] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vM: Applying InputClass "libinput keyboard catchall"
[     5.331] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vM: Applying InputClass "system-keyboard"
[     5.331] (II) Using input driver 'libinput' for 'ckb2: Corsair Gaming GLAIVE RGB Mouse vM'
[     5.331] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vM: always reports core events
[     5.331] (**) Option "Device" "/dev/input/event5"
[     5.331] (**) Option "_source" "server/udev"
[     5.331] (II) event5  - ckb2: Corsair Gaming GLAIVE RGB Mouse vM: is tagged by udev as: Keyboard Mouse
[     5.331] (II) event5  - ckb2: Corsair Gaming GLAIVE RGB Mouse vM: device is a pointer
[     5.331] (II) event5  - ckb2: Corsair Gaming GLAIVE RGB Mouse vM: device is a keyboard
[     5.331] (II) event5  - ckb2: Corsair Gaming GLAIVE RGB Mouse vM: device removed
[     5.360] (II) libinput: ckb2: Corsair Gaming GLAIVE RGB Mouse vM: needs a virtual subdevice
[     5.360] (**) Option "config_info" "udev:/sys/devices/virtual/input/input27/event5"
[     5.360] (II) XINPUT: Adding extended input device "ckb2: Corsair Gaming GLAIVE RGB Mouse vM" (type: MOUSE, id 10)
[     5.360] (**) Option "AccelerationScheme" "none"
[     5.360] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vM: (accel) selected scheme none/0
[     5.360] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vM: (accel) acceleration factor: 2.000
[     5.360] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vM: (accel) acceleration threshold: 4
[     5.360] (II) event5  - ckb2: Corsair Gaming GLAIVE RGB Mouse vM: is tagged by udev as: Keyboard Mouse
[     5.360] (II) event5  - ckb2: Corsair Gaming GLAIVE RGB Mouse vM: device is a pointer
[     5.360] (II) event5  - ckb2: Corsair Gaming GLAIVE RGB Mouse vM: device is a keyboard
[     5.361] (II) config/udev: Adding input device ckb2: Corsair Gaming GLAIVE RGB Mouse vM (/dev/input/mouse1)
[     5.361] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vM: Applying InputClass "system-keyboard"
[     5.361] (II) No input driver specified, ignoring this device.
[     5.361] (II) This device may have been added with another device file.
[     5.361] (II) config/udev: Adding input device ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB (/dev/input/event6)
[     5.361] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: Applying InputClass "evdev pointer catchall"
[     5.361] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: Applying InputClass "evdev keyboard catchall"
[     5.361] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: Applying InputClass "libinput pointer catchall"
[     5.361] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: Applying InputClass "libinput keyboard catchall"
[     5.361] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: Applying InputClass "system-keyboard"
[     5.361] (II) Using input driver 'libinput' for 'ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB'
[     5.361] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: always reports core events
[     5.361] (**) Option "Device" "/dev/input/event6"
[     5.361] (**) Option "_source" "server/udev"
[     5.361] (II) event6  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: is tagged by udev as: Keyboard Mouse
[     5.361] (II) event6  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: device is a pointer
[     5.361] (II) event6  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: device is a keyboard
[     5.361] (II) event6  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: device removed
[     5.383] (II) libinput: ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: needs a virtual subdevice
[     5.383] (**) Option "config_info" "udev:/sys/devices/virtual/input/input28/event6"
[     5.383] (II) XINPUT: Adding extended input device "ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB" (type: MOUSE, id 11)
[     5.383] (**) Option "AccelerationScheme" "none"
[     5.383] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: (accel) selected scheme none/0
[     5.383] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: (accel) acceleration factor: 2.000
[     5.383] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: (accel) acceleration threshold: 4
[     5.384] (II) event6  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: is tagged by udev as: Keyboard Mouse
[     5.384] (II) event6  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: device is a pointer
[     5.384] (II) event6  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: device is a keyboard
[     5.384] (II) config/udev: Adding input device ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM (/dev/input/event7)
[     5.384] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "evdev pointer catchall"
[     5.384] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "evdev keyboard catchall"
[     5.384] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "libinput pointer catchall"
[     5.384] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "libinput keyboard catchall"
[     5.384] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "system-keyboard"
[     5.384] (II) Using input driver 'libinput' for 'ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM'
[     5.384] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: always reports core events
[     5.384] (**) Option "Device" "/dev/input/event7"
