Using livecd v17.0.1 as grub to boot OS with broken bootloader
grub
boot
#1
For most cases (no separate boot, manjaro grub.cfg still good, etc…) this will do.
Start here first.
##################### Simple First Start ########################
  1. boot up livecd in the right mode, uefi or bios-legacy
  2. Do not boot up to live OS, but press ‘c’ at the menu and we’ll get to the grub prompt (grub>).
grub> search.file /etc/manjaro-release  root
grub> configfile /boot/grub/grub.cfg
  1. When booted
sudo grub-install /dev/sda
sudo update-grub
  1. Done.
ps: If UEFI and it is a new installation that does not boot after installation, do the 2 “UEFI - Additional Commands” below at end of Step 4.
##################### End Simple First Try #####################
See below if it’s more ‘complicated’ (like your relationship with your boyfriend/girlfriend).
{And perhaps it’s time to have a simple setup (or relationship - like getting a dog?}
################### ‘More Complicated Setups’ #######################
You may want to check out this link first if the ‘comprehensive’ details here are confusing.
Warning: the link is not that easy either.
Install media versions 17.0.1 and above is using grub as boot mechanism.
Therefore we can use this grub to boot our installed OS’s in case our OS bootloader fail for whatever reason. To do this…
  1. Take the manjaro livecd and start it up in the same mode as your installation (uefi or bios-legacy).
  3. To be sure you’ve started up livecd in the right mode, at grub prompt, check output of
grub> echo $grub_platform
If output is pc, you’ve booted up in bios-legacy.
If output is efi, you’ve booted up in uefi.
If you’re in the wrong mode, reboot livecd in the right mode.
  1. If there are multiple Manjaro’s or if there is a separate boot partition,
    See sections below for required command changes, otherwise proceed right here.
And if the bootloader is broken due to a messed up manjaro grub.cfg itself,
the configfile method won’t work as configfile will just bring up the bad grub.cfg itself.
Then we will need to boot to the kernels directly.
grub> probe -u $root --set=abc
grub> ls ($root)/boot/
  1. copy down kernel and initrd file, say vmlinuz-4.14-x86_64 and initramfs-4.14-x86_64.img
    Use the right kernel below like 4.18 or 4.19 or…
grub> linux /boot/vmlinuz-4.19-x86_64 root=UUID=$abc rw
grub> initrd /boot/initramfs-4.19-x86_64.img
grub> boot
  1. When booted up to manjaro installed OS, at terminal
    Make sure you have version grub 2.03.2-1 or later (check with pacman -Q grub)
    Otherwise, to get it
 pacman -Syyuu
  1. In /etc/default/grub, make sure you have one of the following specified.
    GRUB_TIMEOUT_STYLE=menu
    GRUB_TIMEOUT_STYLE=hidden
    GRUB_TIMEOUT_STYLE=countdown
  2. Also in /etc/default/grub, make sure you have
    GRUB_TIMEOUT=5 (or more; suggest 10, change to 5 later on when you feel more confident)
  3. At terminal,
sudo rm /boot/grub/grubenv
sudo grub-editenv /boot/grub/grubenv create
sudo grub-editenv - set boot_success=0
sudo update-grub
If uefi system, do 2 additional commands listed in section [UEFI - additional commands] below.
  1. Done.
Step 4 variations
and you need to boot up to the right one,
at step 4 above, substitute with
There will be multiple output of your manjaro partitions, use the right one (say (hd2,5)) you want to boot into as follows
grub> set root=(hd2,5)
Then continue with step 5.
If there is a separate boot partition
At step 4 above,
Find out where the /boot partition is, and if there is no other OS (like Arch) with intel-ucode.img
grub> search.file /intel-ucode.img root
If there is another OS with intel-ucode.img (like Arch or another Manjaro) (and their own separate /boot partition)
grub> search.file intel-ucode.img
There will be multiple output, use the right one (say (hd2,5)) and
But step 6 will be (without ‘/boot/’ in linux and initrd lines)
grub> linux /vmlinuz-4.19-x86_64 root=UUID=$abc rw
grub> initrd /initramfs-4.19-x86_64.img
grub> boot
If system is uefi, the following additional commands are required at the end of step 6.
sudo cp /boot/grub/x86_64-efi/core.efi /boot/efi/EFI/boot/bootx64.efi
sudo efibootmgr -c -d /dev/sda -p 1 -L "manjaro" -l "\EFI\Manjaro\grubx64.efi"
Note the second command above is for $esp in sda1.
