Hello everyone, I recently got a Razer Naga Chroma and have gotten the control of the colors using the openrazer-meta package drivers.
The mouse has 12 configurable buttons (which each work and print their corresponding number) that I would like to execute keyboard commands and scripts.
How can I do this?
The wiki page was less than forthcoming on that regard.
I’m on Manjaro KDE.
Kernel: 6.4.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.4-x86_64
root=UUID=f11386cf-342d-47ac-84e6-484b7b2f377d rw rootflags=subvol=@
radeon.modeset=1 nvdia-drm.modeset=1 quiet
cryptdevice=UUID=059df4b4-5be4-44d6-a23a-de81135eb5b4:luks-disk
root=/dev/mapper/luks-disk apparmor=1 security=apparmor
resume=/dev/mapper/luks-swap udev.log_priority=3
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4408
date: 10/27/2022
System RAM: total: 64 GiB note: est. available: 62.71 GiB
used: 28.12 GiB (44.8%)
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 4039 high: 4100 min/max: 2200/6358 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4100 2: 4100
3: 4098 4: 4098 5: 4100 6: 4099 7: 4100 8: 4099 9: 4098 10: 4099 11: 4099
12: 4100 13: 4098 14: 4099 15: 4100 16: 4100 17: 4100 18: 4100 19: 4096
20: 4098 21: 2200 22: 4098 23: 4100 24: 4099 25: 4100 26: 4099 27: 4099
28: 4099 29: 4100 30: 4100 31: 4093 32: 4088 bogomips: 262515
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spec_rstack_overflow mitigation: safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK driver: nvidia
v: 535.98 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 0b:00.0 chip-ID: 10de:2484 class-ID: 0300
Device-2: AMD Cape Verde PRO [Radeon HD 7750/8740 / R7 250E]
vendor: VISIONTEK driver: radeon v: kernel alternate: amdgpu arch: GCN-1
code: Southern Islands process: TSMC 28nm built: 2011-20 pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 ports: active: DP-3,DP-4
empty: DP-1, DP-2, DP-5, DP-6 bus-ID: 0c:00.0 chip-ID: 1002:683f
class-ID: 0300 temp: 59.0 C
Device-3: Microdia USB 2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 9-2:3 chip-ID: 0c45:6367
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: radeonsi
gpu: radeon display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x2160 s-dpi: 80 s-size: 1829x686mm (72.01x27.01")
s-diag: 1953mm (76.91")
Monitor-1: DP-1 pos: 1-2 res: 1920x1080 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Monitor-2: DP-1-3 pos: 2-1 res: 1920x1080 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
Monitor-3: DP-1-4 pos: 1-1 res: 1920x1080 dpi: 93
Monitor-4: DP-3 pos: primary,2-2 res: 1920x1080 dpi: 82
Monitor-5: DP-4 pos: 2-4 res: 1920x1080 dpi: 82
Monitor-6: HDMI-0 pos: 1-3 res: 1920x1080 dpi: 93
API: OpenGL v: 4.6.0 NVIDIA 535.98 renderer: NVIDIA GeForce RTX
3070/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 0b:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series] vendor: VISIONTEK driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 0c:00.1
chip-ID: 1002:aab0 class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Schiit Audio Unison Universal Dac driver: snd-usb-audio type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 30be:1019
class-ID: 0102
Device-5: JMTek LLC. Plugable USB Audio Device
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 5-2:3 chip-ID: 0c76:120b class-ID: 0300
serial: <filter>
Device-6: ASUSTek ASUS AI Noise-Cancelling Mic Adapter
lanes: 1 mode: 1.1 bus-ID: 5-4:4 chip-ID: 0b05:194e class-ID: 0300
serial: <filter>
Device-7: Microdia USB 2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.4.9-1-MANJARO status: kernel-api
Server-2: PipeWire v: 0.3.77 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-5.3:7
chip-ID: 0a12:0001 class-ID: e001
Device-1: luks-c847cf9f-c6b5-4624-a25e-4531e318851a maj-min: 254:2
type: LUKS dm: dm-2 size: 3.64 TiB
Components:
p-1: sda1 maj-min: 8:1 size: 3.64 TiB
Device-2: luks-swap maj-min: 254:1 type: LUKS dm: dm-1 size: 12 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 12 GiB
Device-3: luks-disk maj-min: 254:0 type: LUKS dm: dm-0 size: 919.01 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 919.01 GiB
Local Storage: total: 9.1 TiB used: 3.46 TiB (38.0%)
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 111110WD temp: 55.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 211070WD temp: 50.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD4005FZBX-00K5WB0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1A01 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
ID-5: /dev/sdc maj-min: 8:32 vendor: SanDisk model: Gaming Xbox 360
size: 7.48 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 8.02
scheme: MBR
ID-1: / raw-size: 919.01 GiB size: 919.01 GiB (100.00%)
used: 758.88 GiB (82.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-disk label: N/A uuid: N/A
used: 40.2 MiB (7.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: EFI
uuid: 8922-E04D
ID-3: /home raw-size: 919.01 GiB size: 919.01 GiB (100.00%)
