Still problems. Fresh install. Start KDE hangs, cannot login
Hello,
today installed Manjaro KDE without any problems. First boot, login screen, entering password and nothing happens. Waiting 5 min. nothing, tty not working. What is wrong with my system? My boot log:
  Kernel: 5.15.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=988ce3be-af86-425e-abd3-4398c5213cf8 rw quiet apparmor=1
  Console: pty pts/1 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
    base: Arch Linux
  Type: Desktop System: Micro-Star product: MS-7D53 v: 1.0 serial: N/A
  Mobo: Micro-Star model: MPG X570S EDGE MAX WIFI (MS-7D53) v: 1.0
    serial: <filter> UEFI: American Megatrends LLC. v: 1.10 date: 12/27/2021
  RAM: total: 31.34 GiB used: 2.69 GiB (8.6%)
  Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
    note: est.
  Device-1: DIMM 0 size: No Module Installed
  Device-2: DIMM 1 size: 16 GiB speed: 3600 MT/s type: DDR4
    detail: synchronous unbuffered (unregistered) bus-width: 64 bits
    total: 64 bits manufacturer: G.Skill part-no: F4-3600C16-16GVKC
    serial: N/A
  Device-3: DIMM 0 size: No Module Installed
  Device-4: DIMM 1 size: 16 GiB speed: 3600 MT/s type: DDR4
    serial: N/A
  Info: model: AMD Ryzen 7 5800X socket: AM4 bits: 64 type: MT MCP arch: Zen 3
    family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 2325 high: 4200 min/max: 2200/5361 boost: enabled
    base/boost: 4200/4850 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 4200 2: 2200 3: 2200 4: 2200
    5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
    13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 134436
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
    IBRS_FW, STIBP: always-on, RSB filling
  Device-1: NVIDIA TU106 [GeForce RTX 2070 Rev. A] vendor: Micro-Star MSI
    driver: nouveau v: kernel bus-ID: 2d:00.0 chip-ID: 10de:1f07 class-ID: 0300
  Display: server: X.org 1.21.1.3 compositor: kwin_x11 driver:
    loaded: modesetting alternate: fbdev,vesa resolution: <missing: xdpyinfo>
  Device-1: Creative Labs driver: snd_hda_intel v: kernel bus-ID: 26:00.0
    chip-ID: 1102:0010 class-ID: 0403
  Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel bus-ID: 2d:00.1 chip-ID: 10de:10f9
    class-ID: 0403
  Device-3: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel bus-ID: 2f:00.4 chip-ID: 1022:1487
    class-ID: 0403
  Device-4: GYROCOM C&C Audiotrak ProDigy CUBE type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1.3:6 chip-ID: 1852:7921
    class-ID: 0102
  Device-5: Micro Star USB Audio type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2:3 chip-ID: 0db0:151f
    class-ID: 0300
  Sound Server-1: ALSA v: k5.15.16-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.43 running: yes
  Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel port: f000 bus-ID: 27:00.0 chip-ID: 10ec:8125 class-ID: 0200
  IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
    bus-ID: 28:00.0 chip-ID: 8086:2725 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:8
    chip-ID: 8087:0032 class-ID: e001
  Local Storage: total: 16.08 TiB used: 9.51 GiB (0.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:6 vendor: Samsung model: SSD 980 1TB
    lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7 temp: 39.9 C scheme: GPT
  SMART: yes health: PASSED on: 10d 9h cycles: 90
    read-units: 2,132,594 [1.09 TB] written-units: 4,050,768 [2.07 TB]
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 40.9 C scheme: GPT
  SMART: yes health: PASSED on: 1y 87d 0h cycles: 2,619
    read-units: 78,115,356 [39.9 TB] written-units: 66,966,877 [34.2 TB]
  ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD30PURZ-85GU6Y0 family: Purple size: 2.73 TiB block-size:
    physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: HDD
    rpm: 5400 serial: <filter> rev: 0A80 temp: 31 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 140d 22h cycles: 1809
  ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD20EARX-00PASB0 family: Green size: 1.82 TiB block-size:
    physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: N/A
    serial: <filter> rev: AB51 temp: 31 C scheme: MBR
  SMART: yes state: enabled health: PASSED on: 6y 314d 3h cycles: 4409
  ID-5: /dev/sdc maj-min: 8:32 vendor: Kingston model: SA400S371920G
    size: 1.75 TiB block-size: physical: 512 B logical: 512 B sata: 3.2
    speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1103 temp: 32 C
    scheme: GPT
  SMART: yes state: enabled health: PASSED on: 304d 21h cycles: 1090