Change accordingly if it is not. This command " findmnt /boot/efi " will confirm the $esp partition.
So if $esp is sdb3 or if $esp is /dev/nvme0n1p2, the respective commands are
sudo efibootmgr -c -d /dev/sdb -p 3 -L "manjaro" -l "\EFI\Manjaro\grubx64.efi"
sudo efibootmgr -c -d /dev/nvme0n1 -p 2 -L "manjaro" -l "\EFI\Manjaro\grubx64.efi"
UEFI - if problem persists (or if unsure what to do)
If after doing the above, including at step 6 the 2 additional commands, post in a new topic (or an existing open topic) together with the following output from the terminal when booted to the installed Manjaro OS. And state computer make and model.
efibootmgr -v
sudo parted -l
sudo blkid
findmnt -s
findmnt /boot/efi
Note: ‘parted -l’ --> small ‘L’ and provide information of all disks.
And please print out output, not screen shots.
Some difficult UEFI setups
  1. Lenovo -
    some models are tied in with Microsoft and will only boot to windows efi file.
    to work around it we can ‘fake’ manjaro efi as the windows efi
    or to remove windows totally, and lenovo will look for another efi file.
    This link may help.
  2. HP -
    in some models, the UEFI firmware is flaky
    some members have chosen to use bios-legacy instead.
    This link may help.
    Or screen shot here at post 30.
  3. MSI -
    The ‘gaming’ models need to have these settings in bios settings (F2)
    Turn off secure boot
    Set boot to UEFI (DO NOT USE CSM)
    Set TPM to 2.0 with 1.x compatibility
  4. Asus -
    A small number of models need these F2 settings
    Add a new custom bootentry
    Set the path to that bootentry efi file
    Create the bootentry and make it default.
    This link may help.
  5. Acer -
    At bios settings, enable ‘secure boot’. :open_mouth:
    Add Manjaro efi file to “whitelist”
    Go back to change boot order to ‘manjaro’
    Disable secure boot (optional)
    This link with screen shots here.
Grub miss comfigure after update. Black screen
How to boot into my newly instaled manjaro?
Cannot recover grub after BIOS/UEFI update
Dual Boot Question Again
[Solved] Cannot load Manjaro Partition of Dual Boot after Windows 10 Update
Unable to install Manjaro 17.0.1 KDE - Boost.Python-Fehler in Job "bootloader"
Confusing instructions on "Restore the GRUB Bootloader" wiki
Manjaro Xfce installation problem
[Solved][GRUB Problem] grub rescue but the installation done on external drive
Dual booting Manjaro on MBR disk with Windows 10 installed in legacy mode
[solved] Can’t boot Manjaro on Intel NUC 8i7HVK
Grub rescue options
Windows 10 EFI Dual Boot: Boot directly to windows
Crash during GRUB reinstallation "executing efibootmgr.."
Update-grub error: check your device.map
Improving the Manjaro installer for dual-booting with Windows 10 and UEFI
Cannot boot after installation Manjaro KDE version
No such device, unknown file system, enter grub secure
Slow boot to Manjaro, strange update-grub output
KDE 18.03 installs, then boot to grub rescue, every time, on Dell inspiron 1525 (Resolved by installing 18.04)
Black screen on boot after grub on fresh install
[SOLVED] Unable to overwrite Windows Boot Manager with GRUB in external drive with dual boot setup
rEFInd boot issue after reinstallation
Dual Boot Manjaro-Windows / Windows reinstall failed
[SOLVED] Successful Manjaro install - but still only boots to Windows
Boot problems - only seeing 1 out of 3 distros installed
[Solved] Strange GRUB behaviour - sda GRUB not working
V18.0.3 installation media fails with encryption in autopartition mode
Need to reinstall grub Windows+Manjaro hdd+ssd
Installing windows alongide my Manajaro installation
[SOLVED] How to properly restore GRUB with EFI boot?
Unable to resize partition in either GParted or KDE partition manager
Help with Grub(s)
Windows 10 - Update 1809 breaking grub
Update stopped at grubsection, cant restart pamac. Can i Reboot?
