Nevertheless, I still like howdy to unlock from lock screen, I do this quite more often than login, so I wish to disable it at gdm login but keep it for unlock…
I’m not sure it’s feasible, but if yes, I guess there’s something to do in pam settings files…but not sure which one ?
currently, based on arch wiki page I mentioned, I added a line in /etc/pam.d/system-local-login
is there a suitable pam file or setting to limit howdy only to lockscreen unlock ?
well, currently, both howdy / password works.
This is how I was able to login : @login, howdy pass the login screen, but then I’m stuck in a grey screen because it cannot access to home.
So I hide my camera, wait for howdy to fail and then use password
Your proposal may be a workaround:
at login, I can use password
at unlock I can press enter and let howdy do the job.
it would be great if there’s a way to skip the “press enter” step.
Maybe it’s not possible (yet)
