V18.0.1 xfce bugs
xfce
#1
Hey I’m not sure where to put general bugs but I’ll consolidate things I’ve found in v18.0.1 and put new items here.
#1 V18 xfce: “xflock4” doesn’t activate xscreensaver (also confirmed after installing non-free nvidia) Thanks to @lectrode we have this fixed (see link.)
#2 V18 xfce: Hexchat has no sounds and segfaults on exit?
#3: the “sticky keys” enabled/disabled notification randomly pops up usually during the start of boot and is usally triggered by some combination (or random keypresses) of ctrl, shift, numlock (or number keys when numlock isn’t activated), or my custom-binded “mouse3” button, which is hardware-mapped to “ctrl+w” – which I always use for closing tabs/windows quickly. Going into the accessability preferences always show sticky keys unchecked so I’m not even sure if this “shortcut” is somehow triggered with keystrokes? (Like how in windows if shift is pressed 5 times in a row.)
^edit: Thanks to @Hipster for providing the correct missing numlock property in the ~/.config/xfce4/xfconf/xfce-perchannel-xml/keyboards.xml file per this post which seems to lessen the problem when numlock is initally on, but they sporadically still occur.
#4 (on Nouveau) if media content (like a video or music visualization from audacious) is playing behind thunar windows, these windows sporadically freak out (possibly on mouse hover over an inactive thunar window) and don’t display/render normally until selected and moved. It’s hard to describe and I wish I had a screen recording but I’ve since installed non-free nvidia for hw acceleration purposes and haven’t experienced this issue yet under the new driver.
Auto num lock xfce
[Testing Update] 2019-01-03 - Pacman, Pamac, Deepin, Haskell, Python
#2
#3: That happens to me too, now that i know it’s not my netty screwing on me i’ll try to investigate this.
#3
I suppose the way we can determine if it’s xfsettingsd or not, disable the startup script (“XFCE-Panel Workaround”) in the session settings and then run xfsettingsd --replace & manually if the theme reverts back to adwaita and a breeze cursor – keeping an eye on immediate notifications that may come up. Weirdly, they don’t even register in the notifications log.
edit: nevermind the notifications still randomly occur.
[Testing Update] 2019-01-27 - Kernels, Browsers, CertBot, Deepin, Wine
#4
Only one of them appears to me, and only in the first boot so i don’t really have a problem with that.