Booting multiple OSs from multiple EFI paritions and Restoring Windows and Manjaro Boot after losing EFI Partition
Broke my Manjaro installation... again
[SOLVED] Grub issues with GUID partition table warnings in dual boot setup
Reinstall Windows 10 while keeping Manjaro as main OS
Grub takes very long (several minutes) to open Menu
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) - again
Cant boot into OS after disconnecting ssd from MB [SOLVED]
Windows 10 Manjaro Dualboot
BIOS install won't boot into grub
Dual boot with Windows 10 + Manjaro doesn't show up a grub menu
After install Manjaro only boots into grub rescue
Well....I deleted my /boot/efi partition accidently
Another "can't boot after clean install" post
Creating partition for windows dual boot
Stuck during boot
Installed manjaro on top of my existing manjaro partition now I am getting problems
Latest update broke my system: Can't get into TTY
Can not boot Manjaro after kernel update
Dropped into emergency shell without keyboard access due to a failed hibernation
Help me with kernel panic in manjaro xfce
Cant boot into Manjaro anymore
[Solved] Create New & Paste options are greyed out in right click
[SOLVED] Dual boot Manjaro & Windows 10 Not showing Grub (Acer Aspire E15 E5-573G)
Error Message, No System Commands Work, Can't Find Partitions
Grub does not list Windows, os-prober does nothing
How do I install manjaro kde over ubuntu in win 10 dual boot?
After crash, skips GRUB and boots straight to Windows
Manjaro Installation Error
Manjaro boot stuck at 'started Network Manager script dispatcher service'
Cannot boot alternative kernels
Video input devices working under kernel 4.19.13-1 not working under kernel 4.20.0-1 Manjaro 18 XFCE
[Stable Update] 2019-01-05 - Pacman, Pamac, Deepin, Haskell, Python
Unable to boot
MBR destroyed
GRUB issue (grub_rescue)
After fresh installation of Manjaro XFCE Windows 10 doesn't open
No grub uefi dual boot menu after Windows 10 update
[ 1.484958 usb 3-5: string descriptor 0 read error: - 22]
[wiki] Windows 10 - Manjaro - Dual-boot - Step by Step
Manjaro doesn't boot after system upgrade
Error: resume: hibernation device 'uuid=...' not found
Can't boot into Manjaro: File '/vmlinuz-4.14' not found
Manjaro (Gnome) 18.0 - random boot problems (Dell Inspiron 15-5559 and Crucial MX500 SSD)
Grub-install: error: /boot/efi doesn't look like en EFI partition
GRUB error - no such partition
Problem with dual booting manjaro and windows 7
Dual boot windows 10 / manjaro 18
New installation failed: warning: your core.img is unusually large
Error symbol 'grub_key_is_interrupt' not found
Grub not showing up after fresh install (Manjaro 18 GNOME/HP Elitebook 8460p)
[SOLVED] Boot loop before GRUB
Failing to boot from grub 'grub_efi_find_mmap_size' not found
/sys/firmware/efi/efivars: unknown filesystem type 'efivars'
Grub rescue - no such device - unknown filesystem after install
Impossible to reinstall grub
Dual booting Windows on a Manjaro PC
Problem with Booting on Grub
I can not install Manjaro on my laptop lenovo v330-15ikb 81AX!
The new silent boot - I dont think it's good to have it as default
Grub cannot find kernel
Unable to boot Manjaro, fix or re-install the Grub Boot loader
Installed Partition Can't Boot
MBR broke after updating to latest kernel
Problems installing Manjaro 17 KDE on my Dell Latitude E5550 laptop
Manjaro does no longer boot. grub broken
Calamares doesn't show list of disks to install bootloader
Manjaro not booting from hard disk, just stays in the boot menu
Boost Python error during installation
EFI firmware, do I need to keep windows?
Installation problem 17.02
Can't get Manjaro to install
No grub after Windows 10 upgrade
Uefi doesn't recognize bootloader after disconnecting and reconnecting the ssd
Restore GRUB after Windows 10 reinstall
The "Restore the GRUB Bootloader" in Manjaro wiki needs an update
Bad install, grub not loading properly on NVME? [KDE 17.0.2]
Problems getting grub to load on dual boot
Cannot boot manjaro after mobo replacement
Manjaro not booting after battery change
GRUB now not loading. Reinstall produces /proc/devices issue
Boost.Python error in job "bootloader"
Manjaro menuentry lost from grub
GRUB boots into rescue mode, unknown filesystem
Win 10 *** up my beloved Linux Manjaro
Windows Update: Grub Disappeared
Restore grub
Kernal Panic after upgrade
I broke my system with syslinux
Grub rescue
Disk have become unbootable [Solved]
UEFI: Manjaro is missing
[Solved] Grub3 error. can't install
Normal.mod not fround, entering rescue mod HELP! :(
[SOLVED] Manjaro new installation Black screen - no boot no grub
Grub problem with multible distros [Solved]]
Detecting efi files and booting them from grub
System Stuck at "GRUB _ "
Issues booting after attempted update
Installing Windows 10 for dual boot AFTER installing Manjaro?