[     5.384] (**) Option "_source" "server/udev"
[     5.385] (II) event7  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: is tagged by udev as: Keyboard Mouse
[     5.385] (II) event7  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: device is a pointer
[     5.385] (II) event7  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: device is a keyboard
[     5.385] (II) event7  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: device removed
[     5.413] (II) libinput: ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: needs a virtual subdevice
[     5.413] (**) Option "config_info" "udev:/sys/devices/virtual/input/input29/event7"
[     5.413] (II) XINPUT: Adding extended input device "ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM" (type: MOUSE, id 12)
[     5.413] (**) Option "AccelerationScheme" "none"
[     5.413] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: (accel) selected scheme none/0
[     5.413] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: (accel) acceleration factor: 2.000
[     5.413] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: (accel) acceleration threshold: 4
[     5.414] (II) event7  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: is tagged by udev as: Keyboard Mouse
[     5.414] (II) event7  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: device is a pointer
[     5.414] (II) event7  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: device is a keyboard
[     5.414] (II) config/udev: Adding input device ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM (/dev/input/mouse0)
[     5.414] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "system-keyboard"
[     5.414] (II) No input driver specified, ignoring this device.
[     5.414] (II) This device may have been added with another device file.
[     5.416] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: Applying InputClass "evdev pointer catchall"
[     5.416] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: Applying InputClass "evdev keyboard catchall"
[     5.416] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: Applying InputClass "libinput pointer catchall"
[     5.416] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: Applying InputClass "libinput keyboard catchall"
[     5.416] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: Applying InputClass "system-keyboard"
[     5.416] (II) Using input driver 'libinput' for 'ckb2: Corsair Gaming GLAIVE RGB Mouse vKB'
[     5.416] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: always reports core events
[     5.416] (**) Option "Device" "/dev/input/event4"
[     5.416] (**) Option "_source" "_driver/libinput"
[     5.416] (II) libinput: ckb2: Corsair Gaming GLAIVE RGB Mouse vKB: is a virtual subdevice
[     5.416] (**) Option "config_info" "udev:/sys/devices/virtual/input/input26/event4"
[     5.416] (II) XINPUT: Adding extended input device "ckb2: Corsair Gaming GLAIVE RGB Mouse vKB" (type: KEYBOARD, id 13)
[     5.416] (**) Option "xkb_model" "pc105"
[     5.416] (**) Option "xkb_layout" "dk"
[     5.416] (**) Option "xkb_variant" "winkeys"
[     5.417] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vM: Applying InputClass "evdev pointer catchall"
[     5.417] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vM: Applying InputClass "evdev keyboard catchall"
[     5.417] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vM: Applying InputClass "libinput pointer catchall"
[     5.417] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vM: Applying InputClass "libinput keyboard catchall"
[     5.417] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vM: Applying InputClass "system-keyboard"
[     5.417] (II) Using input driver 'libinput' for 'ckb2: Corsair Gaming GLAIVE RGB Mouse vM'
[     5.417] (**) ckb2: Corsair Gaming GLAIVE RGB Mouse vM: always reports core events
[     5.417] (**) Option "Device" "/dev/input/event5"
[     5.417] (**) Option "_source" "_driver/libinput"
[     5.417] (II) libinput: ckb2: Corsair Gaming GLAIVE RGB Mouse vM: is a virtual subdevice
[     5.417] (**) Option "config_info" "udev:/sys/devices/virtual/input/input27/event5"
[     5.417] (II) XINPUT: Adding extended input device "ckb2: Corsair Gaming GLAIVE RGB Mouse vM" (type: KEYBOARD, id 14)
[     5.417] (**) Option "xkb_model" "pc105"
[     5.417] (**) Option "xkb_layout" "dk"
[     5.417] (**) Option "xkb_variant" "winkeys"
[     5.417] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: Applying InputClass "evdev pointer catchall"
[     5.417] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: Applying InputClass "evdev keyboard catchall"
[     5.417] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: Applying InputClass "libinput pointer catchall"
[     5.417] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: Applying InputClass "libinput keyboard catchall"
[     5.417] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: Applying InputClass "system-keyboard"
[     5.417] (II) Using input driver 'libinput' for 'ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB'
[     5.417] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: always reports core events
[     5.417] (**) Option "Device" "/dev/input/event6"
[     5.417] (II) libinput: ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: is a virtual subdevice
[     5.417] (**) Option "config_info" "udev:/sys/devices/virtual/input/input28/event6"
