Hi,
I’m running a set up with 5 monitors, and 2 nvidia gpus, (an rtx 3090 and a GT 1030). Four of the monitors are connected to the 3090, which work fine, but the fifth is connected to the 1030, which does not display anything once I reach the manjaro login screen. I’ve tried going to the manjaro display settings manager, and I’ve messed around with the Xorg configs to create a second xscreen, but nothing I’ve done so far seems to work. My guess is the 1030 is trying to offload to the 3090, but the 3090 only supports up to 4 displays.
inxi output:
Kernel: 5.10.30-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=d4c9b252-7563-4a8a-bd94-8dee73274b98 rw quiet splash apparmor=1
security=apparmor udev.log_priority=3 nvidia-drm.modeset=1
Desktop: GNOME 3.38.4 tk: GTK 3.24.28 wm: gnome-shell dm: GDM 40.0
Type: Desktop System: Gigabyte product: TRX40 AORUS MASTER v: -CF
serial: <filter>
Mobo: Gigabyte model: TRX40 AORUS MASTER v: x.x serial: <filter>
UEFI: American Megatrends LLC. v: FBh date: 02/19/2021
RAM: total: 62.75 GiB used: 5.25 GiB (8.4%)
Info: 32-Core (4-Die) model: AMD Ryzen Threadripper 3970X bits: 64
type: MT MCP MCM arch: Zen 2 family: 17 (23) model-id: 31 (49) stepping: 0
microcode: 8301039 cache: L2: 16 MiB bogomips: 473635
Speed: 3600 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz):
1: 3600 2: 2057 3: 2199 4: 2198 5: 2199 6: 2202 7: 2201 8: 2198 9: 2200
10: 2200 11: 2199 12: 2201 13: 2057 14: 2205 15: 2198 16: 2198 17: 2198
18: 2200 19: 2200 20: 2200 21: 2200 22: 2200 23: 2199 24: 2057 25: 2199
26: 2199 27: 3602 28: 2080 29: 2059 30: 2080 31: 2054 32: 3595 33: 2051
34: 2051 35: 2057 36: 2200 37: 2198 38: 2197 39: 2200 40: 2199 41: 2199
42: 2201 43: 2200 44: 2198 45: 2200 46: 3599 47: 2198 48: 2198 49: 2199
50: 2200 51: 2202 52: 2200 53: 2195 54: 2195 55: 2199 56: 2200 57: 2054
58: 2201 59: 2197 60: 2202 61: 2196 62: 2056 63: 2199 64: 2200
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload
vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
conditional, RSB filling
Device-1: NVIDIA GA102 [GeForce RTX 3090] driver: nvidia v: 460.67
alternate: nouveau,nvidia_drm bus-ID: 21:00.0 chip-ID: 10de:2204
class-ID: 0300
Device-2: NVIDIA GP108 [GeForce GT 1030] vendor: Micro-Star MSI
driver: nvidia v: 460.67 alternate: nouveau,nvidia_drm bus-ID: 49:00.0
chip-ID: 10de:1d01 class-ID: 0300
Device-3: Logitech Logitech BRIO type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 4-1:2
chip-ID: 046d:085e class-ID: 0300 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: gnome-shell driver:
loaded: nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 9600x2560 s-dpi: 96 s-size: 2540x677mm (100.0x26.7")
s-diag: 2629mm (103.5")
Monitor-1: DP-0.8 res: 1440x2560 hz: 60
Monitor-2: HDMI-0 res: 3840x2160 hz: 60 dpi: 163
size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
Monitor-3: DP-2 res: 1440x2560 hz: 60
Monitor-4: DP-4 res: 1440x2560 hz: 60
OpenGL: renderer: GeForce RTX 3090/PCIe/SSE2 v: 4.6.0 NVIDIA 460.67
direct render: Yes
Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 21:00.1
chip-ID: 10de:1aef class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel v: kernel
bus-ID: 23:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: NVIDIA GP108 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 49:00.1 chip-ID: 10de:0fb8
class-ID: 0403
Device-4: Logitech Logitech BRIO type: USB
Device-5: Apogee Duet USB type: USB driver: snd-usb-audio bus-ID: 5-1:2
chip-ID: 0c60:0016 class-ID: fe01 serial: <filter>
Device-6: Giga-Byte USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-6:4 chip-ID: 0414:a000
class-ID: 0300
Device-7: Giga-Byte USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 7-5:4 chip-ID: 0414:a001
class-ID: 0300
Sound Server-1: ALSA v: k5.10.30-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.25 running: yes
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
port: 9000 bus-ID: 43:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp67s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Aquantia AQC111 NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: Gigabyte driver: atlantic v: kernel port: 9000 bus-ID: 44:00.0
chip-ID: 1d6a:11b1 class-ID: 0200
IF: enp68s0 state: down mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: N/A modules: iwlwifi port: 9000