Restore Manjaro boot
How can I fix dual boot with Manjaro after installing Elementary OS Loki alongside it?
Manjaro-Architect UEFI installation on VB issues
Tutorials Table Of Contents
/boot partition when re-installing Manjaro(dual-boot with Windows 10)
GRUB Bootloader Failed
Deleted Ubuntu Partition. How to fix grub?
UEFI Boot Dual Boot Issues
Can't boot Manjaro\get rid of GRUB in order to boot Manjaro
[Stable Update] 2018-03-27 - Kernels, Krita, Grub, Deepin, Pamac, Pacman-Mirrors, Firefox
GRUB not showing up on UEFI pc
Issue booting into Manjaro and Windows
Manjaro Gnome wont boot up
Boot repair fails asking for grub-efi-amd64 packages
HP Folio1040 boot device not found
Boot problem this morning
Freshly installed Manjaro GRUB minimal bash at boot
Grub Boot not working with EFI
Unable to Boot into Windows or Linux (Dualboot)
Data recovery after resizing partitions
Unable to Boot into Manjaro without using usb livecd
GRUB doesnt show up after installation of Manjaro-Deepin - Dual boot Windows 10 (UEFI)
No GRUB after installing Manjaro next to Windows 10
Dual boot problems
New install medias do not install bootloader
17.1.8 boot problem on fresh install & EFI
Replace Grub with EasyBCD bootloader?
/boot/efi doesn't look like an efi partition
Add grub to UEFI after installation
Error during bootup, related to disk mount
Manjaro-Architect UEFI Installation
Manjaro minimal bash-like line editing is supported
[Solved]GRUB error: unknown filesystem after Windows 10 1803 update
Problem reinstalling grub
Efibootmgr unable to create EFI entry
Dual Boot Windows & Manjaro, after fresh install of Windows, getting "Operating System Not Found"
$esp location in Nvme devices
Installation: Cannot install to hard drive (only to USB stick)
Boot and pad problem after installation
Possible future dual boot with two EFI partition's on two SSD's
Guide to setting up dual boot on NVMe drives?
Dell XPS nvme unknown filesystem
Cannot boot Windows 10 from second hard drive
Manjaro Boot Issues
Can't see Windows 10 in Grub after dual-boot install
No NVRAM entry
Problem after installation(Grub missing?)
Grub weg nach CPU Tausch
No NVRAM entry
Can't boot, no inittab file found, enter runlevel
After installing in dual boot configuration, computer always boots to Windows
Error! GRUB invalid arch-independent
Grub rescue error in dual booting alongside windows 7
Installing Manjaro XFCE on a computer with two hard drives
Not boot normally, only get it started from the live of manjaro when I tell him to detect efibots in the live menu
Hitting walls trying/installing XFCE 17.1.10
I want to dual boot windows 10 on a manjaro machine
Bricked my boot (I think)
Manjaro won't boot after installation
Error you need to load kernel first!
No boot entry found for manjaro also failed to get grub menu
Manjaro has kernel panic after installing opensuse
No wonder Linux is not used on the Desktop
Error: unknown filesystem - How to fix this grub error?
Boot sorunu manjaro açılmıyor
Lenovo Ideapad Y560P - Install Problem?
Boot failure. PC does not start
Es werden keine IMG geladen nach dem Boot
System not booting after update: "ERROR: device UUID <ID> not found. Skipping fsck.", dropped into emergency shell
Problem with dual boot manjaro and windows
How to restore the normal GRUB Menu and to restore the correct GRUB version
Grub-no list of OS choices on start up
Manjaro Duel Boot Win 10 on Asus Vivobook
Dual Boot Mystery - Grub never reached
Dual boot with windows 10 can't get into grub
[SOLVED] Newbie: is installing Manjaro without bootloader in dualboot safe?
17.1.10 fresh install only boots using usb media detect efi
Welcome to GRUB - No Kernels to select - with AMDGPU and RADEON (Manjaro 17.1.10 Hakoila)
Can't boot Manjaro on Lenovo 320 15AST
Desktop won't boot into Manjaro and only gets to Grub with Ubuntu, while it can boot into Windows
Grub installation failed
Install Help - Bootloader / Grub
Trouble with Windows 10/Manjaro dual boot
Manjaro not starting. Can't find any solution and pinpoint exact reason!
Booting stuck with an "error: hibernation device not found" text
Restore Manjaro GRUB entry to UEFI menu
How can I access clean installation in shared partition with windows 10?
