When I install Manjaro using the live ISO, I can use the UBS wireless keyboard on boot menu. Even after install it works great. As soon as I run update-grub or install a new kernel (which runs grub-install), I can no longer use the USB keyboard to select the desired boot option. This being a laptop I can still use the built-in keyboard, without problems.
The keyboard is perfectly usable in BIOS.
Does anyone have an idea what I can do to keep being able to use the keyboard during boot menu?
I’m using grub, everything is up to date, using KDE. I have tried connecting the keyboard to the always-on USB port, connecting it via a hub, etc. Nothing changes. (it worked in any configuration before running the first grub-install/update-grub).
inxi output:
Edit your /etc/mkinitcpio.conf and place the keyboard hook before autodetect.
Note: For systems that are booted with different hardware configurations (e.g. laptops with external keyboard vs. internal keyboard or headless systems), this hook needs to be placed before autodetect in order to be able to use the keyboard at boot time, for example to unlock an encrypted device when using the encrypt hook.
Hi @Yochanan, thanks for your reply. I made the change and ran update-grub, but it did not help:
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr and fsck hooks.
HOOKS=(base udev keyboard autodetect kms modconf block keymap consolefont plymouth filesystems fsck)
I think I need to access the keyboard before boot. The grub boot menu is shown before the OS is selected. It must have something to do with grub and not any setting inside the OS I think.
EDIT: this got me thinking so I added usb_keyboard in /etc/default/grub, then ran update-grub again:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash udev.log_priority=3 video=eDP-1:1024x768"
GRUB_CMDLINE_LINUX=""
GRUB_PRELOAD_MODULES="part_gpt part_msdos usb_keyboard"
but this also did nothing.
Edit2: i tried adding the at_keyboard and usb modules too. also i added them to the GRUB_TERMINAL_INPUT variable:
GRUB_PRELOAD_MODULES="part_gpt part_msdos at_keyboard usb_keyboard usb"
GRUB_TERMINAL_INPUT=console,usb_keyboard,at_keyboard
I did it now, then reran update-grub. no success. What bugs me is that the live iso for example allows me to use the usb keyboard to select boot options, so I definitely know it is possible. I’ve checked the grub config in the live iso and didn’t see anything different that seemed relevant.
The laptop does not have any USB related options in BIOS. They have pared down the features one is able to control via BIOS on the new Lenovo machines. Advanced settings are also no longer available via hidden keys combo.
I tried every port. Interesting thing, when booting straight out fo bios (F10 save and exit), when reaching the grub menu the keyboard is usable. This seems to point out a hardware issue, however, I’m not sure why the keyboard was available in grub menu until the first update-grub.
Update. Apparently this is not OS related. As I said before, the new Lenovo laptops have extremely basic firmware menus. There is no “Enable legacy USB” option. However if I edit the boot order and add “Boot from USB HDD” as the first option (even if no USB drive is connected to any USB port), the USB ports get initialized during POST and the keyboard is recognized in the GRUB menu.
When booting the live ISO the “Boot from USB” is enabled (you wouldn’t be booting the ISO otherwise), that’s why the live ISO always had USB keyboard enabled in grub menu. Also I think the boot-repair utility changes the firmware boot order and removes boot from USB as first option.