    read: 5.28 TiB written: 23.03 TiB
  ID-6: /dev/sdd maj-min: 8:48 vendor: Crucial model: CT2000MX500SSD1
    family: Micron Client SSDs size: 1.82 TiB block-size: physical: 512 B
    logical: 512 B sata: 3.3 speed: 6.0 Gb/s type: SSD serial: <filter>
    rev: 033 temp: 27 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 6d 4h cycles: 77
    written: 1.24 TiB
  ID-7: /dev/sde maj-min: 8:64 vendor: Plextor model: PX-256M6S
    family: M3/M5/M6/M7 Series SSDs size: 238.47 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
    rev: 1.01 scheme: GPT
  SMART: yes state: enabled health: PASSED on: 278d 3h cycles: 4399
    read: 46.1 TiB written: 36.17 TiB
  ID-8: /dev/sdf maj-min: 8:80 vendor: Western Digital
    model: WD3003FZEX-00Z4SA0 family: Black size: 2.73 TiB block-size:
    rpm: 7200 serial: <filter> rev: 1A01 temp: 41 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 2y 315d 8h cycles: 3635
  ID-9: /dev/sdg maj-min: 8:96 type: USB vendor: Western Digital
    model: WD My Passport 25E2 drive model: WD40NMZW-11GX6S1
    family: Elements / My Passport (USB, AF) size: 3.64 TiB block-size:
    physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD
    rpm: 5400 serial: <filter> drive serial: <filter> rev: 4004
    drive rev: 01.01A01 temp: 34 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 352d 16h cycles: 381
  ID-1: / raw-size: 1.75 TiB size: 1.72 TiB (98.37%) used: 9.51 GiB (0.5%)
    fs: ext4 block-size: 4096 B dev: /dev/sdc2 maj-min: 8:34 label: N/A
    uuid: 988ce3be-af86-425e-abd3-4398c5213cf8
    used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdc1 maj-min: 8:33
    label: NO_LABEL uuid: D952-C729
  ID-1: /dev/nvme0n1p1 maj-min: 259:7 size: 16 MiB fs: N/A label: N/A
    uuid: N/A
  ID-2: /dev/nvme0n1p2 maj-min: 259:8 size: 931.5 GiB fs: ntfs label: N/A
    uuid: 324EF1E74EF1A42F
  ID-3: /dev/nvme1n1p1 maj-min: 259:1 size: 499 MiB fs: ntfs label: N/A
    uuid: 925CD01F5CCFFFC1
  ID-4: /dev/nvme1n1p2 maj-min: 259:2 size: 99 MiB fs: vfat label: N/A
    uuid: ECC4-7419
  ID-5: /dev/nvme1n1p3 maj-min: 259:3 size: 16 MiB fs: N/A label: N/A
    uuid: N/A
  ID-6: /dev/nvme1n1p4 maj-min: 259:4 size: 464.53 GiB fs: ntfs label: N/A
    uuid: 6610C53C10C513C9
  ID-7: /dev/nvme1n1p5 maj-min: 259:5 size: 644 MiB fs: ntfs label: N/A
    uuid: E2E49C40E49C193D
  ID-8: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: N/A label: N/A uuid: N/A
  ID-9: /dev/sda2 maj-min: 8:2 size: 2.73 TiB fs: ntfs label: Purple
    uuid: A8849E96849E671A
  ID-10: /dev/sdb1 maj-min: 8:17 size: 1.82 TiB fs: ntfs label: WDG
    uuid: F6987BED987BAAAF
  ID-11: /dev/sdd1 maj-min: 8:49 size: 16 MiB fs: N/A label: N/A uuid: N/A
  ID-12: /dev/sdd2 maj-min: 8:50 size: 1.82 TiB fs: ntfs label: Crucial
    uuid: E41C3D5C1C3D2B46
  ID-13: /dev/sde1 maj-min: 8:65 size: 238.47 GiB fs: ntfs label: Forza
    uuid: A092270C9226E68E
  ID-14: /dev/sdf1 maj-min: 8:81 size: 128 MiB fs: N/A label: N/A uuid: N/A
  ID-15: /dev/sdf2 maj-min: 8:82 size: 2.73 TiB fs: ntfs label: WDBlack
    uuid: 20FA2E01FA2DD436
  ID-16: /dev/sdg1 maj-min: 8:97 size: 3.64 TiB fs: ntfs
    label: WD Passport 4 uuid: 4E2E62292E6209F3
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Hub-2: 1-1:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    speed: 480 Mb/s power: 100mA chip-ID: 174c:2074 class-ID: 0900
  Device-1: 1-1.1:4 info: Razer USA DeathAdder Elite type: Mouse,Keyboard
    driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
    power: 500mA chip-ID: 1532:005c class-ID: 0300
  Hub-3: 1-1.2:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 1-1.2.1:7 info: Microsoft Xbox360 Controller
    type: <vendor specific> driver: xpad interfaces: 4 rev: 2.0 speed: 12 Mb/s
    power: 500mA chip-ID: 045e:028e class-ID: ff00 serial: <filter>
  Device-2: 1-1.3:6 info: GYROCOM C&C Audiotrak ProDigy CUBE type: HID,Audio
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
    speed: 12 Mb/s power: 500mA chip-ID: 1852:7921 class-ID: 0102
  Device-3: 1-2:3 info: Micro Star USB Audio type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
    speed: 480 Mb/s power: 100mA chip-ID: 0db0:151f class-ID: 0300
  Device-4: 1-4:8 info: Intel AX210 Bluetooth type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0032
    class-ID: e001
  Device-5: 1-6:9 info: Corsair CORSAIR K100 RGB Mechanical Gaming Keyboard
    type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    speed: 480 Mb/s power: 500mA chip-ID: 1b1c:1b7d class-ID: 0300
    serial: <filter>
