After you install drivers or change them you NEED to reboot to make them take effect…
Only if you don’t update at all, like a static server, you can get away with not rebooting for that long…
Yes, I will remember that. I did update before but didn’t restart…
Thanks!
If I may add to what @linux-aarhus posted, I have encountered this issue what I found was that ModemManager service was running, this will cause the system to think the USB device is a modem, like a DSL modem, or something to that effect.
Check to see if the service is running:
sudo systemctl status ModemManager
If it is running, temporarily disable using:
sudo systemctl stop ModemManager
If it fixes the issue, disable it from starting at boot:
sudo systemctl disable ModemManager
To start the service again
sudo systemctl start ModemManager
