Hello,
Not having access to internet on my laptop because of a non compatible driver (yet functional on Windows) - I configure a dualboot -
I am trying to install gcc, which is needed for the “make” command needed to install rtw89 to get internet on my laptop.
But shortly after, I downloaded the gcc-11.2 offline using ftp mirrors,
In the gcc folder, I tried the following:
./configure --prefix=/platform \
--enable-shared \
--enable-threads=posix \
--enable-__cxa_atexit \
--enable-clocale=gnu \
--enable-languages=all \
&& make \ && make install
Thus giving me the following result :
zsh: correct 'make' to 'qmake' [nyae]? n
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking target system type... x86_64-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether ln works... yes
checking whether ln -s works... yes
checking for a sed that does not truncate output... /usr/bin/sed
checking for gawk... gawk
checking for libatomic support... yes
checking for libitm support... yes
checking for libsanitizer support... yes
checking for libvtv support... yes
checking for libhsail-rt support... yes
checking for libphobos support... yes
checking for gcc... no
checking for cc... no
checking for cl.exe... no
configure: error: in `/mypath/gcc-11.2.0/gcc-11.2.0':
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details
How am I supposed to get out of this loop?
I looked on the internet, and it seems that a c-compiler should have been present in my manjaro installation … I have installed the full version though.