bus-ID: 45:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 5-4.1:5 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 1.82 TiB used: 17.35 GiB (0.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 rotation: SSD serial: <filter> rev: 2B2QGXA7 temp: 38.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 rotation: SSD serial: <filter> rev: 2B2QGXA7 temp: 36.9 C
scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 17.32 GiB (1.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:3
label: N/A uuid: d4c9b252-7563-4a8a-bd94-8dee73274b98
used: 25.5 MiB (8.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
label: NO_LABEL uuid: 78CE-9555
ID-1: /dev/nvme1n1p1 maj-min: 259:4 size: 931.51 GiB fs: ntfs label: N/A
uuid: 34F43D41F43D0720
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 4-1:2 info: Logitech Logitech BRIO type: Video,Audio,HID
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo interfaces: 6 rev: 3.1
speed: 5 Gb/s power: 896mA chip-ID: 046d:085e class-ID: 0300
serial: <filter>
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 5-1:2 info: Apogee Duet USB type: Audio driver: snd-usb-audio
interfaces: 7 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0c60:0016
Hub-6: 5-4:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 5-4.1:5 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-2: 5-4.3:6 info: Integrated Express IT8297 RGB LED Controller
type: Keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 048d:8297 class-ID: 0301
Device-3: 5-6:4 info: Giga-Byte USB Audio type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 0414:a000 class-ID: 0300
Hub-7: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-8: 7-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 7-1:2 info: SiGma Micro USB Keyboard type: Keyboard,HID
power: 98mA chip-ID: 1c4f:0016 class-ID: 0300
Device-2: 7-2:3 info: Pixart Imaging Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 093a:2510 class-ID: 0301
Device-3: 7-5:4 info: Giga-Byte USB Audio type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 7 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 0414:a001 class-ID: 0300
Hub-9: 7-6:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-10: 8-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 39.4 C mobo: 16.8 C gpu: nvidia temp: 36 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 740 Uptime: 3h 43m wakeups: 11 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: pacman: 1178 lib: 285
flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.04
xrandr output:
Screen 0: minimum 8 x 8, current 9600 x 2560, maximum 32767 x 32767
DP-0.8 connected 1440x2560+1440+0 right (normal left inverted right x axis y axis) 553mm x 311mm
2560x1440 59.95*+
2048x1280 59.96
2048x1080 60.00 24.00
1920x1200 59.88
1920x1080 60.00 59.94 50.00 23.98
1600x1200 60.00
1600x900 60.00
1280x1024 75.02 60.02
1280x720 59.94 50.00
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
HDMI-0 connected primary 3840x2160+2880+0 (normal left inverted right x axis y axis) 600mm x 340mm
3840x2160 60.00*+ 59.94 50.00 30.00 29.97 25.00 23.98 23.98
2560x1440 59.95
1920x1080 60.00 59.94 50.00 29.97 23.98
1600x900 60.00
1280x1024 60.02
1280x800 59.81
1280x720 60.00 59.94
1152x864 60.00
1024x768 60.00
800x600 60.32
720x576 50.00
720x480 59.94
640x480 59.94 59.93
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 connected 1440x2560+6720+0 left (normal left inverted right x axis y axis) 553mm x 311mm
2560x1440 59.95*+
2048x1280 59.96
1920x1200 59.88
1600x1200 60.00
1600x900 60.00
1152x864 75.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 connected 1440x2560+8160+0 left (normal left inverted right x axis y axis) 553mm x 311mm
2560x1440 59.95*+
2048x1280 59.96
1920x1200 59.88
1600x1200 60.00
1600x900 60.00
1152x864 75.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
DP-5 disconnected (normal left inverted right x axis y axis)
DP-1-0 connected (normal left inverted right x axis y axis)
2560x1440 59.95 +
2048x1280 59.96
1920x1200 59.88
1600x1200 60.00
1600x900 60.00
1152x864 75.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
DP-1-1 disconnected (normal left inverted right x axis y axis)
HDMI-1-0 disconnected (normal left inverted right x axis y axis)
2560x1440 (0x1be) 241.500MHz +HSync -VSync
h: width 2560 start 2608 end 2640 total 2720 skew 0 clock 88.79KHz
v: height 1440 start 1443 end 1448 total 1481 clock 59.95Hz
2048x1280 (0x1bf) 220.250MHz -HSync +VSync
h: width 2048 start 2192 end 2408 total 2768 skew 0 clock 79.57KHz
v: height 1280 start 1283 end 1289 total 1327 clock 59.96Hz
2048x1080 (0x1c0) 147.180MHz +HSync -VSync