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) (working on initramfs)
Manjaro grub rescue unknown filesystem
Boot problems after installing Manjaro
Problems with Partition Schema (after Windows 10 Install)
Manjaro Deepin not present in boot loader after dual boot
Grub-install for Manjaro despite Manjaro installed without bootloader?
New to the forum, introduce yourself
Unable to set Manjaro Grub as default
No grub after fresh installation
Linux bootloaders not overriding windows bootloader
Avoid require system update of 1GB for reinstallation of grub from live CD (4 mon. old)
Cannot boot into Manjaro (stuck in grub)
Dual-boot manjaro , windows 7/10
Cant boot win 10 after installing manjaro linux
Couldnot found bootloader.initialising default.grub
Cannot modify my Grub
KDE not started
Boot to Windows not working after renaming efi to fix grub issue
Dual boot win10/manjaro gnome lands me at grub menu
"No bootable devices found" after installing Manjaro
[SOLVED] Windows Boot Manager and Manjaro
Manjaro KDE on MacBook Pro mid 2014
Messed up my grub and now can't boot
I installed Manjaro but I can't get to it
Bootloader broken after replacing Ubuntu installation with Manjaro (dual boot with Win 10)
Manjaro 17.11.1 grub rescue after install
System can't start after update 06.07
Welcome to GRUB! - black screen
Boot Stuck at TPM Error
Windows 10 doesn't show up on grub, tried common methods to solve it
Grub Rescue after windows 10 1803 update
Manjaro live USB crash dual boot Windows 10 eufi
UEFI option not showing up after installation (but USB thumb drive works fine)
Unable to see the bootloader on Windows 10 - Where did I go wrong?
Windows broke my bootloader
Manjaro boots directly to windows on UEFI, aparently is installed in BIOS
Installation as UEFI along with Windows 10- grub failing to install as default bootloader
Grub Error Unknown File System
Grub-mkrescue - making a bootable grub cd
GRUB is not detected by UEFI BIOS, only by live usb
How to restore win10 in grub menu
[TOC] Boot-GRUB problems
Dual Boot Win 10 EFI
Seemingly correct NTFS partition not recognized as EFI, installation fails (system is by default booted in UEFI+Legacy mode)
Systemd-boot not working in manjaro architect
White Login Screen on Deepin (Grub Problem solved)
Grub not detected after install, Manjaro Gnome
Move Manjaro partition
My computer won't load Manjaro boot loader
Manjaro Installer does not install Grub Bootloader (I think)
Unable to load Manjaro KDE from live-usb
Manjaro grub kernel panic
Black screen after fresh installation
[SOLVED] Black screen on bootup, fresh install works
Only windows boots after dual-boot installation
Dual Boot Windows 10 and Manjaro (GRUB NOT SHOWING W10)
Dual boot Manjaro alongside Windows 10 in Dell G3
UEFI Dual booting issues [Solved]
Dual boot efi problems need a little help
UEFI Eintrag fehlt im Bootmenü
Boot issues, "hibernation device ‘UUID=***' not found"
Unable to boot installed Manjaro
Efibootmgr does not show manjaro after install (dual boot uefi)
No boot menu
Freeze during boot
Manjaro bootet nach der Installation nicht
[solved] Laptop boots straight to Windows 10
After installation, booting returns to BIOS screen
Installing windows 8.1 after Manjaro on same SSD
Dual boot windows efi
Solved - No Grub menu after win10 update
Can't boot system
Black screen after installing a second distro
Can't boot system
Restore grub bootloader WIKI
Can't enter BIOS/UEFI menu any more
How does one provide value of xxxxxxxxxx
PC boots into Windows despite setting up dual boot
Manjaro 17 boots to grub command
Cannot dual boot with Windows 7
About Removing GRUB bootloader on Dual Boot
Manjaro Image for installation on Laptop E6412T
Can't boot into Manjaro i3 from rEFInd
Edit grub
'Operation System Not Found' Error
[MSI GS63VR 6RF] Manjaro doesn't boot after install
[SOLVED] Manjaro i3 just won't boot
Can't select manjaro bootloader
USB Stuck at Grub/Boot Drive in grub - rescue
Grub fix does not stick
GRUB not working on IDE-SD adapter
Grub doesn't appear after HP BIOS update
Trouble installing Manjaro on emachines W3623 computer
[Solved] Can't install GRUB after trying to get grub-silent
Problems with booting
Failed to use customized bios boot option in HP notebook?
