User session / system freezes when entering sleep mode
Symptoms
  • My system freezes, when it tries to enter sleep mode. It actually doesn’t get there, but gets stuck with a black screen with only the mouse pointer visible or the Manjaro background.
  • This problem occurs with Wayland as well as X11.
  • What is strange: If I log out first and then click the sleep icon on the login screen, everything works fine. So I’d assume that it is not a basic hardware or kernel problem, but something related to plasma / the user session.
What I’ve tried so far
  • I’ve read the following posts and tried to apply the proposed solutions, where it made sense to me:
  • I’ve updated my bios to the latest version (2025-02-10)
  • I’ve searched for hints in the logs, but so far I haven’t found anything useful. It seems like the system is freezing before it can log any errors.
System Information
inxi -zav7 :
  Kernel: 6.12.12-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=dce06125-26cf-4368-b004-1d587e2a8d69 rw quiet
    cryptdevice=UUID=da950337-6000-48eb-b5be-b55578e786b1:luks-da950337-6000-48eb-b5be-b55578e786b1
    root=/dev/mapper/luks-da950337-6000-48eb-b5be-b55578e786b1 splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.10.0
  Type: Convertible System: HP product: HP ProBook x360 435 G7 v: SBKPF
    serial: <superuser required> Chassis: type: 31 serial: <superuser required>
  Mobo: HP model: 8735 v: KBC Version 09.2F.00 serial: <superuser required>
    part-nu: 1L3R3EA#ABD uuid: <superuser required> UEFI: HP
    v: S80 Ver. 01.20.00 date: 01/14/2025
  ID-1: BAT0 charge: 22.7 Wh (87.3%) condition: 26.0/45.2 Wh (57.4%)
    volts: 12.4 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
    serial: <filter> status: charging cycles: 1002
  System RAM: total: 16 GiB available: 15.03 GiB used: 7.47 GiB (49.7%)
  Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
  Device-1: Bottom-Slot 1(left) type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Hynix/Hyundai
    part-no: HMA82GS6DJR8N-XN serial: <filter>
  Device-2: Bottom-Slot 2(right) type: no module installed
  Info: model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64 type: MCP
    arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x860010D
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 6 smt: <unsupported> cache:
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 1396 min/max: 1400/2375 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1396 2: 1396 3: 1396
    4: 1396 5: 1396 6: 1396 bogomips: 28462
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs
    ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
    overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdpid
    rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca
    smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock
    syscall tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif
    vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
    xsaveopt xtopology
  Type: spec_rstack_overflow mitigation: SMT disabled
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
    Radeon Mobile Series] vendor: Hewlett-Packard driver: amdgpu v: kernel
    arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
    active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:1636
    class-ID: 0300 temp: 51.0 C
  Device-2: Chicony HP HD Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 04f2:b6af
  Display: wayland server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.5
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: AU Optronics 0x4b2d built: 2020 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 166 gamma: 1.2
    size: 293x165mm (11.54x6.5") diag: 336mm (13.2") ratio: 16:9 modes:
    max: 1920x1080 min: 640x480
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
    renoir LLVM 19.1.7 DRM 3.59 6.12.12-2-MANJARO) device-ID: 1002:1636
    memory: 500 MiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.303 layers: N/A device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: N/A device-ID: 1002:1636
    surfaces: xcb,xlib,wayland
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
    Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: Hewlett-Packard driver: N/A alternate: snd_pci_acp3x,
    snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
    snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
    snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5
    chip-ID: 1022:15e2 class-ID: 0480
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.12-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 8087:0029
    class-ID: e001
  Device-1: luks-da950337-6000-48eb-b5be-b55578e786b1 maj-min: 254:0
    type: LUKS dm: dm-0 size: 460.44 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 460.44 GiB
  Local Storage: total: 505.59 GiB used: 749.19 GiB (148.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
    model: BC511 HFM512GDJTNI-82A0A size: 476.94 GiB block-size: physical: 512 B
    fw-rev: HPS0 temp: 48.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: Ultra Fit
    size: 28.65 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 1.00 scheme: MBR
  ID-1: / raw-size: 460.44 GiB size: 452.14 GiB (98.20%)
    used: 195.94 GiB (43.3%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-da950337-6000-48eb-b5be-b55578e786b1 label: ROOT
    uuid: dce06125-26cf-4368-b004-1d587e2a8d69
    used: 41.7 MiB (8.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: SYSTEM uuid: 7AF5-A242
  ID-3: /home/<filter>/OneDrive raw-size: N/A size: 1 TiB
    used: 553.2 GiB (53.8%) fs: fuse.onedriver source: ERR-102
  ID-1: swap-1 type: partition size: 16 GiB used: 12 MiB (0.1%) priority: -2
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: SWAP
    uuid: fb9ae3d4-338a-47f4-8f64-6af02780fea8
  ID-1: /dev/sda1 maj-min: 8:1 size: 4.03 GiB fs: iso9660
  ID-2: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 97A3-D79B
  Device-1: 1-3:2 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Device-2: 1-4:3 info: Synaptics type: <vendor specific> driver: N/A
    interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 06cb:00df class-ID: ff00 serial: <filter>
  Device-1: 3-3:3 info: Chicony HP HD Camera type: video driver: uvcvideo
    interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 04f2:b6af class-ID: 0e02 serial: <filter>
  Device-1: 4-2:2 info: SanDisk Ultra Fit type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5583 class-ID: 0806
    serial: <filter>
  System Temperatures: cpu: 62.8 C mobo: N/A gpu: amdgpu temp: 51.0 C
  Fan Speeds (rpm): N/A
  Processes: 338 Power: uptime: 25m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 5.99 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: 1552 pm: pacman pkgs: 1532 libs: 367 tools: pamac pm: flatpak
    pkgs: 20 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9
    default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.37
cat /sys/power/mem_sleep :
s2idle [deep]
Thank you very much in advance for your support!
Regards, Markus
Hi, in my post Freeze on sleep the new Manjaro installation helped only to the point until I installed rclone again. When I use systemd to mount rclone on the startup, the system freezes. Doing it manually works most of the times. In my case rclone is the problem for sure and I didn’t find a soultion by now.
I don’t know if you use rclone, but maybe it helps.
Thanks for this advice. I don’t have rclone installed, so I guess it’s another problem in my case.
Good news: The problem seems to be gone since the last major system update (kernel, libs, applications…). Unfortunately, I still can’t narrow down the root cause or point in any clearer direction that might help others. However, I think this thread is solved and can be closed. Thanks!
As if by magic. :wink:
Not an actual solution, but we’re glad your issue is no more.