  Hub-4: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-5: 2-1:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s power: 8mA chip-ID: 174c:3074 class-ID: 0900
  Hub-6: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-5:2 info: Micro Star MYSTIC LIGHT type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
    power: 500mA chip-ID: 1462:7d53 class-ID: 0300 serial: <filter>
  Hub-7: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Hub-8: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-9: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-10: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-11: 7-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-12: 8-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Device-1: 8-1:2 info: Western Digital My Passport (WD40NMZW)
    type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
    power: 896mA chip-ID: 1058:25e2 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: N/A mobo: N/A gpu: nouveau temp: 46.0 C
  Fan Speeds (RPM): N/A gpu: nouveau fan: 0
  Processes: 349 Uptime: 1h 3m wakeups: 1 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1207 lib: 332
  flatpak: 0 Shell: Zsh (sudo) v: 5.8 default: Bash v: 5.1.16
  running-in: konsole inxi: 3.3.12
Please help me.
Sorry, not a boot log, just a system info.
then try
reboot on USB live manjaro ( not your disk )
open a terminal
sudo manjaro-chroot -a
pacman -Syy
mhwd -a pci nonfree 0300
pacman -Syyu
exit ( end-chroot )
OK, I’ll try now.
So far, so good. It’s working.
Thanks a lot.
Everything was fine, installed gimp, inkscape. Till to next reboot. Then I saw black screen with:
/dev/sdc2: clean, 359725/117194752 files, 12143941/468765656 blocks with a mouse cursor.
Again tty not working, had to reset manually. Second time there were many text with 10.111006 FS-Cache: N-cookie and 35.286961 audit: type=1334 and so on. (I cannot attach pictures).
What is happening?
Anyone?
I’d like to add that in Windows over 5 hours cinema 4d benchmarking and 0 crashes and not a single bluescreen.
you have to check fisrt errors in logs
reboot on USB live manjaro ( not your disk ) , and a browser on this topic
open a terminal
inxi -Fza
journalctl -b -1 -p4
exit ( end-chroot )
Here it is:
fza:
12System:
  12Kernel 5.15.16-1-MANJARO x86_64 12bits 64 12compiler gcc 12v 11.1.0
    12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro
    misolabel=MANJARO_KDE_2122 quiet systemd.show_status=1 apparmor=1 security=apparmor
    driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  12Console N/A 12wm kwin_x11 12Distro Manjaro Linux 12base Arch Linux
12Machine:
  12Type Desktop 12System Micro-Star 12product MS-7D53 12v 1.0 12serial N/A
  12Mobo Micro-Star 12model MPG X570S EDGE MAX WIFI (MS-7D53) 12v 1.0 12serial <filter>
    12UEFI American Megatrends LLC. 12v 1.10 12date 12/27/2021
12CPU:
  12Info 12model AMD Ryzen 7 5800X 12socket AM4 12bits 64 12type MT MCP 12arch Zen 3 12family 0x19 (25)
    12model-id 0x21 (33) 12stepping 0 12microcode 0xA201016
  12Topology 12cpus 1x 12cores 8 12tpc 2 12threads 16 12smt enabled 12cache 12L1 512 KiB
    12desc d-8x32 KiB; i-8x32 KiB 12L2 4 MiB 12desc 8x512 KiB 12L3 32 MiB 12desc 1x32 MiB
  12Speed (MHz) 12avg 2200 12min/max 2200/5361 12boost enabled 12base/boost 4200/4850 12scaling
    12driver acpi-cpufreq 12governor schedutil 12volts 1.1 V 12ext-clock 100 MHz 12cores 121 2200 122 2200 123 2200
    124 2200 125 2200 126 2200 127 2200 128 2200 129 2200 1210 2200 1211 2200 1212 2200 1213 2200 1214 2200 1215 2200
    1216 2200 12bogomips 134449
  12Flags avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  12Vulnerabilities
  12Type itlb_multihit 12status Not affected
  12Type l1tf 12status Not affected
  12Type mds 12status Not affected
  12Type meltdown 12status Not affected
  12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via prctl and seccomp
  12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer sanitization
  12Type spectre_v2
    12mitigation Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB filling
  12Type srbds 12status Not affected
  12Type tsx_async_abort 12status Not affected
12Graphics:
  12Device-1 NVIDIA TU106 [GeForce RTX 2070 Rev. A] 12vendor Micro-Star MSI 12driver nouveau 12v kernel
    12alternate nvidia_drm,nvidia 12bus-ID 2d:00.0 12chip-ID 10de:1f07 12class-ID 0300
  12Display 12server X.org 1.21.1.3 12compositor kwin_x11 12driver 12loaded nvidia
    12resolution <missing: xdpyinfo>
  12Message Unable to show advanced data. Required tool glxinfo missing.