Grub legacy
Grub rescue fails
Issues enabling "smooth boot" -Testing
[SOLVED] Just installed manjaro alongside Windows 10, finished the installer and restarted, and then this happened
Manjaro crashes after installation
[solved] Laptop boots into bios after install
Grub legacy
Win-Manjaro dualboot -> Grub completely gone after windows update
Opensuse GRUB Bootloader problem with Manjaro
Boot EFI stopped working in a removable external HDD on Mac mini
Installing Windows made Manjaro boot in Emergency Mode
Can you check the health of boot and grub of my external HDD plugged on my Mac mini before I do something stupid?
Problem after update,.computer won't boot
Stuck at ‘Started TLP system startup/shutdown’ after latest update (not during installation)
Restoring GRUB2 after Windows 10 install
Filesystem unknown on Linux partition. Can I boot into windows?
Grub-install required with grub repo package
Multiboot With Windows 10 Pro
Manjaro Manual Partitioning - Windows will still boot even after creating an /boot/efi partition with esp flag
Edit grub
PC doesn't boot from new SSD 4TB
Surface Pro 4 Win10 + Manjaro on uSD
Kernel panic in Manjaro after updating the system
[SOLVED] Won't start after deleting Fat16 partition
Two empty ubuntus in my boot order (no Manjaro)
[Solved] Messed up my EFI partition
Grub Install Error Cannot Find EFI Directory
[SOLVED] EFI stuff crashes system on istallation
Tried to install Manjaro now I can't get into anything.
Issues with grub and efibootmgr while dual booting
[Done] Can't boot after updating kernel
efi partition fubared (not nuked). Grub couldn't help.
Hard drive stopped booting
[Solved] Restoring GRUB after BIOS/UEFI reset with dual-boot Windows & (LUKS encrypted) Manjaro
missing grub screen
Can't boot manjaro on intel nuc 8i7hvk
Manjaro vanished after update
Update-grub not detecting Manjaro after installing Windows 7
#2
Bumping this topic as I get a PM that they could not reply to post a comment.
By bumping this, people can comment further.
Hopefully it works (so people can comment).
In case it still don’t work (people cannot post), there is a message that says…
Hi. Your post worked for me after reinstalling Windows. I just wanted to comment that, not every computer would have dev/sda as their OS partition. For example, on my computer it was dev/nvme0p1. I guess experienced users would know already but it might still be nice to point it out in your original thread as well? I couldn’t leave a comment or reply there. Thanks.
Followed by…
Also, in my case /dev/sda actually came to represent the USB stick that I was booting the computer with. There might be problems if the original commands targeting /dev/sda were run?
My reply is as follows…
Will work for uefi/gpt system regardless of where the $esp is.
Note also the command “sudo grub-install” (without /dev/sda) will work nicely; but it will also work with /dev/sda ie., “sudo grub-install /dev/sda”.
As for bios-legacy/msdos system, the command “sudo grub-install /dev/sda” must be used.
“sudo grub-install” won’t work.
For a nvme device, I have not heard of any nvme devices using bios-legacy/msdos. They are all uefi/gpt. That’s why for simplicity and not to complicate matters, in my step 6, I use the command
Are there anyone here with nvme devices but on bios-legacy/msdos ?
If there are, please let us know.
If there is, the command to use would be
sudo grub-install /dev/nvme0
not sudo grub-install dev/nvme0p1
as that would be the partition and not the device.
But as stated, it will work if system is uefi/gpt. We can put anything actually as /dev/xxxx and it would work. Regardless /dev/sda is the usb or any other disk (it does not matter).
Hope this replies well for the PM I receive (which I also PM the reply).
Cheers.
ps: I thank everyone for their comments as it is the feedback that makes all of us better.
UEFI not showing Manjaro after an install
#3
I’ve added an additional command for UEFI installs in the first post above (at bottom).
That new command wasn’t necessary before until recently.
Perhaps the new version of ‘grub-install’ did not incorporate it (the command) as it did before (or is missing).
I think it is important enough to merit a new post here so people can be aware of it.
Cheers.
[SOLVED]Windows 10 Dual Booting issue with latest stable release of Manjaro KDE
#4
  1. efibootmgr -v
    sudo parted -l
    sudo blkid
    findmnt -s
    findmnt /boot/efi
    note: ‘parted -l’ --> small ‘L’ and provide information of all disks. [a]
  2. Computer make and model. Some computers have issues with UEFI particularly
Lenovo - some models are tied in with Microsoft and will only boot to windows efi file.
