Use auto-cpu-freq with TLP?
Hello,
can we use auto-cpu-freq and TLP together ? Use auto-cpu-freq to set all the parts about cpu only and use TLP to set the rest (usb, wifi, …). Is it a good choice ? I’m planning to install the two software and disable all the elements for cpu in TLP. Is it a good idea ?
Thanks.
Hi @AlanP,
From auto-cpufreq Github page:
…it’s recommended to remove TLP
Hope it helps!
Edit:
However, it does seem like it can be used together:
…If both are used for same functionality, i.e: to set CPU frequencies it’ll lead to unwanted results like overheating. Hence, only use both tools in tandem if you know what you’re doing.
@Mirdarthos: Yes, it’s recommended to remove TLP, but as you said it can be used together. It’s seems that we can disable all the parts for cpu in TLP , so, there will be no conflict with auto-cpu-freq but I want to be sure. That’s why I posted this message.
Is someone here use the both ?
Thanks.
There’s only one way to be 100% sure if your, or any idea will work, and that is to do it and see. If it doesn’t you can always just remove it.
:man_shrugging:
I installed the two software, I will see if there is some change with the battery consumption.
I’ve been busy lately, haven’t had time to check that it works. I will see later.
