I want to report an issue that it looks like all the peripheral devices susdenly disconnected for no reason.
The app using the vulkan RHI crashes, I can’t use my usb mouse or keyboard, while I can use those one on the laptop itself.
When I found this, I call out the kconsole and restarted the KDE with no luck.
kquitapp5 plasmashell
kstart5 plasmashell
Then I think I could just try to re-plug those usb devices, and it works again. (The action is recorded in the logs bellow)
BTW, theose USB mouse and keyboard is connected to my external monitor.
Logs from KSystemLog app (logs of “normal” level is filtered out):
13/09/24 上午12:54 kdesud kf.i18n: KLocalizedString: Domain is not set for this string, translation will not work. Please see https://api.kde.org/frameworks/ki18n/html/prg_guide.html msgid: "Geert Jansen" msgid_plural: "" msgctxt: ""
13/09/24 上午12:54 kdesud kf.i18n: KLocalizedString: Domain is not set for this string, translation will not work. Please see https://api.kde.org/frameworks/ki18n/html/prg_guide.html msgid: "Author" msgid_plural: "" msgctxt: ""
13/09/24 上午12:54 kdesud kf.i18n: KLocalizedString: Domain is not set for this string, translation will not work. Please see https://api.kde.org/frameworks/ki18n/html/prg_guide.html msgid: "KDE su daemon" msgid_plural: "" msgctxt: ""
13/09/24 上午12:54 kdesud kf.i18n: KLocalizedString: Domain is not set for this string, translation will not work. Please see https://api.kde.org/frameworks/ki18n/html/prg_guide.html msgid: "Daemon used by kdesu" msgid_plural: "" msgctxt: ""
13/09/24 上午12:54 kdesud kf.i18n: KLocalizedString: Domain is not set for this string, translation will not work. Please see https://api.kde.org/frameworks/ki18n/html/prg_guide.html msgid: "Copyright (c) 1999,2000 Geert Jansen" msgid_plural: "" msgctxt: ""
13/09/24 上午12:54 kdesu Qt: Session management error: Authentication Rejected, reason : MIT-MAGIC-COOKIE-1 authentication rejected
13/09/24 上午12:54 plasmashell Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
13/09/24 上午12:54 rtkit-daemon Supervising 7 threads of 4 processes of 1 users.
13/09/24 上午12:53 rtkit-daemon Supervising 7 threads of 4 processes of 1 users.
13/09/24 上午12:53 rtkit-daemon Supervising 6 threads of 3 processes of 1 users.
13/09/24 上午12:51 kcminit kcm_touchpad: Using X11 backend
13/09/24 上午12:51 kcminit Initializing "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_touchpad.so"
13/09/24 上午12:51 kcminit Initializing "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_mouse.so"
13/09/24 上午12:49 kwin_x11 Graphics device lost, cleaning up scenegraph and releasing RHI
13/09/24 上午12:49 kwin_x11 QRhiGles2: Context is lost.
13/09/24 上午12:45 konsole Qt: Session management error: Authentication Rejected, reason : MIT-MAGIC-COOKIE-1 authentication rejected
13/09/24 上午12:45 konsole qt.core.qobject.connect: QObject::disconnect: Unexpected nullptr parameter
13/09/24 上午12:45 systemd dbus-:1.2-org.kde.KSplash@1.service: Failed with result 'exit-code'.
13/09/24 上午12:44 plasmashell qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml:201:9: QML QQuickImage: Error decoding: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml?timestamp=1726159467009: Unsupported image format
13/09/24 上午12:44 plasmashell QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
13/09/24 上午12:44 plasmashell qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
13/09/24 上午12:44 plasmashell qml: SystemTray ItemLoader: Invalid state, cannot determine source!