12Audio:
  12Device-1 Creative Labs 12driver snd_hda_intel 12v kernel 12bus-ID 26:00.0 12chip-ID 1102:0010
    12class-ID 0403
  12Device-2 NVIDIA TU106 High Definition Audio 12vendor Micro-Star MSI 12driver snd_hda_intel
    12v kernel 12bus-ID 2d:00.1 12chip-ID 10de:10f9 12class-ID 0403
  12Device-3 AMD Starship/Matisse HD Audio 12vendor Micro-Star MSI 12driver snd_hda_intel 12v kernel
    12bus-ID 2f:00.4 12chip-ID 1022:1487 12class-ID 0403
  12Device-4 GYROCOM C&C Audiotrak ProDigy CUBE 12type USB 12driver hid-generic,snd-usb-audio,usbhid
    12bus-ID 1-1.3:6 12chip-ID 1852:7921 12class-ID 0102
  12Device-5 Micro Star USB Audio 12type USB 12driver hid-generic,snd-usb-audio,usbhid 12bus-ID 1-2:3
    12chip-ID 0db0:151f 12class-ID 0300
  12Sound Server-1 ALSA 12v k5.15.16-1-MANJARO 12running yes
  12Sound Server-2 JACK 12v 1.9.20 12running no
  12Sound Server-3 PulseAudio 12v 15.0 12running yes
  12Sound Server-4 PipeWire 12v 0.3.43 12running yes
12Network:
  12Device-1 Realtek RTL8125 2.5GbE 12vendor Micro-Star MSI 12driver r8169 12v kernel 12port f000
    12bus-ID 27:00.0 12chip-ID 10ec:8125 12class-ID 0200
  12IF enp39s0 12state up 12speed 1000 Mbps 12duplex full 12mac <filter>
  12Device-2 Intel Wi-Fi 6 AX210/AX211/AX411 160MHz 12driver iwlwifi 12v kernel 12bus-ID 28:00.0
    12chip-ID 8086:2725 12class-ID 0280
  12IF wlo1 12state down 12mac <filter>
12Bluetooth:
  12Device-1 Intel AX210 Bluetooth 12type USB 12driver btusb 12v 0.8 12bus-ID 1-4:8 12chip-ID 8087:0032
    12class-ID e001
  12Report rfkill 12ID hci0 12rfk-id 0 12state up 12address see --recommends
12Drives:
  12Local Storage 12total 16.09 TiB 12used 18.02 GiB (0.1%)
  12ID-1 /dev/nvme0n1 12maj-min 259:6 12vendor Samsung 12model SSD 980 1TB 12size 931.51 GiB 12block-size
    12physical 512 B 12logical 512 B 12speed 31.6 Gb/s 12lanes 4 12type SSD 12serial <filter> 12rev 1B4QFXO7
    12temp 36.9 C
  12SMART yes 12health PASSED 12on 10d 9h 12cycles 92 12read-units 2,143,045 [1.09 TB]
    12written-units 4,059,547 [2.07 TB]
  12ID-2 /dev/nvme1n1 12maj-min 259:0 12vendor Samsung 12model SSD 970 EVO 500GB 12size 465.76 GiB
    12block-size 12physical 512 B 12logical 512 B 12speed 31.6 Gb/s 12lanes 4 12type SSD 12serial <filter>
    12rev 2B2QEXE7 12temp 36.9 C
  12SMART yes 12health PASSED 12on 1y 87d 0h 12cycles 2,621 12read-units 78,115,609 [39.9 TB]
    12written-units 66,966,880 [34.2 TB]
  12ID-3 /dev/sda 12maj-min 8:0 12vendor Western Digital 12model WD30PURZ-85GU6Y0 12family Purple
    12size 2.73 TiB 12block-size 12physical 4096 B 12logical 512 B 12sata 3.0 12speed 6.0 Gb/s 12type HDD 12rpm 5400
    12serial <filter> 12rev 0A80 12temp 30 C
  12SMART yes 12state enabled 12health PASSED 12on 1y 141d 2h 12cycles 1811
  12ID-4 /dev/sdb 12maj-min 8:16 12vendor Western Digital 12model WD20EARX-00PASB0 12family Green
    12size 1.82 TiB 12block-size 12physical 4096 B 12logical 512 B 12sata 3.0 12speed 6.0 Gb/s 12type N/A
    12serial <filter> 12rev AB51 12temp 30 C