… … … … to work around it we can ‘fake’ manjaro efi as the windows efi
… … … … or to remove windows totally, and lenovo will look for another efi file.
This link may help.
HP - in some models, the UEFI firmware is flaky
… … some members have chosen to use bios-legacy instead.
This link may help.
MSI - the ‘gaming’ models need to have these settings in bios settings (F2)
… … . Turn off secure boot
… … . Set boot to UEFI (DO NOT USE CSM)
… … . Set TPM to 2.0 with 1.x compatibility
Asus - a small number of models need these F2 settings
… … . . Add a new custom bootentry
… … . . Set the path to that bootentry efi file
… … . . Create the bootentry and make it default.
This link may help
[a] - it is important to provide all disks from ‘parted -l’ because as one recent topic demonstrates, the user’s problem is that he/she had 5 disks and he/she provide just 2 disks. Not all sata ports (mostly 2, a few-4) are ‘bios-bootable’ and found to his/her surprise, the problem is resolved when he/she installed to another disk. It’s clearly not a uefi problem but were mislead into thinking it was. Even if that is not the case (sata bios-bootable disks), a full ‘parted -l’ is required in understanding ‘efibootmgr -v’, which is least to say, more confusing in that particular case. So, please, provide full ‘parted -l’.
This and some other commands are in “smart quotes” which may create problem.
Please, @gohlip correct them when possible for future proofing.
I have just corrected the first Topic (wiki).
Edit: @jonathon Discource engine "corrects" quotes to “smart quotes” except if they are in code blocks. Can this be corrected or users have to be warned to use code blocks in these cases?
(check this post in edit mode…)
Trouble in boot to grub
#6
Petsam, I think your edit makes it less readable (and less copiable and pasteable).
Can you see if anything can be done?
I also think in that particular case, the user somehow copied wrongly, not because of ‘smart quotes’ (which I don’t understand anyway). I just find this whole discourse thingy including bb codes not very usable. I cannot put in color and within ‘fences’ (why the heck is that called) I cannot add more bbcodes, etc. I find difficulty and not productive using this discourse thingy. Perhaps I’m just not that technical. :wink:
If you can in post #3, the lenovo, HP, MSI, asus part , can you fix that?
I want clarity of space for readability and I put in ‘…’ for spacing.
And when I put in 1. 2. 3… anything in codes or quotes break that up.
And… shessh… Right, I’m just not technical. Maybe linux too hard for me. :rofl:
I am not that elevated, so I can’t edit others’ posts (yet).
This has been a fact, check the link in my post.
Just use what you have/are provided…
I think BBcodes and HTML can be used in some extend.
I never thought I would point you to the xyproblem.info .
What you think it’s more clear it may not be (depending) for the majority/minority.
I like to use the tools (bullets & numbering, quotes & titles) so it is consistent as designed from Discource.
Whatever… :neutral_face:
@petsam
Here. i copied and paste the above command , note the ‘manjaro’ entry was not there before doing the command. I do not see any error. BTW, the command was also done in the German section, presumably they do not use ‘english fonts’ nor qwerty keyboard.
What do you think is the problem?
[pop@Dec ~]$ efibootmgr
BootNext: 0002
Timeout: 1 seconds
BootOrder: 0000,0002,0001,0004
Boot0000* pop
Boot0001* Hard Drive
Boot0002* Systemd Boot Manager
Boot0004* UEFI: KINGSTON SV3
[pop@Dec ~]$ sudo efibootmgr -c -d /dev/sda -p 1 -L "manjaro" -l "\EFI\Manjaro\grubx64.efi"
[sudo] password for pop:
BootNext: 0002
Timeout: 1 seconds
BootOrder: 0003,0000,0002,0001,0004
Boot0000* pop
Boot0003* manjaro
[pop@Dec ~]$
ps: I normally remove all other efi bootentries (including disk boots - bootx64.efi), will do so (remove ‘manjaro’) after this.
I noticed I left ‘systemd boot’, will also remove it later.
ps: I think your reference to ‘xy problem’ is ad hominem and non sequitur.
GTranslate: gooseberry and it does not follow
Not a latin-aware person… sorry :grin:
The problem is not here (anymore, it is corrected in the initial post). It comes up on new posts (that I cannot edit :laughing: ) where code isn’t enclosed in code-specific blocks (it makes sense IMHO).
Or check another example
Forgive me that I insist on quoting you, but you are rightfully the most widely known Boot/EFI supporter. If you teach by example that using proper code quoting is sometimes interfering or bugging the troubleshooting attempts, others will follow/benefit. And as always :heart_eyes:
Maybe try with this
“manjaro” instead of "manjaro"
Heck, I don’t have this in my qwerty keyboard.
