I have used this guide to install to a usb.
after reboot I am getting “Failed to mount /data” and Dependency failed for Local File system
I checked the UUID for sda5 and it looks correct.
I have another post here relating in how to get my wifi to work with this.
Remove the data partition from your fstab - it is not required to mount at boot.
Just a thought - if you really followed that guide then sdy5 is the encrypted partition and storage partition is sdy3.
That is correct.
Moderator you can delete this thread. I have decided to use another tool for this project.
I used this article to create my live persistent system that I can update and add packages to.
https://www.linuxadictos.com/en/como-instalar-manjaro-con-almacenamiento-persistente-en-un-pendrive.html
Essentially the same as