  12SMART yes 12state enabled 12health PASSED 12on 6y 314d 7h 12cycles 4411
  12ID-5 /dev/sdc 12maj-min 8:32 12vendor Kingston 12model SA400S371920G 12size 1.75 TiB 12block-size
    12physical 512 B 12logical 512 B 12sata 3.2 12speed 6.0 Gb/s 12type SSD 12serial <filter> 12rev 1103 12temp 31 C
  12SMART yes 12state enabled 12health PASSED 12on 305d 0h 12cycles 1092 12read 5.28 TiB 12written 23.1 TiB
  12ID-6 /dev/sdd 12maj-min 8:48 12vendor Crucial 12model CT2000MX500SSD1 12family Micron Client SSDs
    12size 1.82 TiB 12block-size 12physical 512 B 12logical 512 B 12sata 3.3 12speed 6.0 Gb/s 12type SSD
    12serial <filter> 12rev 033 12temp 27 C
  12SMART yes 12state enabled 12health PASSED 12on 6d 8h 12cycles 79 12written 1.24 TiB
  12ID-7 /dev/sde 12maj-min 8:64 12vendor Plextor 12model PX-256M6S 12family M3/M5/M6/M7 Series SSDs
    12size 238.47 GiB 12block-size 12physical 512 B 12logical 512 B 12sata 3.1 12speed 6.0 Gb/s 12type SSD
    12serial <filter> 12rev 1.01
  12SMART yes 12state enabled 12health PASSED 12on 278d 3h 12cycles 4401 12read 46.1 TiB 12written 36.17 TiB
  12ID-8 /dev/sdf 12maj-min 8:80 12vendor Western Digital 12model WD3003FZEX-00Z4SA0 12family Black
    12size 2.73 TiB 12block-size 12physical 4096 B 12logical 512 B 12sata 3.0 12speed 6.0 Gb/s 12type HDD 12rpm 7200
    12serial <filter> 12rev 1A01 12temp 41 C
  12SMART yes 12state enabled 12health PASSED 12on 2y 315d 12h 12cycles 3637
  12ID-9 /dev/sdg 12maj-min 8:96 12type USB 12vendor Western Digital 12model WD My Passport 25E2
    12drive model WD40NMZW-11GX6S1 12family Elements / My Passport (USB, AF) 12size 3.64 TiB 12block-size
    12physical 4096 B 12logical 512 B 12sata 3.1 12speed 6.0 Gb/s 12type HDD 12rpm 5400 12serial <filter>
    12drive serial <filter> 12rev 4004 12drive rev 01.01A01 12temp 43 C
  12SMART yes 12state enabled 12health PASSED 12on 1y 352d 20h 12cycles 383
  12ID-10 /dev/sdh 12maj-min 8:112 12type USB 12vendor SanDisk 12model Cruzer Blade 12size 7.45 GiB
    12block-size 12physical 512 B 12logical 512 B 12type N/A 12serial <filter> 12rev 1.27
  12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
12Partition:
  12ID-1 / 12raw-size 1.75 TiB 12size 1.72 TiB (98.37%) 12used 18.02 GiB (1.0%) 12fs ext4 12block-size 4096 B
    12dev /dev/sdc2 12maj-min 8:34
  12ID-2 /boot/efi 12raw-size 300 MiB 12size 299.4 MiB (99.80%) 12used 288 KiB (0.1%) 12fs vfat
    12block-size 512 B 12dev /dev/sdc1 12maj-min 8:33
12Swap:
  12Alert No swap data was found.
12Sensors:
  12System Temperatures 12cpu N/A 12mobo N/A 12gpu nouveau 12temp 38.0 C
  12Fan Speeds (RPM) N/A 12gpu nouveau 12fan 0
12Info:
  12Processes 394 12Uptime 1m 12wakeups 1 12Memory 31.34 GiB 12used 1.95 GiB (6.2%) 12Init systemd 12v 250
  12tool systemctl 12Compilers 12gcc 11.1.0 12clang 13.0.0 12Packages 12pacman 1323 12lib 374 12flatpak 0
  12Client Unknown Client: systemd 12inxi 3.3.12
[manjaro /]# journalctl -b -1 -p4
Jan 28 23:25:48 ryzen kernel:   #9 #10 #11 #12 #13 #14 #15
Jan 28 23:25:48 ryzen kernel: nvme nvme1: missing or invalid SUBNQN field.