13/09/24 上午12:44 plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:162:21: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
13/09/24 上午12:44 plasmashell file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:196:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
13/09/24 上午12:44 plasmashell Qt: Session management error: Authentication Rejected, reason : MIT-MAGIC-COOKIE-1 authentication rejected
13/09/24 上午12:44 plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:250: TypeError: Cannot read property 'plasmoid' of undefined
13/09/24 上午12:44 plasmashell QObject::~QObject: Timers cannot be stopped from another thread
13/09/24 上午12:44 plasmashell QObject::killTimer: Timers cannot be stopped from another thread
13/09/24 上午12:44 plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:136: TypeError: Cannot read property 'screenGeometry' of null
13/09/24 上午12:43 konsole Qt: Session management error: Authentication Rejected, reason : MIT-MAGIC-COOKIE-1 authentication rejected
13/09/24 上午12:42 kwin_x11 ZoomConfig::instance called after the first use - ignoring
13/09/24 上午12:42 kwin_x11 WindowViewConfig::instance called after the first use - ignoring
13/09/24 上午12:42 kwin_x11 SlidingPopupsConfig::instance called after the first use - ignoring
13/09/24 上午12:42 kwin_x11 SlideConfig::instance called after the first use - ignoring
13/09/24 上午12:42 kwin_x11 OverviewConfig::instance called after the first use - ignoring
13/09/24 上午12:42 kwin_x11 KscreenConfig::instance called after the first use - ignoring
13/09/24 上午12:42 kwin_x11 GlideConfig::instance called after the first use - ignoring
13/09/24 上午12:42 kwin_x11 BlurConfig::instance called after the first use - ignoring
13/09/24 上午12:42 plasmashell Graphics device lost, cleaning up scenegraph and releasing RHI
13/09/24 上午12:42 plasmashell QRhiGles2: Context is lost.
13/09/24 上午12:42 kcminit kcm_touchpad: Using X11 backend
13/09/24 上午12:42 kcminit Initializing "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_touchpad.so"
13/09/24 上午12:42 kcminit Initializing "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_mouse.so"
13/09/24 上午12:42 kwin_x11 kwin_effect_blur: Failed to map vertex buffer
13/09/24 上午12:42 user@1000.service spa.bluez5.midi: org.bluez.GattManager1.RegisterApplication() failed: GDBus.Error:org.bluez.Error.AlreadyExists: Already Exists
13/09/24 上午12:42 kwin_x11 kwin_effect_blur: Failed to create an offscreen framebuffer
13/09/24 上午12:42 kwin_x11 kwin_scene_opengl: Invalid framebuffer status: "GL_FRAMEBUFFER_UNSUPPORTED"
13/09/24 上午12:42 kwin_x11 kwin_scene_opengl: 0x506: GL_INVALID_FRAMEBUFFER_OPERATION error generated. Operation is not valid because a bound framebuffer is not framebuffer complete.
13/09/24 上午12:42 kwin_x11 kwin_scene_opengl: 0x505: GL_OUT_OF_MEMORY error generated. Failed to allocate memory for buffer object.
13/09/24 上午12:41 kernel hub 1-1:1.0: hub_ext_port_status failed (err = -71)
13/09/24 上午12:41 kernel usb 1-1-port4: cannot disable (err = -71)
13/09/24 上午12:41 kernel usb 1-1-port4: Cannot enable. Maybe the USB cable is bad?
13/09/24 上午12:41 kernel usb 1-1-port4: cannot reset (err = -71)
13/09/24 上午12:37 kernel usb 1-1-port3: unable to enumerate USB device
13/09/24 上午12:37 kernel usb 1-1.3: WARN: invalid context state for evaluate context command.
13/09/24 上午12:37 kernel usb 1-1.3: device not accepting address 13, error -71
13/09/24 上午12:37 kernel usb 1-1.3: Device not responding to setup address.
13/09/24 上午12:37 kernel usb 1-1.3: device not accepting address 12, error -71
13/09/24 上午12:37 kernel usb 1-1.3: device descriptor read/64, error -32
13/09/24 上午12:37 kernel usb 1-1.3: device not accepting address 9, error -71
