Hello,
I am facing a problem with an USB Conference Speaker connected to a Display and USB Switch (to switch devices between two PCs).
Also connecting external drives (like USB drives or hard disks) somtimes fails on the second account. So it might be a more general USB problem but I focus on the sound issue here.
This is the setup:
Two PCs share
- two monitors,
- mouse,
- keyboard,
- a USB webcam and
- the USB conference speaker
being connected to a KVM202DH switch (Amazon-Link)
With this switch I can use all the peripherals with two computers. Pressing a button I switch over to the other computer.
The issue is with the Anker conference speaker (Amazon-Link).
The problem:
Eveything works fine with manjaro Linux on the first account that has been generated during installation.
I added a second user account later which I also made member of the sudoers. For this second user the sound crashes after less then a second when e. g. playing something on youtube or when starting a call on Teams, Discord aso. After that, only two of the four device buttons are light, no sound is active any more. Looking intro the sound setting shows that sound output is mapped to “Dummy device” while the USB device is not available. Reconecting brings back the device but it crashes again immediatly after being accessed.
Again, this only happens for the second user. Everything works fine for the first one (as well as on the second PC - a Windows 10 machine).
Here are my system info (from the first user account):
Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=ebf35e94-6a30-4d8f-af4e-f6d01c380f71 rw quiet apparmor=1
security=apparmor resume=UUID=64bdb3e4-c962-4715-abad-b3763baf0ded
udev.log_priority=3
Desktop: Cinnamon v: 5.6.8 tk: GTK v: 3.24.37 vt: 7 dm: LightDM v: 1.32.0
Type: Desktop Mobo: ASRock model: B550M Pro4 serial: <superuser required>
UEFI: American Megatrends LLC. v: P2.50 date: 10/19/2022
System RAM: available: 15 GiB used: 3.55 GiB (23.7%)
Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000D
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 1816 high: 3900 min/max: 1400/4464 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 3900
3: 1400 4: 1400 5: 1400 6: 1400 7: 1400 8: 3900 9: 1400 10: 1400 11: 1400
12: 1400 bogomips: 93467
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: DP-1,HDMI-A-1 empty: DP-2 bus-ID: 06:00.0
chip-ID: 1002:1638 class-ID: 0300 temp: 28.0 C
Device-2: webcam driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6.1:4 chip-ID: 1d6c:0103
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: amdgpu
unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 2960x1050 s-dpi: 96 s-size: 783x277mm (30.83x10.91")
s-diag: 831mm (32.7")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: left model: AOC LM765
serial: <filter> built: 2005 res: 1280x1024 hz: 75 dpi: 96 gamma: 1.2
size: 340x270mm (13.39x10.63") diag: 434mm (17.1") ratio: 5:4 modes:
max: 1280x1024 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,right model: AOC 2219
serial: <filter> built: 2010 res: 1680x1050 hz: 60 dpi: 90 gamma: 1.2
size: 474x296mm (18.66x11.65") diag: 559mm (22") ratio: 16:10 modes:
max: 1680x1050 min: 720x400
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.1.31-2-MANJARO) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: webcam driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
Device-4: ANKER PowerConf S330 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6.4:9
chip-ID: 291a:3308 class-ID: 0300 serial: <filter>
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:3165 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:7 chip-ID: 8087:0a2a
class-ID: e001
Local Storage: total: 2.27 TiB used: 145.85 GiB (6.3%)
model: WD Blue SN570 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 234110WD temp: 31.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Hitachi model: HUA723020ALA641
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: A840 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSD6 rev: LU00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 48.83 GiB size: 47.76 GiB (97.81%) used: 22.41 GiB (46.9%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: ebf35e94-6a30-4d8f-af4e-f6d01c380f71
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: C823-B964
ID-3: /home raw-size: 351.79 GiB size: 345.2 GiB (98.13%)
used: 123.44 GiB (35.8%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: a8cb0171-846f-4c15-b551-737b7369c45b
ID-1: swap-1 type: partition size: 16.02 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 64bdb3e4-c962-4715-abad-b3763baf0ded
ID-1: /dev/nvme0n1p4 maj-min: 259:4 size: 48.83 GiB fs: ext4 label: N/A
uuid: aeb3e618-3e72-4cfe-9378-5cc206c719a8
ID-2: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: ext4 label: Lager
uuid: d1372eab-dd0f-4891-b737-f32a88bd6c40
Hub-2: 1-6:2 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-6.1:4 info: webcam type: video,audio
chip-ID: 1d6c:0103 class-ID: 0102 serial: <filter>
Device-2: 1-6.2:6 info: Cherry GmbH Corded Device type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 046a:c098 class-ID: 0300
Device-3: 1-6.3:8 info: Primax HP Optical Mouse type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 0461:4d20 class-ID: 0301
Device-4: 1-6.4:9 info: ANKER PowerConf S330 type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 5 rev: 2.0
Hub-3: 1-7:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-8:5 info: ASRock LED Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 26ce:01a2 class-ID: 0300
serial: <filter>
Device-2: 1-9:7 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0a2a class-ID: e001
Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 3-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
chip-ID: 174c:2074 class-ID: 0900
Hub-7: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-8: 4-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
chip-ID: 174c:3074 class-ID: 0900
Hub-9: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-10: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 31.4 C mobo: N/A gpu: amdgpu temp: 29.0 C
Processes: 323 Uptime: 49m wakeups: 0 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1498
pm: pacman pkgs: 1490 libs: 479 tools: gnome-software,pamac,yay pm: flatpak
pkgs: 8 Shell: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.27
Can anyone help to solve this wired problem?