Jan 28 23:25:48 ryzen kernel: ata3.00: ATA Identify Device Log not supported
Jan 28 23:25:48 ryzen kernel: ata6.00: supports DRM functions and may not be fully accessible
Jan 28 23:25:48 ryzen kernel: ata10.00: ATA Identify Device Log not supported
Jan 28 23:25:48 ryzen kernel: ata4.00: ATA Identify Device Log not supported
Jan 28 23:25:48 ryzen kernel: usb: port power management may be unreliable
Jan 28 23:25:48 ryzen systemd-journald[435]: File /var/log/journal/bea8f33586d94002b3e6eed88dbc4000/system.journal corrupted >
Jan 28 23:25:48 ryzen kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on>
Jan 28 23:25:48 ryzen kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Jan 28 23:25:48 ryzen kernel: nvidia: loading out-of-tree module taints kernel.
Jan 28 23:25:48 ryzen kernel: nvidia: module license 'NVIDIA' taints kernel.
Jan 28 23:25:48 ryzen kernel: Disabling lock debugging due to kernel taint
Jan 28 23:25:48 ryzen kernel: sd 10:0:0:0: [sdg] No Caching mode page found
Jan 28 23:25:48 ryzen kernel: sd 10:0:0:0: [sdg] Assuming drive cache: write through
Jan 28 23:25:48 ryzen kernel: snd_hda_intel 0000:2f:00.4: no codecs found!
Jan 28 23:25:48 ryzen kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  495.46  Wed Oct 27 16:31:33 UTC 2021
Jan 28 23:25:49 ryzen kernel: scsi 10:0:0:1: Wrong diagnostic page; asked for 1 got 8
Jan 28 23:25:49 ryzen kernel: scsi 10:0:0:1: Failed to get diagnostic page 0x1
Jan 28 23:25:49 ryzen kernel: scsi 10:0:0:1: Failed to bind enclosure -19
Jan 28 23:25:49 ryzen kernel: hid-generic 0003:1852:7921.0005: No inputs registered, leaving
Jan 28 23:25:49 ryzen kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Jan 28 23:25:50 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:Master Playback Volume:0 is already present
Jan 28 23:25:50 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:Master Playback Switch:0 is already present
Jan 28 23:25:50 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:Capture Volume:0 is already present
Jan 28 23:25:50 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:Capture Switch:0 is already present
Jan 28 23:25:50 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:Analog-Mic2 Capture Volume:0 is already present
Jan 28 23:25:50 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:Analog-Mic2 Capture Switch:0 is already present
Jan 28 23:25:50 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:What U Hear Capture Volume:0 is already present
Jan 28 23:25:50 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:What U Hear Capture Switch:0 is already present
Jan 28 23:25:50 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:Mic1-Boost (30dB) Capture Switch:0 is already present
Jan 28 23:25:50 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:HP/Speaker Playback Switch:0 is already present
Jan 28 23:25:50 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:AMic1/DMic Capture Switch:0 is already present
Jan 28 23:25:50 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:HP/Speaker Auto Detect Playback Switch:0 is already p>
Jan 28 23:25:50 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:AMic1/DMic Auto Detect Capture Switch:0 is already pr>
Jan 28 23:25:50 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:Surround Playback Switch:0 is already present
Jan 28 23:25:50 ryzen kernel: snd_hda_codec_ca0132: probe of hdaudioC0D2 failed with error -16
Jan 28 23:25:50 ryzen kernel: general protection fault, probably for non-canonical address 0xf5eabe7bdb6ccfd0: 0000 [#1] PREE>
Jan 28 23:25:50 ryzen kernel: CPU: 8 PID: 274 Comm: kworker/8:2 Tainted: P           OE     5.15.16-1-MANJARO #1 b9dc4de00f51>
Jan 28 23:25:50 ryzen kernel: Hardware name: Micro-Star International Co., Ltd. MS-7D53/MPG X570S EDGE MAX WIFI (MS-7D53), BI>
Jan 28 23:25:50 ryzen kernel: Workqueue: events snd_hdac_bus_process_unsol_events [snd_hda_core]
Jan 28 23:25:50 ryzen kernel: RIP: 0010:call_jack_callback+0x1d/0xe0 [snd_hda_codec]
Jan 28 23:25:50 ryzen kernel: Code: fe ff ff 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 41 55 41 89 f5 41 54 49 89 d4 55 48>
Jan 28 23:25:50 ryzen kernel: RSP: 0018:ffffb44d41ff7e38 EFLAGS: 00010286
Jan 28 23:25:50 ryzen kernel: RAX: 0000000000000000 RBX: f5eabe7bdb6ccfb8 RCX: 0000000000000000