h: width 2048 start 2096 end 2128 total 2208 skew 0 clock 66.66KHz
v: height 1080 start 1083 end 1093 total 1111 clock 60.00Hz
2048x1080 (0x1c1) 58.230MHz +HSync -VSync
h: width 2048 start 2096 end 2128 total 2208 skew 0 clock 26.37KHz
v: height 1080 start 1083 end 1093 total 1099 clock 24.00Hz
1920x1200 (0x1c2) 193.250MHz -HSync +VSync
h: width 1920 start 2056 end 2256 total 2592 skew 0 clock 74.56KHz
v: height 1200 start 1203 end 1209 total 1245 clock 59.88Hz
1920x1080 (0x1c3) 148.500MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x1c4) 148.350MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1920x1080 (0x1c5) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1920x1080 (0x1c6) 74.180MHz +HSync +VSync
h: width 1920 start 2558 end 2602 total 2750 skew 0 clock 26.97KHz
v: height 1080 start 1084 end 1089 total 1125 clock 23.98Hz
1600x1200 (0x1c7) 162.000MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 75.00KHz
v: height 1200 start 1201 end 1204 total 1250 clock 60.00Hz
1600x900 (0x1c8) 108.000MHz +HSync +VSync
h: width 1600 start 1624 end 1704 total 1800 skew 0 clock 60.00KHz
v: height 900 start 901 end 904 total 1000 clock 60.00Hz
1280x1024 (0x1c9) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x1ca) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1280x720 (0x1cb) 74.180MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1280x720 (0x1cc) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1152x864 (0x1cd) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1024x768 (0x1ce) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x1cf) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x1d0) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x1d1) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
720x576 (0x1d2) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x480 (0x1d3) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
640x480 (0x1d4) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x1d5) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
640x480 (0x1d6) 25.170MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.46KHz
v: height 480 start 490 end 492 total 525 clock 59.93Hz
xrandr --listproviders ✔ base
Providers: number : 2
Provider 0: id: 0x1b8 cap: 0x1, Source Output crtcs: 4 outputs: 8 associated providers: 1 name:NVIDIA-0
Provider 1: id: 0x382 cap: 0x2, Sink Output crtcs: 2 outputs: 3 associated providers: 1 name:NVIDIA-G0
Below is what I think is the relevant piece of the Xorg log, copied from /var/lib/gdm/.local/share/xoorg/Xorg.0.log:
[ 12.865] (II) NVIDIA(G0): NVIDIA GPU GeForce GT 1030 (GP108-A) at PCI:73:0:0 (GPU-1)
[ 12.865] (--) NVIDIA(G0): Memory: 2097152 kBytes
[ 12.865] (--) NVIDIA(G0): VideoBIOS: 86.08.17.00.5f
[ 12.865] (II) NVIDIA(G0): Detected PCI Express Link width: 4X
[ 12.865] (--) NVIDIA(GPU-1): DELL U2520D (DFP-0): connected
[ 12.865] (--) NVIDIA(GPU-1): DELL U2520D (DFP-0): Internal DisplayPort
[ 12.865] (--) NVIDIA(GPU-1): DELL U2520D (DFP-0): 1440.0 MHz maximum pixel clock
[ 12.868] (--) NVIDIA(GPU-1): DFP-1: disconnected
[ 12.868] (--) NVIDIA(GPU-1): DFP-1: Internal TMDS
[ 12.868] (--) NVIDIA(GPU-1): DFP-1: 165.0 MHz maximum pixel clock
[ 12.868] (--) NVIDIA(GPU-1): DFP-2: disconnected
[ 12.868] (--) NVIDIA(GPU-1): DFP-2: Internal TMDS
[ 12.868] (--) NVIDIA(GPU-1): DFP-2: 165.0 MHz maximum pixel clock
[ 12.873] (II) NVIDIA(G0): Validated MetaModes:
[ 12.873] (II) NVIDIA(G0): "NULL"
[ 12.873] (II) NVIDIA(G0): Virtual screen size determined to be 640 x 480
[ 12.879] (WW) NVIDIA(G0): Cannot find size of first mode for DELL U2520D (DFP-0); cannot
[ 12.879] (WW) NVIDIA(G0): compute DPI from DELL U2520D (DFP-0)'s EDID.
[ 12.879] (==) NVIDIA(G0): DPI set to (75, 75); computed from built-in default
[ 12.879] (WW) NVIDIA: Failed to bind sideband socket to
[ 12.879] (WW) NVIDIA: '/var/run/nvidia-xdriver-f9e7d04f' Permission denied
[ 12.880] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[ 12.880] (II) NVIDIA: access.
Running xrandr --auto gives:
xrandr: Configure crtc 4 failed
Any help would be very useful. I’m comfortable with the terminal, but I’m pretty new to the linux desktop environment, especially when it comes to X11. I’ve spent many hours looking over docs and wiki’s, but nothing I’ve done has worked. All five monitors light up with the manjaro logo on boot, but once it gets to the login screen, the fifth monitor goes blank and shuts down.
Happy to provide more stuff if asked. Thanks!
