Hi,
I tried to use Timeshift to create a backup no a 64GB USB.
It took ages to do that. When checked it after 10h or so Timeshift said that the backup was created.
Now USB is not recognized anywhere. It’s like dead.
How can I restore it?
With USB in:
[jesuslinux@T2310 ~]$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 74,5G 0 disk
├─sda1 8:1 0 35,7G 0 part
├─sda2 8:2 0 35,8G 0 part /
└─sda4 8:4 0 3G 0 part
sdb 8:16 1 0B 0 disk
sr0 11:0 1 1024M 0 rom
With no USB in:
Moderator edit: Please edit your first post instead of replying to yourself
It is probably dead. It is a bad idea to use timeshift, therefore rsync, on flash drive which has limited write cycles. And you know 10h of writing constantly to a flash stick can overheat it as well.
[jesuslinux@T2310 ~]$ sudo dmesg --follow-new
[sudo] password for jesuslinux:
[13692.554238] usb 2-1: new high-speed USB device number 9 using ehci-pci
[13692.701289] usb 2-1: New USB device found, idVendor=1e3d, idProduct=198a, bcdDevice= 1.00
[13692.701308] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[13692.701902] usb-storage 2-1:1.0: USB Mass Storage device detected
[13692.702377] scsi host5: usb-storage 2-1:1.0
[13693.711714] scsi 5:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[13693.714681] sd 5:0:0:0: [sdb] Media removed, stopped polling
[13693.715930] sd 5:0:0:0: [sdb] Attached SCSI removable disk
Ran the command again and remove the USB:
[14150.355867] usb 2-1: USB disconnect, device number 9
So it’s detected…so why can I access it and format?
After that, it should usually attach and determine the capabilities of the device, but didn’t. That makes me think that the flash drive reaches its limit. There is not much to investigate.