Jan 28 23:25:50 ryzen kernel: RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
Jan 28 23:25:50 ryzen kernel: RBP: ffff9f72c760f800 R08: 0000000000000000 R09: 0000000000000000
Jan 28 23:25:50 ryzen kernel: R10: 0000000000000000 R11: 0000000000000000 R12: ffff9f72c70d3c70
Jan 28 23:25:50 ryzen kernel: R13: 000000000ec00001 R14: 0000000000000000 R15: ffff9f79bec36905
Jan 28 23:25:50 ryzen kernel: FS:  0000000000000000(0000) GS:ffff9f79bec00000(0000) knlGS:0000000000000000
Jan 28 23:25:50 ryzen kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jan 28 23:25:50 ryzen kernel: CR2: 00007f0724620698 CR3: 00000006a2010000 CR4: 0000000000750ee0
Jan 28 23:25:50 ryzen kernel: PKRU: 55555554
Jan 28 23:25:50 ryzen kernel: Call Trace:
Jan 28 23:25:50 ryzen kernel:  <TASK>
Jan 28 23:25:50 ryzen kernel:  snd_hda_jack_unsol_event+0x95/0x150 [snd_hda_codec e1091118c4360d376c3bb86df2bc5d8684474b72]
Jan 28 23:25:50 ryzen kernel:  snd_hdac_bus_process_unsol_events+0x84/0xb0 [snd_hda_core 714c00848bb72520aab92ee065f07d84c626>
Jan 28 23:25:50 ryzen kernel:  process_one_work+0x1e8/0x3c0
Jan 28 23:25:50 ryzen kernel:  worker_thread+0x50/0x3c0
Jan 28 23:25:50 ryzen kernel:  ? process_one_work+0x3c0/0x3c0
Jan 28 23:25:50 ryzen kernel:  kthread+0x132/0x160
Jan 28 23:25:50 ryzen kernel:  ? set_kthread_struct+0x50/0x50
Jan 28 23:25:50 ryzen kernel:  ret_from_fork+0x22/0x30
Jan 28 23:25:50 ryzen kernel:  </TASK>
Jan 28 23:25:50 ryzen kernel: Modules linked in: btbcm btintel amd64_edac(-) cfg80211 bluetooth snd_usb_audio(+) r8169 snd_us>
Jan 28 23:25:50 ryzen kernel: ---[ end trace 1ecbd447bd201112 ]---
Jan 28 23:25:50 ryzen kernel: iwlwifi 0000:28:00.0: api flags index 2 larger than supported by driver
Jan 28 23:25:50 ryzen kernel: thermal thermal_zone0: failed to read out thermal zone (-61)
Jan 28 23:25:51 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:Master Playback Volume:0 is already present
Jan 28 23:25:51 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:Master Playback Switch:0 is already present
Jan 28 23:25:51 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:Capture Volume:0 is already present
Jan 28 23:25:51 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:Capture Switch:0 is already present
Jan 28 23:25:51 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:Analog-Mic2 Capture Volume:0 is already present
Jan 28 23:25:51 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:Analog-Mic2 Capture Switch:0 is already present
Jan 28 23:25:51 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:What U Hear Capture Volume:0 is already present
Jan 28 23:25:51 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:What U Hear Capture Switch:0 is already present
Jan 28 23:25:51 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:Mic1-Boost (30dB) Capture Switch:0 is already present
Jan 28 23:25:51 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:HP/Speaker Playback Switch:0 is already present
Jan 28 23:25:51 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:AMic1/DMic Capture Switch:0 is already present
Jan 28 23:25:51 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:HP/Speaker Auto Detect Playback Switch:0 is already p>
Jan 28 23:25:51 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:AMic1/DMic Auto Detect Capture Switch:0 is already pr>
Jan 28 23:25:51 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:Surround Playback Switch:0 is already present
Jan 28 23:25:51 ryzen kernel: snd_hda_codec_ca0132: probe of hdaudioC0D2 failed with error -16
Jan 28 23:25:51 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:IEC958 Default PCM Playback Switch:0 is already prese>
Jan 28 23:25:51 ryzen kernel: snd_hda_codec_generic: probe of hdaudioC0D2 failed with error -16
Jan 28 23:25:51 ryzen kernel: kauditd_printk_skb: 54 callbacks suppressed
Jan 28 23:25:51 ryzen kernel: hdaudio hdaudioC0D2: Unable to configure, disabling
Jan 28 23:25:55 ryzen kernel: CIFS: No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or la>
Jan 28 23:25:55 ryzen kernel: FS-Cache: Duplicate cookie detected
Jan 28 23:25:55 ryzen kernel: FS-Cache: O-cookie c=00000003 [p=00000002 fl=222 nc=0 na=1]
Jan 28 23:25:55 ryzen kernel: FS-Cache: O-cookie d=000000005c487269{CIFS.server} n=000000007fa05820
Jan 28 23:25:55 ryzen kernel: FS-Cache: O-key=[8] '020001bdc0a8001c'
