/usr/local uses and security
So I just set my /usr/local folder to belong to root:wheel so I could use it without a password on my admin account. Is this safe to do? Is it practical? What does Manjaro even use it for?
None of the Linux relevant files are located in /usr/local.
https://refspecs.linuxfoundation.org/FHS_3.0/fhs/ch04s09.html
You can use it to store locally provide applications. E.g. self compile binaries, your own scripts, etc.
From that point of view the ownership of /usr/local is more a matter of convenience than security.
Why?
If you want a location for your user to write to then just use your $HOME .
This directory is for system-wide local-system files, e.g. system administrator-managed files rather than package-managed files.
awesome! this is exactly the kind of thing i want to use it for i just dont want admins (wheel group) to need a password as a matter of convinience and i wanted to make sure i didnt compromise my security to do so.
i want a public location that all users can read and execute from and allow admins to write to as well.
Sounds like an ideal use of /usr/local .
There's no real need to change the group permissions though - if members of the wheel group have sudo rights then they can write to any filesystem location already.
I just wanted to avoid having to use sudo but I wanted to make sure this was safe to do.
