all the sudden after updates my usb ports stopped working. i tried everything i found searching and the only thing that works is removing TLP which sucks because it helps the battery. i also tried to to disable “USB_AUTOSUSPEND” in tlp settings…it asks for my password to save config but doesn’t hold after reboot? appreciate the help
> System: Kernel: 5.10.32-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.21.4 Distro: Manjaro Linux
> base: Arch Linux
> Machine: Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X712DAP_M712DA v: 1.0 serial: <filter>
> Mobo: ASUSTeK model: X712DAP v: 1.0 serial: <filter> UEFI: American Megatrends v: X712DAP.301 date: 03/02/2020
> Battery: ID-1: BAT0 charge: 22.8 Wh (75.0%) condition: 30.4/32.1 Wh (94.7%) volts: 7.9 min: 7.9 model: ASUSTeK ASUS Battery
> status: Discharging
> CPU: Info: Dual Core model: AMD Ryzen 3 3250U with Radeon Graphics bits: 64 type: MT MCP arch: Zen/Zen+ note: check
> rev: 1 cache: L2: 1024 KiB
> flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 20761
> Speed: 1235 MHz min/max: 1400/2600 MHz boost: enabled Core speeds (MHz): 1: 1235 2: 1223 3: 1253 4: 1265
> Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Picasso vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 02:00.0
> Display: x11 server: X.Org 1.20.11 driver: loaded: amdgpu,ati unloaded: modesetting resolution: 1920x1080~60Hz
> OpenGL: renderer: AMD Radeon Vega 3 Graphics (RAVEN2 DRM 3.40.0 5.10.32-1-MANJARO LLVM 11.1.0) v: 4.6 Mesa 21.0.3
> direct render: Yes
> Audio: Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel v: kernel
> bus-ID: 02:00.1
> Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A bus-ID: 02:00.5
> Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
> bus-ID: 02:00.6
> Sound Server-1: ALSA v: k5.10.32-1-MANJARO running: yes
> Sound Server-2: JACK v: 0.125.0 running: no
> Sound Server-3: PulseAudio v: 14.2 running: yes
> Sound Server-4: PipeWire v: 0.3.26 running: no
> Network: Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel bus-ID: 01:00.0
> IF: wlp1s0 state: up mac: <filter>
> Drives: Local Storage: total: 931.51 GiB used: 7.75 GiB (0.8%)
> ID-1: /dev/sda vendor: Western Digital model: WDS100T2B0B-00YS70 size: 931.51 GiB
> Partition: ID-1: / size: 896.48 GiB used: 7.75 GiB (0.9%) fs: ext4 dev: /dev/sda2
> ID-2: /boot/efi size: 299.4 MiB used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1
> Swap: ID-1: swap-1 type: partition size: 19.35 GiB used: 0 KiB (0.0%) dev: /dev/sda3
> Sensors: System Temperatures: cpu: 46.5 C mobo: 46.0 C gpu: amdgpu temp: 46.0 C
> Fan Speeds (RPM): cpu: 2400
> Info: Processes: 178 Uptime: 2h 59m Memory: 17.59 GiB used: 1.73 GiB (9.8%) Init: systemd Compilers: gcc: N/A
> Packages: 1182 Shell: Bash v: 5.1.0 inxi: 3.3.04
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