Jan 28 23:25:55 ryzen kernel: FS-Cache: N-cookie c=00000004 [p=00000002 fl=2 nc=0 na=1]
Jan 28 23:25:55 ryzen kernel: FS-Cache: N-cookie d=000000005c487269{CIFS.server} n=00000000479c9959
Jan 28 23:25:55 ryzen kernel: FS-Cache: N-key=[8] '020001bdc0a8001c'
Jan 28 23:25:55 ryzen kernel: FS-Cache: N-cookie c=00000005 [p=00000002 fl=2 nc=0 na=1]
Jan 28 23:25:55 ryzen kernel: FS-Cache: N-cookie d=000000005c487269{CIFS.server} n=00000000918cbae8
Jan 28 23:25:55 ryzen kernel: FS-Cache: N-cookie c=00000006 [p=00000002 fl=2 nc=0 na=1]
Jan 28 23:25:55 ryzen kernel: FS-Cache: N-cookie d=000000005c487269{CIFS.server} n=0000000021e0635d
Jan 28 23:25:56 ryzen kernel: FS-Cache: O-cookie c=00000003 [p=00000002 fl=222 nc=0 na=1]
Jan 28 23:25:56 ryzen kernel: FS-Cache: O-cookie d=000000005c487269{CIFS.server} n=000000007fa05820
Jan 28 23:25:56 ryzen kernel: FS-Cache: O-key=[8] '020001bdc0a8001c'
Jan 28 23:25:56 ryzen kernel: FS-Cache: N-cookie c=00000007 [p=00000002 fl=2 nc=0 na=1]
Jan 28 23:25:56 ryzen kernel: FS-Cache: N-cookie d=000000005c487269{CIFS.server} n=000000001d664b74
Jan 28 23:25:56 ryzen kernel: FS-Cache: N-key=[8] '020001bdc0a8001c'
Jan 28 23:25:56 ryzen kernel: FS-Cache: Duplicate cookie detected
Jan 28 23:25:56 ryzen kernel: FS-Cache: N-cookie c=00000008 [p=00000002 fl=2 nc=0 na=1]
Jan 28 23:25:56 ryzen kernel: FS-Cache: N-cookie d=000000005c487269{CIFS.server} n=00000000463b000a
Jan 28 23:27:20 ryzen systemd[1]: systemd-logind.service: start operation timed out. Terminating.
and journal:
Jan 28 23:25:48 ryzen systemd-journald[435]: File /var/log/journal/bea8f33586d94002b3e6eed88dbc4000/system.journal corrupted or uncleanly shut d>
Jan 28 23:25:48 ryzen kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Jan 28 23:25:50 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:HP/Speaker Auto Detect Playback Switch:0 is already present
Jan 28 23:25:50 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:AMic1/DMic Auto Detect Capture Switch:0 is already present
Jan 28 23:25:50 ryzen kernel: general protection fault, probably for non-canonical address 0xf5eabe7bdb6ccfd0: 0000 [#1] PREEMPT SMP NOPTI
Jan 28 23:25:50 ryzen kernel: CPU: 8 PID: 274 Comm: kworker/8:2 Tainted: P           OE     5.15.16-1-MANJARO #1 b9dc4de00f51b119e02c16819fef338>
Jan 28 23:25:50 ryzen kernel: Hardware name: Micro-Star International Co., Ltd. MS-7D53/MPG X570S EDGE MAX WIFI (MS-7D53), BIOS 1.10 12/27/2021
Jan 28 23:25:50 ryzen kernel: Code: fe ff ff 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 41 55 41 89 f5 41 54 49 89 d4 55 48 89 fd 53 48 8b 5a >
Jan 28 23:25:50 ryzen kernel:  snd_hdac_bus_process_unsol_events+0x84/0xb0 [snd_hda_core 714c00848bb72520aab92ee065f07d84c6260b6b]
Jan 28 23:25:50 ryzen kernel: Modules linked in: btbcm btintel amd64_edac(-) cfg80211 bluetooth snd_usb_audio(+) r8169 snd_usbmidi_lib snd_rawmi>
Jan 28 23:25:51 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:HP/Speaker Auto Detect Playback Switch:0 is already present
Jan 28 23:25:51 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:AMic1/DMic Auto Detect Capture Switch:0 is already present
Jan 28 23:25:51 ryzen kernel: snd_hda_intel 0000:26:00.0: control 2:0:0:IEC958 Default PCM Playback Switch:0 is already present
Jan 28 23:25:55 ryzen kernel: CIFS: No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3.1.1)>
Your system is still using the free drivers for GPU, while you have installed the proprietary ones.
Try this:
sudo mhwd -r pci video-linux
sudo mhwd -F -i pci video-nvidia
You should be able to do this from TTY, not only from chrooted system, but see what works best for you.
I did this. Installed successfuly from tty. So rebooted after instalation and still having problem to login. Black screen with mouse cursor and no login manager, also cannot login with TTY. After third reboot successfuly logged. What to check next?
you are logged with GUI or TTY ?
I’m logged with GUI.
After third reboot login to GUI succeed. Maybe SDDM doesn’t like my nvidia?
This happens with every distribution that I tried: Ubuntu, Debian, Arch, Garuda, PopOS.
Previously had Intel CPU, motherboard, different RAM, SSD - the same problems.
The only hardware that didn’t change is Nvidia graphics card, Creative audio card and PSU.