ID-4: /run/media/sarah/ConvergentRefuge raw-size: 3.64 TiB
size: 3.64 TiB (100.00%) used: 2.55 TiB (70.2%) fs: btrfs dev: /dev/dm-2
maj-min: 254:2 mapped: luks-c847cf9f-c6b5-4624-a25e-4531e318851a
label: ConvergentRefuge uuid: 7d295e73-4143-4eb1-9d22-75a06b1d2984
ID-5: /run/media/sarah/MSS_EXtended raw-size: 475.51 GiB
size: 475.51 GiB (100.00%) used: 170.06 GiB (35.8%) fs: btrfs
dev: /dev/nvme1n1p1 maj-min: 259:5 label: MSS EXtended
uuid: f98b3a12-e0e4-48c7-91c2-6e3aa6dcd32c
ID-1: swap-1 type: partition size: 12 GiB used: 127.8 MiB (1.0%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1 mapped: luks-swap label: SWAP
uuid: c8991364-85a7-4e6c-8380-49cd5bd7a873
ID-1: /dev/nvme1n1p2 maj-min: 259:6 size: 456 GiB fs: ntfs label: N/A
uuid: 5ECA358FCA356485
ID-2: /dev/sdb1 maj-min: 8:17 size: 3.64 TiB fs: ntfs
label: JerichoVariance uuid: 1AB22D5664889CBD
ID-3: /dev/sdc1 maj-min: 8:33 size: 3.59 GiB fs: iso9660
ID-4: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 1517-A94A
Hub-2: 1-2:2 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 chip-ID: 045b:0209 class-ID: 0900
Device-1: 1-4:3 info: Microsoft Xbox One Controller (Firmware 2015)
type: <vendor specific> driver: xpad interfaces: 3 rev: 2.0
chip-ID: 045e:02dd class-ID: ff00 serial: <filter>
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.0
Hub-4: 2-2:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 chip-ID: 045b:0210 class-ID: 0900
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-6: 3-1:2 info: VIA Labs Hub ports: 4 rev: 2.1
chip-ID: 2109:3431 class-ID: 0900
Hub-7: 3-1.2:3 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2813
Hub-8: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
Hub-9: 4-2:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0813
Hub-10: 5-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 5-1:2 info: Schiit Audio Unison Universal Dac type: audio
driver: snd-usb-audio interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 30be:1019 class-ID: 0102
Device-2: 5-2:3 info: JMTek LLC. Plugable USB Audio Device type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
chip-ID: 0c76:120b class-ID: 0300 serial: <filter>
Device-3: 5-4:4 info: ASUSTek ASUS AI Noise-Cancelling Mic Adapter
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
chip-ID: 0b05:194e class-ID: 0300 serial: <filter>
Hub-11: 5-5:5 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 5-5.3:7 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-12: 5-6:6 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-13: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-14: 7-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 7-4:2 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
serial: <filter>
Device-2: 7-6:3 info: SanDisk Cruzer Micro Flash Drive type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 200mA chip-ID: 0781:5151 class-ID: 0806
serial: <filter>
Hub-15: 8-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-16: 9-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-17: 9-1:2 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
chip-ID: 1a40:0201 class-ID: 0900
Device-1: 9-1.1:4 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
type: mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: 1bcf:08a0 class-ID: 0301
Device-2: 9-1.4:6 info: Razer USA Naga Chroma type: mouse,keyboard
driver: razermouse,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:0053 class-ID: 0300
Device-3: 9-1.5:8 info: Microdia Backlit Gaming Keyboard
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 400mA
chip-ID: 0c45:652f class-ID: 0301
Device-4: 9-1.6:9 info: HUION H420 type: mouse,HID driver: uclogic,usbhid
interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 256c:006e class-ID: 0300
Hub-18: 9-1.7:11 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 9-1.7.2:12 info: GoPro MMP SDK type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 4255:0001 class-ID: 0000 serial: <filter>
Device-2: 9-1.7.4:14 info: Texas Instruments TI-Nspire Calculator
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 0451:e012 class-ID: 0000
Device-3: 9-2:3 info: Microdia USB 2.0 Camera type: video,audio
chip-ID: 0c45:6367 class-ID: 0102 serial: <filter>
Device-4: 9-3:10 info: VKB-Sim © Alex Oz 2021 VKBsim Gladiator EVO R
type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0
chip-ID: 231d:0200 class-ID: 0300
Device-5: 9-4:13 info: VKB-Sim © Alex Oz 2021 VKBsim Gladiator EVO L
chip-ID: 231d:0201 class-ID: 0300
Hub-19: 10-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 41.5 C mobo: 45.0 C gpu: radeon temp: 58.0 C
Fan Speeds (rpm): fan-1: 863 fan-2: 779 fan-3: 1004 fan-4: 941 fan-5: 3117
fan-6: 0 fan-7: 0
Processes: 803 Uptime: 2h 20m wakeups: 1 Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
clang: 15.0.7 Packages: 2273 pm: pacman pkgs: 2213 libs: 513 tools: pamac,yay
pm: flatpak pkgs: 43 pm: snap pkgs: 17 Shell: Bash v: 5.1.16
running-in: yakuake inxi: 3.3.29
