Hello Manjaro Community!
I own a HyperX 7.1 Kingston USB Headphone. Now when I plug it in, Pulse shows (Internal Audio, echo cancelled with HyperX7.1 Audio Analog Stereo). As a microphone input device.
Problem is, that it actually is not the headphone, but it is the internal microphone of my notebook.
How do I make the system recognize the USB Microphone properly?
here is the output of list-sources:
acmd list-sources
5 source(s) available.
index: 0
driver: <module-alsa-source.c>
flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9030
volume: front-left: 45875 / 70% / -9,29 dB, front-right: 45875 / 70% / -9,29 dB
balance 0,00
base volume: 65536 / 100% / 0,00 dB
volume steps: 65537
muted: yes
current latency: 0,00 ms
max rewind: 0 KiB
sample spec: s16le 2ch 48000Hz
channel map: front-left,front-right
Stereo
used by: 0
linked by: 1
configured latency: 0,00 ms; range is 0,50 .. 1837,50 ms
module: 6
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "92HD81B1X5 Analog"
alsa.id = "92HD81B1X5 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xd4730000 irq 35"
device.bus_path = "pci-0000:00:1b.0"
sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "1e20"
device.product.name = "7 Series/C216 Chipset Family High Definition Audio Controller"
device.string = "hw:0,0"
device.buffering.buffer_size = "352800"
device.buffering.fragment_size = "176400"
device.access_mode = "mmap+timer"
device.description = "Internes Audio"
device.icon_name = "audio-input-microphone-pci"
* index: 2
driver: <module-echo-cancel.c>
flags: HW_MUTE_CTRL LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 1000
volume: front-left: 45875 / 70%, front-right: 45875 / 70%
balance 0,00
volume steps: 65537
muted: no
max rewind: 0 KiB
sample spec: float32le 2ch 32000Hz
Stereo
used by: 0
linked by: 0
module: 27
properties:
device.master_device = "alsa_input.hw_0_0"
device.class = "filter"
device.intended_roles = "phone"
device.description = "Internes Audio (echo cancelled with HyperX 7.1 Audio Analog Stereo)"
index: 3
flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 1000
volume: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
balance 0,00
volume steps: 65537
muted: no
max rewind: 5 KiB
Stereo
used by: 0
linked by: 0
configured latency: 0,00 ms; range is 0,50 .. 2000,00 ms
monitor_of: 1
module: 27
properties:
device.description = "Monitor of HyperX 7.1 Audio Analog Stereo (echo cancelled with Internes Audio)"
device.class = "monitor"
index: 4
driver: <module-alsa-card.c>
state: SUSPENDED
suspend cause: IDLE
priority: 1030
balance 0,00
volume steps: 65537
muted: no
max rewind: 0 KiB
sample spec: s16le 2ch 44100Hz
Stereo
used by: 0
linked by: 0
monitor_of: 2
card: 1 <alsa_card.pci-0000_00_1b.0>
module: 28
properties:
device.description = "Monitor of Internes Audio Digital Stereo (HDMI 2)"
alsa.card = "0"
device.bus = "pci"
device.string = "0"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
index: 7
name: <alsa_output.usb-Kingston_HyperX_Virtual_Surround_Sound_00000000-00.analog-stereo.monitor>
state: IDLE
suspend cause: (none)
priority: 1040
balance 0,00
volume steps: 65537
muted: no
max rewind: 4 KiB
Stereo
used by: 0
linked by: 0
configured latency: 2000,00 ms; range is 0,50 .. 2000,00 ms
monitor_of: 5
card: 4 <alsa_card.usb-Kingston_HyperX_Virtual_Surround_Sound_00000000-00>
module: 31
properties:
device.description = "Monitor of HyperX 7.1 Audio Analog Stereo"
alsa.card = "1"
alsa.card_name = "HyperX Virtual Surround Sound"
alsa.long_card_name = "Kingston HyperX Virtual Surround Sound at usb-0000:00:1a.0-1.2, full speed"
alsa.driver_name = "snd_usb_audio"
device.bus_path = "pci-0000:00:1a.0-usb-0:1.2:1.0"
sysfs.path = "/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/sound/card1"
udev.id = "usb-Kingston_HyperX_Virtual_Surround_Sound_00000000-00"
device.bus = "usb"
device.vendor.id = "0951"
device.vendor.name = "Kingston Technology"
device.product.id = "16a4"
device.product.name = "HyperX 7.1 Audio"
device.serial = "Kingston_HyperX_Virtual_Surround_Sound_00000000"
device.string = "1"
device.icon_name = "audio-card-usb"
