Hi everyone, after trying for multiple hours I’m here asking for guidance, I tried multiple posts from hee and SO but none works.
(see debug info on bottom)
I have a USB wifi adapter (TP Link Archer T4U / AC 1300 / High Gain Wireless MU-MIMO) and it does not work or turn on the light with my Majaro. I tried another USB adapter and it worked fine.
I already tried switching kernel to 5.12 and 5.4, installing headers and retrying a couple of tutorials, but nothing made the network list even show.
NOTE: For the output bellow I only used the T4U and not the other one, the internet I’m using is from cable
The tutorial I followed was (from archive install-rtl8812au-dkms-git-driver/52343/3 and t/third-party-wifi-driver-issues/34010) but it did not work either, none of the steps helped me.
Also, the adapter is working fine on two Windows 10 machines.
DEBUG INFORMATION
Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=906f1185-1ba5-407d-9488-09cfc5b206e5 rw quiet apparmor=1
security=apparmor resume=UUID=39398501-9649-4d93-bb06-2d75b79b7b5e
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm4 vt: 7
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS_BR v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 2407 date: 07/01/2020
RAM: total: 31.33 GiB used: 4.14 GiB (13.2%)
Info: 8-Core model: AMD Ryzen 7 3800XT bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L2: 4 MiB bogomips: 134458
Speed: 4193 MHz min/max: 2200/4200 MHz boost: enabled Core speeds (MHz):
1: 4193 2: 4219 3: 4198 4: 4200 5: 4200 6: 4180 7: 4200 8: 4214 9: 4199
10: 4201 11: 4199 12: 4201 13: 4198 14: 4235 15: 4192 16: 4217
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload
vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
conditional, RSB filling
Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: Gigabyte
driver: nvidia v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 08:00.0
chip-ID: 10de:1f06 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-4.3.2:7 chip-ID: 046d:08e5
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.20.11 driver: loaded: nvidia display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.0x11.3")
s-diag: 1055mm (41.6")
Monitor-1: DP-0 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
Monitor-2: DP-4 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: NVIDIA GeForce RTX 2060 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 465.31 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 10de:10f9
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0a:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Logitech HD Pro Webcam C920 type: USB
Device-4: Realtek USB Audio type: USB driver: snd-usb-audio
bus-ID: 3-4.3.4:9 chip-ID: 0bda:402e class-ID: 0102 serial: <filter>
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus-ID: 04:00.0
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 4-4.4:4 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp5s0f3u4u4 state: down mac: <filter>
IF-ID-1: br-13ee87304115 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 1.38 TiB used: 256.53 GiB (18.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate model: XPG SPECTRIX S40G
lanes: 4 rotation: SSD serial: <filter> rev: VB431D51 temp: 40.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Seagate
model: ST1000LM024 HN-M101MBB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B rotation: 5400 rpm serial: <filter> rev: 1.14 scheme: GPT
ID-1: / raw-size: 442.18 GiB size: 434.17 GiB (98.19%)
used: 256.53 GiB (59.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 906f1185-1ba5-407d-9488-09cfc5b206e5
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: CC43-F5A7
ID-1: swap-1 type: partition size: 34.46 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 39398501-9649-4d93-bb06-2d75b79b7b5e
ID-1: /dev/sda1 maj-min: 8:1 size: 499 MiB fs: <superuser required>
label: Windows RE tools uuid: 801E446D1E445DF2
ID-2: /dev/sda2 maj-min: 8:2 size: 300 MiB fs: <superuser required>
label: SYSTEM uuid: 8A0A-D1C8
ID-3: /dev/sda3 maj-min: 8:3 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sda4 maj-min: 8:4 size: 914.56 GiB fs: <superuser required>
label: Backup Andressa uuid: 22780B96780B683D
ID-5: /dev/sda5 maj-min: 8:5 size: 15.05 GiB fs: <superuser required>
label: SAMSUNG_REC2 uuid: 3098E4CD98E492A0
ID-6: /dev/sda6 maj-min: 8:6 size: 1024 MiB fs: <superuser required>
label: SAMSUNG_REC uuid: 225A-F3BC
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 1-1:2 info: Logitech G413 Gaming Keyboard type: Keyboard,HID
power: 500mA chip-ID: 046d:c33a class-ID: 0300 serial: <filter>
Device-2: 1-3:3 info: Initio INIC-1618L SATA type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 2mA
chip-ID: 13fd:0840 class-ID: 0806 serial: <filter>
Device-3: 1-4:4 info: TP-Link Archer T4U ver.3 type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA
chip-ID: 2357:0115 class-ID: 0000 serial: <filter>
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 3-2:2 info: Corsair H100i Platinum type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 64mA
chip-ID: 1b1c:0c15 class-ID: 0000 serial: <filter>
Hub-4: 3-4:3 info: Realtek Dell dock ports: 5 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5487 class-ID: 0900
Hub-5: 3-4.3:5 info: Realtek Dell dock ports: 6 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5413 class-ID: 0900
Device-1: 3-4.3.2:7 info: Logitech HD Pro Webcam C920 type: Video,Audio
power: 500mA chip-ID: 046d:08e5 class-ID: 0102 serial: <filter>
Device-2: 3-4.3.3:8 info: Holtek E-Signal LUOM G10 Mechanical Gaming Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 04d9:a09f class-ID: 0300
Device-3: 3-4.3.4:9 info: Realtek USB Audio type: Audio
driver: snd-usb-audio interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-4: 3-4.3.5:10 info: Dell Dell dock type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 413c:b06f class-ID: 0300
Device-5: 3-4.5:6 info: Dell Dell dock type: HID driver: hid-generic,usbhid
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 413c:b06e
class-ID: 0300
Device-6: 3-6:4 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-7: 4-4:2 info: Realtek Dell dock ports: 4 rev: 3.1 speed: 10 Gb/s
chip-ID: 0bda:0487 class-ID: 0900
Hub-8: 4-4.3:3 info: Realtek Dell dock ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 0bda:0413 class-ID: 0900
Device-1: 4-4.4:4 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 288mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
Hub-9: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-10: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-11: 7-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-12: 8-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
System Temperatures: cpu: 43.6 C mobo: 0 C gpu: nvidia temp: 43 C
Processes: 370 Uptime: 19m wakeups: 0 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1132 pacman: 1120 lib: 301 flatpak: 0
snap: 12 Shell: Zsh v: 5.8 running-in: xfce4-terminal inxi: 3.3.04
sudo lshw -C network (it is enp5s0f3u4u4, and weird enough it shows as ethernet device where the other show wireless something)
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:04:00.0
logical name: enp4s0
version: 26
serial: 24:4b:fe:0c:86:79
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.10.42-1-MANJARO duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=192.168.15.7 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
resources: irq:35 ioport:f000(size=256) memory:fc604000-fc604fff memory:fc600000-fc603fff
*-network
physical id: 2
bus info: usb@4:4.4
logical name: `enp5s0f3u4u4`
serial: 98:e7:43:2e:d2:3b
capacity: 1Gbit/s
capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8152 driverversion=v1.11.11 duplex=half firmware=rtl8153b-2 v1 10/23/19 link=no multicast=yes port=MII speed=10Mbit/s
pacman -Qsq ^linux | grep ^linux | grep -viE ‘api|firm|nvidia’ && echo Running Kernel $(uname -r)
linux510
linux510-headers
linux510-virtualbox-host-modules
linux512
linux512-headers
linux512-virtualbox-host-modules
linux54
linux54-headers
linux54-virtualbox-host-modules
Running Kernel 5.10.42-1-MANJARO