Only (’) and (") (~) (`) - nothing else resembling your “manjaro” (copied and pasted from yours).
So I couldn’t have typed that (your ‘quote’ ‘unquote’) anytime, before or after any edit.
So the error could have come from them manually typing ‘quote’ ‘unquote’ {Your quotes}; not copying from my command above.
ps: Don’t hassle about ‘reputation’ about anything here. We’re all equals here. No such thing as ‘more equal than others’. There are many things you are much better than I, but I don’t sweat it. We just want to get things right. I’m sure you agree.
Can i use Manjaro-Architect ISO (17.1.11) to fix grub using Live CD. I hope Manjaro Architect has grub as bootloader
#13
I don’t think you can if m-a is a stand-alone iso.
But if you have any other OS in your system using grub2, regardless of distro, you can use their grub menu (press ‘c’).
I have Ubuntu Budgie 18.04 LTS amd64 bootable USB which was created in May 2018 to test run Live boot Ubuntu session.
Will give it a try. Hopefully it wud work.
#15
If you boot up this Ubuntu livecd in uefi, it should give a grub menu.
But if booted in bios-legacy, it would not.
Don’t know if you want to boot up in uefi or in bios-legacy, but take note.
ps: Ubuntu said it would use grub for all uefi and bios-legacy, but it hasn’t for 18.04.
Manjaro live is all grub, uefi or bios-legacy.
What I said earlier is if you have an existing installed linux OS using grub2 in your system, either uefi or bios-legacy, it would work.
Manjaro Architect uses grub2 and it works.
I have legacy bios and it did not work as you said so instead i used Manjaro Architect Live boot iso. on Boot Menu / grub menu pressed ‘c’ and smooth sailing thereafter. I cud fix grub after booting manjaro as explained in the original post on this thread.
:joy::joy:
You’re welcome.
Sharing alternative approach to boot OS with broken bootloader.
Note: I have legacy BIOS and steps detailed below works for me. I hope UEFI Bios / GPT setup wud also work provide relevant efi grub was installed and configured correctly.
We can also boot manjaro using Super Grub 2 Disk.
from https://www.supergrubdisk.org/
Just 20 mb iso file. write it to a usb drive or add it to multiboot usb.
Boot ur pc with Super Grub 2 Disk bootable USB and select first option to detect OS. Thereafter Manjaro Grub Menu is displayed along with other linux distros if multiple OS exist.
You can also boot desired kernel for desired OS if multiple linux distros with multiple linux kernel installed.
[Stable Update] 2018-10-08 - Kernels, Gnome 3.30, Cinnamon, Deepin, Pamac, SPL/ZFS
#19
Note this is a major update on how to get back our broken Manjaro bootloader since the introduction of fedora-grub. All edited at first post.
Some notes below.
  1. grub version 2.03.2-1 (or later)
  2. There is no need to set or unset menu_auto_hide though that by the stanza’s in 01_header and 01_menu_auto_hide will also work.
  3. hidden menu has “Welcome to Grub” removed.
    Some distros, when compiling grub, has that removed as well by removing a couple of lines in stock grub.
  4. ‘countdown’ in all stock or recompiled grub will show a small countdown timer and will not show “Welcome to Grub”
  5. fedora-grub will, by 00_header and 01_menu_auto_hide and using grubenv, automatically hide menu if Manjaro is the sole OS. Other distro’s do that as well in a less convoluted way.
    And users by themselves can manage it manually in much more simpler way without the use of grubenv or changing stanza’s in /etc/grub.d
  6. In Fedora and related distros, different grub.cfg are generated for bios-legacy and uefi.
  7. grubenv causes issues for some filesystems like f2fs or btrfs (no sparse file) as well as other complications (like lvm or encryption).
  8. grub, is itself simple, just kernels and the path to it.
    Simpler than refind definitely, as simple as systemd-boot, just much more versatile.
    In taking advantage of its versatility, we created more complications (and more things that can go wrong) than it’s worth.
God bless you Sir gohlip! Something foobard my 4.19.16-1 update installation early this week. The first two lines of your Simple First Start got me back to my desktop (many times!) until I could figure out how to restore GruB.
I do have a Samsung 960 NVME drive as legacy bios boot. I was refused nvme0n1p1 ( / ) with the “embedded blacklist” error by grub-install. /dev/nvme0n1 worked :smiley:
Your choice of beverage when we meet
