Hi everyone, first time poster, been using Manjaro for 8 months now. I’m making this thread because I can’t figure this one out on my own.
The Issue
- 125GiB partition - 104GiB used - 21GiB available
- I shouldn’t be using this much disk space. I’m unable to figure out what is causing this.
- QDirStat / FileLight only able to find 50GiB of it.
Below a list of commands I found on other topics diagnosing disk usage related issues, hopefully these give you guys enough information.
lsblk -o NAME,FSTYPE,SIZE,FSUSED,FSAVAIL,FSUSE%,MOUNTPOINTS --exclude 8
NAME FSTYPE SIZE FSUSED FSAVAIL FSUSE% MOUNTPOINTS
nvme0n1 465,8G
├─nvme0n1p1 16M
├─nvme0n1p2 vfat 512M 712K 510,3M 0% /boot/efi
├─nvme0n1p3 swap 8G [SWAP]
└─nvme0n1p4 btrfs 125G 103,4G 20,4G 83% /run/timeshift/backup
/var/lib/docker/btrfs
/home
df -h
df: /run/user/1000/doc: Operation not permitted
Filesystem Size Used Avail Use% Mounted on
dev 7,8G 44K 7,8G 1% /dev
run 7,8G 2,8M 7,8G 1% /run
/dev/nvme0n1p4 125G 104G 21G 84% /
tmpfs 7,8G 4,0K 7,8G 1% /dev/shm
tmpfs 7,8G 51M 7,8G 1% /tmp
/dev/nvme0n1p4 125G 104G 21G 84% /home
/dev/sdc2 3,7T 3,4T 320G 92% /disk/4
/dev/sda1 7,3T 6,7T 686G 91% /disk/8
/dev/nvme0n1p2 511M 712K 511M 1% /boot/efi
/dev/sdd1 11T 2,7T 8,3T 25% /disk/12
tmpfs 1,6G 92K 1,6G 1% /run/user/1000
/dev/sdb4 209G 183G 26G 88% /run/media/fw/4A2E84702E84573B
/dev/nvme0n1p4 125G 104G 21G 84% /run/timeshift/backup
sudo du -ha -d1 --exclude "/proc" --exclude "/sys" / | sort -hr | head -30
du: cannot access '/run/user/1000/doc': Permission denied
du: cannot access '/run/user/1000/gvfs': Permission denied
14T /
13T /disk
598G /run
34G /var
21G /home
20G /usr
441M /opt
101M /boot
51M /tmp
17M /root
14M /etc
168K /file
48K /dev
24K /desktopfs-pkgs.txt
8,0K /rootfs-pkgs.txt
4,0K /sbin
4,0K /.manjaro-tools
4,0K /lib64
4,0K /lib
4,0K /bin
0 /srv
0 /mnt
QDirStat: 50GiB
Thanks in advance.