[     5.417] (II) XINPUT: Adding extended input device "ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB" (type: KEYBOARD, id 15)
[     5.417] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "evdev pointer catchall"
[     5.417] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "evdev keyboard catchall"
[     5.417] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "libinput pointer catchall"
[     5.417] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "libinput keyboard catchall"
[     5.417] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "system-keyboard"
[     5.417] (II) Using input driver 'libinput' for 'ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM'
[     5.417] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: always reports core events
[     5.417] (**) Option "Device" "/dev/input/event7"
[     5.417] (II) libinput: ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: is a virtual subdevice
[     5.417] (**) Option "config_info" "udev:/sys/devices/virtual/input/input29/event7"
[     5.417] (II) XINPUT: Adding extended input device "ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM" (type: KEYBOARD, id 16)
[     5.417] (II) config/udev: Adding input device ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM (/dev/input/mouse0)
[     5.418] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "system-keyboard"
[     5.418] (II) No input driver specified, ignoring this device.
[     5.418] (II) This device may have been added with another device file.
[     5.418] (II) config/udev: removing device ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM
[     5.418] (II) UnloadModule: "libinput"
[     5.418] (II) event7  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: device removed
[     5.436] (II) UnloadModule: "libinput"
[     5.437] (II) config/udev: Adding input device ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM (/dev/input/event7)
[     5.437] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "evdev pointer catchall"
[     5.437] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "evdev keyboard catchall"
[     5.437] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "libinput pointer catchall"
[     5.437] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "libinput keyboard catchall"
[     5.437] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "system-keyboard"
[     5.437] (II) Using input driver 'libinput' for 'ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM'
[     5.437] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: always reports core events
[     5.437] (**) Option "Device" "/dev/input/event7"
[     5.437] (**) Option "_source" "server/udev"
[     5.437] (II) event7  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: is tagged by udev as: Keyboard Mouse
[     5.437] (II) event7  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: device is a pointer
[     5.437] (II) event7  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: device is a keyboard
[     5.437] (II) event7  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: device removed
[     5.480] (II) libinput: ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: needs a virtual subdevice
[     5.480] (**) Option "config_info" "udev:/sys/devices/virtual/input/input29/event7"
[     5.480] (II) XINPUT: Adding extended input device "ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM" (type: MOUSE, id 12)
[     5.480] (**) Option "AccelerationScheme" "none"
[     5.480] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: (accel) selected scheme none/0
[     5.480] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: (accel) acceleration factor: 2.000
[     5.480] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: (accel) acceleration threshold: 4
[     5.480] (II) event7  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: is tagged by udev as: Keyboard Mouse
[     5.480] (II) event7  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: device is a pointer
[     5.480] (II) event7  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: device is a keyboard
[     5.481] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "evdev pointer catchall"
[     5.481] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "evdev keyboard catchall"
[     5.481] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "libinput pointer catchall"
[     5.481] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "libinput keyboard catchall"
[     5.481] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: Applying InputClass "system-keyboard"
[     5.481] (II) Using input driver 'libinput' for 'ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM'
[     5.481] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: always reports core events
[     5.481] (**) Option "Device" "/dev/input/event7"
[     5.481] (**) Option "_source" "_driver/libinput"
[     5.481] (II) libinput: ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM: is a virtual subdevice
[     5.481] (**) Option "config_info" "udev:/sys/devices/virtual/input/input29/event7"
[     5.481] (II) XINPUT: Adding extended input device "ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vM" (type: KEYBOARD, id 16)
[     5.481] (**) Option "xkb_model" "pc105"
[     5.481] (**) Option "xkb_layout" "dk"
[     5.481] (**) Option "xkb_variant" "winkeys"
[     5.481] (II) config/udev: removing device ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB
[     5.481] (II) UnloadModule: "libinput"
[     5.481] (II) event6  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: device removed
[     5.503] (II) UnloadModule: "libinput"
[     5.504] (II) config/udev: Adding input device ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB (/dev/input/event6)
[     5.504] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: Applying InputClass "evdev pointer catchall"
[     5.504] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: Applying InputClass "evdev keyboard catchall"
[     5.504] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: Applying InputClass "libinput pointer catchall"
[     5.504] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: Applying InputClass "libinput keyboard catchall"
[     5.504] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: Applying InputClass "system-keyboard"
[     5.504] (II) Using input driver 'libinput' for 'ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB'
[     5.504] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: always reports core events
[     5.504] (**) Option "Device" "/dev/input/event6"
[     5.504] (**) Option "_source" "server/udev"
[     5.504] (II) event6  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: is tagged by udev as: Keyboard Mouse
[     5.504] (II) event6  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: device is a pointer
[     5.504] (II) event6  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: device is a keyboard
[     5.504] (II) event6  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: device removed
[     5.547] (II) libinput: ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: needs a virtual subdevice
[     5.547] (**) Option "config_info" "udev:/sys/devices/virtual/input/input28/event6"
[     5.547] (II) XINPUT: Adding extended input device "ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB" (type: MOUSE, id 11)
[     5.547] (**) Option "AccelerationScheme" "none"
[     5.547] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: (accel) selected scheme none/0
[     5.547] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: (accel) acceleration factor: 2.000
[     5.547] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: (accel) acceleration threshold: 4
[     5.547] (II) event6  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: is tagged by udev as: Keyboard Mouse
[     5.547] (II) event6  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: device is a pointer
[     5.547] (II) event6  - ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: device is a keyboard
[     5.547] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: Applying InputClass "evdev pointer catchall"
[     5.547] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: Applying InputClass "evdev keyboard catchall"
[     5.547] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: Applying InputClass "libinput pointer catchall"
[     5.547] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: Applying InputClass "libinput keyboard catchall"
[     5.547] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: Applying InputClass "system-keyboard"
[     5.547] (II) Using input driver 'libinput' for 'ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB'
[     5.547] (**) ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: always reports core events
[     5.547] (**) Option "Device" "/dev/input/event6"
[     5.547] (**) Option "_source" "_driver/libinput"
[     5.547] (II) libinput: ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB: is a virtual subdevice
[     5.547] (II) XINPUT: Adding extended input device "ckb1: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard vKB" (type: KEYBOARD, id 15)
[     5.547] (**) Option "xkb_model" "pc105"
[     5.547] (**) Option "xkb_layout" "dk"
[     5.547] (**) Option "xkb_variant" "winkeys"
#26
very good point there :grin:.
i dont know exactly how amdgpu works, but should he not have any monitor/gpu configurations in /etc/X11/* ? i dont see any. also is video-linux or vesa supposed to be installed alongside amdgpu?
nice tutorial by btw, i didnt know amdgpu was installed with mhwd, i thought it required manual intervention. so in this situation it would be as simple as?
sudo mhwd -a pci free 0300
IIRC this would also setup monitor configs that are missing ?
#27
that one is only aimed at old GCN 1.1 cards. Vega is GCN 5.
video-linux = opensource drivers. It’s a metapackage that installs all intel, nvidia and AMD mesa drivers and the vulkan and vaapi parts. mesa itself decides which one is loaded and:
that line tells that the correct driver is used.
Just tried with my Asus Vega64 and Ryzen 2700X on Live boot, and it works out of the box.
So we are dealing with something more troublesome here.
For me it seems that xorg or mesa don’t get the correct resolutions reported by the screen or the card. That could be a cable fault or a screen fault or some weird scenario with the drivers.
#28
It seems Vega is a difficult hardware on Linux. Several topics about troubleshooting refer to grub parameters.
Example is this, from which you can try some of them.
I think @Tids knows this stuff…
I 'm afraid it’s only a general rule, not really useful here… :sob:
video-linux includes amdgpu, though (as you advised OP) it is replaced with experimental, which I have no idea when is useful. Do you? :rofl:
vesa might be tried as “replacement”, I think, not in parallel.
