Hi all.
I’m new to this so lets hope I can learn to make this easy.
The TP-Link AC 1300 Archer T3U Plus works fine in windows, but its not visible in Manjaro. Some help troubleshooting and/or installing a driver would be great.
> [mjb@optiplex7020kman ~]$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=3a3ebf1d-9300-4d7b-9597-67ad95de9e21 ro quiet apparmor=1
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop System: Dell product: OptiPlex 7020 v: 00 serial: <filter>
Chassis: type: 6 serial: <filter>
Mobo: Dell model: 0F5C5X v: A00 serial: <filter> BIOS: Dell v: A15
date: 02/02/2018
RAM: total: 7.69 GiB used: 3.45 GiB (44.9%)
Info: Quad Core model: Intel Core i5-4690 bits: 64 type: MCP arch: Haswell
family: 6 model-id: 3C (60) stepping: 3 microcode: 28 L2 cache: 6 MiB
bogomips: 27946
Speed: 1181 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 1181 2: 1104
3: 1270 4: 1297
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good
sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Dell driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0412
class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: VGA1 res: 1920x1080 hz: 60 dpi: 92 size: 530x300mm (20.9x11.8")
diag: 609mm (24")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
v: 4.5 Mesa 20.3.4 compat-v: 3.0 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:0c0c
class ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
class ID: 0403
Device-3: Logitech H600 [Wireless Headset] type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 2-6:4 chip ID: 046d:0a29
class ID: 0300 serial: <filter>
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: kernel
port: f080 bus ID: 00:19.0 chip ID: 8086:153a class ID: 0200
Device-2: TP-Link 802.11ac NIC type: USB driver: usb-network bus ID: 2-3:2
chip ID: 2357:0138 class ID: 0000 serial: <filter>
Message: No Bluetooth data was found.
Local Storage: total: 465.76 GiB used: 79.89 GiB (17.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500DM002-1BD142
size: 465.76 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: KC45 scheme: MBR
Optical-1: /dev/sr0 vendor: PLDS model: DVD+-RW DH-16AES rev: DD11
dev-links: cdrom
ID-1: / raw size: 97.88 GiB size: 95.84 GiB (97.92%) used: 19.86 GiB (20.7%)
fs: ext4 dev: /dev/sda7 maj-min: 8:7 label: manjaro
uuid: 3a3ebf1d-9300-4d7b-9597-67ad95de9e21
ID-2: /run/media/mjb/Win10ntfs raw size: 186.54 GiB
size: 186.54 GiB (100.00%) used: 60.04 GiB (32.2%) fs: ntfs dev: /dev/sda2
maj-min: 8:2 label: Win10ntfs uuid: 388020998020601C
ID-1: /dev/sda1 maj-min: 8:1 size: 549 MiB fs: ntfs label: System Reserved
uuid: FE641F9C641F56AD
ID-2: /dev/sda10 maj-min: 8:10 size: 9.84 GiB fs: vfat label: FAT32
uuid: 9DF6-1654
ID-3: /dev/sda11 maj-min: 8:11 size: 32.22 GiB fs: vfat label: IDK
uuid: DC9E-1FFC
ID-4: /dev/sda12 maj-min: 8:12 size: 48.92 GiB fs: ext4 label: N/A
uuid: 28f4a783-caa4-4b40-8462-035dd8f0c037
ID-5: /dev/sda3 maj-min: 8:3 size: 538 MiB fs: ntfs label: N/A
uuid: D0A2CF03A2CEED52
ID-6: /dev/sda4 maj-min: 8:4 size: 1 KiB fs: <superuser required> label: N/A
uuid: N/A
ID-7: /dev/sda5 maj-min: 8:5 size: 513 MiB fs: vfat label: WIN10SYS
uuid: 296D-52D2
ID-8: /dev/sda6 maj-min: 8:6 size: 48.82 GiB fs: ext4 label: kubuntu
uuid: c4bce986-e80d-4a87-9541-7d4cf80d72ec
ID-9: /dev/sda8 maj-min: 8:8 size: 9.77 GiB fs: swap label: N/A
uuid: c4d00717-02f1-43b3-8528-d3781a57027a
ID-10: /dev/sda9 maj-min: 8:9 size: 30.21 GiB fs: ext4 label: lithium
uuid: 3c28fcaa-3307-4603-a07e-62c692129f5e
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
speed: 480 Mb/s chip ID: 8087:8008 class ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 15 rev: 2.0
Device-1: 2-3:2 info: TP-Link 802.11ac NIC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.1 speed: 480 Mb/s chip ID: 2357:0138
Device-2: 2-5:3 info: Dell KB212-B Quiet Key Keyboard type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
chip ID: 413c:2107 class ID: 0301
Device-3: 2-6:4 info: Logitech H600 [Wireless Headset] type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s chip ID: 046d:0a29 class ID: 0300 serial: <filter>
Device-4: 2-9:5 info: Logitech M105 Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
chip ID: 046d:c077 class ID: 0301
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
Hub-5: 3-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip ID: 8087:8000 class ID: 0900
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003 class ID: 0900
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 193 Uptime: 1d 21h 58m wakeups: 20 Init: systemd v: 247
Compilers: gcc: N/A Packages: pacman: 1309 lib: 405 flatpak: 0 Shell: Bash
v: 5.1.0 running in: konsole inxi: 3.3.01
Thanks