AFAIK there are no auto-monitor configs. If needed, they should be manually created, using real EDID and xrandr, creating/adding new resolutions.
#29
those are for APU’s on notebooks and non-default mainboards (meaning stuff like proprietary HP or Dell boards)
free drivers don’t need configs. If you add a config, Prime won’t work anymore.
#30
ok so my advice on removing video-linux = not so good :disappointed:
and should now be reinstalled with sudo mhwd -a free 0300 ?
#31
But… it’s a single GPU here…??
Would a “monitor-only” config break anything Xorg/amdgpu?
#32
Yes, that should be done @Nikolailarsen01
It should not, but it won’t solve much as the correct driver is already loaded and used.
@Nikolailarsen01
That command should list the modes the screen reports:
xrandr --props
The first line is the most interesting one, but please post the output of the whole command.
#33
A search suggests there is at least one same GPU that works fine!
#34
xrandr --props
Screen 0: minimum 320 x 200, current 640 x 480, maximum 16384 x 16384
DisplayPort-0 disconnected (normal left inverted right x axis y axis)
        GAMMA_LUT_SIZE: 4096
                range: (0, -1)
        DEGAMMA_LUT_SIZE: 4096
                range: (0, -1)
        GAMMA_LUT: 0
                range: (0, 65535)
        CTM: 0
        DEGAMMA_LUT: 0
                range: (0, 65535)
        TearFree: auto
                supported: off, on, auto
        max bpc: 8
                range: (8, 16)
        underscan vborder: 0
                range: (0, 128)
        underscan hborder: 0
                range: (0, 128)
        underscan: off
        scaling mode: None
                supported: None, Full, Center, Full aspect
        link-status: Good
                supported: Good, Bad
        CONNECTOR_ID: 56
                supported: 56
        non-desktop: 0
                range: (0, 1)
DisplayPort-1 connected primary 640x480+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
                range: (0, -1)
                range: (0, -1)
        GAMMA_LUT: 0
                range: (0, 65535)
        CTM: 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0
                0 1
        DEGAMMA_LUT: 0
                range: (0, 65535)
        TearFree: auto
        max bpc: 8
                range: (8, 16)
                range: (0, 128)
                range: (0, 128)
        underscan: off
        scaling mode: None
        link-status: Good
        CONNECTOR_ID: 58
                supported: 58
        non-desktop: 0
                range: (0, 1)
   640x480       59.94*
HDMI-A-0 disconnected (normal left inverted right x axis y axis)
                range: (0, -1)
                range: (0, -1)
        GAMMA_LUT: 0
                range: (0, 65535)
        CTM: 0
        DEGAMMA_LUT: 0
                range: (0, 65535)
        TearFree: auto
        max bpc: 8
                range: (8, 16)
                range: (0, 128)
                range: (0, 128)
        underscan: off
        scaling mode: None
        link-status: Good
        CONNECTOR_ID: 60
                supported: 60
        non-desktop: 0
                range: (0, 1)
HDMI-A-1 disconnected (normal left inverted right x axis y axis)
                range: (0, -1)
                range: (0, -1)
        GAMMA_LUT: 0
                range: (0, 65535)
        CTM: 0
        DEGAMMA_LUT: 0
                range: (0, 65535)
        TearFree: auto
        max bpc: 8
                range: (8, 16)
                range: (0, 128)
                range: (0, 128)
        underscan: off
        scaling mode: None
        link-status: Good
        CONNECTOR_ID: 62
                supported: 62
        non-desktop: 0
                range: (0, 1)
#35
only…
#36
Please try the other display port on your card or another display port cable (or maybe an HDMI cable) - your screen does not report the correct resolutions.
#37
Were you using the same connection type (DP) with nvidia, or something else?
An old report (xorg log etc) containing EDID/Modelines for the monitor might make it easier…
#38
Swapping displayports did not work. My monitor does not support HDMI.
I used the same monitor and Display cable when I had my gtx 960.
#39
the GTX 960 only used Displayport 1.2 while the Vega64 has Display Port 1.4 HDR. It might be that the cable worked ok with 1.2 but won’t work with 1.4
What is the exact name and model of your screen?
#40
